    @drboss
    /monthly_2020_02/image.png.e1b4977eff4531ba34504712a70a29bc.png" />
    Thx for answer i will try it, have you ever tried a slider in your Dashboard for heating? I try it last night and it doesnt work. Now iam use the button with temp. Like 21 Grad.
    Very very nice, i see you use nest, i have the thermostat from fibaro via zwave. You have There a solution for?
    no nest. at all.
    I have 5 broadlinks + old "Mitsubishi Heavy" AC with heating...
    just using UI for nest for turing on / off / setting temp...
    @ctyd
    Edited by 10der
    thx for the code now i have to marry this with my fibaro node.
    can you tell me what is the code for dimm a lamp?? example: colour temp is "setcolour" and heating is "heating" but what is dimm? ist it brightness oder dimmlvl? the idea is that i want to put a slider before an aktor-node, and the aktor is a dimmer and only the Number isnt working for a dimmer.
    Edited by ctyd
    Ok, will create sample
    @ctyd
    thx 10der, now its running, its so easy bu i think i try this last night and it doesnt work but now it works for me. i used the aktor nodes from your example and i had to delete it and replace them.
    NB: xActor node you can use only for specifiv devices... like thermostat / etc... all others mosted devices you can use only actor.
    i think now it's more clear for you.
    have a nice HA
    yes now its clear, and thank you again for your nodes its awesome and i think i dont need the HC3 because with this nodes and the old HC2 i dont have a "+" on my home automatiation.
    nice HA too!!!
    what news in 0.0.37? ;-)
    reconnection bugfix
    sometimes when HC is gone node lose connection... and stoped... that’s behavior  was fixed
    i have a problem with the heating xaktor and the dashboard, i make some buttons on my dashboard with 22-25 C and i can set the temperature from the Thermostat, this works good. now i want to have a feedback from my HC2 that the HC2 has set the new Temperature, is there a way that i can light a led or other button colour that the Hc has set the new Settings? i tried many things but nothing works for me.
    Thx for the work on the Update!!!! @10der
    Edited by ctyd
    i solved my problem i put a led after the button that shows me the status.
    saw a new update can you say whats new or fixed?
    only fixes and improvements. for example now we can use this scene for POST-ing data from HC instead of pooling from NODE-RED
    Thanks for idea to @drboss
    Edited by 10der
    I use this scene for send any other message to mqtt (via POST or GET) from any VD or scene:
    fibaro:startScene(scene_id ,{'http://192.168.1.10:1880/fromHC2', 'POST', 'application/json', '{"name":"Nick"}', '',''})
    fibaro:startScene(scene_id ,{'http://192.168.1.10:1880/fromHC2?name=Nick&colour=blu', 'GET', '', '', '',''})
    (this is adopted part of another plugin script of GEA env from fibaro.domotique.fr)
    /monthly_2020_02/image.png.d36dcb4c21dd74817b1fed7975907f1b.png" />
    nothing new
    just "glamour"
    /monthly_2020_02/image.png.386e463735da9b8b78e8c13b2a486658.png" />image.png.95f9ee4c467872c0450beed6951a7169.png
    • Thanks 2
