1 hour ago, petrho said:
Is there any workaround until bug is fixed?
Just reload service.
i will fix it tonight. Ok
ha.
@petrho can you add reset
it re-init device list when you click on this element
28 minutes ago, 10der said:
ha.
Hmm. Not sure I understand. I have tested to manually inject without success. And my config is already as attached
but anyways I have update node..
now it works.
btw, if you use user != admin user — do not forget grant to this user new devices.
Edited by 10der
now it works.
btw, if you use user != admin users do not forget grant to this user new devices.
Thanks for quick support. I will test and give feedback!
now it works.
Hi, unfortuantely it doesn't work with latest either. Only way is to reload whole Node-Red
Ok
can you provide me steps for reproduction
thnak you
6 minutes ago, 10der said:
Ok
thnak you
Using your latest version (0.0.75)
Add a new device (for example a wall plug) in Home Center (4.512 Beta)
Add a hc2 device and use the correct hc2 server configuration.
Press the search (magnifying glass icon) but can't find the newly added device
Tried to press reset for the server.No difference
Rebooted my raspberry (which is running node red)
Now it works
Edited by petrho
just restart service with node red instead of rebooting
but got it, ok.
Can’t reproduced.
user - user
have  granted only 1 device
drop node red HC2 device
yes can desover only one device
go to HC2
grant second device
back to node red
still discover only one device
click reset
now device can discover two devices
strange. Ok will look again after my working day at evening
Edited by 10der
is hc2-dispatcher removed in version 0.0.75?
/monthly_2018_11/1609477030_Skrmavbild2018-11-21kl_21_39_24.png.c2fcf1d770365eb33b2ec032bae057cb.png" alt="1609477030_Skrmavbild2018-11-21kl_21_39_24.png.c2fcf1d770365eb33b2ec032bae057cb.png" />
yep, Sir!
Anyone that have a flow with HC2 --> NR-->Sonos?
suddenly i got this, did work earlier this morning
Edited by jompa68
@jompa68
HTTP Status Code 401: The request has not been applied because it lacks valid authentication credentials for the target resource.
but got it, ok.
Can’t reproduced.
user - user
go to HC2
grant second device
back to node red
click reset
Hello, any news regarding the strange bug? I have just updated to 4.520 but same problem. I always need to restart node-red...
I have a deadline in my current project, so  will do. OK
sorry!
sorry!
No problem - I'm just curious :-)
I mean - your plugin is so good so it's hard to go back to Fibaro LUA...
How can I get status from a motion sensor? Can I get status out from the device node? or do I need to go through the server node?
EDIT: I got it...
Edited by petrho
no. now all coming from dev node.
5 min
I should garb coffee and can draw flow for you
