    sorry but MQTT have relate to node-red like rastaman to no ganja smoking :)
    MQTT server (service) it's independed service. it settuped / installed separately from NODE-RED, configured separately from NODE_RED.
    Edited by 10der
    commented
    Quote
    how can i disable user and password in mqtt?
    commented
    edited
    I use mosquitto and I just leave in the mqtt.cfg file the 2 lines for user PW commented:
    #.user=
    #.pwd=
    You can of course also delete the 2 lines.
    But the question belongs rather to a MQTT area than to this area.
    If your question is regarding sonoff then leave in the user_config.h the 2 lines below as they are:
    #define MQTT_USER "DVES_USER" // [MqttUser] Optional user
    #define MQTT_PASS "DVES_PASS" // [MqttPassword] Optional password
    Like this you have no PW set in the server and you do not care, what sonoff is sending.
    commented
    on mosquitto configuration file there is an option for anonymous allowed. If this is set to TRUE you can come with any password and any user and even empty ones and have full access.
    Tanks for the flow ctyd
    I am trying to get heating node to turn on/off my wallplug . But as i can se in debug it only get command false, and i dont understand where that command coming from. Trying to upload flow here.
    But i dont understand how i should get the commands true or false to be sent to the node wallplug.   Should it be sent from heating node or are i missing somthing here
    Quote
    Quote
    Quote
    Edited by oddmn
    Ok, Mosquitto installed on my RPI and now the WD is working properly.
    Only a question :
    Colud you suggest the right way to manage the DV loop crash after this exception error (see screenshot)?
    This happens when the RPI rebbot or if the HC2 <-> RPI connection has been lost.
    Many thanks
    Edited by anonymous_66
    1) check via scebe/device warchdog (search by forum)
    2) cover VD code via pcall
    I meant a your VD source solution.
    The fish ? Now is too expensive
    yes. in my VD.
    you may wrap code via pcall
    not tested,
    i am not use HC2 at this time as developer. all functionality ported to NODE-RED
    new node (ported from HA)
    trigger-state
    /monthly_2020_03/image.png.c5dec0df7e5e9e52c66fb4b4f111e66a.png" />
    turn on off by remotec keyfob
    trigger event for more sources
    motion event triggerd when all lights is off
    about a new node
    I want to turn ON/OFF my lighting (969) according my light lux sensor (1449 )
    it's very easy
    /monthly_2020_04/image.png.9291401c052b8fcaf94b8afb81527418.png" />
    On 3/30/2020 at 9:16 PM, 10der said:
    yes. in my VD.
    not tested,
    Thanks to your suggestion , let me post the VD code that avoids the main loop crash in case of RPI connection lost.
    local MQTT_TOPIC = "home/fibaro"
    function callback(topic, payload)
        fibaro:debug(topic .. "=>" .. payload)
    local function shift_left(value, shift)
        return (value * 2 ^ shift)
    local function shift_right(value, shift)
        return (math.floor(value / 2 ^ shift))
    local function encode_utf8(input)
        local output
        output = string.char(math.floor(#input / 256))
        output = output .. string.char(#input % 256)
        output = output .. input
        return (output)
    function message_write(tcp_socket, message_type, payload)
        local message = string.char(shift_left(message_type, 4))
        if (payload == nil) then
            message = message .. string.char(0) -- Zero length, no payload
        else
            local remaining_length = #payload
            repeat
                local digit = remaining_length % 128
                remaining_length = math.floor(remaining_length / 128)
                if (remaining_length > 0) then
                    digit = digit + 128
                end -- continuation bit
                message = message .. string.char(digit)
            until remaining_length == 0
            message = message .. payload
        return tcp_socket:write(message)
    function connect(hostname, port)
        local function uuid()
            local random = math.random
            local template = "xxxxxxxx-xxxx-4xxx-yxxx-xxxxxxxxxxxx"
            return string.gsub(
                template,
                "[xy]",
                function(c)
                    local v = (c == "x") and random(0, 0xf) or random(8, 0xb)
                    return string.format("%x", v)
        local payload
        payload = encode_utf8("MQIsdp")
        payload = payload .. string.char(0x03)
        identifier = encode_utf8(uuid())
        -- Connect flags (byte 10)
        -- bit    7: Username flag =  0  -- recommended no more than 12 characters
        -- bit    6: Password flag =  0  -- ditto
        -- bit    5: Will retain   =  0
        -- bits 4,3: Will QOS      = 00
        -- bit    2: Will flag     =  0
        -- bit    1: Clean session =  1
        -- bit    0: Unused        =  0
        if (will_topic == nil) then
            payload = payload .. string.char(0x02) -- Clean session, no last will
        else
            local flags
            flags = shift_left(will_retain, 5)
            flags = flags + shift_left(will_qos, 3) + 0x06
            payload = payload .. string.char(flags)
        -- Keep alive timer
        payload = payload .. string.char(math.floor(60 / 256)) -- seconds (maximum is 65535)
        payload = payload .. string.char(60 % 256)
        -- Client identifier
        payload = payload .. identifier
        -- Send MQTT message
        local tcpSocket = Net.FTcpSocket(hostname, port)
        tcpSocket:setReadTimeout(250)
        local bytes, errorCode = message_write(tcpSocket, 0x01, payload)
        if (errorCode == 0) then
            -- all OK
            return tcpSocket
        else
            fibaro:debug("Error on connect")
            return nil
    function subscribe(connection, topic)
        local message_id = 1
        local message
        message = string.char(math.floor(message_id / 256))
        message = message .. string.char(message_id % 256)
        message = message .. encode_utf8(topic)
        message = message .. string.char(0) -- QOS level 0
        return message_write(connection, 0x08, message)
    function unsubscribe(connection, topic)
        local message
        return message_write(connection, 0x0a, message)
    function parse_message_publish(message_type_flags, remaining_length, message)
        local topic_length = string.byte(message, 1) * 256
        topic_length = topic_length + string.byte(message, 2)
        local topic = string.sub(message, 3, topic_length + 2)
        local index = topic_length + 3
        local qos = shift_left(message_type_flags, 1) % 3
        if (qos > 0) then
            local message_id = string.byte(message, index) * 256
            message_id = message_id + string.byte(message, index + 1)
            index = index + 2
        local payload_length = remaining_length - index + 1
        local payload = string.sub(message, index, index + payload_length - 1)
    function parse_message(message_type_flags, remaining_length, message)
        local message_type = shift_right(message_type_flags, 4)
        if message_type == 0x02 then -- CONACK
            fibaro:call(fibaro:getSelfId(), "setProperty", "ui.lblStatus.value", "CONACK")
        elseif message_type == 0x09 then -- SUBACK
            fibaro:call(fibaro:getSelfId(), "setProperty", "ui.lblStatus.value", "SUBACK")
        elseif message_type == 0x03 then -- PUBLISH
            fibaro:call(fibaro:getSelfId(), "setProperty", "ui.lblStatus.value", "PUBLISH")
        elseif message_type == 0x0d then -- PINGRESP
            fibaro:call(fibaro:getSelfId(), "setProperty", "ui.lblStatus.value", "PINGRESP")
        else
            -- print(message_type)
            -- unknown
            fibaro:call(fibaro:getSelfId(), "setProperty", "ui.lblStatus.value", "DATA")
    function handle_response(buffer)
        if (buffer ~= nil and #buffer > 0) then
            local index = 1
            -- Parse individual messages (each must be at least 2 bytes long)
            -- Decode "remaining length" (MQTT v3.1 specification pages 6 and 7)
            while (index < #buffer) do
                local message_type_flags = string.byte(buffer, index)
                local multiplier = 1
                local remaining_length = 0
                repeat
                    index = index + 1
                    local digit = string.byte(buffer, index)
                    remaining_length = remaining_length + ((digit % 128) * multiplier)
                    multiplier = multiplier * 128
                until digit < 128 -- check continuation bit
                local message = string.sub(buffer, index + 1, index + remaining_length)
                if (#message == remaining_length) then
                else
                    print("Incorrect remaining length: " .. remaining_length .. " ~= message length: " .. #message)
                index = index + remaining_length + 1
            -- Check for any left over bytes, i.e. partial message received
            if (index ~= (#buffer + 1)) then
                --- why I am here?
                print("Partial message received" .. index .. " ~= " .. (#buffer + 1))
    function handler(connection)
        local bytes, errorCode = message_write(connection, 0x0c, nil)
        if (errorCode ~= 0) then
            fibaro:debug("MQTT.client:message_write(): " .. tostring(errorCode))
            return errorCode
        else
            local response, errorCode = connection:read()
                return errorCode
            else
                if (string.len(response or "") > 0) then
                    handle_response(response)
                else
                    fibaro:debug("Error: Invalid response. response length: " .. string.len(state or ""))
    function publish(connection, topic, payload)
        local message = encode_utf8(topic) .. payload
        return message_write(connection, 0x03, message)
    --if not connection then
    --    connection = connect(fibaro:get(fibaro:getSelfId(), "IPAddress"), fibaro:get(fibaro:getSelfId(), "TCPPort"))
    --    local bytes, errorCode = subscribe(connection, MQTT_TOPIC)
    --end
    --fibaro:call(fibaro:getSelfId(), "setProperty", "ui.lblStatus.value", "OK")
    while true do
    local ok, result =
    pcall(
      function()
    --local echo_topic = "home/fibaro"
    local connection = connect(fibaro:get(fibaro:getSelfId(), "IPAddress"), fibaro:get(fibaro:getSelfId(), "TCPPort"))
    local bytes, errorCode = subscribe(connection, "prova")
    --print(bytes, errorCode)
    fibaro:debug("MQTT Loop started")
    --local bytes, errorCode = publish(connection, MQTT_TOPIC, "Hello from HC2!!!")
    local error_message = nil
    while (error_message == nil) do
        fibaro:sleep(500)
        error_message = handler(connection)
        fibaro:sleep(500)
    if error_message == 2 then
           fibaro:call(fibaro:getSelfId(), "setProperty", "ui.lblStatus.value", "AUTH ERR")
           fibaro:debug("Disable password authorisation in mosquitto or set alow_anonymous true")
        else
           fibaro:call(fibaro:getSelfId(), "setProperty", "ui.lblStatus.value", error_message)
    fibaro:debug("Error code "..error_message)
    unsubscribe(connection, MQTT_TOPIC)
    connection = nil
    fibaro:sleep(30000);
    • 2 months later...
    Hello  @10der congratulations for the excellent work!
    i am very bad with programing, i am trying to write it propertly but it is not working, would you be so kind to build a code for the following; I have a fibaro motion sensor, if it detect movement i want to switch on a light.
    How can i do that?
    Thanks in advance
    @MadHouseINC already publishe more than 1y ago node for it.
    working  with this node
    /monthly_2020_06/image.png.2614356031a5ddc7e11fdc98ae639446.png" />
    about  Overrides
    by default 60 min time for off
    but owerride sction can obwerride any riles here
    for exampe i want timeout from sunset  till 24h -  30 min and from 24 til sunrise 15min... and at the day 5 min
    {"times":{"sunset..00:00":{"timeout":"30m"},"00:00..sunrise":{"timeout":"15m"}, "sunrise..sunset":{"timeout":"5m"}}}",
    another ex
    i want to overrude default min lux at the day
    {"times":{"sunrise..sunset":{"minLux":20}}
    @MadHouseINC
    Ah ok, thanks for the info @10der. i thought with the actual installed repository nodes it could be possible, maybe i didn’t explain properly exactly what i want to achieve.
    I saw in one of your examples that you have a Fibaro Sensor Node that caches the Lux levels and switch a light on or of with a FibaroXactor.
    What i am trying to do is to use the fibaro motion sensor that if it detects movement to switch on a light, the only way i manage to do it is by connecting it with a http request via api, but i was wondering if it is possible to do it with a fibaroActor
    Edited by MadHouseINC
    the 1st of you are wrong wire MOVE-M1
    it should be UP connector
    sorry my ignorance @10der what is the UP connector? i am really a noob with programing... how can i set it up. as of now it is working with the example of http request via api but i rather have it with your solution.
    huh
    5 mins @MadHouseINC
    @MadHouseINC
    thanks a million @10der you are a rockstar!! i will do some test later and report back. ?
    • 4 weeks later...
    You've alread mentioned you won't get a hc3 but I ask anyways: Does your node red modul work with hc3? If not, could hc3 compatibility be added in case just some minor tweaks would be needed to make it work?
    /monthly_2020_06/image.png.ca38a3d12e73c817c523227e229787de.png" />
    @Automator
    Edited by 10der
