1 minute ago, 10der said:
as I can understand you HC2 and node-red not in the local network.... ohhh
I have a separate VLAN for IoT devices. As you probably know these are the most vulnerable devices, even in a LAN network.
Because the communications you are using are unencrypted, password are easy to intercept. That's why I made a comment about the Global Variable writing, using a administrator account.
The only way to use encrypted communications available by the Fibaro HC2, is to use scenes. They have the capability to set up encrypted  communications.
Just my two cents, though....;D
PS: basic auth - hash and not provide login / password.
PS2: grab events on HC2 and pass to node-red it’s good idea... maybe... but I am think what initiator should be on node-red side plus node red must be as receiver.... and finally: Fibaro develop own API for end users that the end users afraid use it, isn’t it?! :)
Edited by 10der
good news
welcome!
and thanks for the support!
  • Like 3
@10der This looks like an amazing solution, but I'm new to Node-RED and mqtt and it would be great if someone could make a little guid.
I already setup node-red and can controll my philips hue lights and installed mqtt mosquito and tested it with my pc, but somehow the connection to my hc2 does not work.
I get Error: getaddrinfo ENOTFOUND "username" "username":80
@PreHack
check IP
/monthly_2018_07/image.png.5ef3dd6e072c7a2819faa0aab407548b.png" alt="image.png.5ef3dd6e072c7a2819faa0aab407548b.png" />
IP, Username and PW are correct, I copyd the topic you have but it does not work for me.
can you check from node-red PC?
Edited by 10der
this gets the following output
Quote
Thanks for your help I found the problem there seems to be some problems with special characters in the password.
Edited by PreHack
please,
1) click on IP field
2) tab
3) filed should change color
4) [SAVE]
5) publish
Edited by 10der
I changed my password one the HC2 and without any special characters it seems to work. There was some json output but I cleared it and now I only get.
hc2.error.invalid-json
is any comment under node?
if no - not valid credentials for example
nothing only for a short moment there is "hc2 status requesting"
Guest kallecux
Hi 10der,
what means the topic "home/status"?
Greetings
PS I get all "values" from all devices?!
Edited by kallecux
3 minutes ago, kallecux said:
Hi 10der,
Greetings
no. topic used for OUT not for in
node can't get start json like you already show
you still have issue with
- IP address field
- login / password filed
Edited by 10der
now I get spammed with output :) I don't know what has changed but it seems to work :) know I need to figure out Node-Red and the future will be good :) what would you say? how low can I have my polling intervall bevor i get any problems?
reproduced:
@10der I'm not shure why but it seems to work maybe it took a while till hc2 changed to the new password or something but im pleased whit the output (post above)  I get, the rest I hope I can learn from any Node-Red example :)
Edited by PreHack
Quote
10 sec = ooook!
but FIBARO poll every 1 sec :
but, Quod licet Iovi, non licet bovi!
Edited by 10der
ok 10 sec is fine :) but it means that I need to push some events becouse scene would be to slow if i only get pooling every 10 sec. But first I will need to learn some node-red :)
Edited by PreHack
yes, motion lights flow need 1sec poll circle... Just so long as FIBARO is not dead after DDOS pooling :)
