If I use any calculated condition in assert - I have an error assertion failed. O.E:
gives:
Tested on .80 and .97, the same result. On HC3 - ok.
When I wrote:
there's no error.
I'm installing and using versions as they are coming, but to be honest have no idea which one can be presume stable.
One remark about WATCH window: this debugger does not include text with "". Text is brown, instead; when o.e. value false is blue.
Edited by Łukasz997
    So, assert, if the test condition is false will generate an error and show the optional message.
    It seems to be failing on line 100 in your example showing the message "assertion failed!" - is that correct?
    I was a bit thrown off because your example has the text "Do inicjalizacji sterownika brama nie może być uchylona"...
    Anyway, assertion works, it generates an error with the traceback. The prefix "[C]]"may not be so nice and I will fix that.
    So the problem is that you have a test that works on the HC3 (lastCmd == "ajar") and not on in the emulator?
    The question is then how lastCmd is computed, then we can try to understand if there is a difference.
    Are you running offline, or in proxy mode or?
    I do appreciate these error reports from you, and I'm happy if I can help you.
    The QA you are developing, is it something that you can PM me so I could test it? or does it depend too much on external devices? (some of it I can fake).
    I would go with the latest now. 1.0.98 - I been using since 1.0.96 for my own QA developments.
    I'm only fixing bugs now so I hope to come out with a 1.1 soon that I would consider "stable"
    The morning is wiser than the evening, we said in Poland - and I know what's happening.
    I'm running online with proxy.
    Yes, program ends with assertion in line 100, no my message as needed.
    But real line 100 was other that - for simplicity - I wrote in last message (additionally I've made an error with condition). Real is:
    and inform returns nil.
    I forgot to return a string in function inform (which write on the QA UI and throw push), having assert error without message.
    The construction is such because I would like to squeeze inform and assert in one line.
    I'm sorry for wasting your time!
    Only profit is that I noticed: even if the assert condition is TRUE (so assert could continue, no error throwing) the function inform is executed. But if we have pure text as second argument - no print occurs, as expected.
    So when condition == false I have message on the UI + on the debug console and error by assertion.
    When condition == true I still get a message in the UI anyway.
    Yes, that's the way lua works.
    assert is just a function, and lua will always evaluate all function  arguments before calling the function.
    So, yes, don't do anything complicated in the second argument of assert, as it will always be computed.
    Then if the test is false, assert will throw the result of the second argument upwards as the error message...
    For efficiency I sometimes make the test explicit. Instead of
    that will do the string.format every time, even if the test is true, I do
    This way, the strain is only formatted and thrown with an error if the test fails
    Pushed v1.1.0-1
    • Major re-implementation of the API code. Hopefully better performance and easier to maintain...
    • Better error messages
    • Lots of small bugfixes
    • Improved setup/bootstrap procedure
    So, there have been a large rewrite of the core API handling mechanism in hc3emu, starting from v1.0.81.  It has stabilized now and it runs through all the tests that v1.0.80 did - and more. I have been using this since v1.0.96 myself for my rather complicated QAs and it works well.
    The main usage of hc3emu when developing QAs is to enable "proxy mode", meaning that there is a proxy QA for your QA running on the HC3 where you interact with (end define ) the UI, and the proxy relays button presses etc back to the emulated code in hc3emu, so one can interact and debug like everything was running on the HC3.
    There is also an "offline mode", where everything runs in the emulator and there is a limited webUI generated for the QA running so one can interact with it.
    However, running offline there are limitations as not all HC3 APIs are implemented, alarms, climate, energy etc... on the other hand, WebSocket,MQTT, TCPClient etc are all there so it's suitable for developing and debugging more advanced network interactions. Offline mode can also run QuickApp children.
    If you have an "UI intensive" QA, I strongly recommend to run in proxy mode as it will give you the ability to debug the real UI with all it's quirks... ;-)
    Ex. I have a HASS QA that generates ~30 QA children for the different types of devices imported from HASS. I can run it offline, but some of the children like the sonos player don't have a good webUI interface, so that's missing. However running online I have the real QA child UIs and I can debug the interaction with each child.
    Good evening,
    I have another issue, I hope not my error this time.
    I have my own event manager that handles events from RefreshStateSubscriber().
    I have the situation that in  v1.1.0 the events are called twice. O.e. I hit the button and event handler is called, and it's called with the same event once again. Maybe not all events, but this comes from the button - duplicates. I do not investigate it deeper.
    In HC3 for sure it's working ok. In .80 also OK.
    This occurs only in hc3emu 1.1.0
    What can be the reason???
    Event handler is very simple (shortened):
    Yes, that's a bug. I'll fix it tomorrow - needs some brain cells to fix...
    Pushed v1.1.1-1
    • Fix for duplicate events introduced in 1.1.0.
    vscode logging merge identical log messages into 1 single line starting with the number of identical log messages. I was blind to this in my test examples before releasing 1.1.0...
    Lesson, don't rely on visual inspection of log outputs... and 1.1.1 is maybe a lucky number :-)
    9 hours ago, jgab said:
    Pushed v1.1.1-1
    I was using v1.0.76-1 since a while with no issue. Seeing that you made few new updates I updated from 1.1.0.76-1 to 80 without any issue with the QA under development but from v1.0.90-1 and all intermediate version and  v1.1.1-1 I have the following error:
    HC3Emu - Tiny QuickApp emulator for the Fibaro Home Center 3, v1.0.92
    ...s\luarocks\current\rocks\share\lua\5.4\hc3emu\config.lua:119: Failed to open file: hc3emuHelper.fqa (coroutine: copas_initializer, socket: nil)
    stack traceback:
        [C]: in function 'assert'
        ...s\luarocks\current\rocks\share\lua\5.4\hc3emu\config.lua:119: in function 'hc3emu.config.loadResource'
        ...s\luarocks\current\rocks\share\lua\5.4\hc3emu\helper.lua:12: in upvalue 'installHelper'
        ...s\luarocks\current\rocks\share\lua\5.4\hc3emu\helper.lua:92: in function 'hc3emu.helper.start'
        ...apps\luarocks\current\rocks\share\lua\5.4\hc3emu\api.lua:175: in method 'start'
        ...apps\luarocks\current\rocks\share\lua\5.4\hc3emu\emu.lua:199: in function 'hc3emu.emu.setupApi'
        ...apps\luarocks\current\rocks\share\lua\5.4\hc3emu\emu.lua:648: in function <...apps\luarocks\current\rocks\share\lua\5.4\hc3emu\emu.lua:644>
        (...tail calls...)
    'hc3emuHelper.fqa' file exists in C:\Users\ASUS\scoop\persist\luarocks\rocks\lib\luarocks\rocks-5.4\hc3emu\1.1.1-1\rsrcs.
    Is it an issue with a missing path?
    Yes, on Windows, that is a bit tricky with the path, the algorithm to find the resource directory is that it should be in a path
    C:\Users\...\scoop\apps\luarocks\
    but I see that you have it in
    C:\Users\...\scoop\persists\luarocks\
    I think they link to the same place.
    Can you see if you have the file in
    \Users\ASUS\scoop\apps\luarocks\3.11.1\rocks\lib\luarocks\rocks-5.4\hc3emu\<version>\rsrcs
    You should also be able to set the windows environment variable EMU_RSRCS
    to the ...\rsrcs\
    directory.
    Note though that vscode is a bit tricky what environment variables it relays to the running program. Think it should be set in launch.json
    To be more specific,
    If the emulator can't figure out where my hc3emu directory is, and I have it in, ex.
    then I can set the user environment variable EMU_RSRC to C:\Users\jgab\scoop\apps\luarocks\3.11.1\rocks\lib\luarocks\rocks-5.4\hc3emu
    This way the emulator will look in that directory for the latest hc3emu installation and it's rsrcs directory.
    /monthly_2025_05/image.png.635f1a1eb7d8326af5c4e197cb0ce869.png" />
    This also works on MacOS, but there it's usually not a problem for the emulator to guess the directory...
    Pushed v1.1.3-1
    • Bugfixes and code cleanup
    Tips and tricks
    1. Bypassing the emulator for api calls not implemented
    When running the emulator, all api.* calls goes through the emulator.
    Some calls may not be implemented yet and may thus return a 501 code...
    It is possible to bypass the emulator, and calling the HC3 directly by using
    api.hc3.*
    Ex.
    If panels/sprinklers is not implemented in the emulator, this is the way we can call out and get. the value directly from the HC3.
    We can conditionally use that form if we are running in the emulator, so we later can move the code to the HC3
    If we are running online, most unimplemented calls will try to call directly to the HC3 as a fallback, so the case with sprinklers above is not necessary in that case.
    However, if we are running offline, this can be a way to do certain calls to the HC3 anyway, for debugging purposes.
    2. Restricted Lua function.
    A QA has a restricted Lua environment where not all standard Lua functions are available.
    In the emulator some the missing functions are available from fibaro.hc3emu.lua.*
    Ex.
    Obviously they will not work on the HC3, but for debugging purposes in the emulator they can be handy.
    3. Access to emulator tools.
    The emulator functions are available via fibaro.hc3emu.*
    The existence of fibaro.hc3emu is a good test if your QA runs in the emulator or on the HC3.
    fibaro.hc3emu also contains a suite of useful  functions and values
    Running hc3emu in vscode devcontainer
    Requirements
    • Install vscode
    • Install Docker desktop
    • Install vscode docker extension
    This is probably one of the easiest way to get going.
    The devcontainer model creates a virtual container with Linux, install all the tools and connects vscode editor to the container.
    This is a good way to develop without having to install a lot of stuff in your system, Tried on MacOS and WIndows11
    In the video I rebuild the container without cache to show the full process. Normally the container image is cached so the startup is very fast.
    The preferred approach is to have the credentials for the HC3 stored in the config file in your home directory. When running a container, the home directory is inside the container (usually at root/.hc3emu.lua) and the config file will be lost when rebuilding the container.
    Instead, we can add the credentials to the .devcontainer/resources/devcontainer.json as environment variables as shown in the video.
    It's important to set the HC3EMUHOST variable to the laptop IP (the PC running the emulator) to make the webUI work. It's a bit complicated to serve traffic in and out of a container.
    It's also possible to create a config file in the workspace directory (the vscode workspace directory is mounted to the container so we can work with the files like a normal vscode workspace project).
    I have this file 'hc3emuHelper.fqa' in 2 places:
    C:\Users\ASUS\scoop\apps\luarocks\current\rocks\lib\luarocks\rocks-5.4\hc3emu\1.1.3-1\rsrcs
    C:\Users\ASUS\scoop\apps\luarocks\3.11.1\rocks\lib\luarocks\rocks-5.4\hc3emu\1.1.3-1\rsrcs
    I have still the error in the DEBUG CONSOLE:
    [12.05.2025][16:01:35][SYSERR]    Failed to load resource .\rsrcs\hc3emuHelper.fqa
    ...s\luarocks\current\rocks\share\lua\5.4\hc3emu\config.lua:122: Failed to open file: hc3emuHelper.fqa (coroutine: copas_initializer, socket: nil)
    stack traceback:
        ...s\luarocks\current\rocks\share\lua\5.4\hc3emu\config.lua:122: in function 'hc3emu.config.loadResource'
        ...s\luarocks\current\rocks\share\lua\5.4\hc3emu\helper.lua:102: in function 'hc3emu.helper.start'
        ...apps\luarocks\current\rocks\share\lua\5.4\hc3emu\api.lua:155: in method 'start'
        ...apps\luarocks\current\rocks\share\lua\5.4\hc3emu\emu.lua:200: in function 'hc3emu.emu.setupApi'
        ...apps\luarocks\current\rocks\share\lua\5.4\hc3emu\emu.lua:660: in function <...apps\luarocks\current\rocks\share\lua\5.4\hc3emu\emu.lua:656>
        (...tail calls...)
    the EMU_RSRCS path is: C:\Users\ASUS\scoop\apps\luarocks\3.11.1\rocks\lib\luarocks\rocks-5.4\hc3emu
    Even if I add this one: C:\Users\ASUS\scoop\apps\luarocks\current\rocks\lib\luarocks\rocks-5.4\hc3emu\1.1.3-1\rsrcs, error is stille there...
    Do you think that if I make devcontainer installation, this will resolve my path issue for versions over 1.1.0.80-1?
    If yes, do I have to desinstall all previous installations?
    stack traceback:
        (...tail calls...)
    Is
    _DEVELOP=true
    set at the top of the QA file you try to run?
    If that is set it tries to load the emulator files from the local directory, assuming it's the full repo of hc3emu.
    It's used for developing and debugging the emulator.
    Your error says
    which says that it's looking in the current directory - and _DEVELOP=true is set. There the file is in <workspace>/rsrcs/hc3emuHelper.fqa
    Many files in my examples/ directory has that flag set as I use them for debugging/testing the emulator
    Just comment out that line, and the emulator will fetch the files from the place where luarocks install them.
    30 minutes ago, jgab said:
    Is
    _DEVELOP=true
    NO, I have learn that few weeks ago...
    This QA file is one I started to develop with your first emulator on ZeroBrane, modified it for using fibemu and now hc3emu.
    Is is perfectly working** using your version 1.0.80-1🙂
    ** except for my few remaining bugs 🫣
    Edited by Christb
    can you PM me the file so I can test?
    Attached
    Note: if you are using a proxi view on your HC3, do not select new view (forcing choice of a select button does not mork then)
    Edited by Christb
    adding a note
