@10der Thank you very muche now I have a nice holiday project :)
welcome, do not hesitate to contact me
Edited by 10der
I see now why it took a while to get it working :)
I have got a mail from Fibaro :)
Quote
Suspicious Login Attempts Prevented
We noticed 5 failed login attempts to your HC2 that seemed suspicious.
For your security, the following IP address: 192.168.11.11 has been locked for 30 minutes.
/monthly_2018_07/image.png.579c0319b816ac5712898c429381f5bf.png" />
[email protected]
now you can also use any fibaro command.
example (set arm for some devices)
notice args = [0,1111]
0 - un-ARM
1111 pin code
http://192.168.1.36/api/callAction?deviceID=8&name=setArmed&arg1=0&arg2=1111
Edited by 10der
I like to thank @10der for this huge effort! also @Lambik implementation worked well for months till now
You can say I'm  fool.
I try to use the module on nodered. I successfully connected to HC2 and got polling. The issue is that HC2 Server did not output to MQTT on Topic "home/status".
According to what I have understand, I added a block for MQTT input using topic "home/status/#" and connected with a HC2 device. I used just the ID (number) of the device. There is no debug output on this chain...I suppose I should get everything from a fibaro PIR sensor.
For troubleshooting, i used just a MQTT input using topic "home/status" and connected with a debug output. No output at all.
Any help?
Edited by 10der
@10der no luck! No output!
I tried also other device id that I can see that they reported on the debug of HC2 Server, with/without value and no output on device debug chain :(
is the topic home/status/# is the correct? Do I need something to build on HC2 side (suppose not)?
Edited by korniza
Stop!
can you add debug here?
and disable debug output in
stop stop stoip
i see issue! Ж)
you forgot about MQTT outer
lets play
Edited by 10der
15 minutes ago, 10der said:
Stop!
stop stop stoip
i see issue! Ж)
lets play
What a stupid! I thought that you already include MTTQ output on the HC2 Server module :)
Now I got it work! Huge Help!
Thank you!
welcome!
Just to ask about Topic home/command/#. It is supposed to send a command back to HC2? Can you provide an example?
sure!
topic: home/command/deviceid
payload true / false  ===> on / off
              any number 0..99 ===>  for dimmer level
the last version support json object in payload like params for API calling
for example
{"name":"setColor","args":[255,0,0,0]}
turn on a red channel in Fibaro RGBW controller
Edited by 10der
A last one (real)!
Do you have a VD switch that nodered can read status?
I try to connect a wemo bulb using nodered. So I need a VD switch just to get status from nodered and turn on/off wemo bulb. Any example?
Also, what about Globals? how can I read/write a global on HC2 using this module? I see the example you uploaded on the past. Should I use home/global as Topic?
Edited by korniza
5
no. but you can. click VD button in Ffibaro UI and you will see in debug window with this event in node-red. just create a hook and go :)
it's the second question!
I try to upgrade the Global Variables setup so to poll all the globals and structure them as home/globals/variablename/value as it is done with devices.
As I'm not so familiar with nodered, I ask someone to do the dirty job :)
i'm close!!!
believe it or not for me it's a huge step.
What is done:
I get all the values from Global variables and build a home/global/<variable_name> topic which has the value as payload. the reason of that is I do not want to query individual global. still I need to find a way to keep info about the variable is read-only/write.
Also there are variables that return as strings but they are tables. Need a way to manipulate them.
You may see that nodes are messy for now. Hoping some help to do it better.
Another issue till now is that I get errors on the "write" part of globals when I perform a request for reading but till now, I did not perform any troubleshooting on that. hope to find a solution.
PS: your json block is invalid... maybe forum past/copy broke it.
Edited by 10der
3 hours ago, 10der said:
I get error on function node TypeError: Cannot read property 'value' of undefined
it is different approach from yours. I got an idea about the other parts I miss.
Nice start, realy cool! :)
I think there is something strange with the dispatcher, I can only get it to work by using JSON-formated payload.
And there is a small typo in the device, says "Fivaro HC2 device".
