@AutoFrank ofcourse, it is all about sharing, i see no issues with that.
No clue what happened here.
Till yesterday all was working fine, but today when trying to start npm I get the following:
Never mind...
Restarted the RPI and all is working fine again!
On 23.1.2017 at 9:16 PM, AutoFrank said:
I included some code above to replace any spaces with a + so you can send a normal sentence and encode and send within the button or scene
hope this helps...
-frank
Hi Frank,
thanks for help. It works now for me but i must use %20 in html code for blanks and can not use + symbols.
This example works for me
    8 minutes ago, gobbli said:
    Hi Frank,
    Hi @gobbli
    Glad its working
    Quick question
    The format I use is /room/say/words/volume but you seem to have a / in the middle of the words to be spoken
    response = sonos:GET("/Hobbyraum/say/Hallo%20von%20Sonos/de-DE/40")
    I'm not sure if you know that its not needed
    -f
    ok frank, now i know it ;-)
    @Guest
    Whats you new encoding function to get rid of saying the +
    thanks
    -f
    Hi All,
    I switched over to using AWS Polly TTS and the voice is good bit better.
    I have to update the settings.json file on the api to reflect the new TTS service
    The format for VoiceRSS is
    The format for AWS Polly is
    I also upgraded the latest api (version": "1.2.6") and between both changes encoding the string by replacing a space with a + is no longer working as it speaks the plus sign so I needed a new encoding solution and this what I'm now using.
    AWS Polly also requires the name of the voice before the volume (Amy above)
    Hey @AutoFrank, I'm thinking of switching from the kirkoffs vd to your solution.
    To test I tried to get node.js running on my old qnap but it wouldn't work.. So before I pull my hair out getting this to work on one of my old R-pi's, it there still the same delay as in kirkoffs vd when running a tts?
    Jim
    Hi @jimicr
    The delay is about 1-2 seconds for me and I think it works very well
    I was using voiceRSS and recently switched to AWS Polly. The performance is the same but polly has more natural sounding voices.
    If you want to just get it up and running quickly on a pi, I suggest the following approach (15 mins)
    Use the sonos-api precompiled rpi image at
     (apply to blank sd card)
    when you login over SSH (with something like putty) the password is root
    Map a network drive or Start Run to \\<IP of PI>\flash
    click apps folder and you'll see the sonos-http-api folder
    Get an API from VoiceRSS and create a settings.json file (details in the post) and drop it into the sonos-http-api folder
    Reboot the Pi and that's it - test through browser with something like http://<ip-of-Pi:5005/<playername>/Say/Hello
    If you want to upgrade to the latest api release
    Download the latest zip from
     (green button on right)
    In the flash folder rename the sonos-http-api to -old
    Rename what you downloaded to to sonos-http-api
    Drop in your settings.json file
    SSH into the Pi - login = root
    cd /flash/apps
    cd sonos-http-api
    npm install --production
    when finished reboot
    **I also added this information to the first post**
    hope this helps
    -f
    Edited by AutoFrank
    Looks easy enough, will try as soon as possible!!
    thanks @AutoFrank
    thanks @AutoFrank
    @jimicr
    No worries, give me a shout if you get stuck
    TBH - for me it transformed the level of control I have with my players and 90% of our use is now automated:-)
    Any idea why my VD stops updating? Everything seems to be working fine and I have full control, but things like volume, track, etc just stop updating in the VD but as soon as I hit the "save" icon it updates.
    Hi @Desmo
    Could you post the main loop code or export the vd and attach and I can take a look ...
    Have you verified that the device that is running the api is working all the time.
    Main loop...
    local device = fibaro:getSelfId();
    local zonename = fibaro:getName(device);
    local ipaddress = fibaro:getValue(device, "IPAddress");
    local port = fibaro:getValue(device, "TCPPort");
    sonos = Net.FHttp(ipaddress, port);
    response = sonos:GET("/Nursery/state");
    jsonTable = json.decode(response);
    fibaro:debug(jsonTable.volume)
    fibaro:debug(jsonTable.playbackState)
    fibaro:debug(jsonTable.currentTrack.title)
    fibaro:call(device,"setProperty","ui.lblState.value", jsonTable.playbackState);
    fibaro:call(device,"setProperty","ui.lblVol.value", jsonTable.volume);
    fibaro:call(device,"setProperty","ui.lblTitle.value", jsonTable.currentTrack.title);
    fibaro:log(jsonTable.playbackState)
    fibaro:setGlobal("Nursery_Sonos", jsonTable.playbackState);
    I put some debug lines in and they always report corrcectly, it's just the lines in the VD update for a while (been working fine for the last hour since hitting save) but then just stop updating.
    1 hour ago, Desmo said:
    Main loop...
    Hi @Desmo
    I have it working here for the last 15 mins and will keep it running for the next while but we have multiple zones running all day and never saw this issue
    Any error in the vd main loop will cause the updating to stop .
    The only thing I have seen is that depending on what you're listening to the 'title' can be blank but I've never seen it stop the main loop
    Are you listening to the same music during in this time ?
    Two things to try when it stops next
    click the debug button on the main loop and see if there are any errors there, it may help pinpoint the issue.
    drop http://<ip-of-Pi>:5005/Nursery/State in to a browser and see if the usual json formatted data is there (this will tell you if the api is still running)
    Unrelated but ...
    I listen to most internet radio and don't use currentTrack.title much as its just garbage, I tend to use currentTrack.artist more
    Updated first post with information on getting the api running on a pi in 15 mins or less
    Thanks @AutoFrank... I'll try some of your suggestions and see how I get on :)
    OK...just taken a look as it stopped updating again. Taking a look at the Jason data direct is fine, it's all showing as it should be. When I debug the VD it's stopped updating itself with no errors. I've just hit "save" again and it starts updating again instantly.
    I'm going to keep an eye on how long it runs for to see if it's consistent in time run before it stops. I'm getting the same problem with all of my Sonos speakers, not just this one. I wonder if it's a bigger system wide problem.
    Hi @Desmo
    That's very odd alright.
    Do they all stop together ?
    I have 14 sonos players and I have a vd that monitors them all and it's been running for months updating volume and status every second and I've never day it freeze or stop.
    I assume you have restarted the pi?
    Have you tried to reinstall the api?
    I wonder is something on your HC2 impacting the VD?. You could try checking cpu/mem when it stops ?
    Could you export the VD and let me know how long it m takes to stop.
    I think I posted the code for my vd that monitors all my zones, if not I could send it on and you could install that and see if that also stops updating?
