MQTT Broker implementation
JCM
I have a working solution by using a scene to send MQTT commands to a Node-Red HTTP(S) node, which publish it to a MQTT broker, also installed on the RasPi. That way I communicate with several other IoT devices, like the Athom Homey.
/monthly_2018_06/654607458_HC2--Node-RedHTTPS--MQTT.png.fcda053a2cf94b81edfed9b9ca3d1092.png" />
The problem is, I didn't figured out a way to receive any data from the MQTT broker to the HC2.
Does anyone has an idea how to get that accomplished? An encrypted solution should be preferred. If we have to wait for Fibaro it will never be done.
If anyone is interested I could post the scene code.
Edited by Lambik
wow! please share it!
    Wow! Sounds interesting. It would be great if you shared the code. I am also trying around with Node-RED and mosquitto .. this sounds like a good first step for me with HC2 onto the MQTT stage.. :-)
    Edited by JCM
    Christ, you're so bloody naive!
    Actually, I was going to leave this community ...
    yeah...
    Instead of asking from Fibaro this function, you are trying to find workarounds...
    so, MQTT bridge for 5 mins
    1.  [email protected]:~ $ sudo apt-get install mosquitto-clients
    2. Please login or register to see this code.
      3.
      4. run
               5. Voila!
    bye!
    I'm not naive @10der. I used this to gradually dismantle my HC2 configuration, which is large after building it  since 2013. I use it solely as Z-Wave gateway at the moment with some core (own written) lua Virtual Devices. All other is done by other IoT devices/gateway/services.
    For @korniza and @JCM hereby my Scene code used:
    To get started, make 5 global variables:
    'SC_MQTT_Topic'        -- Name of topic (trigger!)
    'SC_MQTT_VarVal'         -- Value of topic
    'SC_MQTT_Retain'     -- Retain message (true/false)
    'SC_MQTT_QoS'            -- QoS of message (0,1,2)
    'SC_MQTT_VarLog '    -- Logmessage to send
    to send MQTT command, write a value to 'SC_MQTT_VarVal' and the Topic to 'SC_MQTT_Topic'. When a string is written to 'SC_MQTT_Topic' the scene is triggered and a API command is constructed which communicates with the Node-Red http(s)-node. The root topic  = 'hc2/mqtt'
    If no values are written to 'SC_MQTT_Retain', 'SC_MQTT_QoS' and 'SC_MQTT_VarLog' there will be default values written to them:
    'SC_MQTT_Retain' default value is false, 'SC_MQTT_QoS'  default is 0 and 'SC_MQTT_VarLog'  default is <date> <time> <hc2/mqtt/MQTT-Topic> --> <Mqtt-Value>
    In Node-Red all values are stored as 'payload' so you need to move the values with a function node containing (msg.payload --> msg):
    After being moved you can strip the log-content to store to a log-file (msg.log)
    /monthly_2018_06/968946960_StripLogData.png.e8efb2ff347fad2cb91b405559758a7a.png" />
    The MQTT data is send to the MQTT-node, containing msg.topic, msg.retain, msg.qos and msg.payload.
    The respond is done by constructing msg.payload containing {"status":"OK"} which is send to the http-node output. This will be send to the HC2 scene to confirm the command is received:
    You can watch the Scene debug window to monitor what is happening.
    In short, if you want send value TEST to topic /hc2/mqtt/MYTOPIC with QoS=2 and retain=true then you write to HC2 global variables, for example with a VD-button:
    Enjoy!
    Edited by Lambik
    typo
    • Thanks 2
    Now I can control my wemo lamps!! @Lambik you are one of my heros here!
    I already use MQTT to send notifications on Google Home but the code was messy. You provide a general way to bridge what ever I want!
    I think now everyone imagination is the limit!
    @korniza You're welcome! I'm pleased to see my modest contribution suits your needs. ;D
    BTW, here is some additional info:
    EDIT: I see you already knew that topic.... :oops:
    Edited by Lambik
    Added a link to another topic containing addditional info
    Hereby some modest contribution to the Fibaro forum community. (You absolutely rock!) ;D
    When posting variables in a small time range, the scene I posted before could be 'stressed'. To resend values without overflow the MQTT-send scene I wrote a scene to prevent that for being happening.
    When the MQTT-send scene is busy, it will wait to become ready again. Also it will not (re)send values when they are the same (optionLastValue = true).
    Note: A extra global variable is needed for every monitored global variable, in the example below this is the 'SC_PD2MQTT_LV'.
    Note: I used a logValue = 'NO' to prevent it from being stored in my log file. This is done by my Node-Red flows (red function node):
    In the below example I monitor the
    global variable (VD_PD_Status534) and send the value to the MQTT-send scene. You could change the code in the Custom code-header to your needs (pdValue).
    Succes!
    Some Icons I made...
    Enjoy!
    Edited by Lambik
    • 3 weeks later...
    JFYI:
    simple MQTT <=HC2=> Bridge based on Node-Red
    attach HC2.json
    notice: do not forget setup
    a) address from MQTT server
    b) HC2 basic auth credentials
    and simple how to use
    attach sample.json
    notice: supported commands:
    true / false  ===> simple turn on / off
    any numeric 0 .. 99 ===> Dimming
    string startwith # ===> RGB
    string startwith $ ===> RGB-white channel dimming.
    On 7/5/2018 at 8:56 AM, 10der said:
    JFYI:
    Thank you @10der!!
    I did some tweaking and testing and this is working like a charm!! Thumbs Up!!
    With Androids
    app I now can easily monitor and control the HC2 by MQTT. A nice solution for a wall-mounted tablet!
    Edited by Lambik
    3 hours ago, Lambik said:
    Androids
    app
    Wow! Thank you!
    6 minutes ago, 10der said:
    Wow! Thank you!
    You're very welcome! I'm glad to return a favour to your highly appreciated solution. Keep up the  good work!
    UPD:
    + some minor fixes
    Edited by 10der
    UPD V3
    1) init action, so now you can get messages on flow start
    2) some minor changes / improvements / optimisations
    3) payload now is "typed" : string / bool / float
    bug free :)
    example:
    Edited by 10der
    @10der working like a charm. Nice!
    Even when you changes HC2 Device (ID), only the device description has to be modified, which is easy to do. Also the devices MQTT path are adjusted. Brilliant!
    One question though, is it possible to read/write HC2 global variables?
    draft
    get / set global value
    so, you can putt to MQTT:
    home/global/GlobalName
    and asp payload = VALUE
    and node-red change your global value in HC2
    btw. last flow you can save as sub-flow and use....
    check this!
    sub flow
    and result
    cool!
    2 hours ago, 10der said:
    cool!
    Indeed! ;D
    Just a remark, to write a value to the HC2 global variable you need a HC2 account with administrator privileges. Due to the lack of the HC2 to get/put encrypted API commands, this could be a real vulnerability.....;(
    @Lambik Hi!
    now I wrote node-red module... nodejs\node-red-contrib-fibaro-hc2
    and configuration should be very easy.
    so, I'll post a link on npm module here when I'll have done
    Wow! Way over my head to code a Node Red module... o.O
    Respect!
    BTW, with the new 4.503-beta version I noticed some messages about API changes, so aren't you afraid that a lot of coding could be obsolete?
