    1 hour ago, gggizmo said:
    just an example,. Every lines where a condition is present to check if light is on or off by value
    Interesting...
    Please download attachment.
    By the way this attachment has an option to use slave global variables. Same format as devices &<varName>'<slaveName>.
    For example to use global "Test" in HC2 -> use in jM as &Test'hc2.
    Let me know if it fix the issue.
    By the way please check CPU load, should be less than before.
    Edited by cag014
    2 hours ago, cag014 said:
    5 hours ago, Rover said:
    trueAct={"<QA-ID>", '+Send_Pushover,json[["title","priority","sound","message"]]' ,""}...
    What do you mean how to use it?
    I thought it works
    Sorry that I made myself not clear enough.
    Yes, Pushover works!
    But --[[ in combination with "message"]] disturbs the possibility of giving comment status to a block of text.
    How to print a value for debugging?
    Post an example of what you need to print, but all values of all items  are displayed in HCwebEye...
    I will have a better look at the possibilities of HCwebEye.
    Please post exactly what you're trying to do, including text message
    {3,"`Voordeur`",{state="value=true",
    trueAct={{"`Pushover`", '+Send_Pushover,json[["Voordeur","0","none","Open"]]' ,""}},
    falseAct={{"`Pushover`", '+Send_Pushover,json[["Voordeur","0","none","Dicht"]]' ,""}},
    timeoutAct={{"&VoordeurStatus","setGlobal","TeLangOpen"},{"`Pushover`", '+Send_Pushover,json[["Voordeur","0","none","Te lang open"]]' ,""}}}},
    Yes, same problem in Lua code.
    That happens in your case, because your table after json.encode() has [...] square brackets. In other cases it's defferent.
    Nothing I can help, this is a json format.
    Since the code constantly updates values, actions and conditions it is not so easy to find the right place to print data, you can end-up with endless print outs.
    Please tell me what you need to print and where, it might be a good idea to include printout option in AOQ.
    By the way please pay attention then print debug commands are "eating" CPU big times.
    Yes for sure!
    Before this attachment CPU load average 60% with long big peaks of 95%, a filled picture.
    With the last attachment CPU load average 15% with small peaks until 90%, an almost empty picture!
    9 minutes ago, Rover said:
    Yes for sure!
    Thanks for confirming that.
    --Check DeurenRamen
    {0, "`DeurenRamenGroep`",{state="value=true",
    --trueAct={"&DeurenRamen","setGlobal","Open"},falseAct={"&DeurenRamen","setGlobal","Dicht"}}},
    trueAct={"&DeurenRamen","setGlobal","Open"},falseAct={"&DeurenRamen","setGlobal","Dicht","{`DeurenRamenStatus`:value=false}"}}},
    I was testing your instructions how to work work with groups of devices by using your example.
    The falseAct did not trigger with ,"{`DeurenRamenStatus`:value=false}  and without this condition it works. So I wanted to know what the status of DeurenRamenStatus was at that moment.
    19 hours ago, cag014 said:
    20 hours ago, Rover said:
    It works perfect with controlling HC2-devices. ?
    But the proof of the pudding does not succeed: How to add HC2-devices to Alarm zones? Result is: no devices of this type...
    Thanks for finding the bug... fixed.
    But not fixed in the last attachment ?‍♂️
    --Check DeurenRamen
    That's what I said, use hcWebEye.
    By hovering over the actions you'll see exactly the current values and states/status of all items defined in AOQ.
    Forgive me for my harsh language...just another F%%%ing day spent trying to solve hc3 issue.
    So: new version of aoq reduces cpu load.. thanks cag. Just some spikes but nothing compared to 98% cpu load i had in the morning.
    So i just soft reconfigured again every device,add again hue lights, change js line due to some devices that change id during reconfiguration process, and create brand new template in home remote...i'm a little tired....
    On 8/26/2020 at 7:29 PM, cag014 said:
    so the issue you are trying to use 3-deep nesting....!
     AlleLichten="`Huiskamer`|`Librije`|`Keukenlamp`|`Bijkeuken`|`LampHal`|`RaamGloriaLamp`|`Achtertuin`|`ZonneschermLicht`|`TuinFlood`",
    where Librije nested as well...
     LinksBoekenkast=102, BoekenkastRechts=241, BovenraamLibrije=62, Librije="`LinksBoekenkast`|`BoekenkastRechts`",
    Will try to include let's 5-deep nesting option...
    Is 3-deep nesting already possible?
    And is calling HC2 scenes from HC3 possible?
    5-deep possible
    Scenes not yet, work-in-progress
    Wow... reconfiguration of devices always very painful process.
    The spikes coming from HC3 to communicate with  Zwave devices.
    5-deep possible
    Randomseed has to run once at startup.
    This does not work.
    How to implement randomseed?
    Since the userKeyword executed at the begining the randomseed executed as well.
    Now you don't need to do anyhing with the new keyword, it's already started, so your line should be normal.
    {0, "$24clock",{state="value=0",timeSlot="?00:00+(random(0,120)*60)?~,~03:00", }},
    Edited by cag014
    At the moment testing HC2 globals does not work anymore.
    Earlier this evening it has worked.
    (Difference by adding UserKeyWord $rSeed?)
    BTW I have a global Huisstatus in HC3 as well as in HC2. Earlier this evening both were visible in the WebEye.
    have you introduced some kind of timeout to reduce cpu load?
    Every action starts with 1 or 2 sec delay...
    And i noticed also that cpu load go to 100% during esecution of some lines. Ex. motion sensor trig a light and after 30sec safe turn off light. till lights off cpu load stay high near to 100%.
    I don't think it's aoq related , but i just asking for suggestion on further investigation:-(
    Edited by gggizmo
    --========================== USER CONFIGURABLE PARAMETERS ===============================
    jSlave={
        hc3={user="minsad99",passwd="12345678!",ip="12.10.79.127"},
     jS2n={sensor1="336'hc3"},{lightSw="229'hc3"}
    jM={
     {0"$RAM",{state="value>85",trueAct={{"RAM>85%","sendNote","Warning. \nSystem memory is $RAM% ",true},{"|$lineId|","setStateValue","80"}},falseAct={{"|$lineId|","setStateValue","85"},{"RAM<80%","sendNote","System memory is $RAM%"}}}},
     {0"$HC3onLine",{state="value=true",trueAct={"","tts","$dayTime, Home center is on line"},falseAct={"","tts","$dayTime, Home center is off line"}}},
     {0"$internet",{state="value=online",trigAct={"","tts","$dayTime, Internet is $internet"}}},
     {0,"`sensor1`", {state ="value = true", trueAct = {"`lightSw`","turnOn",""}, falseAct = {"`lightSw`","turnOff""180"}}},
    After setting as above
    Error
    Isn't hc3PROXY supported?
    [09.09.2020] [15:58:03] [ERROR] [QUICKAPP112]: QuickApp crashed[09.09.2020] [15:58:03] [ERROR] [QUICKAPP112]: Unknown error occurred: attempt to index a nil value[09.09.2020] [15:59:02] [ERROR] [QUICKAPP112]: QuickApp crashed[09.09.2020] [15:59:02] [ERROR] [QUICKAPP112]: Unknown error occurred: attempt to index a nil value
