hi @petrho you get the status with Actornode when you enable the "event passtrough"
    some usefull flows
    1) get rooms and store in global context
    /monthly_2020_01/image.png.8ead5805fb514e82af5f5f697baa4402.png" />
    2) het all ligths and sjow in table
    ad.2 return empty area, why?
    31.01.2020, 12:48:33node: 3a33ce9c.9201ba
    visible=true&enabled=true&interface=light&property=[isLight,true] : msg : Object
    object
    _msgid: "38a46297.e48cbe"
    topic: "visible=true&enabled=true&interface=light&property=[isLight,true]"
    payload: 1580471313713
    currentState: array[0]
    31.01.2020, 12:48:33node: b61a848f.ccb63visible=true&enabled=true&interface=light&property=[isLight,true] : msg.payload : array[0]
    [ empty ]
    object
    [ empty ]
    query by string supported >0.32
    Edited by 10der
    You update to fast ? at last night I updated to fresh 0.32 and today I don't things to check for new version.
    Thx
    For query can I use any of parameters and property, i things yes? and for VD too? I ask because I'm on trip without stable access to my test HC2. Another question about global variable, is it possible to use it as (like) the sensor if changed.
    yes. aby for devices.
    it's pain.
    reading not impemented yet
    changing - pain pain pain :) no admin access
    Yes i know limitation for no admin access, i things for most case only reading is ok. For change, if needed and acceptable from risk point of view, is no problem use rest api. But for use as trigger in mqtt ... we wait for next step of your big work ;-)?
    I forgot, but error generate by FibaroApi without debug returned (i not remember exactly the version from return):
    Payload empty json {}
    topic query
    Another issue after upgrade > 32
    FibaroSensor stopped inform about scene events. Before they give payload.value.keyId and payload.value.keyAttribute when any buttom for ex on remote is pressed if "Handle additional events" checked.
    second method don't work too
    FibaroAPI inform about scenes events:
    but without device ID. And it's not usable without device ID.
    Opps
    sorry
    in work trip
    will be at home tomorrow
    don't worry, the world is better with your app with this small problem that without this apps. I wait and quiet return to home
    .35 - fixed
    hi,
    can somebody say me what i has to wirte in the example node from 10der?
    my Problem:
    in the example there is a motion sensor with lux an timeofday with dimming stats, my problem is that i dont have a rgb aktor is use the dimmer2 and i dont know what i has to write in the passtru node so that the dimmer will dimm my lamps automitacally in the night and other in the day.
    actually there is wirtten:
    if (msg.payload > 0) {
        msg.payload = {
            arg1:255,
            arg2:255,
            arg3:255,
            arg4:255
    } else {
        msg.payload = {
    return msg;
    and this i need for dimmer 2 not for rgb.
    thanks for your help
    @ctyd LoL
    please change deviceId
    thx for your answer but that i dont mean my english is not so good sorry.
    i mean the node in my picture there is code for rgb but i need code for dimmer and dont know what i have to write there.
    I can't see inside node via image :)
    please show me code
    /monthly_2020_02/image.png.21f6125043c42f211a96fd5cfb206468.png" />
    you know what i mean? the Example is from you, i want that the dimmer has the dimm lvl from the example, but in your example you use a rgb aktor and i have a dimmer, i need the code for the dimmer
    Edited by ctyd
    Drop this node. Just drop. And replace actor on actor
    that’s all
    actor can get int value as dimmer
