2 minutes ago, 10der said:
no. now all coming from dev node.
5 min
I should garb coffee and can draw flow for you
Now I remembered. Just use the server node and filter it with the device node :-)
Edited by petrho
yep, Sir!
Sorry for spamming you. Do you have support for the RGBW device? How can I for example send setW=128?
look on flow RGBW label
Edited by 10der
Thanks for the example. If I just want to send in a value to set the White channel to 128 - how can I do that simple?
PS: look like a bug.  was designed for color # for white $ but I forget to add setColor command. Ok. will be fixed in the next version. now you may add "name" manually (attached)
Sometimes I got following message...
can you remove periodic resetting via "inject node" and check it again?
ha! stop
Did you mean the 60 min reset? If yes - there is no difference
stop. I have checked.
it fails new code with events triggering.
on it!
on it!
Yes - it’s related to events
Last days (last version?) I sometimes get ”Suspicious Login Attempts Prevented” without any known reason...
@petrho not sure what red-node is the root issue here
5 days uptime
I get the problem exact same time every night. 00.01
only thing I can suspect is that I am switch off a number of devices at same time. Can HC2 and the plugin handle that?
Edited by petrho
so, if you sure what re-set - getting new devices is root issue here, you can simply confirm reproducing just now - just click inject right now and you should be locked by HC2. isn't it?
Tested to run everything manually (the reset runt also every 60 minutes) with no problem. Lets see what happened 00:01 tonight
Sorry - I got the problem when I runt the reset manually.
It’s now possible to reproduce it. It seems happen when I do many requests at same time. Like that turn off a couple of lights exatly same time and/or if a reset maybe is running in parallel.
When modify like this it seems to be more stable (but not so practical)
Hmm still same problems. I don’t know why...   :-(
@petrho can you stop flow. and look is the issue still here =)
