Good morning @cag014
This morning at 9:32 two fatal LUA errors occured with AOS 3.1 more then 7 hours after the last change in AOS code.
One of the errors has been notified by e-mail and iPhone push.
There is only 1 Startscene in AOS which scene has run successful the last time at 8:54.
Can I do something in help debugging?
New e-mail:
AOS 3.1 failed at Fri Aug 28 09:32:26 2020 last debug message:
/opt/fibaro/scenes/431.lua;407: attempt to index a nil value
At a closer look the problem has nothing to do with the Startscene because all the debug messages deal with scene 431, that is my ID of AOS 3.1.
@cag014
I get an error e-mail each 2 hours:
the first:
the following:
AOS 3.1 failed at Fri Aug 28 11:32:28 2020 last debug message:
/opt/fibaro/scenes/431.lua;1358: Assertion failed: Expected string
AOS 3.1 failed at Fri Aug 28 13:32:30 2020 last debug message:
AOS 3.1 failed at Fri Aug 28 15:32:32 2020 last debug message:
I am thinking on a race condition, because the DimmerHal light was off after trigger of the PIR:
First setting dimmerlevel of dimmer and then turnOn of the dimmer. But the turnOn could be faster. So I inserted a delay of 0.5 seconds before turnOn the dimmer. Let's see whether the LUA error stops.
trueAct={
        --Overdag: Dimlevel = DimlevelOverdag als Constant Hallicht Uit EN LampHal is Uit EN Huisstatus<>Slapen EN weinig licht in hal
          {"`DimmerHal`","setValue,@&DimlevelOverdag>value","","{&ConstantHalLicht:value=0|`LampHal`:value=false|&Huisstatus:value<>Slapen|`LichtHal`:value<40}",false},
        --Avond: Dimlevel = DimlevelAvond als Constant Hallicht Uit EN LampHal is Aan OF Huisstatus=Slapen
        {"`DimmerHal`","setValue,@&DimlevelAvond>value","","{&ConstantHalLicht:value=0|`LampHal`:value=true}|{&ConstantHalLicht:value=0|&Huisstatus:value=Slapen}",false},
           --Altijd Aan als Constant Hallicht Uit
        {"`DimmerHal`","turnOn","0.5","{&ConstantHalLicht:value=0}",false}},
BTW: is there a possibility for an inhibit condition of the AOS rules in case of &ConstantHalLicht:value=0, instead of repeating this condition element in each condition?
No improvent:
AOS 3.1 failed at Fri Aug 28 17:32:34 2020 last debug message:
$24Clock line : turnOn a lot of devices: just some of them were turned on.
It seems that AOS is not reliable working any more, what to do?
    What do you mean by turning them ON? I don't see on the last executed commands line.
    20 hours ago, Rover said:
    No improvent:
    Since code lines different between users (depends on jS2n and jM sizes) could you please post actual lines of errors.
    I mean line 407, 1358 and etc....
    {0, "$24clock",{state="value=0",timeSlot="?$sunsetHour-(60*60)?~",
          trueAct={{"`Huiskamer`|`Librije`|`Keukenlamp`|`AanrechtBijkeuken`|`LampHal`|`RaamGloriaLamp`|`Achtertuin`","turnOn","",false},
            {"`ZonneschermLicht`","turnOn","","{&LEDs_Zonnescherm:value=Aan}"},{"`Kerstboom`|`OmasKast`","turnOn","","{&KerstPeriode:value=Aan}",false},
            {"&ZonsondergangMin1","setGlobal","1"},{"_`RandomLight`","startScene","",false}}}},
    Only `Achtertuin`","turnOn", was active last evening.
    AOS 3.1 failed at Sat Aug 29 15:32:57 2020 last debug message:
    line 407:  if val2get=="modified" or index=="lastBreached" then return getModificationTime(cmd) else return jDlist[index..id] and jDlist[index..id] or tostring(api.get("/devices/"..id.."/properties/"..index)[val2get]) end
    AOS 3.1 failed at Sat Aug 29 01:32:43 2020 last debug message:
    line 1358:  if autoRestart then homeTts("Warning! "..sceneName.." failed and restarted");fibaro:startScene(__fibaroSceneId,{"restart"});fibaro:setGlobal(gData.webVar,"<font color=red>Scene failed and restarted</font>")
    OK,
    I think two errors I have fixed.
    Now could you post your jM{} array...
    jM={
    --Licht Hal
    {0,"`BewegingHal`",{state="value=true",
        trueAct={
        falseAct={
            --Save DimlevelOverdag als Constant Hallicht Uit EN LampHal is Uit EN Huisstatus<>Slapen
            {"&DimlevelOverdag","setGlobal","@`DimmerHal`>value","{&ConstantHalLicht:value=0|`LampHal`:value=false|&Huisstatus:value<>Slapen}",false},
            {"&DimlevelOverdag","setGlobal","50","{&ConstantHalLicht:value=0|`LampHal`:value=false|&Huisstatus:value<>Slapen|`DimmerHal`:value=0}",false},
            --Save DimlevelAvond als Constant Hallicht Uit EN LampHal is Aan OF Huisstatus=Slapen
            {"&DimlevelAvond","setGlobal","@`DimmerHal`>value","{&ConstantHalLicht:value=0|`LampHal`:value=true}|{&ConstantHalLicht:value=0|&Huisstatus:value=Slapen}",false},
               {"&DimlevelAvond","setGlobal","49","{&ConstantHalLicht:value=0|`LampHal`:value=true|`DimmerHal`:value=0}|{&ConstantHalLicht:value=0|&Huisstatus:value=Slapen|`DimmerHal`:value=0}",false},
            --Altijd Uit als Constant Hallicht Uit
            {"`DimmerHal`","turnOff","","{&ConstantHalLicht:value=0}",false}}}},
    --Licht Hal Manueel
    {0,"`DimmerHal`",{state="sceneActivation=10",
          -- 1x op Omhoog klikken
          trueAct={ {"&ConstantHalLicht","setGlobal","1"},{"`DimmerHal`","setValue,99",""},{"`DimmerHal`","turnOff","1*60",false},{"&ConstantHalLicht","setGlobal","0"},{"Dimmerlicht","sendEmail[2]","SceneActivation 10: 1x op Omhoog klikken"} } }},
    {0,"`DimmerHal`",{state="sceneActivation=11",
          -- 1x op Omlaag klikken
          trueAct={ {"&ConstantHalLicht","setGlobal","0"},{"`DimmerHal`","turnOff","",false},{"Dimmerlicht","sendEmail[2]","SceneActivation 11: 1x op Omlaag klikken"} } }},
    --Licht Overloop
    {0,"`BewegingOverloop`",{state="value=true",
          trueAct={{"`Schilderijspot`","turnOn","",false},{"`SpotsTrapOverloop`","turnOn","","{&Huisstatus:value<>Slapen}",false}},
             falseAct={{"`Schilderijspot`|`SpotsTrapOverloop`","turnOff","",false}}}},
    --GIA
          trueAct={{"`GIA`","turnOn","",false}},
             falseAct={{"`GIA`","turnOff","",false}}}},
          trueAct={{"`GIA`","turnOff","","{`BewegingHal`:value=true}",false},{"`GIA`","turnOn","0.4","{`BewegingHal`:value=true}",false},
            {"`GIA`","turnOff","1.1","{`BewegingHal`:value=true}",false}}}}, --korter dan 0,4 en 1,1 sec. gaat niet, want dat kan de switch niet bijhouden
    --Waterval
    {0, "$24clock",{state="value=0",timeSlot="10:00~,~22:00",
          trueAct={{"`Watervall`","turnOn","","{&Waterval:value=Aan}",false},{"&ZonsondergangMin1","setGlobal","0",false},{"Waterval","sendEmail[2]","Waterval aan"}},
          falseAct={{"`Watervall`","turnOff","",false},{"Waterval","sendEmail[2]","Waterval uit"}}}},
    --Centrale verlichting
    {0,"&LichtenAanManueel",{trigAct={"`GIA`","turnOn",""}}},
    {0, "$24clock",{state="value=0",timeSlot="?00:00+(60*60)?~,~03:00",
          trueAct={{"`Huiskamer`|`Librije`|`Keukenlamp`|`Bijkeuken`|`LampHal`|`RaamGloriaLamp`|`Achtertuin`|`ZonneschermLicht`|`TuinFlood`","turnOff","","{&Huisstatus:value=Weg}",false},{"&ZonsondergangMin1","setGlobal","0",false},{"Weg: Lichten Uit","sendEmail[2]","Weg: Alle Lichten Uit","{&Huisstatus:value=Weg}"}},
          falseAct={{"`Huiskamer`|`Librije`|`Keukenlamp`|`Bijkeuken`|`LampHal`|`RaamGloriaLamp`|`Achtertuin`|`ZonneschermLicht`|`TuinFlood`","turnOff","","{`LampenSchouw`:value=true}",false},{"&ZonsondergangMin1","setGlobal","0",false},{"Thuis: Lichten Uit","sendEmail[2]","Thuis: Alle Lichten Uit","{`LampenSchouw`:value=true}"}}}},
    --System Keys
    {0, "$RAM",{state="value>85",trueAct={{"RAM>85%","sendNote","Warning. \nSystem memory is $RAM% ",true},{"|$lineId|","setStateValue","80"}},falseAct={{"|$lineId|","setStateValue","85"},{"RAM<80%","sendNote","System memory is $RAM%"}}}},
    {0, "$HC2onLine",{state="value=true",trueAct={"","tts","$dayTime, Home center is on line"},falseAct={"","tts","$dayTime, Home center is off line"}}},
    {0, "$internet",{state="value=online",trigAct={"","tts","$dayTime, Internet is $internet"}}},
    Yes, but only if the entire line ( I mean all commands) needs same condition.
    You can use lineState="{....}" as a rule. The format is exactly the same as in conditions.
    {0,"470",{lineState="{&ConstantHalLicht:value=0}", state="vlue=xxx",trueAct={..............}...}}},
    The code checks lineState first and if it's OK the checks all other conditions.
    Another suggestion... I see in your jM{} you're trying not to execute all commands on startup by using false parameter in all of them.
    You can use rule initOnStartup=false and entire line won't be executed on startup.
    {0,"XXX","{InitOnStartup=false, state="value=xxx",trueAct={...}, falseAct={...}}},
    The idea of false parameter in actions table it's if only you need to avoid execution of specific command on startup.
    Hi @cag014,
    I learn a lot from you ?
    Adding all these practical tips in the guides can teach/helps others too.
    I think I have found the issue... the usage of @[DEVID]>[property] format is for devices only!
    You're using same format for variables:
    For variable just use variable name
    &DimlevelOverdag
    Will set a note in documentation.
    Please try it and let me know if it works w/o errors.
    For next release will check that as well.
    Edited by cag014
    &DimlevelOverdag
    Will seat a note in documentation.
    I have repaired the issues. Let's hope on good working.
    {0,"`BewegingHal`",{lineState="{&ConstantHalLicht:value=0}",state="value=true",
        trueAct={
        trueAct={
    Sorry, my bad
    lineState={"{&ConstantHalLicht:value=0}"}
    {0,"`BewegingHal`",InitOnStartup=false,{state="value=true",
    /monthly_2020_08/screenshot(3).png.264582736c4fba1b996a014ff24cf2cb.png" />
    it should be part of the rules and action table.
    see my example
    {0,"XXX", InitOnStartup=false, state="value=xxx",trueAct={...}, falseAct={...}}},
    see my example
    {0,"`BewegingHal`",{InitOnStartup=false,lineState={"{&ConstantHalLicht:value=0}"},state="value=true",
    /monthly_2020_08/screenshot(4).png.dc36cc7027717a431bbd758367c0e357.png" />
