hi drboss i think so to, i will see what i do
@10der any news in the update?
    Bug fix for MQTT mode (was stupid issue)
    and new feature
    on start server node now send 3 events vi 2nd output
    sections list
    rooms list
    devices list
    and after last (devices) server node starts  to poll HC2
    so topic /devices on 2nd output can be as flag what HC2 server node totally inited.
    oh nice thx for work
    i solved the Problem with my Heating Radiators from Fibaro. If you have The Heat Thermostat from Fibaro and want to add it in node red you have to set sensitivität in Prarameter 2 from your Thermostat in the hc. without the Check the Thermostat will sometimes work or not.
    BTW
    The main rule with Fibaro products - turn off all Fibaro features ;) otherwise you may have the strange behavior anywhere
    if you use own heating system in nodered you must turn off Fibaro heating system - cuz conflicts
    for example cuz I never have a plan to buy HC3 and do not trust Fibaro anymore now my HC2 is totally naked- only devices here
    all functionality on node red
    ZigBee devices now living on rPI4 also here lives latest UZB(700)  from Selicon Labs - process “goodby Fibaro was started.
    my HC2 is naked too only zwave controller function. @10der on what system are you running node red? my node red is running on raspberry pi 3, but i dont know is it better on another system or is the rasp a good alternative?
    and what ui (Visualization) are you using? i have the node red UI (Dashboard) at the moment.
    Edited by ctyd
    Node-red on RPI4 (It’s like HC3 but more powerful on %10) , was QNAP NAS (intel)
    yes dashboard UI
    Edited by 10der
    saw update 0.0.45 any news for that?
    /monthly_2020_02/image.png.8a51372217f951a6c2d90562f591055c.png" />
    abstart fibaro device(s) (without actions)
    just provice in config device(s) separated with comma and you will rcvd any events for this device(s)
    simple filter for group devices without defining.
    Guys
    my account 10der was deactivated after changing forum method authentication.
    keep calm ;)
    • 3 weeks later...
    On 1/31/2020 at 10:56 AM, 10der said:
    some usefull flows
    1) get rooms and store in global context
    @10der. Any idea why I get below error?
    TypeError: rooms.find is not a function
    The error is in block 'final adopt'.
    The flow seems to be ok.
    In latest version you can easy use topic for this
    on start HC2 sent always rooms devices and sections
    just hook message by topic
    delete old flow
    g
    Edited by oddmn
    delete post
    On 2/23/2020 at 11:56 AM, 10der said:
    @ctyd
    I have imported this flow.
    Need som help here. Cant get currenttemp to show. it is only showing 23 c My thermostat is showing 22,2 . is there any place i have to put some info aboth my themostat.
    I se the inputnode currenttemp is at 23. is it in this i have to change somthing to get it to read temp from my fibaro thermostat.
    in "adopt" you have 1485 and 1483. is this your thermostat and heating device.
    so i have thermostat fibaro id 240
    fibaro wallplug is 242. conected to  heating device
    Is there a easy way to explain to my how to set this up.
    I got this  from debug.
    22.3.2020, 17:24:06
    msg : string[21]
    "Missing: currentTemp "
    22.3.2020, 17:24:06
    msg : error
    "TypeError: Cannot read property 'hasOwnProperty' of undefined"
    Edited by oddmn
    debug
    @oddmn 1) i am sorry, i do not undestand what are you dooing
    2) mire than I am not Guru with node node-red-contrib-heater-controller. I am not author
    3) and last currenttemp  it's the current ambient temperature. it's not thermostat temp
    4) and lasl-last - its sample injection for demo
    /monthly_2020_03/image.png.c3f67b8565415aaec418d7369b07ae0b.png" />
    it have nothing to do with the question about how to read the current heat-point etc. at all.
    Edited by 10der
    On 1/16/2020 at 10:35 AM, 10der said:
    simple MQTT IN
    @drbosswelcome for fixes
    change topic + callback action
    Hi , I tried your VD but always get the following error message.
    I post my NodeRed Mqtt broker settings.
    Thanks for your support.
    it wrote black on white - turn OFF auth in your MQTT server, it's simple VD and this VD can not use uath and ssl connection to MQTT
    I know but , looking at my Node-Red broker screenshots , where I made the mistake?
