yes. you use 70 ver. bug (typo) here!
please update .71
please update .71
Now it works! :-)
cool! Thank you again!
+ [email protected]
warn:
hc2-dispatcher removed. no hc2-dispatcher. all functionality now in hc2-device
7 hours ago, 10der said:
+ [email protected]
warn:
Great! Do you have any examples or documentation you can share?
yep. Sir!
many examples, but poor documentation only internal node-red help
btw. nothing changed for you. just my nodes not sending any commands to HC2 via MQTT. Now devices can send command directly.
no additional topics just now. only one topic for translating HC2 device statices to MQTT. another additional topic for global vars. if you do not use it - please don't care.
On 9/26/2018 at 11:19 AM, 10der said:
@petrho thank you so much. bug. UI controls not understand values in "string" and cast non-objects types to false. so. thank you. fixed! waiting for update.
UPD: + [email protected]
PS: now you may subscribe on Global Values changes via
home/globalVariables
topic
@JCM I am sorry. I am hijacked your topic!
Maybe I have missed that but can you also change Global Variables via your nodes?
no. changing GV required admin creds in HC API access. I can be turning on this feature (already developed but disabled) if you ask... but with some limited
Looks like that feature would be great to have but good if it can be disabled if needed :-)
Hi again!
I can't see that changing the Topic status will make difference - it's still fibaro_in
/monthly_2018_10/Capture.JPG.0ab551177513ae63fde28273aecf6640.JPG" alt="Capture.JPG.0ab551177513ae63fde28273aecf6640.JPG" />
@petrho default "hardcoded" topic is home/status not fibaro_in.
so you maybe override topic in your logic... somewhere else
Maybe I have misunderstood something?
Sir. I am david copperfield
and I am asking you open Inject  Node. and roll topic name! :)
You are best!
Doesn't it remind you of something? :)
Yes, I've lost my mind! :)
just for test...
  • 5 weeks later...
Hi, is it possible to catch 1xclick, 2xclick, 3xclick and hold from a fibaro switch plug (which has it when using fibaro gui)?
idk, just will checking
@petrho so. it's my fail. I forget about "events". Events what are you asking coming to my node via  events, via CentralSceneEvent
example (just tested)
but I forget to parse and interpret these events.
I will fix it in next version ASAP.
sorry!
I have updated to Beta 4.512 and now it seems that I can't find newly created devices when press search in device node.
known issue. I have the same issue.
1st in todo.
thank you!
Is there any workaround until bug is fixed?
