All-in-One Scene: How to do it Better
cag014
  • 3 hours ago, Sjakie said:
    My smart implant give notification dead (13 devices!!) and direct after its awake again 13 devices.
    It are 26 ting ting.......... and offcourse panic attac
    OK, sounds reasonable to reduce number of warning... working on that., only one warning for master device.
  • On 4/26/2021 at 10:04 AM, Sjakie said:
    Great thanks!
    Attached version reports only on one child  dead/wake-up device (first reported by the system)
    Please note if your HC2 has another HC2 as a slave, all dead devices will be reported as usual because.
    In master controller no parent device ID defined  for slave devices and there is no way to find out if this is the same physical device
    Let me know if it works
    Edited by cag014
    Hello Cag,
    My NON-excistance device gone with swapper despite the message does not excist.
    Since update V11.6 I did not see any message about "dead" devices.
    Thank you very much!!!
    //Sjakie
    Hello Cag,
    I recieve msg first dead and direct its alive.
    The device is a USB powered PIR. In device list its shows no batteries
    possible to adapt?
    Thanks!
    //Sjakie
    Hi @cag014,
    I have used "Sproeien Aan/Uit" as userdescription in AOQ_Remote, but even addition of the % character cannot avoid an arithmetic treatment.
    Edited by Rover
  • 3 hours ago, Rover said:
    Could you post the jM line of that?
    {"`AOQ_Remote`",{initOnStartup=false,state="userDescription=Sproeien Aan/%Uit",trueAct={
    I recommend not to use mathematical operators in strings. It could create a mess if you will need calculation with that value.
    You can use underscore
    Sproeien Aan_Uit
    In any case I'll fix that tomorrow
    Hi cag014,
    I just installed a new device IBT4ZWAVE and would like to embed it in the AiO script, switching on lights, when the garden gate is opening. I thought it will be simple, but struggling to get the parameter set properly. The device has no value, but the following status options for property state:
    Open
    Opening
    Stopped
    Closing
    Close
    The last attempt I tried is this:
    {0, "`CarGate`",{state="state=Opening",trueAct={{"`EntranceStairsLight`","turnOn",""},{"`EntranceStairsLight`","turnOff","180"}}}},
    17 hours ago, Pretender said:
    Hi cag014,
    Open
    Opening
    Stopped
    Closing
    Close
    Can I ask you what is the gate opener's type?
  • On 5/27/2021 at 11:52 PM, Pretender said:
    Hi cag014,
    Open
    Opening
    Stopped
    Closing
    Close
    Could you post the device API data to get correct parameters value?
    http://<HCIP>/api/devices/IBT4ZWAVE-ID>
    Here is what I got:
    It's a Nice ROA40. Modul fits and I could already create a separate LUA scene, managing the light. AiO inclusion would make it perfect though :-)
  • 11 hours ago, Pretender said:
    Here is what I got:
    As I see the "state=Closed", using same logic when it open then "state=Opened". Please open the gate and verify that.
    Now your line should be
    {0, "`CarGate`",{state="state=Opened",trueAct={{"`EntranceStairsLight`","turnOn",""},{"`EntranceStairsLight`","turnOff","180"}}}},
    correct. I checked when executing my script. When pushing the button to open, status is changing from Closed to Opening. After one minute rechecking the status again and it's set to Opened. Tested successfully witht a separate script.
    When activating the line I am getting an error message:
    /monthly_2021_05/image.png.51b70c623ddf49b751d5a99a00dc3c5d.png" />
    Line used:
    Can it be by any chance that the expression state="state=Opened" is causing an issue as it is expecting numeric values only or the expression state is reserved and I can't use it as criteria?
  • On 5/31/2021 at 12:36 PM, Pretender said:
    Line used:
    My bad, this problem has been fixed on HC3, but not on HC2
    Please use attached version
    This is only the code w/o header and user configuration
    In you scene go to the line
     --======================Copy form here for updates===========================================================================
    and replace with attached version to the end of your code.
    Please let me know if it works.
    Works perfect. Now I can fine tune my line in the code. Thanks a lot for fixing!
    Hi cag! I have an interesting question for you. I have a WalliDimmer, and a WalliOutlet. In the AOQ I can change this devices parameters? I would like to change the device's LED color.
    Edited by SmartLifeSystems
    Hi!
    What would be the best way to set a switch to be on for 2 hours then off for 1 hour, repeating?
