5 minutes ago, AutoFrank said:
Hi @jimicr
Here's on for your players if you don't have something like it already
import the vd below, add your players to the main loop table
name the labels accordingly
Create one variable called SonosTable
and use this scene to populate it at the start (adjust names to suit player names)
Try not having an underscore in the player name as VD labels don't seem to like them for some reason
The SonosTable will track status and it has other variables like volume and favorite, etc which may prove useful in the future
You could also trigger other events off the sonos state changes such as tv on/off
I did publish this VD a good while back but the user had to create a block of code for each player which was not ideal
...end result is a status of all you players in one place :-)
_f
Thanks!
Will play with it this afternoon :)
    2 minutes ago, jimicr said:
    Thanks!
    @jimicr, how the back healing coming along ?
    Thanks for asking, a lot slower than hoped for.
    But will be okay :)
    But will be okay :)
    Thats good to hear....
    Got it to work, I was using your other one with this in the main loop (I added the sleep at the end)
    This works perfect aswell, what are the benefits of using the new one?
    Jim
    Jim
    @jimicr
    its better coded (uses a table) so when you get your next few sonos zones you can just add them to the table
    The sonos table is a bit better  as well....
    .. plus it keep your lua skills sharp :-)
    14 minutes ago, AutoFrank said:
    @jimicr
    You are right :)
    Just to learn I adjusted the mainloop I added the following line:
    At line 18, I like "paused" better then "paused_playback" :)
    3 minutes ago, jimicr said:
    You are right :)
    Nice one @jimicr
    I must add that to mine as well
    This works for the remote you posted in the OP:
    change this:
    to:
    Edited by jimicr
    Currently I`m using "SONOS Virtual Device made by Krikroff" but considering switch to this solution since there is option to use Synology NAS for this API :)
    The most important for me would be TTS. In Krikroff I have delay about 8 seconds so this is way too long response time to create whole logic for may use case.
    I see that using this API there are more options. How is about response time there? Which service seems to be the fastest?
    My internet connection should not be problem (low pings and quite fast). I would like to be able to use language PL or EN.
    Maybe someone switched from Krikroff solution or have both to give more info :)
    Hi @Bezan
    I use AWS Polly and have used VoiceRSS.  for me the TTS response time is 1-2 seconds which for me is very acceptable. I am not sure about Google TTS or what is available in Poland but perhaps others could comment on their experience
    @AutoFrank thanks for answer. Up to 2 seconds response time would be superb :)
    After while of research it seems that my Synology NAS does not allow Docker. On the other hand there are more issues running it this way.
    So, instead of changing NAS best would be to buy Raspberry PI and configure Sonos and other node like Alexa etc. there :)
    Do you have any step by step tutorial, website link where rookie can go through and have sonos api running on rpi? :)
    @Bezan, mine didnt either :-(
    Yes, If you go to the first post of this topic you will find the steps there
    I have previous Sonos VD still installed and now added sonos node api.
    After importing VD, putting IP to RPI and port 5005 it is not showing any informations. Buttons are also not working.
    Where should I start to look into it?
    Hi @Bezan
    You also need to add your player name (exactly) to either the code or the VD general tab depending on which VD you have
    If you post the code from the main loop I should be able to tell from there
    I recently had a power cut and my sonos api  (and HA bridge) got corrupted.
    Luckly I had a copy of my sd card so I was just able to swap it in.
    This reminded me that I never posted about making a copy of your rpi card
    anyway here is is
    taken from
    I always have a copy of the latest image and a spare sd card with that image
    @AutoFrank,I added name exactly as in my Sonos app ( used %20 for space ).
    Now it seems to be working but not showing State. It is very important for me to control lights based on this status. Any idea why it is empty?
    Moreover, Sonos Players Status is also not showing status.
    Edited by Bezan
    Hi @Bezan
    Could you export your vd and include in post and I can take a look....
    _f
    @AutoFrank VD attached
    @Bezan
    Slight change to main loop.. (this must have been an early VD)
    Change zoneState line to the following
    and the status will show
    /monthly_2017_07/Capture.PNG.31e6696c0c1cd9e4114bd70cfaa30db2.PNG" alt="Capture.PNG.31e6696c0c1cd9e4114bd70cfaa30db2.PNG" />
    Also instead of Title - you could display what they call artist (its also the radio station for internet radio)
    you can get this from
    If you're interested the full json data for a player can be found through the browser by going to http://<ip of api:5005>/playername/state
    there are other parameters there that may interest you like elapsed time or station name, etc
    It's worth nothing that some of the data displayed is a little different depending on audio source
    .. anyway, hope this helps
    _f
