    Did you first install openssl with brew?
    The openssl dir will then typically be in /opt/homebrew/opt/openssl
    I've tried to install openssl after installing luarocks and before hc3emu. And later, also try to reinstall after hc3emu. No difference: as I see from log - hc3emu try to install open ssl with the same result as standalone installation: missing dependencies for lua-websockets-bit32 2.0.1-8.
    You have done
    and it worked?
    You have then used
    and you still get complaints it can't find the header file for openssl ?
    No - previously I did:
    brew install luasec - as the log prompts. It failed and installing hc3emu too.
    But now I did:
    brew install openssl (patience, very long process)
    sudo luarocks install luasec
    sudo luarocks install hc3emu
    Then take .json files from your repository to my_project/.vscode
    And on my Fusion OSX 12.6 VM it works after all.
    Because of performance and other reasons I cannot work on the VM. Unfortunately, all above can't be repeated with success on my physical mac.
    There are many errors that investigating over the forum seems to me useless. It's probably a real mess in there.
    Edited by Łukasz997
    Maybe close to the success. After total removing, reinstalling I've come to this debug console message:
    I have in ./.vscode: launch, settings, tasks copied unchanged from your repo. In '.' project directory I have .hc3emu with credentials, and hc3emu.lua unchanged from repo (is it necessary?)
    Could you tell me where and what exactly I have to set?
    Yes, it looks like you managed to install 👍
    You need to generate a config file.
    There are 2 ways to generate it.
    First, you need to set the emulator in offline mode, otherwise it will complain that hc3emu.URL is not set
    Do the by adding the directive
    your New_QA.lua in this case.
    First approach is to install the vscode extension "Live Server" by Ritwick.
    ...and also add the directive
    to your New_QA.lua.
    This directive tells the emulator to start generating webUIs for the emulator and QAs - a little like fibemu.
    Then you have a directory generated in your workspace folder named 'emu'
    There you have _setup.html
    If you open that page with live server extension (right click on file and "Open with Live Server")
    you have a menu to generate and edit the settings files.
    There are 2 files, one project file in your workspace, and one "global" in your home directory". The workspace overrides the global.
    I recommend that you set the HC3 IP, user, pwd in the global and leave them out from the project (or don't generate a project config at all).
    The edit settings is a simple web form to edit the values (there is a save button at the bottom)
    The second approach is that you run
    in your New_QA.lua
    It will generate a project and global file
    and
    and then you need to edit the json with an editor. I recommend to only set the credentials in the global/homedir config file.
    To be more specific. "Live Server" opens an external web browser page. And it is easiest, but have some issues.
    I use instead the vscode extension "Live Preview" by Microsoft.
    It works better but have the drawback that the html file needs to be open in vscode for to preview to update.
    The live server does not work - it means it repeatedly refresh the page (not main, but the web form; safari, firefox).
    Microsoft preview works. But...
    Edit global lead me to the web form. I can write data and install global config. However after reopen the web form - the IP number remains as at the first open, my IP was not saved. Interesting but login and password was saved.
    I have to leave it for a day.
    Today I can't open the config for edit. To be honest, I have no idea what I did that situation changes. 192.168.2.101 is proper IP number of my mac.
    File named .hc3emu.json is present in my homedir (//Users/lukasz). I edit it and correct ip for HC3. The error below - remains.
    When I remove directive
    --%%offline=true
    I have still missing URL at debug console
    /monthly_2025_04/image.png.26214dc55e4f613871b128dcd4da1110.png" />
    The emulator needs to be running for the web forms to work (they make calls back to the running emulator).
    So you need to have a QA running. The fetch error you get is because there is no answer to the request the form is making.
    Thank you very much for help. Now, all data is saved.
    However the message:
    [29.04.2025][20:00:00][SYSERR]  Missing hc3emu.URL - Please set url to HC3 in config file
    still persists when I try to run the task to download the qa from HC3. Or does not have --offline=true in my LUA file.
    Edited by Łukasz997
    I left IP with '<' and '>' and probably this caused "missing url" .
    No more this error. But - running simplest QA code (function onInit printing something)I have the following message now:
    Could you advice me please how can I mend it?
    Downgrade to v1.0.80
    there is some issues in the latest build
    There will be a new version tomorrow.
    I remade a large part of the API architecture in v1.0.81, and I'm slowly recovering from all bugs that I introduced :-)
    There is a pre-release v1.0.87 out now. It should run.
    Still some minor improvements coming up for v1.0.90...
    Thank you - now it's working.
    Pushed v1.0.90-1
    • Major reimplementation of the API code. Hopefully better performance and easier to maintain...
    • New installation bootstrap
    Ex.
    Will install .hc3emu.json in home directory with the user/password/url setup.
    The new API approach uses a method that if offline=false, a small helper QA is installed on the HC3 (invisible) to help out with some API REST calls that are tricky to do remotely. Its name is 'hc3emuHelper'. When the emulator is run it will check if helper is installed, and if not install it. (It will also check version, and upgrade if a new is available, but I believe that the helper will not be upgraded a lot...). This should be totally invisible and nothing to care about.
    In the past this "service" was done by the proxy QA that was installed, but now the proxy and helper are separate, allowing all REST API calls even if we don't run with a proxy.
    After upgrade 1.0.91 it gives the following error:
    I'm not pretty sure if I can give --%%install once or always, but whatever I did the result is as above.
    Sorry, bug I thought was fixed..., try v1.0.92 that I just uploaded
    After upgrading to .93 proxy shows only few messages and no more, but buttons are functional.
    I thought that maybe proxy should be installed again by .93 and delete the proxy.
    And now I have:
    This is messages after deleting the proxy. New proxy, despite the errors, is installed. After I restarted it again, only the difference is: Proxy found. In .80 this QA is working OK.
    I'm wondering If you're feeling pressured to quickly fix this complicated and large application... If so, please don't. I’m happy to downgrade to stable version .80 and wait patiently for the updated release. Thank you for all.
    EDIT: the probably cause is that local Variable of QA was not set. In such case getVariable does not return nil or empty string but something other like NOTHING. And json.decode fails with it. Maybe it will help. Please see the value of set.getVariable("non_existing_var"):
    /monthly_2025_05/image.png.8ef18b01d950d32351fad856f76ee2af.png" />
    Edited by Łukasz997
    Yes, it dies because you call json.decode with a bad value
    That error you will get on the HC3 too.
    self:getVariable( returns the empty string for non-existent variables (Fibaro's decision).
    In the vscode watch panel it looks like jsonVal =
    because it's an empty string as value - not so clear maybe... but they decided not to quote strings...
    Trying to decode an empty string gives the error message "json.decode error: value expected at position 1"
    So, I would file this as "expected emulator/HC3 behavior"
    I do have other errors though, so please report your issues... :-)
