12 minutes ago, cag014 said:
3 hours ago, Rover said:
How to attach HC2-devices to Alarm Zone?
This is totally different approach for alarm in HC3.
In HC2 during arming the HC3 alarm, just include command to arm sensors in HC2 and vise versa.
Same way that you did in HC2
So Alarm Zone concept not usable with devices still in HC2.
Is this concept useful at all using AOQ, even when the HC2 devices have been migrated to HC3?
    4 hours ago, gggizmo said:
    may i ask you all of you which browser you use to connect to hc3?
    Microsoft Edge -85.0.564.44 (Official build) (64-bit)
    Firefox 80.0.1 (64-bit) for hcWebEye
    @cag only issue i have now is weird toggle light behavior i can't figure out why with aoq1.2 everything works and with aoq 2 not.
    I'm trying to simulate that, but it works OK for me. (with Fibaro key-fob)
    Just for testing could you please change the follow line in mainCode. Please ignore any delays
    fibaro.setTimeout(400, function() self:refreshState(lastNext-1)
    to
    fibaro.setTimeout(400, function() self:refreshState(lastNext)
    Let me know if it helps....
    Could you post information about your remotes (brand and model to take a look on manuals)
    Edited by cag014
    When you migrate devices from HC2 to HC3 this is the only concept to use the Alarm.
    In HC3 you cannot arm or disarm any sensor by itself. They must be included in Alarm Zone.
    But I do suggest to create alarm zones in HC3 and to included in AOQ. After transferring devices to HC3 it takes few seconds to update the zones with sensors.
    In addition in HC3 AOQ supports arm/disarm/breached states of the alarm for every included sensor. The breached state of the sensor is not available by default in HC3 as a command or status.
    Edited by cag014
    5 hours ago, Rover said:
    I am sorry to bother you with my typo. It should be &Huisstatus'hc2 and not &Huisstatus|hc2 and it works. ?
    No problem.... I thank you for your help...
    On 9/5/2020 at 7:42 PM, cag014 said:
    To notify on breached sensors at any time could be done as well, but it's a little bit tricky.
    1. You need to set variable for every sensor and during the arming alarm to use them.
    2.Every sensor will send notification, but no variables required.
    Let me know if you do need this option and will provide an example
    In HC2 alarm scene each device is tested on breaching and if yes a Pushover message is sent per breached device.
    Also in the arming scene each device is tested on being closed and if not a Pushover message is sent per open door/window. After arming is tested if all doors/windows have been armed.
    How to implement this in an intelligent way in AOQ?
    So the procedure is to implement all alarming scenes in AOS and not AOQ. After migration of the HC2-devices to HC3 the alarm zones have to be implemented. Right?
    Same in HC3 , you'll need to test every device for status same as in HC2.
    By the way it could be done only with AOQ.
    The standard alarm trigger in HC3 does not specify which sensor is armed/disarmed/breached, only for entire alarm zone
    May I ask you if you did find the jP2n{} table?
    Edited by cag014
    6 hours ago, Rover said:
    7 hours ago, cag014 said:
    7 hours ago, Rover said:
    No jP2n in the new version...
    Is there... in main. Right above jS2n table
    It is not.
    The new mainCode has one line more than the previous one.
    Sorry again!
    I only changed the mainCode and not the main, so it was not there, while you said explicitly it is in main ?.
    It is present in main. ?
    13 hours ago, Rover said:
    Scenario:
    A light is started at random time and stopped at random time and started at random time and stopped at random time ...
    All this started when a global parameter has been changed and stopped by clocktime or other global parameter.
    How to implement this in AOQ? In particular the repeat action bothers me.
    Any suggestion?
    11 minutes ago, Rover said:
    Scenario:
    Any specific time limit how long the light could be on, random between  10 to 30 minutes? Same for Off
    Yes.
    40 minutes ago, Rover said:
    Seconds or Minutes ?
    57 minutes ago, Rover said:
    Interesting... below the time slot is in minutes... try it... when you'll run first time the AOQ it will be active for 10 minutes...after that it's random
    {10,"$gName",{state="value=start", timeLoopAct={{"$lineId","setTimeSpan","?random(`RandomMinTijd`,`RandomMaxTijd`)?"},{"lightId","turnOn;else;turnOff","","{lightId:value=false}"}}}},
    Now set $gName variable to your variable and set to start or stop. Change lightId to your light device number.
    Let me know if it works...
    Edited by cag014
    to
    yes it's ok now.
    Any impact of this modification overall system?
    You are really a genius ? , especially in the middle of the night ?
    It works!
    In minutes is good.
    Now I begin to comprehend the possibilities of timeLoopAct and setTimeSpan for loop activities!
    Anyone can tell me how to use HUE settings
    Brightness,
    Hue,
    Saturation
    Transitiumtime
    Color
    Thanks in advance,
    //Sjakie
    9 hours ago, gggizmo said:
    yes it's ok now.
    attached remote manual
    Edited by Rover
    Brightness,
    Hue,
    Saturation
    Transitiumtime
    Color
    Thanks in advance,
    //Sjakie
    that's the reply cag sent to me for driving hue lights.
    Now, to add non exist device's command, add plus sign "+" before the command. The command will be added without any verification.
    Please be careful, any error in command name won't generate any warning. It's user's responsibility to verify if it works.
    for example:
    {"817","+changeBrightness,255",""}
    {"817","+changeHue,255",""}
    {"817","+changeSaturation,255",""}
    So I think you have simply to put+ in front of the settings you want to push to hue light
    12 hours ago, gggizmo said:
    yes it's ok now.
    Yes, It could have delays on slave devices up to 30 seconds, depends on HC3 activities rate.
    Let me to try something to solve the problem.
    This does not work:
    Does exist a syntax for combining setGlobal operations?
    What about this puterror?
