Ahh - that solved my problem as well. Thanks
On 8/12/2018 at 5:14 PM, Rikard Ronnkvist said:
think there is something strange with the dispatcher, I can only get it to work by using JSON-formated payload
fixed 0.56
thank you so much. fixed!
Edited by 10der
And again - your node will be awsome! Big thanks!
How is the device-node working? Do you have any example?
this object still in development, under construction... :D
but you can use it as a filter.
so, you subscribe on ALL events
and separate events via HC device
for example
in output, you will have the only event for this device.
Time to play more with this now, thanks for the updated version @10der
for example
Ok - like a filter?
yep!
6 hours ago, petrho said:
Ok - like a filter?
so it suppose to work also with global variables? Variables are missing "value" payload.
Global vars not supported this node. sorry. maybe todo.
here is workaround
here is workaround
Thanks! Do you have similar example for how change global variables from nodered?
I can't get the reset to work (actually not sure what expect to happen)
Edited by petrho
node retrieve all devices states again. this feature just like a watchdog.
Quote
Nothing happened when I press the reset (sending a 0 as payload)
are you waiting for magic? :)  no no  no ;)
just turn on debug and press reset. you can see statuses of all devices
so. just inject string "0" as payload
exactly what I did but nothing in the debug window (I think it worked with earlier version?)
It looks different from your example (see picture) But I have tried the proposal with a 0 in the payload. Same outcome - no debug info)
Now it's working - I just used your example file and when I changed to string and payload 0 it works!
latest here:
on global changes events you can subscribe like a home/globals/#
  • Thanks 2
You deserve respect from everyone!
I hope also fibaro to saw some respect to us and integrate that so not required the 10 sec delay!
Also some very popular scenes/vd here (for example Smart Message) need to implement this and add Google Home notifications (huge step!) or chromecast interaction.
Is it possible to update a label on a VD ?
Would be really cool to take som MQTT-data and push it to a VD so that you can display it in the app...
or native solution
very simple!
