2 hours ago, cag014 said:
2. I think this is preferred option.  You can represent (simulate) the data as after json.encode and use variables or keywords to update the values.
The correct string should be:
    trueAct={{"&pushoverBody","setGlobal","&priority=0@title=Open&sound=pushover&message=Voordeur Open"}}}},
So no json.encode but just a string.
But then parsing error: "global variable 'priority' not found" because the string begins with &
    Ok, this is much easier.
    In order to use &, $, @ signs as characters add % after the character.
    Should be
    "&%priority=0@%title=Open&%sound=pushover&%message=Voordeur Open"
    Should be
    trueAct={{"&pushoverBody","setGlobal","&%priority=0@%title=Open&%sound=pushover&%message=Voordeur Open"}}}},
    In this way AOS parsing is OK, but the accepting Pushover scene did not accept processing of the pushoverBody string ("priority has illegal value" ??), while in the Pushover scene I cannot see a faulty pushoverBody string.
    It looks like a mission impossible.
    Trouble with HC-WebEye2. Till yesterday it has working excellent.
    Now I only get Cross-Origin Reuest Blocked on Firefox (extension CORS E enabled) and Edge (2 CORS extensions enabled).
    But the pushoverBody variable has the correct string, right?
    I assume the problem is in your scene. I can take a look if you will post the scene.
    Working fine on Firefox (80.0) and Chrome.
    Please check IP address of HC2 ...
    Yes the string in the scene looks OK.:
    %% properties
    %% globals
    pushoverBody
    --Prevents the scene from running again when the Global pushoverBody variable get's reset to 0 the end of this scene
    if (tonumber(fibaro:getGlobalValue("pushoverBody")) == 0) then
        fibaro:abort();
    local selfhttp = net.HTTPClient({timeout=2000})
    local tkn = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
    local usr = "yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy"
    local msg = fibaro:getGlobalValue("pushoverBody")
    print("msg= "..msg)
    local requestBody = 'token=' ..tkn ..'&user=' ..usr ..msg
    print(requestBody);
    selfhttp:request('https://api.pushover.net/1/messages.json', {
    options={
    headers = selfhttp.controlHeaders,
    data = requestBody,
    method ='POST',
    timeout =5000
    success =function(status)
    local result = json.decode(status.data);
    print("status: ",status);
    if result.status ==1 then
     print("successful");
     print("Request: "..result.request);
    else
     print("failed");
     print(status.data);
    end,
    error =function(error)
    print"ERROR"
    print(error)
    end})
    --Reset the global pushoverBody variable to 0,this makes sure that when the same pushover message is send again it will change the global variable and trigger this scene.
    fibaro:setGlobal("pushoverBody","0")
    Yes it was an error in the IP address of HC2! ?
    So Firefox (80.0) runs OK, but Edge still has its Cross-Origin Request Blocked for HC2 and HC3.
    Edited by Rover
    Cag just a question about delay time in action : must the delay number be an integer?
    i need to send 2 pulses to fgs-223 to drive an electric gate...
    something like this:
    {0,"`igate`",{state="centralSceneSupport=1.Pressed",trueAct={{"`gate`","turnOn",""},{"`gate`","turnoff","0.2"}}}}},
    The time delay based on os.time() function which has resolution of seconds only.
    What is the maximum requirements for time between the pulses?
    I think I can create a command like
    "turnON,pulse2"
    which will turn ON/OFF the switch according to defined pulses number.
    Let me know which option will work best for you?
    Edited by cag014
    usually pulse must be 200-500ms, no mandatory interval between pulses
    Unfortunately the os.time() gives minimum one second.
    Try to use one second and see if it works.
    by the way I assume you have it in some scene... can you post how you do it?
    Edited by cag014
    ok tnx
    On 9/1/2020 at 4:16 PM, Rover said:
    data = requestBody,
    1.
    You do realize that data=requestBody is not a json array?
    Maybe you need to wrap it as a json array
    data="["..requestBody.."]"
    How it worked before using AOS?
    2.
    Edge has no way to unblock CORS yet. According to Microsoft it will be in the future.
    6 minutes ago, gggizmo said:
    ok tnx
    Any news about the next release of aoq? Have you figured out how to drive a slave hc2/hcl?
    Yes, it works already for Zwave devices.
    This Monday will release the version.
    Next release will control VDs, Scenes and variables... hope sow...
    Perfect. I have only devices on slave gateway. I create scene only on primary gateway.For now i create a block scene on hcl for irrigation.
    I noticed a better zwave range in hc3, but noticed the sometimes hc3 is " less reactive". Randomly i have some delay in light scenes, and  cpu load seems to be higher in hc3 than in hc2, more spikes.
    Worst part...migration: i had to soft reconfigure every single device (70) to have them recognized in alexa. And after a backup hc3 restard in recovery mode. I had to reset to defaults and restore the last backup.
    And there's not any tablet app...
    Last week end  was not easy...
    So you have primary HC2 and slave HC2?
    Device are on slave HC2?
    It should be interesting to see if AOQ can directly control slave HC2. Right now I control devices on my primary HC2.
    I used to have a pulse light as signal in HC2 by means of
    fibaro:call(GIAID, "turnOff")
        fibaro:sleep(500)
        fibaro:call(GIAID, "turnOn")
        fibaro:sleep(500)
    but I saw indeed that
     trueAct={{"`GIA`","turnOff","","{`BewegingHal`:value=true}"},{"`GIA`","turnOn","0.4","{`BewegingHal`:value=true}"},{"`GIA`","turnOff","0.5","{`BewegingHal`:value=true}"}}}},
    in AOS created a "pulse" of a too long pulsetime, apparently 1 second.
    So if it is possible to have a delay time less then 1 second, I support the wish to have it.
    Yes, requestBody is a string.
    Before AOS:
        local prio ="0"
        local ttl ="Open"
        local msg ="Voordeur open"
        local snd ="none"
        local requestBody ='&priority='..prio ..'&title='..ttl ..'&sound='..snd ..'&message='..msg
        fibaro:setGlobal("pushoverBody", requestBody)
    which in the Pushover scene in unpacked as string and further processed:
       print("msg= "..msg)
       print(requestBody);
       options={
       data = requestBody,
       method ='POST',
       timeout =5000
       etc.
    In AOS the Pushover scene complains with "msg is empty" ???
    @Rover
    May I ask you why in AOS you're using '@" character in title?
    According to your scene it should be the same as for others '&"
    so in AOS it should be -
    "&%priority=0&%title=Open&%sound=pushover&%message=Voordeur Open"
    Edited by cag014
    15 minutes ago, cag014 said:
    @Rover
    @cag014,
    ?? Im so glad you are awake! It works from AOS!
    Edited by Rover
