:P
as good as done...
Just a request if you do not mind, can the MQTT (root/sub-)paths be changed by user?
done!
** DELETED **
You're &*I%ing fast! ;D
Edited by Lambik
Can I create a path that includes the room ?
interesting question...
now modelue support publishing only in a/b/c/devliceID notation
and as an undocumented feature module publish additional properties as
a/b/c/ devliceID/prop
for example
your idea a/b/c/roomName/devliceID  is challenging idea... but :(
... but I can grab rooms on start and can change the topic via config, for example!
At the moment I can adapt your previous flow so it’s no problem ...  unless the capabilities start to diverge significantly.
It,s a shame you have to poll but until Fibaro assist by implementing something that’s the way it has to be...
Thanks for this... it’s allowing Fibaro to catch up a bit with the rest of the world.
do not forget change subscribe pattern
ps: do not ask me to provide room name instead of roomID...
Cyrillics / umlauts... topic - idk how MQTT working with it....
sorry
Edited by 10der
JFYI
jFYI
npm notice
npm notice package: [email protected]
npm notice === Tarball Contents ===
npm notice 376B   package.json
npm notice 2.0kB  README.md
npm notice 4.2kB  fibaro-hc2/fibaro-hc2.html
npm notice 16.4kB fibaro-hc2/fibaro-hc2.js
npm notice 2.3kB  icons/fibaro_hc2.png
npm notice 20.8kB images/example.png
npm notice === Tarball Details ===
npm notice name:          node-red-contrib-fibaro-hc2
npm notice version:       0.0.45
npm notice package size:  26.9 kB
npm notice unpacked size: 46.1 kB
npm notice shasum:        9ca6c8d44f998c1f1f4badaec83e279a16222392
npm notice integrity:     sha512-pGIUi6Q/e963W[...]Vb5LTG0nxqg0A==
npm notice total files:   6
npm notice
+ [email protected]
Edited by 10der
Hi, this is very cool topic! Thanks for all contributors. Atleast community ppl work on dusty Fibaro dino to look fresh'n'cool 8-)
This is really cool way for those have another device (like Pi) running. But for the common users would be much better to have the MQTT broker running on the HC* side.
¯ \ _ (ツ) _ / ¯
@10der I'm trying to figure out this node-js/npm thing (on my raspberry) for a while now. Can you give us some basic node-js command examples, for example to update/upgrade/install and so on?
Keep on the good work! It's highly appreciated!
cd :~/.node-red
npm install node-red-contrib-fibaro-hc2
/etc/init.d/node-red restart
Edited by 10der
Thanks! Are there minimum npm/NodeRed version requirements?
Edited by Lambik
btw. after round the clock :) module will be acceptable in nore-red palette.
no restrictions
btw.,
about HC-device: just simple wrapper for filtering messages by id/property.
notice: all messages from HC2 passed to MQTT in
you_ topic/room_if_configured/deviceId/value_or_propery
so. if you setup in hc2-device just only id (or name) you will get _all_ messages from your device, for example, if a device is a wall plug you will get:
you_ topic/room_if_configured/125/value (on / off)
you_ topic/room_if_configured/125/power
you_ topic/room_if_configured/125/power(supply pressure)
you_ topic/room_if_configured/125/blabla
so, if want to get _only_ on / off state just configure as "125/value"
Edited by 10der
Just to go a bit off-topic...
I was thinking, can the 'get last past param' be initiated by the HC2 (using lua) and send it to a scene, using https (like I did with my scene solution)?
Or will this be a 'slow' solution?
Edited by Lambik
typo
What do you get out of it? example, please!
Well, I seeking a way to get the data encrypted that way. I know this will only work one way: HC2 --> HTTPS to Node-Red --> MQTT.
Secondly, you can use the initialisation (trigger) by using lua VD or scene.
But if I'm talking rubbish, then just ignore me... ;)
Edited by Lambik
Quote
fibaro? ssl? a-ha-ha..
i. e. miaow! :)
as I can understand you have HC2 and node-red not in the local network.... ohhh
Edited by 10der
