1 hour ago, cag014 said:
So you have primary HC2 and slave HC2?
Device are on slave HC2?
It should be interesting to see if AOQ can directly control slave HC2. Right now I control devices on my primary HC2.
not any more. I replaced my master hc2 with hc3, and now i have a standalone hcl just for garden
But it's not a problem if you need feedback: i can restore the old hc2 with no device, set hcl as slave import device and test. For my needs ( 4 sprinkler, one water pump, and 2 lights) in garden hcl has enough power.
And don't worry...i switched to hc3 cause after 3 years everything was working perfectly on hc2...too boring:-)
    @Rover
    Thanks... I have my moments?
    No. That's better to use primary controller.
    Edited by cag014
    Working now with AOS and AOQ I feel the need for calling AOS/AOQ lines as subroutine from a line or from a scene. In that case a line should be named.
    Please share an example..
    Today you can run action of the line from other line.
    {0,"400",{state="value=true",truAct={"600","turnOn",""},falseAct={"600","turnOff",""}}},
    {0,"500",{statue="value=true",trueAct=("400>1","runAction,trueAct",""}}},
    Edited by cag014
    For example I should like to have a callable line that checks doors and windows on the open/closed state and change a global variable if a door or window is open.
    Other lines (f.i. arm for night, or arm for away) call this line and also other "subroutines" like the one that arms doors and windows and checks whether this has been successful.
    But if the global variable reflects the windows/doors states, just check the variable in other lines.
    You mean that the global could sync with each change of door/window sensors?
    Yes, you can sync variable or you can check the doors/windows status on line.
    for example:
    1. define sensors and groups in jS2n{}
    jS2n={
    door1=400,door2=500, wnd1=600,wnd2=700,
    dwGrp="`door1`|`door2`|`wnd1`|`wnd2`",  -- as list of devices of the line
    dwGrpState="`door1`,`door2`,`wnd1`,`wnd2`" - as list of devices for condition
    2. example to update global variable dwGlobal
    {0, "`dwGrp`",{state="value=true",trueAct={"dwGlobal","setGlobal","breached"},falseAct={{"dwGlobal","setGlobal","safe","{`dwGrpState`:value=false}"}}},
     Now dwGlobal changes to "breached" or "safe" according to the doors/windows states and can be used as condition in other lines.
    3. example to check the status on line let's say at 1am and if all safe to arm alarm. No global variable required.
    (0,"$24clock",{state="value=01:00",trueAct={"myZone","aramAlarm","","{`dwGrpState`:value=false}"}}},
    Edited by cag014
    Looks very smart! ?
    Now a door is open and I want to generate a notification on which door is open, how to do this?
    Now a window/door has not succeeded in getting armed and I want to generate a notification on which window/door, how to do this?
    Notification on which door opened as follow (in this example TTS generated)
    {0, "`dwGrp`",{state="value=true",trueAct={{"dwGlobal","setGlobal","breached"},{"",tts","$name is breached"}},falseAct={{"dwGlobal","setGlobal","safe","{`dwGrpState`:value=false}"}}}},
    in HC3 the alarm is armed even the sensor is breached. It will alarm on next breach.
    In HC2 I use forceArm command to arm the sensor even if the sensor is breached.
    To notify on breached sensors at any time could be done as well, but it's a little bit tricky.
    1. You need to set variable for every sensor and during the arming alarm to use them.
    2.Every sensor will send notification, but no variables required.
    Let me know if you do need this option and will provide an example
    Edited by cag014
    And when using Pushover in AOQ for every door/window that was open? This is a format using a Pushover QA
        requestBody = json.encode({"Raam Open","0,""none","Velux Kamer Gloria"})
        fibaro.call(Pushover,"Send_Pushover",requestBody)
    What it is pushover QA? Is it your QA?
    By the way you can call any QA from AOQ with all parameters...
    No, I am not so smart to create this, made by @FBerges
    How to embed these 2 statements in AOQ?
    Why?
    AOQ has ability to send push notification (standard and interactive) without any QA.
    Just set
    {"subject","sendPush","body message"}
    or
    {"subject","sendiPush","body message"} -- Special optional argument could be applied, ‘run’ and executed when user presses RUN button on the message in mobile application.
    • To run scene use “run_” (e.g. “sendiPush,run_42”)
    • To run device use “run{command [,arg1,arg2….argN]” (e.g “sendiPush,run41{setLevel,99}”)
    Edited by cag014
    Why?
    Just set
    or
    {"subject","sendiPush","body message"} -- Special optional argument could be applied, ‘run’ and executed when user presses RUN button on the message in mobile application. To run scene use “run_” (e.g. “sendiPush,run_42”) o To run device use “run{command [,arg1,arg2….argN]” (e.g “sendiPush,run41{setLevel,99}”)
    The standard push messages of Fibaro are to limited: no different sounds, secure service available (while Fibaro push often fails),  no persistent messaging, no image including, no support of iOS critical alerts, ...
    So many people adopted Pushover with great satisfaction, like me. But I have not used the push possibilities of AOQ with iOS and I will try this.
    I do no see different sounds for sendPush or sendiPush  in AOS Advanced guide.
    Works very well for me, but on Android.
    Any how AOQ can call your QA.
    Please post the QA and I'll guide you how to use it.
    Edited by Rover
    @Rover
    By the way, AOS/AOQ have many option to perform same task differently (even I'm finding always new ways to do same task more efficiently).
    For example regrading your lights with wait time for one hour, it could be done also like that:
    Assuming your motion sensor defines at first line in jM{} table (marked as bold)
    The idea when sceneActivation = 10 the BewegingHal suspended and after span time of 60 minutes light turned OFF and  BewegingHal activated again.
    When sceneActivation=11 then lights turned OFF and BewegingHal activated also.
    I was so stupid to have sent you the Pushover.fqa with user en token codes, so I am getting stalked with messages of idiotes ?
