2 minutes ago, petrho said:
Will it be possible to configure the output topic for the device so instead of fibaro_out you can configure it to example hc2_out or something else?
Hmnm!
HC2 dispatcher listen for example fibaro_out/# topic
so, devices should always send commands to fibaro_out topic
so.. full example
o!!!
more simple example!!!
When I run the example above its works perfectly when you use the button to switch on/off a wall plug (also I can see that the native fibaro app follow the changes. But when I use the native fibaro app and switch on/off the wallplug goes back to the initial state in a couple of seconds
Ok, let me check
@petrho thank you so much. bug. UI controls not understand values in "string" and cast non-objects types to false. so. thank you. fixed! waiting for update.
UPD: + [email protected]
PS: now you may subscribe on Global Values changes via
home/globalVariables
topic
@JCM I am sorry. I am hijacked your topic!
Edited by 10der
@petrho but Sir, you are right! for easy using when user checking the box "I want to control this device blablba"  I should propose to provide an input line for command topic.
otherwise you sholud set topic in each UI board controls. facepalm!
thank you again! you best tester and idea man! bow!
Edited by 10der
Probably a very silly question...
When I install latest version it provides 3 nodes in palette but the hc2-server-config is missing.
/monthly_2018_09/image.png.8ed045bdde4d8a3e6aad394d203fa683.png" />
It is greyed out in the palette manager . I think this might be a hidden or legacy component ?
However I can not get any configuration option in any of the other 3 nodes to display like this
mine displays differently..
What am I missing ?  I can set the topic and room mode but only by editing one of the code snippets you post and then copy pasting that into a new flow.
I can't see how to add or edit these through any of the supplied nodes ?
K
Edited by xAPPO
@xAPPO
sudo /etc/init.d/node-red restart
browser Ctrl+F5
and yes config should be gray cuz is not "active" not it
I have restarted nodeRED several times .. even restarted the whole machine that it is running on and have tried the full browser refresh - even cleared cookies and tried another two browsers.
I'm wondering if it is something to do with NodeRED running in a docker container.
0.0.69 seems to work fine! Thanks again!
I have installed ver .0.0.70 but the example with the lamp and button dosen't work anymore. What do I need to change? I understand that you can configure topic in the device now... What is the topic name it that example? I have tested with home/command and also fibaro_out with no success
remove topic from switch. at all
Hmm. I have maybe mixed up everything with the topic now. Can you please expain MQTT Topic for Server, Dispatcher and the Device node
and new flow without a topic in UI controls
aaa! sorry bug! :(
past-copy from another my module. sorry
thanks, how is your server and dispatcher configured now?
nothing changed.
everything is working but the "button" is not changed when I use the native fibaro app...
so. it;'s mean what you not rcv in messages.
nessages
nessages
nothing from the debug nodes when using the fibaro app
both?
on first node you should recvd all mesages
so you have the wrong configuration from out from hc2-server
full flow here
10 minutes ago, 10der said:
both?
full flow here
now the button is moving when using the native app but when I use the buttion nothing happened. Can it be wrong topic? See picture
