1 minute ago, 10der said:
@petrho can you stop flow. and look is the issue still here =)
Ok
some days ago I did see a message here about the same issue.  and no node-red and others "outside services"...
Edited by 10der
Ok so maybe related to fibaro api?
Have you same experience regarding lockouts as me? Very annoying
TBH my node-red works 24/7. No issues with lockout. Are you really sure what node-red is root(!) issue here?
Can you turning off node red for one day, for example if we you sure what node red is root issue in HC2 lockouts.
Not sure but the lock-out IP address is from node-red server
It's very strange. A couple of times per day I will get error 401 and also receiving a security alert email. but still - it seems that I can continue to login.
Can it be a problem with the Swedish characters (åäö)?
no
Each device now use common credentials oh HC server node for actions
so, can you check each node of your flow what you have and clearly check for right assignment credentials
also I can propose check at first nodes what can potential run at 00:00 for exaplme
AFAIR you said about at this time HC2 lock your node red server
Still same random problems with locked out account (nodered server) error 401. Only thing I can suspect is when a lot of requests come from Nodered to HC at exatly same time. I did a couple (6) of new devices and the when I pressed deply I got error directly.
guys sorry
I have a deadline for project 14 dec.
I will fix it after.
thank you for understanding and I apologize for the oversight
guys sorry
No hurry (and no pressure) - just wanted to give you some hints when it occured.
And again - thanks a lot for your fantastic work!
  • 4 weeks later...
happy 2019!
I try to install fibaro module on nodered container. Here there are some errors that I got
Other modules have been installed successful, so I support that it may be an syntax error...
My nodered version is 0.9.15, running on ubuntu 18.0.4 and node version is v6.16.0.
EDIT: FIXED ! i UPDATE TO V8 NODE.
Edited by FSE
admin@smarthome:~$ uname -a
Linux smarthome 4.2.8 #1 SMP Wed Nov 14 00:59:34 CST 2018 x86_64 GNU/Linux
I try to control wemo lamps from a VD. what is the best practice to read On/Off button and brightness slide value via HC2 node?
using globalVariables  or using hc2-device node?
Wemo node gets json on the following way.
I like also to get the status of bulb polling their status and passing back to HC2.  Does someone build a similar VD?
@10der happy new year, sir!
I need a simple example of VD that when a number change on node-red flow, the label of button on VD will change.
I also try to read the value of a slider from this VD and pass it to nodered, without globalVariable. Is it possible?
Thank you!
Thank you!
Was already in this post IMHO.
But ok, I am going to work trip again - after ok will do
@10der thank you! I m sure that your time is precious, I tried to figure out by your previous posts but I found your examples complex.
anyway, thanks again for sharing your time with all of us that try to learn.
 :so. I am not at home now (work-trip0 but can access my home remote.
I can post here step by step cuz not enough time for it, sorry
so I have VD (sonoff relay)
so just drop MQTT In - HC2 device and fill data with VD id
now save flow
and back to HC2 UI
just click on buttons
and
yes you can read any labels and as a bonus changed icon in VD.
have a nice day!
now we want to turn on and off my sonoff VD from node-red
lest check what VD is off
back to node-red
just add to previous flow inject node for On and for off
set code for ON
and off
click inject On
yay!!!!
trying to click inject for off
cheers! :0
yes, it works!
and btw
you can get status back as well
@FSE done
@10der it is CRYSTAL CLEAR!
I have another challenge but I do not need a answer as I think I have a workaround.
how to pass a json from VD to nodered?
My workaround is just to change the label on VD and trigger a function according to label on nodered.
I suppose there is another way but I do not like to take advance of your kindness.
