@10der should not the UHASPresentState show something in debug when i change this variable?
If possible i want to use that in next step where i will update a VD (that i got working already)
ahhh! the same time i did press submit i did see that i should address it like /home/globals
sorry for that :oops:
@10der
how to deal with predefined variable? Based on the value i will update label with different text.
Can you give some example?
Think i got it, perhaps not the best way but it is working
/monthly_2018_08/1420972753_Skrmavbild2018-08-27kl_21_15_18.png.45c2720fda2496c41a2a521acbfe129e.png" alt="1420972753_Skrmavbild2018-08-27kl_21_15_18.png.45c2720fda2496c41a2a521acbfe129e.png" />
On 8/27/2018 at 12:05 PM, 10der said:
Maybe I'ts to early in the morning - but why can't I find the ID for my virtual devices in the HC2 GUI?
Edited by petrho
Edit VD and you will see it
Hmm, I am probably blind but see the attached image to the previous post
Look in the address bar
Ahh - of course :-) But I think I have seen it in the GUI earlier?
Edited by petrho
No ;) Fibaro devs always thinking about end users and always provide user friendly interface...
so, you can very easy find Id of your VD, you can very easy develop a new icon for your VD find new icon ID. Etc etc
sarcasm, sorry.
  • 4 weeks later...
Hi!
Anyone else wondering what I develop?
profit! :)
so, now you can use HC2 devices in Node-red without headaches.
I'm always wondering and this looks really interesting...
K
another feature with devices:
dashboard ui
wow!
dashboard ui
wow!
Is that in a newer version than 0.66? I can't find that features...
10-15 min for deploying,,, waiting
I can't wait! ;)
npm version patch
v0.0.67
pushed
20 minutes ago, 10der said:
npm version patch
v0.0.67
pushed
Do I need to run "npm install node-red-contrib-fibaro-hc2" from my raspian terminal console instead of manage palette from inside node-red? Do I still keep my current flows?
Will it be reachable from palette then?
will be reachable after some period...  usually ~1h
flow for ui board example
Wow - latest 0.0.68 is amazing - thanks a lot!
Will it be possible to configure the output topic for the device so instead of fibaro_out you can configure it to example hc2_out or something else?
