    1 hour ago, gggizmo said:
    sorry to diasappoint you cag. In my configuration cpu load is higher near all the time to 100% and delay increased from 2-3 sec to 7-10:-(
    This is very weird... it works always vice versa. Higher CPU less delays.
    Have tested again, no delays.
    Are you sure you running one (latest) AOQ?
    Anyone else has same behavior?
    Rough estimation:
    Previous version: average 15% spikes 50%
    This version: average 20% spikes 50%
    1 minute ago, Rover said:
    Rough estimation:
    This is the same what I have as well.
    Previous version has delays, this one no delays with almost same CPU load.
    @Rover
    What about delays? in HC3 and HC2?
    @gggizmo
    How look like your CPU load without AOQ?
    3 minutes ago, cag014 said:
    @Rover
    No delays to complain of.
    @Rover
    By the way what about HC2 global variable in conditions? &Huisstatus'hc2
    Is it works OK now?
    @gggizmo
    Here my CPU load without AOQ.
    I have only three zWave devices which not triggered or activated by any scene or QA, so this is pure system load.
    Edited by cag014
    26 minutes ago, cag014 said:
    Rover
    Is it works OK now?
    Yes, it works! ?
    Even the synchronization of &Huisstatus'hc2 to &Huisstatus works! But no need anymore because HC2 global variable in conditions work.
    15 minutes ago, Rover said:
    Yes, it works! ?
    Great.
    Thank you for finding the bug
    5 hours ago, cag014 said:
    Here the latest and greates
    1. Fast response, no delays
    2. Keeps CPU Low
    3. @Rover check using global in conditions (I think have found the bug....)
    4. @minsad79 you can use HC3 slave devices, not yet QA globals. You can try to use HC3 slave global values... not sure if it works smoothly yet.
    5. some cosmetic improvements
    --========================== USER CONFIGURABLE PARAMETERS ===============================
    jSlave={
        hc3={user="minsad99",passwd="123456789!",ip="12.10.79.127"}
    jS2n={sensor="304'hc3",switch="247'hc3"}
    jM={
     {0"$RAM",{state="value>85",trueAct={{"RAM>85%","sendNote","Warning. \nSystem memory is $RAM% ",true},{"|$lineId|","setStateValue","80"}},falseAct={{"|$lineId|","setStateValue","85"},{"RAM<80%","sendNote","System memory is $RAM%"}}}},
     {0"$HC3onLine",{state="value=true",trueAct={"","tts","$dayTime, Home center is on line"},falseAct={"","tts","$dayTime, Home center is off line"}}},
     {0"$internet",{state="value=online",trigAct={"","tts","$dayTime, Internet is $internet"}}},
     {0,"304'hc3",{state="value=true",trueAct={"247'hc3","turnOn",""},falseAct={"247'hc3","turnOff","180"}}},
    Was tested
    But still error
    under
    [10.09.2020] [10:02:48] [ERROR] [QUICKAPP116]: QuickApp crashed[10.09.2020] [10:02:48] [ERROR] [QUICKAPP116]: mainCode.lua:799: attempt to concatenate a boolean value (local 'val')[10.09.2020] [10:03:51] [ERROR] [QUICKAPP116]: QuickApp crashed[10.09.2020] [10:03:51] [ERROR] [QUICKAPP116]: mainCode.lua:799: attempt to concatenate a boolean value (local 'val')
    load with aoq
    load without aoq
    Take a look to attached txt file copied from History detail. One shows delay in turning on lights triggered by a motion sensor, the other one shows lights go on and off after remote button pressed.
    cpu load with aoq and slave hcl lines commented
    without slave things work better. less delay and less ( but quite high) cpu load.
    I can't understand why system reacts like there is some sort of timeout...so no delay for the first cicle of operation then 10 sec no reaction then all works again
    13 hours ago, cag014 said:
    Have added Fibaro key-fob to simulate the procedure and everything works fine.
    What key-fob you're using? Some key-fobs sends pressed and then released commands, so in this case your second line will do that (turning On/Off)
    further test on lights. Noway, not working and looks like the line can't evaluate condition...command tunroff else turnoff are executed sequence after evaluation. If light is on then on and off, and viceversa
    노예가 없으면 일이 더 잘 작동합니다. 지연이 적고 CPU 부하가 적습니다.
    나는 시스템이 일종의 시간 초과가있는 것처럼 반응하는 이유를 이해할 수 없으므로 첫 번째 작동에 대한 지연이없고 10 초 동안 반응이 없으면 모두 다시 작동합니다.
    80EA Zwave devices
    0ea zwave devices
    Your HC3 is weird
    My aoq
    CPU is not high
    Looking in event history of HC2 and HC3:
    HC2: delay between breaching motion sensor and lights turned on: 1 second.
    HC3: delay between breaching motion sensor and lights turned on: 1 second.
    This works:
    Why?
    27 minutes ago, Rover said:
    This works:
    Sorry, my fault: &Huisstatus cannot have value 0.
    Still not OK:
    This works:
    Why?
    JS2n:
    How to use parameters?
    Scenario:
    A light is started at random time and stopped at random time and started at random time and stopped at random time ...
    All this started when a global parameter has been changed and stopped by clocktime or other global parameter.
    How to implement this in AOQ? In particular the repeat action bothers me.
    1 hour ago, Rover said:
    JS2n:
    in event history the minimum resolution is 1 seconds. (used with os.time()) so you will never see less than 1 sec.
    Edited by cag014
