First of all, I would like to express my sincere appreciation to @10der  @Alex @petergebruers  @robmac  @amilanov @Bodyart @drboss and others for their time and help to improve / debug the code.
The scene “analyzes” mesh network configuration in the system and displays the location efficiency of the devices in table format. Table sorted by the rooms according to average location efficiency of the devices in the room (in ascending  order - from lowest to highest efficiency). More like "Z-wave mapping" in your residence.
In addition scene analyzes location efficiency of HC2 location.
To achieve precise data, please make sure your devices' physical location correctly associated with room names.
For example:
in-wall switch located in kitchen, but controls lights in garden, should be assigned to kitchen and not garden.  (the device name should be assigned as  garden lights)
Usually inclusion of the device done close to HC2 therefore the route table is incorrect. To achieve reliable data, perform inclusion when device located in designated place/spot in residence or perform Mesh Reconfiguration to device after inclusion near to HC2.
User configurable parameters,:
  1. showDevices=false          if set tot true,not sorted table of all devices will be displayed also).
  2. fontSize=100     font size percentage (80% - 150%).
Big Note:
If you've removed device which is part of mesh route to others, the route table doesn't get updated !
Controller continues to maintain undated route table! Mesh table must be reconfigured. (Z-Range Analyzer identifies these devices.)
Warning: Battery powered devices cannot forward packets and cannot be used in route for others.
Spoiler
To observe data in graphic, use @10der's visualizer.
Run the scene and here some details on what will be displayed:
When or if corrupted/deleted devices have found in your system, data details will be printed before table appearance.
Spoiler
Table header:
Spoiler
·       Number of master (physical) and slave devices in the system. By hovering mouse over controller name, table color index and Z-Capacity are shown
Spoiler
·       Date range of displayed data (if any changes done like adding, relocating devices after this date, mesh reconfiguration requires)
·       HC and devices location efficiency.  If devices lack mesh route data (colored by red) present in the system, two efficiency numbers displayed. (50%/60%).
  1. including devices with no routes and neighbors data
  2. excluding these devices.
Table columns:
1.
Script's total serial number / Script's serial number in room
2.    Room Name  %
Spoiler
Room name and average location efficiency of the devices in room
3.    Parent ID: Name
Spoiler
Parent (master) device ID, name and room. Devices lack mesh route data colored by red. By hovering mouse over, child (slave) devices list is shown (and number of last 24 hours z-wave events of each slave)
4.   %
Percentage of location efficiency of each device in the room.
5.     iSee
Spoiler
Total number of neighbors (adjacent) devices that it can communicate with (seen by device). By hovering mouse over, devices details are shown. Great view on how device located by seeing who neighbors are.
    The data shown in two colors:
                    I.            green - Device can communicate directly to controller. Shades of green according to number of adjacent neighbors. greener, more neighbors)
                  II.            red - Device doesn’t communicate directly to controller.  Shades of red according to number of adjacent neighbors. (redder, less neighbors)
If tilde sign appears before  the number - means the list includes device(s) that not in the system (deleted device). I devices details menu this device marked grey.
4.     Last Route
 List of devices that participate in route communication to controller. By hovering mouse over list of devices details is shown.
Spoiler
3.     iRoute
Total number of devices where this device is part of communication route. By hovering mouse over, devices details are shown.
5.     Status
Last working route status. (OK, pending, in progress, error)
6.     Time Stamp
Time stamp of last working route reported to the controller.
7.     24History
Master's last 24 hours events number and percentage of total events. By hovering mouse over parent in Parent ID: Description column, number of z-wave events for each slave is shown. Please notice 24 hours history based on saved logs in event panel. If you have devices that excluded from saving logs,  theirs events are not available.
Points for improvement
Location efficiency calculated relatively to your best device in system, therefore red and yellow marked devices don't necessary indicates that your system is broken.
Special attention requires when changing/removing physical place of devices in location with low efficiency level, it could cause loss of communication or delays.
        I.            Parent ID: Description - Device marked red indicates lack of route data. Perform mesh reconfiguration for this device. If reconfiguration failed, recommended to exclude/include the device (Painful process and occasionally updates in code are required).
      II.            Last Route - More devices in route increase probability of communication delay and indicates that device is in distance from controller.  Since in Z-Wave each device calculates the shortest route to the destination (up to 4 hops), therefore if route includes more than three devices recommended
  1. Check/verify devices in route as well. Mesh reconfiguration recommended.
  2. Device is far away from HC2 or Z-wave signal interrupted.
    III.            iSee - If number is in shade of red and relatively low, means the device located far away from controller and low number of adjacent neighbors in that area or device located where physical barriers such as metal panels, concrete walls and etc. are blocking Z-Wave signal. (or located in-wall socket and Z-wave signal interrupted) Increased probability of packets loss rate, delay expected.
    IV.            iRoute - As much as number is higher, means increased workload for this device (needs to track messages from this number of neighbors). Increased probability of delays from device and routed devices.  Recommended number less than five devices.
      V.            Route tables do not get automatically updated by adding a new device or device relocation. Mesh reconfiguration (in Z-Wave Panel) requires.
Do not reconfigure mesh network when devices are not in designated spot.
What's New in Version 1.3   See changelog
Added new column 24History
Last 24 hours events number and percentage of total events. By hovering mouse over parent in Parent ID: Name column, number of z-wave events for each slave is shown.
Spoiler
Spoiler
Please notice 24 hours history based on saved logs in event panel. If you have devices that excluded from saving logs,  their events are not available.
nicopret
Thank you @cag014  for another brilliant tool that helped me to improve my HC2 zWave network. I believe I have already identified and addressed the main issues I had such as:
  • 2 missing devices from routes table
  • Battery powered devices which I added years ago which had low NodeID's. I removed some of them and then added them again.
In general my HC2 is working well now and better than before. However, I'm trying to further optimise my network.
From the Z-Range analyzer 1.3 documentation above, it states:
Quote
I was not aware that the room allocation of a device can affect the routing? I have some switches that control lights/devices in different areas, i.e. a switch box with multiple switches in the Kitchen that control Kitchen lights and that control Outside lights. It is just more intuitive for me from the Fibaro app side to control lights/devices in the area where they are used. I moved some of the "Master" devices (which are mostly hidden from my system) to the rooms where they are physically located and then ran reconfigure mesh for the specific devices. The slave devices are, however still allocated to the areas they control. Example Room: Kitchen, Parent ID: OutsideLightSW. Can that be a problem?
I have done the same with a number of devices in the PoolRoom and then I reconfigured zWave mesh for those devices individually. However, some of them are still listed in the "Unassigned" room even though I have moved them to the PoolRoom and re-configured the mesh. Examples are: 543:StatueFountainSW and
513:StudyPatioSW.  667:TVStripSW is in TVRoom and has always been, but is also listed in "Unassigned" room. It this perhaps because the slave devices are in a different rooms?
Please see the z-range-analyzer output for my network below:
Spoiler
1-Dec 07:39:22 : ZRangev1.3 12Devices: masters=69 slaves=247123Data date range: 01 Dec 2022 - 01 Dec 2022
WinelandsHC2-022267 efficiency: HC2 location 51% Devices location 79%
# Room Name Parent ID:Name % iSee Last Route iRoute Status Time Stamp 24History
1/1 PoolRoom 27% 519:RimflowSwitch 20% 5 150,667,513 1 ok Dec/01/22 06:48:04
2/2 556:HeatPumpHDSW 24% 6 612,925,519   ok Dec/01/22 06:48:07
3/3 249:RimflowSpeedSW 31% 8 612,925   ok Dec/01/22 06:47:42 6/0.2%
4/4 925:PoolRoomSW2 31% 8 747,667 3 ok Dec/01/22 06:48:37 16/0.7%
5/1 Outside 35% 578:WaterFeatureSW 35% 9 181,617   ok Dec/01/22 06:48:08 4/0.1%
6/1 Borehole 39% 409:BoreholeSwitch 39% 10 181,693,208,617   ok Dec/01/22 06:48:01 24/1.1%
7/1 Foyer 43% 936:FoyerSensor 43% 11 96   ok Dec/01/22 06:48:38 153/7%
8/1 Entrance 59% 331:EntranceSensor 31% 8 655   ok Dec/01/22 06:47:52 204/9.4%
9/2 918:FrontDoorLock 31% 8 200,212,87,414   ok Dec/01/22 06:48:36 11/0.5%
10/3 396:EntranceSensor2 50% 13 632   ok Dec/01/22 06:47:58 299/13.8%
11/4 312:SWentrance 81% 21 96   ok Dec/01/22 06:47:51 21/0.9%
12/5 595:ChandelierSW 99% 34     ok Dec/01/22 06:48:10 5/0.2%
13/1 Porsche 64% 372:DoorSwPorsche 62% 16 62   ok Dec/01/22 06:47:57 8/0.3%
14/2 228:PorscheGarageSW 66% 17 62,204   ok Dec/01/22 06:47:42
15/1 Kitchen 71% 791:OutsideLightsSW 4% 1 200,522,711,208   ok Dec/01/22 06:48:32 5/0.2%
16/2 945:KitchenSensor 54% 14 612   ok Dec/01/22 06:48:40 207/9.5%
17/3 208:KitchenSwitch 99% 26 62,204 2 ok Dec/01/22 06:47:33 20/0.9%
18/4 885:(ROFilterFloodSensor) 99% 37 414,57   ok Dec/01/22 06:48:36 4/0.1%
19/5 871:KitchenFloodSensor1 99% 40     ok Dec/01/22 06:48:35 6/0.2%
20/1 TopLounge 72% 253:TopLoungeSensor 58% 15     ok Dec/01/22 06:47:46 144/6.6%
21/2 346:TopPassSensor 58% 15     ok Dec/01/22 06:47:54 154/7.1%
22/3 87:TopPassageSwitch 99% 31   5 ok Dec/01/22 06:47:20 15/0.6%
23/1 Study 74% 931:StudySensor 74% 19 62   ok Dec/01/22 06:48:38 126/5.8%
24/1 BMW 77% 376:DoorSwBMW 77% 20 747,367   ok Dec/01/22 06:47:57 4/0.1%
25/1 MainBedroom 82% 127:MainBedSensor 24% 6 87,132   ok Dec/01/22 06:47:22 209/9.6%
26/2 729:MirrorSW 89% 23 632,78   ok Dec/01/22 06:48:31 8/0.3%
27/3 166:MainBedSwitch 99% 27 150,57 1 ok Dec/01/22 06:47:26 2/0%
28/4 154:MainBedPassSwitch 99% 28 96,612   ok Dec/01/22 06:47:26 11/0.5%
29/5 742:Walli 99% 32 96,78   ok Dec/01/22 06:48:32 40/1.8%
30/1 MainBathroom 87% 424:MainBathSensor 74% 19 200,57   ok Dec/01/22 06:48:03 190/8.7%
31/2 132:MainBathSwitch 99% 27 150,87 1 ok Dec/01/22 06:47:23 23/1%
32/1 Unassigned 88% 419:BoreholeTanks1SW 16% 4 181,166   ok Dec/01/22 06:48:02 22/1%
33/2 513:StudyPatioSW 24% 6 655,650,543 2 ok Dec/01/22 06:48:03 12/0.5%
34/3 543:StatueFountainSW 31% 8 612,925,513 1 ok Dec/01/22 06:48:07 2/0%
35/4 302:RefuseSwitch 77% 20 200   ok Dec/01/22 06:47:48 8/0.3%
36/5 667:TVStripSW 77% 20 150 2 ok Dec/01/22 06:48:29
37/6 522:ServantSW 97% 25 606,581,367 1 ok Dec/01/22 06:48:06 2/0%
38/7 91:DininingDimSwitch 99% 26     ok Dec/01/22 06:47:20 4/0.1%
39/8 650:MainBedDimSW 99% 26 632,78 1 ok Dec/01/22 06:48:27 10/0.4%
40/9 852:MainBathTowelSW 99% 26 204,57   ok Dec/01/22 06:48:33
41/10 297:StoreLightSwitch 99% 28 404,655   ok Dec/01/22 06:47:48 4/0.1%
42/11 640:StreetLampSW 99% 29 87,212   ok Dec/01/22 06:48:27 5/0.2%
43/12 414:BMWLightSW 99% 34   2 ok Dec/01/22 06:48:02
44/13 617:JanDimmerMod 99% 34   2 ok Dec/01/22 06:48:20
45/14 661:BraaiSW 99% 34 62   ok Dec/01/22 06:48:29 20/0.9%
46/15 367:DimSWChandelier 99% 36 655 2 ok Dec/01/22 06:47:55 17/0.7%
47/16 693:MainBathSW 99% 36 655,57 2 ok Dec/01/22 06:48:30 12/0.5%
48/17 747:StudySW 99% 36 62 3 ok Dec/01/22 06:48:32 13/0.6%
49/18 861:BraaiDimSW 99% 41 62   ok Dec/01/22 06:48:33
50/19 200:SpareBedSwitch 99% 43   6 ok Dec/01/22 06:47:30
51/20 404:FoyerSwitch 99% 44   2 ok Dec/01/22 06:48:00 12/0.5%
52/21 632:TopLoungeStripSW 99% 47   3 ok Dec/01/22 06:48:24 8/0.3%
53/22 655:PatioSW 99% 47   5 ok Dec/01/22 06:48:29 5/0.2%
54/23 204:CarelBedroomSwitch 99% 53 62 4 ok Dec/01/22 06:47:30
55/1 Roof 92% 866:(SmokeMotion1) 62% 16 404,747,181,693   ok Dec/01/22 06:48:35
56/2 941:FloodSensor 99% 29 200   ok Dec/01/22 06:48:39 16/0.7%
57/3 78:Geyser1HDSwitch 99% 30 96 3 ok Dec/01/22 06:47:18 2/0%
58/4 96:Geyser3HDSwitch 99% 36   6 ok Dec/01/22 06:47:21
59/5 57:Geyser2HDSwitch 99% 38 96 5 ok Dec/01/22 06:47:14
60/1 Jan 97% 62:JanBedroomSw 97% 25 87 9 ok Dec/01/22 06:47:15 2/0%
61/1 TVRoom 98% 220:TVLoungeSwitch 97% 25 181,150   ok Dec/01/22 06:47:34 4/0.1%
62/2 612:TVRoomDimMod 99% 50   6 ok Dec/01/22 06:48:19 5/0.2%
63/1 DiningRoom 99% 606:DiningSW1 99% 44   1 ok Dec/01/22 06:48:10 10/0.4%
64/1 Server 99% 150:ServerRoomSwitch 99% 41   5 ok Dec/01/22 06:47:23 2/0%
65/1 Carel 99% 196:CarelBathSwitch 99% 38     ok Dec/01/22 06:47:30
66/1 Spare 99% 212:SpareBathSwitch 99% 36 62,204 2 ok Dec/01/22 06:47:34
67/1 GuestToilet 99% 581:(GuestToiletLights) 99% 35 612 1 ok Dec/01/22 06:48:08 4/0.1%
68/1 Staircase 99% 181:StaircaseSwitch 99% 33   5 ok Dec/01/22 06:47:29 22/1%
69/1 Scullery 99% 711:ScullerySW 99% 30 200 1 ok Dec/01/22 06:48:30 22/1%
Last 24History data is based on saved logs in event panel (some devices might be excluded)
Total saved events = 2165
Average Z-traffic = 39.9 sec.
I clearly have a problem with device: 791:OutsideLightsSW according to the report. This device is in the same box as 208:KitchenSwitch. I have, however, not noticed any communication problems or delays with this device. I'll first remove it and then add the device to the network again to see if it improves, otherwise I guess I'll have to replace it. The main area where I have "poor communication" is in the "PoolRoom" due to it's physical location and distance from the HC2 controller.
I also read the following valuable post by @alex88
and various valuable forum posts from @petergebruers to better understand how I can optimise my zWave network that has grown to 69 devices over the years with many scenes and virtual devices and also devices.
Below also the output from the ListNodeIdsv2.lua script by @petergebruers . Thank you Peter for your many valuable posts to help me better understand zWave and so many other related matters. I also attached Peter's LWR and Neighbors script output.
Spoiler
Do you see any other areas of concern and what can I do to further optimise my mesh routing table and to correctly update it based on the above and before going to the next step to use a Zniffer or to get a zWave repeater?
Thank you,
Nico
Edited by nicopret
nicopret
Some additional feedback on my post above. One of the things I did not mention/understood at the time of my previous post was that mesh table would not update/change when I reconfigured the mesh for the OutsideLightsSW. I have since replaced this device with a new FGS223 and then immediately after this the Mesh Table started updating again and I could then optimise the rest of the table further.
After noticing the following in another forum post by @petergebruers it makes even more sense
On 12/17/2018 at 10:18 PM, petergebruers said:
That is exactly what other users have seen with some of their FGS223. It is a strange thing, especially because the "mesh update" does not even start!
I can report that my mesh table report from @cag014 z-range-analyzer has been much improved already. I'm still busy optimising it further by running individual mesh updates. Something that is still not clear to me is whether "Unassigned" devices will have an impact on the mesh routing?
nicopret
I'll try to answer my own post above after having spent more time with z-range-analyzer and after realising that some of my questions/comments above might not have been clear or obvious enough and it could have been confusing. Hopefully the below can also help others.
I'll start by clarifying or providing more context regarding some of my comments/questions above. Before using z-range-analyzer, the importance of allocating all slaves devices and more importantly hidden master devices to a specific room was not a priority for me. Basically, my logic was to only allocate the devices I used to specific rooms and to leave the rest at "default" settings. As an example where I previously installed a double switch and only used one of the switches on the module. I therefore ended up with many master and slave devices that where being listed in "Unassigned". This also included some of the "deviceID.0" slaves switches which I've never understood why 3 switches are listed on a double switch when it only has 2 switches.
In the past, I have not bothered to check routing paths for my devices as I assumed that HC2 will work out the best path via the mesh as long as I have enough devices. After having read several forum posts regarding zWave routing I realised that this is not necessarily the case, especially since my HC2 has been running many years and many devices have been replaced and added over the years. In the past I simply used the function to reconfigure the entire mesh, but now understand why it is much better to reconfigure the mesh selectively.
However, I now also realise that this was not a good way to do it and I understand that you want to make sure your master devices are allocated to the rooms where they are physically located to make it easier for yourself to identify and troubleshoot problematic communication by room. My understanding is, however, that the allocation or grouping has no impact or influence on the  routing decision. The source routing decision is taken at a much lower level. The type of devices and the order in which you add them to your zWave network is, however, important since lower nodeID (please note that nodeID is not the same as device ID) have a higher priority. Thank you @petergebruers for so many informative forum posts that helped clarify many questions I had.
The end result of optimising my HC with the help @cag014's brilliant set of tools such as z-wave-analyzer and zwave monitor (which I also used previously) is that my HC2 is far more responsive and the odd dreaded 503 errors that I sometimes randomly ran into and could never really pinpoint is something of the past. I have also noticed that my HC2 CPU utilisation seems to be significantly lower than before the optimisation.
Below the "after optimisation" z-wave-analyzer output of my HC2. There are no noticeable delays or communication issues anywhere my zWave network.  I
still want to do some further fine-tuning and I specifically want to try and improve the communication to my Borehole and PoolRoom areas because I don't like to see red or orange numbers/percentages. I'll likely have to install a zWave repeater to do so due to the physical position and distance of these areas.
Spoiler
3-Dec 14:48:59 : ZRangev1.3 12Devices: masters=68 slaves=244123Data date range: 02 Dec 2022 - 02 Dec 2022
WinelandsHC2-022267 efficiency: HC2 location 58% Devices location 80%
1/1 Borehole 20% 419:BoreholeTanks1SW 20% 5 150,693   ok Dec/02/22 23:49:23 18/0.2%
2/1 PoolRoom 26% 519:RimflowSwitch 20% 5 612,925 2 ok Dec/02/22 23:49:32
3/2 556:HeatPumpHDSW 24% 6 612,925,519   ok Dec/02/22 23:49:39
4/3 249:RimflowSpeedSW 27% 7 612,925   ok Dec/02/22 23:48:59 4/0%
5/4 513:StudyPatioSW 27% 7 612,925,519   ok Dec/02/22 23:49:25 5/0%
6/5 925:PoolRoomSW2 27% 7 96,612 4 ok Dec/02/22 23:49:59 4/0%
7/6 543:StudyFountainSW 31% 8 742,166   ok Dec/02/22 23:49:33 4/0%
8/1 Outside 55% 578:WaterFeatureSW 39% 10 632,617   ok Dec/02/22 23:49:42 4/0%
9/2 409:BoreholeSwitch 70% 18     ok Dec/02/22 23:49:21 20/0.2%
10/1 Porsche 60% 228:PorscheGarageSW 58% 15 96,861   ok Dec/03/22 14:38:05
11/2 372:DoorSwPorsche 62% 16 606,312   ok Dec/02/22 23:49:17 6/0%
12/1 Entrance 64% 331:EntranceSensor 31% 8 204   ok Dec/02/22 23:49:10 1113/15.4%
13/2 918:FrontDoorLock 31% 8     ok Dec/02/22 23:49:58 7/0%
14/3 396:EntranceSensor2 50% 13 595 595:ChandelierSW:Entrance   ok Dec/02/22 23:49:18 1194/16.5%
15/4 312:SWentrance 70% 18 200,181 1 ok Dec/03/22 14:45:32 12/0.1%
16/5 367:DimSWChandelier 99% 33   1 ok Dec/02/22 23:49:15 7/0%
17/6 595:ChandelierSW 99% 35   1 ok Dec/02/22 23:49:44 6/0%
18/1 Foyer 71% 936:FoyerSensor 43% 11     ok Dec/02/22 23:50:00 1384/19.1%
19/2 404:FoyerSwitch 99% 43     ok Dec/02/22 23:49:19 8/0.1%
20/1 Refuse 77% 302:RefuseSwitch 77% 20 204,57 1 ok Dec/03/22 14:39:06 8/0.1%
21/1 Scullery 79% 640:StreetLampSW 58% 15 200   ok Dec/03/22 14:47:55 4/0%
22/2 711:ScullerySW 99% 28 87,367,200   ok Dec/02/22 23:49:52 14/0.1%
23/1 TopLounge 82% 346:TopPassSensor 54% 14 154,78   ok Dec/02/22 23:49:14 397/5.5%
24/2 253:TopLoungeSensor 58% 15     ok Dec/02/22 23:49:01 738/10.2%
25/3 87:TopPassageSwitch 99% 30   1 ok Dec/02/22 23:48:32 34/0.4%
26/4 632:TopLoungeStripSW 99% 47   3 ok Dec/02/22 23:49:47 18/0.2%
27/5 655:PatioSW 99% 48   1 ok Dec/02/22 23:49:49 32/0.4%
28/1 MainBedroom 84% 127:MainBedSensor 24% 6 57   ok Dec/02/22 23:48:37 657/9.1%
29/2 650:MainBedDimSW 89% 23 861,78 1 ok Dec/02/22 23:49:48 8/0.1%
30/3 729:MirrorSW 89% 23 632,78   ok Dec/02/22 23:49:53 41/0.5%
31/4 166:MainBedroomSW 99% 26 96,606 1 ok Dec/02/22 23:48:38 2/0%
32/5 154:MainBedPassSwitch 99% 29 96 1 ok Dec/02/22 23:48:38 8/0.1%
33/6 742:Walli 99% 30 852,57 1 ok Dec/02/22 23:49:53 76/1%
34/1 Study 87% 931:StudySensor 74% 19 62   ok Dec/02/22 23:49:59 336/4.6%
35/2 747:StudySW 99% 35     ok Dec/02/22 23:49:54 13/0.1%
36/1 BMW 88% 376:DoorSwBMW 77% 20 414   ok Dec/02/22 23:49:17 2/0%
37/2 414:BMWLightSW 99% 35   1 ok Dec/02/22 23:49:21
38/1 Kitchen 88% 945:KitchenSensor 54% 14 200   ok Dec/02/22 23:50:01 481/6.6%
39/2 955:KitchenSW 99% 30     ok Dec/02/22 23:50:02 80/1.1%
40/3 885:ROFloodSensor 99% 36     ok Dec/02/22 23:49:58 4/0%
41/4 871:KitchenFloodSensor1 99% 39 204,650,693,200   ok Dec/02/22 23:49:57 10/0.1%
42/1 TVRoom 92% 667:TVStripSW 77% 20 96,612   ok Dec/02/22 23:49:51 2/0%
43/2 220:TVRoomSW 99% 35 612   ok Dec/02/22 23:48:55 4/0%
44/3 612:TVRoomDimMod 99% 51   8 ok Dec/02/22 23:49:45 4/0%
45/1 Roof 92% 866:SmokeSensorUnit 62% 16 612,693   ok Dec/02/22 23:49:56
46/2 941:FloodSensor 99% 29 861   ok Dec/02/22 23:50:00 27/0.3%
47/3 78:Geyser1HDSwitch 99% 31 96 3 ok Dec/02/22 23:48:31 2/0%
48/4 57:Geyser2HDSwitch 99% 33 96 5 ok Dec/02/22 23:48:27
49/5 96:Geyser3HDSwitch 99% 35   8 ok Dec/02/22 23:48:35
50/1 MainBathroom 93% 424:MainBathSensor 74% 19 200,57   ok Dec/02/22 23:49:25 243/3.3%
51/2 132:MainBathroomSW 99% 28 96,606   ok Dec/02/22 23:48:37 32/0.4%
52/3 852:MainBathTowelSW 99% 29 200 1 ok Dec/02/22 23:49:55
53/4 693:MainBathSW 99% 39 632,57 4 ok Dec/02/22 23:49:51 12/0.1%
54/1 Server 99% 150:ServerRoomSW 99% 39   1 ok Dec/02/22 23:48:38 4/0%
55/1 GuestToilet 99% 581:GuestToiletSW 99% 39     ok Dec/02/22 23:49:43 4/0%
56/1 Carel 99% 196:CarelBathSW 99% 38   1 ok Dec/02/22 23:48:44 16/0.2%
57/2 204:CarelBedroomSwitch 99% 54   4 ok Dec/02/22 23:48:48 8/0.1%
58/1 Braai 99% 661:BraaiSW 99% 35     ok Dec/02/22 23:49:50 21/0.2%
59/2 861:BraaiDimSW 99% 38   3 ok Dec/03/22 14:26:04 3/0%
60/1 Staircase 99% 181:StaircaseSW 99% 33   1 ok Dec/02/22 23:48:43 38/0.5%
61/1 Workshop 99% 522:WorkshopSW 99% 30     ok Dec/02/22 23:49:33
62/1 Jan 99% 62:JanSW 99% 28   1 ok Dec/02/22 23:48:28 4/0%
63/2 617:JanDimmerMod 99% 33   1 ok Dec/02/22 23:49:46 4/0%
64/1 Store 99% 297:StoreLightSwitch 99% 28 196,655,693,302   ok Dec/03/22 14:31:34 1/0%
65/1 DiningRoom 99% 91:DininingDimSW 99% 27     ok Dec/02/22 23:48:34 4/0%
66/2 606:DiningSW1 99% 42   3 ok Dec/02/22 23:49:45 8/0.1%
Total saved events = 7216
Average Z-traffic = 11.9 sec.
nicopret
Hi @cag014, I picked up an anomaly where one of my master switches (200: GuestDimSW in room Guest) which is an "important repeater" in my network is not listed in Parent-ID data in the z-range-analyzer report. The device is listed in the Last Route for several other devices.
I can select the device in Mesh network reconfiguration and have also done so, and the New neigbor list is received. As far as I can see all works well otherwise.
Please see the detailed output below:
Spoiler
4-Dec 10:56:20 : ZRangev1.3 12Devices: masters=68 slaves=244123Data date range: 04 Dec 2022 - 04 Dec 2022
# Parent ID:Description Last Route iRoute iSee Status Time Stamp 24History
1 513:StudyPatioSW:PoolRoom 612,925,519 1 7 26% ok Dec/04/22 05:52:22
2 519:RimflowSW:PoolRoom 150,667,513 2 5 19% ok Dec/04/22 05:52:23
3 556:HeatPumpHDSW:PoolRoom 612,925,519   6 23% ok Dec/04/22 05:52:26
4 711:ScullerySW:Scullery 87,367,200   29 99% ok Dec/04/22 05:52:46 26/0.3%
5 925:PoolRoomSW2:PoolRoom 581,955,612 3 7 26% ok Dec/04/22 05:52:50 4/0%
6 166:MainBedroomSW:MainBedroom 96,204   28 99% ok Dec/04/22 10:51:04 4/0%
7 228:PorscheGarageSW:Porsche 96,861   15 56% ok Dec/04/22 05:51:56
8 249:RimflowSpeedSW:PoolRoom 612,925   7 26% ok Dec/04/22 05:52:00 4/0%
9 297:StoreSW:Store 96,200   24 89% ok Dec/04/22 09:51:47
10 302:RefuseSW:Refuse 96,404   20 75% ok Dec/04/22 05:52:06
11 346:TopPassSensor:TopLounge 154,78   14 52% ok Dec/04/22 05:52:10 210/3.1%
12 419:BoreholeTankSW:Borehole 150,693   5 19% ok Dec/04/22 05:52:20 11/0.1%
13 424:MainBathSensor:MainBathroom 200,57   19 71% ok Dec/04/22 05:52:20 201/3%
14 543:StudyFountainSW:PoolRoom 204,606   8 30% ok Dec/04/22 05:52:24 2/0%
15 650:MainBedDimSW:MainBedroom 852,57   23 86% ok Dec/04/22 05:52:39 58/0.8%
16 667:TVStripSW:TVRoom 91,612 1 23 86% ok Dec/04/22 10:44:38
17 693:MainBathSW:MainBathroom 96,78 2 37 99% ok Dec/04/22 05:52:45 9/0.1%
18 729:MirrorSW:MainBedroom 96,606   23 86% ok Dec/04/22 05:52:46 37/0.5%
19 742:Walli:MainBedroom 852,57   30 99% ok Dec/04/22 05:52:47 59/0.8%
20 861:BraaiDimSW:Braai 96,632 1 40 99% ok Dec/04/22 10:40:46 3/0%
21 866:SmokeSensorUnit:Roof 612,693   16 60% ok Dec/04/22 05:52:48
22 57:Geyser2HDSwitch:Roof 96 4 33 99% ok Dec/04/22 05:51:26
23 78:Geyser1HDSwitch:Roof 96 2 30 99% ok Dec/04/22 05:51:32 2/0%
24 127:MainBedSensor:MainBedroom 57   6 23% ok Dec/04/22 05:51:38 633/9.5%
25 132:MainBathroomSW:MainBathroom 200   28 99% ok Dec/04/22 05:51:39 49/0.7%
26 212:GuestBathSW:Guest 204   36 99% ok Dec/04/22 05:51:54 8/0.1%
27 220:TVRoomSW:TVRoom 612   35 99% ok Dec/04/22 05:51:55 4/0%
28 312:EntranceStripSW:Entrance 204   18 67% ok Dec/04/22 05:52:09 12/0.1%
29 331:EntranceSensor:Entrance 204   8 30% ok Dec/04/22 05:52:09 1146/17.2%
30 372:DoorSwPorsche:Porsche 62   16 60% ok Dec/04/22 05:52:15 6/0%
31 376:DoorSwBMW:BMW 414   20 75% ok Dec/04/22 05:52:16
32 396:EntranceSensor2:Entrance 595   13 49% ok Dec/04/22 05:52:16 1196/18%
33 581:GuestToiletSW:GuestToilet 62 1 39 99% ok Dec/04/22 10:41:56 1/0%
34 640:StreetLampSW:Scullery 200   15 56% ok Dec/04/22 05:52:34 4/0%
35 852:MainBathTowelSW:MainBathroom 200 2 27 99% ok Dec/04/22 05:52:47
36 885:ROFloodSensor:Kitchen 96   36 99% ok Dec/04/22 05:52:49 5/0%
37 931:StudySensor:Study 62   19 71% ok Dec/04/22 05:52:50 243/3.6%
38 945:KitchenSensor:Kitchen 200   14 52% ok Dec/04/22 05:52:52 362/5.4%
39 62:JanSW:Jan   3 28 99% ok Dec/04/22 05:51:27
40 87:TopPassageSW:TopLounge   1 31 99% ok Dec/04/22 05:51:34 32/0.4%
41 91:DininingDimSW:DiningRoom   1 28 99% ok Dec/04/22 05:51:36
42 96:Geyser3HDSwitch:Roof   10 38 99% ok Dec/04/22 10:55:05
43 150:ServerRoomSW:Server   2 40 99% ok Dec/04/22 05:51:39
44 154:MainBedPassSW:MainBedroom   1 29 99% ok Dec/04/22 05:51:41 43/0.6%
45 181:StaircaseSW:Staircase     33 99% ok Dec/04/22 05:51:45 24/0.3%
46 196:CarelBathSW:Carel     39 99% ok Dec/04/22 05:51:45 9/0.1%
47 200:GuestDimSW:Guest   7 43 99% ok Dec/04/22 09:59:36 1/0%
48 204:CarelDimSW:Carel   5 53 99% ok Dec/04/22 05:51:48 4/0%
49 253:TopLoungeSensor:TopLounge     15 56% ok Dec/04/22 05:52:04 751/11.3%
50 367:EntranceDownSW:Entrance   1 33 99% ok Dec/04/22 05:52:10 6/0%
51 404:FoyerSW:Foyer   1 44 99% ok Dec/04/22 05:52:18 2/0%
52 409:BoreholeSW:Outside     19 71% ok Dec/04/22 05:52:18 10/0.1%
53 414:BMWLightSW:BMW   1 35 99% ok Dec/04/22 05:52:20
54 522:WorkshopSW:Workshop     30 99% ok Dec/04/22 05:52:23
55 578:WaterFeatureSW:Outside     9 34% ok Dec/04/22 05:52:26 4/0%
56 595:ChandelierDimSW:Entrance   1 37 99% ok Dec/04/22 05:52:27
57 606:DiningSW:DiningRoom   2 41 99% ok Dec/04/22 05:52:27 10/0.1%
58 612:TVRoomDimSW:TVRoom   7 51 99% ok Dec/04/22 05:52:28 6/0%
59 617:JanDimSW:Jan     33 99% ok Dec/04/22 05:52:28
60 632:TopLoungeStripSW:TopLounge   1 47 99% ok Dec/04/22 05:52:29 22/0.3%
61 655:PatioSW:TopLounge     47 99% ok Dec/04/22 05:52:40 32/0.4%
62 661:BraaiSW:Braai     37 99% ok Dec/04/22 10:38:01 11/0.1%
63 747:StudySW:Study     35 99% ok Dec/04/22 05:52:47 12/0.1%
64 871:KitchenFloodSensor1:Kitchen     39 99% ok Dec/04/22 05:52:49 10/0.1%
65 918:FrontDoorLock:Entrance     7 26% ok Dec/04/22 05:52:50 11/0.1%
66 936:FoyerSensor:Foyer     11 41% ok Dec/04/22 05:52:51 1263/19%
67 941:FloodSensor:Roof     29 99% ok Dec/04/22 05:52:52 36/0.5%
68 955:KitchenSW:Kitchen   1 31 99% ok Dec/04/22 05:52:52 28/0.4%
Residence location efficiency (in ascending order)
1/1 Borehole 19% 419:BoreholeTankSW 19% 5 150,693   ok Dec/04/22 05:52:20 11/0.1%
2/1 PoolRoom 25% 519:RimflowSW 19% 5 150,667,513 2 ok Dec/04/22 05:52:23
3/2 556:HeatPumpHDSW 23% 6 612,925,519   ok Dec/04/22 05:52:26
4/3 249:RimflowSpeedSW 26% 7 612,925   ok Dec/04/22 05:52:00 4/0%
5/4 513:StudyPatioSW 26% 7 612,925,519 1 ok Dec/04/22 05:52:22
6/5 925:PoolRoomSW2 26% 7 581,955,612 3 ok Dec/04/22 05:52:50 4/0%
7/6 543:StudyFountainSW 30% 8 204,606   ok Dec/04/22 05:52:24 2/0%
8/1 Outside 53% 578:WaterFeatureSW 34% 9     ok Dec/04/22 05:52:26 4/0%
9/2 409:BoreholeSW 71% 19     ok Dec/04/22 05:52:18 10/0.1%
10/1 Porsche 58% 228:PorscheGarageSW 56% 15 96,861   ok Dec/04/22 05:51:56
11/2 372:DoorSwPorsche 60% 16 62   ok Dec/04/22 05:52:15 6/0%
12/1 Entrance 62% 918:FrontDoorLock 26% 7     ok Dec/04/22 05:52:50 11/0.1%
13/2 331:EntranceSensor 30% 8 204   ok Dec/04/22 05:52:09 1146/17.2%
14/3 396:EntranceSensor2 49% 13 595   ok Dec/04/22 05:52:16 1196/18%
15/4 312:EntranceStripSW 67% 18 204   ok Dec/04/22 05:52:09 12/0.1%
16/5 367:EntranceDownSW 99% 33   1 ok Dec/04/22 05:52:10 6/0%
17/6 595:ChandelierDimSW 99% 37   1 ok Dec/04/22 05:52:27
18/1 Foyer 70% 936:FoyerSensor 41% 11     ok Dec/04/22 05:52:51 1263/19%
19/2 404:FoyerSW 99% 44   1 ok Dec/04/22 05:52:18 2/0%
20/1 Refuse 75% 302:RefuseSW 75% 20 96,404   ok Dec/04/22 05:52:06
21/1 Scullery 78% 640:StreetLampSW 56% 15 200   ok Dec/04/22 05:52:34 4/0%
22/2 711:ScullerySW 99% 29 87,367,200   ok Dec/04/22 05:52:46 26/0.3%
23/1 TopLounge 81% 346:TopPassSensor 52% 14 154,78   ok Dec/04/22 05:52:10 210/3.1%
24/2 253:TopLoungeSensor 56% 15     ok Dec/04/22 05:52:04 751/11.3%
25/3 87:TopPassageSW 99% 31   1 ok Dec/04/22 05:51:34 32/0.4%
26/4 632:TopLoungeStripSW 99% 47   1 ok Dec/04/22 05:52:29 22/0.3%
27/5 655:PatioSW 99% 47     ok Dec/04/22 05:52:40 32/0.4%
28/1 MainBedroom 82% 127:MainBedSensor 23% 6 57   ok Dec/04/22 05:51:38 633/9.5%
29/2 650:MainBedDimSW 86% 23 852,57   ok Dec/04/22 05:52:39 58/0.8%
30/3 729:MirrorSW 86% 23 96,606   ok Dec/04/22 05:52:46 37/0.5%
31/4 166:MainBedroomSW 99% 28 96,204   ok Dec/04/22 10:51:04 4/0%
32/5 154:MainBedPassSW 99% 29   1 ok Dec/04/22 05:51:41 43/0.6%
33/6 742:Walli 99% 30 852,57   ok Dec/04/22 05:52:47 59/0.8%
34/1 Study 85% 931:StudySensor 71% 19 62   ok Dec/04/22 05:52:50 243/3.6%
35/2 747:StudySW 99% 35     ok Dec/04/22 05:52:47 12/0.1%
36/1 BMW 87% 376:DoorSwBMW 75% 20 414   ok Dec/04/22 05:52:16
37/2 414:BMWLightSW 99% 35   1 ok Dec/04/22 05:52:20
38/1 Kitchen 88% 945:KitchenSensor 52% 14 200   ok Dec/04/22 05:52:52 362/5.4%
39/2 955:KitchenSW 99% 31   1 ok Dec/04/22 05:52:52 28/0.4%
40/3 885:ROFloodSensor 99% 36 96   ok Dec/04/22 05:52:49 5/0%
41/4 871:KitchenFloodSensor1 99% 39     ok Dec/04/22 05:52:49 10/0.1%
42/1 Store 89% 297:StoreSW 89% 24 96,200   ok Dec/04/22 09:51:47
43/1 MainBathroom 92% 424:MainBathSensor 71% 19 200,57   ok Dec/04/22 05:52:20 201/3%
44/2 852:MainBathTowelSW 99% 27 200 2 ok Dec/04/22 05:52:47
45/3 132:MainBathroomSW 99% 28 200   ok Dec/04/22 05:51:39 49/0.7%
46/4 693:MainBathSW 99% 37 96,78 2 ok Dec/04/22 05:52:45 9/0.1%
47/1 Roof 92% 866:SmokeSensorUnit 60% 16 612,693   ok Dec/04/22 05:52:48
48/2 941:FloodSensor 99% 29     ok Dec/04/22 05:52:52 36/0.5%
49/3 78:Geyser1HDSwitch 99% 30 96 2 ok Dec/04/22 05:51:32 2/0%
50/4 57:Geyser2HDSwitch 99% 33 96 4 ok Dec/04/22 05:51:26
51/5 96:Geyser3HDSwitch 99% 38   10 ok Dec/04/22 10:55:05
52/1 TVRoom 95% 667:TVStripSW 86% 23 91,612 1 ok Dec/04/22 10:44:38
53/2 220:TVRoomSW 99% 35 612   ok Dec/04/22 05:51:55 4/0%
54/3 612:TVRoomDimSW 99% 51   7 ok Dec/04/22 05:52:28 6/0%
55/1 Server 99% 150:ServerRoomSW 99% 40   2 ok Dec/04/22 05:51:39
56/1 Carel 99% 196:CarelBathSW 99% 39     ok Dec/04/22 05:51:45 9/0.1%
57/2 204:CarelDimSW 99% 53   5 ok Dec/04/22 05:51:48 4/0%
58/1 GuestToilet 99% 581:GuestToiletSW 99% 39 62 1 ok Dec/04/22 10:41:56 1/0%
59/1 Braai 99% 661:BraaiSW 99% 37     ok Dec/04/22 10:38:01 11/0.1%
60/2 861:BraaiDimSW 99% 40 96,632 1 ok Dec/04/22 10:40:46 3/0%
61/1 Staircase 99% 181:StaircaseSW 99% 33     ok Dec/04/22 05:51:45 24/0.3%
62/1 Workshop 99% 522:WorkshopSW 99% 30     ok Dec/04/22 05:52:23
63/1 Jan 99% 62:JanSW 99% 28   3 ok Dec/04/22 05:51:27
64/2 617:JanDimSW 99% 33     ok Dec/04/22 05:52:28
65/1 DiningRoom 99% 91:DininingDimSW 99% 28   1 ok Dec/04/22 05:51:36
66/2 606:DiningSW 99% 41   2 ok Dec/04/22 05:52:27 10/0.1%
Total saved events = 6626
Average Z-traffic = 13 sec.
Please also see DeviceList v2.2 output below which do list 200: GuestDimSW it in the Guest Room:
Spoiler
4-Dec 11:12:22 : 1🎬V2.2 Scanning 481 elements. 100%
4-Dec 11:12:24 : Sun Dec 4 11:12:22 2022
______________________ Roof section ______________________
--~~== Roof room ==~~--
57: Geyser2HDSwitch [ zwaveDevice : Parent of [268,269] : zwaveRoute [1,96] : AEON Labs : Hidden ]
78: Geyser1HDSwitch [ zwaveDevice : Parent of [264,265] : zwaveRoute [1,96] : AEON Labs : Hidden ]
96: Geyser3HDSwitch [ zwaveDevice : Parent of [266,267] : zwaveRoute [1] : AEON Labs : Hidden ]
264: Geyser1Switch [ binarySwitch : ParentID=78 : AEON Labs ] [ value=true ] [ power=0w ]
265: Geyser1Temp [ temperatureSensor : ParentID=78 : AEON Labs ] [ value=0C ]
266: Geyser3Switch [ binarySwitch : ParentID=96 : AEON Labs ] [ value=true ] [ power=0w ]
267: Geyser3Temp [ temperatureSensor : ParentID=96 : AEON Labs ] [ value=24.2C ]
268: Geyser2Switch [ binarySwitch : ParentID=57 : AEON Labs ] [ value=true ] [ power=0w ]
269: Geyser2Temp [ temperatureSensor : ParentID=57 : AEON Labs ] [ value=0C ]
866: SmokeSensorUnit [ zwaveDevice : Parent of [867,868] : zwaveRoute [1,612,693] : Shenzhen Heiman Technology Co., Ltd : Hidden ]
867: SmokeMotion1 [ motionSensor : ParentID=866 : Shenzhen Heiman Technology Co., Ltd : Battery=91% ] [ value=false ]
868: SmokeSensor1 [ smokeSensor : ParentID=866 : Shenzhen Heiman Technology Co., Ltd : Battery=91% ] [ value=false ]
941: FloodSensor [ zwaveDevice : Parent of [942,943,944] : zwaveRoute [1] : Fibargroup : Hidden ]
942: FloodSense [ floodSensor : ParentID=941 : Fibargroup : Battery=41% ] [ value=false ]
943: FloodMotion [ motionSensor : ParentID=941 : Fibargroup : Hidden ] [ value=false ]
944: FloodTemp [ temperatureSensor : ParentID=941 : Fibargroup ] [ value=26.13C ]
______________________ Outside section ______________________
--~~== Outside room ==~~--
409: BoreholeSW [ zwaveDevice : Parent of [410,411,412] : zwaveRoute [1] : Fibargroup : Hidden ]
410: 409.0 [ binarySwitch : ParentID=409 : Fibargroup ] [ value=false ]
412: 409.2 [ binarySwitch : ParentID=409 : Fibargroup : Hidden ] [ value=false ]
547: StatueFountain [ binarySwitch : ParentID=543 : Fibargroup ] [ value=true ] [ power=16.9w ]
578: WaterFeatureSW [ zwaveDevice : Parent of [579,580] : zwaveRoute [1] : Fibargroup : Hidden ]
579: WaterFeature [ binarySwitch : ParentID=578 : Fibargroup ] [ value=true ]
580: 578.0.1 [ remoteController : ParentID=578 : Fibargroup : Hidden ]
644: StreetLamps [ binarySwitch : ParentID=640 : Fibargroup ] [ value=false ] [ power=0w ]
960: OutsideLights [ binarySwitch : ParentID=955 : Fibargroup ] [ value=false ] [ power=0w ]
179: OutsideALC [ luaScene : Max Instances=6 : Instances=1 : TRIGGER_AND_MANUAL ]
--~~== Store room ==~~--
297: StoreSW [ zwaveDevice : Parent of [298,299,300,301] : zwaveRoute [1,96,200] : Fibargroup : Hidden ]
298: 297.0 [ binarySwitch : ParentID=297 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
299: 297.0.1 [ remoteController : ParentID=297 : Fibargroup : Hidden ]
300: StoreLights [ binarySwitch : ParentID=297 : Fibargroup ] [ value=false ] [ power=0w ]
301: 297.2 [ binarySwitch : ParentID=297 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
--~~== Refuse room ==~~--
302: RefuseSW [ zwaveDevice : Parent of [303,304,305,306] : zwaveRoute [1,96,404] : Fibargroup : Hidden ]
303: 302.0 [ binarySwitch : ParentID=302 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
304: 302.0.1 [ remoteController : ParentID=302 : Fibargroup : Hidden ]
305: RefuseLights [ binarySwitch : ParentID=302 : Fibargroup ] [ value=false ] [ power=0w ]
306: RefuseLightsOutside [ binarySwitch : ParentID=302 : Fibargroup ] [ value=false ] [ power=0w ]
--~~== Borehole room ==~~--
411: BoreholePump [ binarySwitch : ParentID=409 : Fibargroup ] [ value=true ]
419: BoreholeTankSW [ zwaveDevice : Parent of [420,421,422,423] : zwaveRoute [1,150,693] : Fibargroup : Hidden ]
420: 419.0 [ binarySwitch : ParentID=419 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
421: 419.0.1 [ remoteController : ParentID=419 : Fibargroup : Hidden ]
422: FloatSwitch [ binarySwitch : ParentID=419 : Fibargroup ] [ value=true ] [ power=0w ]
423: BoreholeLights [ binarySwitch : ParentID=419 : Fibargroup ] [ value=false ] [ power=0w ]
496: PumpMonitor [ virtual_device ]
99: BHPumpStatus [ luaScene : Max Instances=4 : Instances=0 : Autostart : TRIGGER_AND_MANUAL ]
--~~== Patio room ==~~--
517: StudyPatioLights [ binarySwitch : ParentID=513 : Fibargroup ] [ value=false ] [ power=0w ]
929: LoungePatioLights [ binarySwitch : ParentID=925 : Fibargroup ] [ value=false ] [ power=0w ]
--~~== PoolRoom room ==~~--
249: RimflowSpeedSW [ zwaveDevice : Parent of [250,251,252] : zwaveRoute [1,612,925] : Fibargroup : Hidden ]
250: 249.0 [ binarySwitch : ParentID=249 : Fibargroup : Hidden ] [ value=false ]
251: RimflowSlow [ binarySwitch : ParentID=249 : Fibargroup ] [ value=false ]
252: RimflowFast [ binarySwitch : ParentID=249 : Fibargroup ] [ value=false ]
513: StudyPatioSW [ zwaveDevice : Parent of [514,515,516,517,518] : zwaveRoute [1,612,925,519] : Fibargroup : Hidden ]
514: 513.0 [ binarySwitch : ParentID=513 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
515: 513.0.1 [ remoteController : ParentID=513 : Fibargroup : Hidden ]
516: 513.0.2 [ heatDetector : ParentID=513 : Fibargroup : Hidden ] [ value=false ]
518: PoolRoomLights [ binarySwitch : ParentID=513 : Fibargroup ] [ value=false ] [ power=0w ]
519: RimflowSW [ zwaveDevice : Parent of [520,521] : zwaveRoute [1,150,667,513] : AEON Labs : Hidden ]
520: RimFlow [ binarySwitch : ParentID=519 : AEON Labs ] [ value=true ] [ power=3.47w ]
521: PoolRoomTemp [ temperatureSensor : ParentID=519 : AEON Labs ] [ value=0C ]
543: StudyFountainSW [ zwaveDevice : Parent of [544,545,546,547,548] : zwaveRoute [1,204,606] : Fibargroup : Hidden ]
544: 543.0 [ binarySwitch : ParentID=543 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
545: 543.0.1 [ remoteController : ParentID=543 : Fibargroup : Hidden ]
546: 543.0.2 [ heatDetector : ParentID=543 : Fibargroup : Hidden ] [ value=false ]
548: 543.2 [ binarySwitch : ParentID=543 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
556: HeatPumpHDSW [ zwaveDevice : Parent of [557,558] : zwaveRoute [1,612,925,519] : AEON Labs : Hidden ]
557: Heatpump [ binarySwitch : ParentID=556 : AEON Labs ] [ value=false ] [ power=0w ]
558: 556.0.1 [ temperatureSensor : ParentID=556 : AEON Labs : Hidden ] [ value=0C ]
925: PoolRoomSW2 [ zwaveDevice : Parent of [926,927,928,929,930] : zwaveRoute [1,581,955,612] : Fibargroup : Hidden ]
926: 925.0 [ binarySwitch : ParentID=925 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
927: 925.0.1 [ remoteController : ParentID=925 : Fibargroup : Hidden ]
928: PoolRoomTemperature [ heatDetector : ParentID=925 : Fibargroup : Hidden ] [ value=false ]
930: PoolLights [ binarySwitch : ParentID=925 : Fibargroup ] [ value=false ] [ power=0w ]
______________________ TopFloor section ______________________
--~~== MainBedroom room ==~~--
127: MainBedSensor [ zwaveDevice : Parent of [128,129,130,131] : zwaveRoute [1,57] : Fibargroup : Hidden ]
128: MainBedroomMotion [ motionSensor : ParentID=127 : Fibargroup : Battery=100% ] [ value=false ]
129: MainBedroomTemp [ temperatureSensor : ParentID=127 : Fibargroup : Battery=100% ] [ value=25.2C ]
130: MainBedroomLux [ lightSensor : ParentID=127 : Fibargroup : Battery=100% ] [ value=610lux ]
131: MainBedroomSeismo [ seismometer : ParentID=127 : Fibargroup : Battery=100% : Hidden ] [ value=0 ]
135: MainBedStriplights [ binarySwitch : ParentID=132 : Fibargroup ] [ value=false ] [ power=0w ]
154: MainBedPassSW [ zwaveDevice : Parent of [155,156,157] : zwaveRoute [1] : Fibargroup : Hidden ]
155: 154.0 [ binarySwitch : ParentID=154 : Fibargroup : Hidden ] [ value=true ] [ power=80w ]
156: PassageLights [ binarySwitch : ParentID=154 : Fibargroup ] [ value=false ]
157: 154.2 [ binarySwitch : ParentID=154 : Fibargroup : Hidden ] [ value=false ]
166: MainBedroomSW [ zwaveDevice : Parent of [167,168,169] : zwaveRoute [1,96,204] : Fibargroup : Hidden ]
167: 166.0 [ binarySwitch : ParentID=166 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
168: StoepLights [ binarySwitch : ParentID=166 : Fibargroup ] [ value=false ]
169: 166.2 [ binarySwitch : ParentID=166 : Fibargroup : Hidden ] [ value=true ]
560: MainBedroom Aircon [ virtual_device ]
650: MainBedDimSW [ zwaveDevice : Parent of [651,652,653,654] : zwaveRoute [1,852,57] : Fibargroup : Hidden ]
651: 650.0 [ remoteController : ParentID=650 : Fibargroup : Hidden ] [ value=0 ] [ power=0w ]
652: 650.0.1 [ remoteController : ParentID=650 : Fibargroup : Hidden ]
653: MainBedroomDimmer [ remoteController : ParentID=650 : Fibargroup ] [ value=0 ] [ power=0w ]
654: 650.2 [ remoteController : ParentID=650 : Fibargroup : Hidden ] [ value=0 ]
704: MainBedroomSpeakers [ virtual_device ]
729: MirrorSW [ zwaveDevice : Parent of [730,731,732,733,734] : zwaveRoute [1,96,606] : Fibargroup : Hidden ]
730: 729.0 [ binarySwitch : ParentID=729 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
731: 729.0.1 [ remoteController : ParentID=729 : Fibargroup : Hidden ]
732: 729.0.2 [ heatDetector : ParentID=729 : Fibargroup : Hidden ] [ value=false ]
733: Mirror [ binarySwitch : ParentID=729 : Fibargroup ] [ value=false ] [ power=0w ]
734: MirrorSpare [ binarySwitch : ParentID=729 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
742: Walli [ zwaveDevice : Parent of [743,744] : zwaveRoute [1,852,57] : Fibargroup : Hidden ]
743: WalliSwitch [ remoteController : ParentID=742 : Fibargroup : Hidden ]
744: WalliTemp [ temperatureSensor : ParentID=742 : Fibargroup ] [ value=22.6C ]
811: Sheer2 [ virtual_device ]
812: Sheer4 [ virtual_device ]
829: Blockout2 [ virtual_device ]
832: Sheer1 [ virtual_device ]
834: Blockout4 [ virtual_device ]
835: MainbedroomBlockouts [ virtual_device ]
841: MainbedroomCurtains [ virtual_device ]
843: Blockout3 [ virtual_device ]
845: Blockout1 [ virtual_device ]
849: MainbedroomSheers [ virtual_device ]
851: Sheer3 [ virtual_device ]
890: Alarm Clock v1.1 [ virtual_device ]
906: Room Sleep v1.3 [ virtual_device ]
138: Mirror MainBedroom [ magicScene : Max Instances=2 : Instances=0 : Hidden : Alexa enable : TRIGGER_AND_MANUAL ]
142: MainBathroomLights M [ magicScene : Max Instances=2 : Instances=0 : Hidden : Alexa enable : TRIGGER_AND_MANUAL ]
144: MainBathroomLights2 [ magicScene : Max Instances=2 : Instances=0 : Hidden : Alexa enable : TRIGGER_AND_MANUAL ]
145: MirrorMainBedroom [ magicScene : Max Instances=2 : Instances=0 : Hidden : Alexa enable : TRIGGER_AND_MANUAL ]
161: Alarm Clock V1.3 [ luaScene : Max Instances=2 : Instances=0 : TRIGGER_AND_MANUAL ]
172: MainbedroomVSB [ luaScene : Max Instances=6 : Instances=0 : MANUAL_ONLY ]
173: MainbedroomALC [ luaScene : Max Instances=6 : Instances=0 : TRIGGER_AND_MANUAL ]
--~~== MainBathroom room ==~~--
132: MainBathroomSW [ zwaveDevice : Parent of [133,134,135] : zwaveRoute [1,200] : Fibargroup : Hidden ]
133: 132.0 [ binarySwitch : ParentID=132 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
134: MainBathroomLights [ binarySwitch : ParentID=132 : Fibargroup ] [ value=false ]
424: MainBathSensor [ zwaveDevice : Parent of [425,426,427,428,429] : zwaveRoute [1,200,57] : Fibargroup : Hidden ]
425: MainBathMotion [ FGMS001 : ParentID=424 : Fibargroup : Battery=100% ] [ value=false ]
426: MainBathTemp [ temperatureSensor : ParentID=424 : Fibargroup : Battery=100% ] [ value=25.1C ]
427: MainBathLux [ lightSensor : ParentID=424 : Fibargroup : Battery=100% ] [ value=37lux ]
428: MainBathSeismo [ seismometer : ParentID=424 : Fibargroup : Battery=100% : Hidden ] [ value=0MMI ]
429: MainBathAccel [ accelerometer : ParentID=424 : Fibargroup : Battery=100% : Hidden ] [ value=table: 0xa550e88 ]
693: MainBathSW [ zwaveDevice : Parent of [694,695,696,697,698] : zwaveRoute [1,96,78] : Fibargroup : Hidden ]
694: 693.0 [ binarySwitch : ParentID=693 : Fibargroup : Hidden ] [ value=true ] [ power=40.4w ]
695: 693.0.1 [ remoteController : ParentID=693 : Fibargroup : Hidden ]
696: 693.0.2 [ heatDetector : ParentID=693 : Fibargroup : Hidden ] [ value=false ]
697: ExtractorFan [ binarySwitch : ParentID=693 : Fibargroup ] [ value=false ] [ power=0w ]
698: TowelRail1 [ binarySwitch : ParentID=693 : Fibargroup ] [ value=false ] [ power=0w ]
709: MainbathroomSpeakers [ virtual_device ]
852: MainBathTowelSW [ zwaveDevice : Parent of [853,854,855,856,857] : zwaveRoute [1,200] : Fibargroup : Hidden ]
853: 852.0 [ binarySwitch : ParentID=852 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
854: 852.0.1 [ remoteController : ParentID=852 : Fibargroup : Hidden ]
855: 852.0.2 [ heatDetector : ParentID=852 : Fibargroup : Hidden ] [ value=false ]
856: TowelRail2 [ binarySwitch : ParentID=852 : Fibargroup ] [ value=false ] [ power=0w ]
857: 852.2 [ binarySwitch : ParentID=852 : Fibargroup : Hidden ] [ value=true ] [ power=0w ]
911: MainBathroomSleep [ virtual_device ]
174: MainBathroomALC [ luaScene : Max Instances=6 : Instances=0 : TRIGGER_AND_MANUAL ]
--~~== Staircase room ==~~--
181: StaircaseSW [ zwaveDevice : Parent of [182,183,184] : zwaveRoute [1] : Fibargroup : Hidden ]
182: 181.0 [ binarySwitch : ParentID=181 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
183: StaircaseLights [ binarySwitch : ParentID=181 : Fibargroup ] [ value=false ]
184: StaircaseChandelier [ binarySwitch : ParentID=181 : Fibargroup ] [ value=false ] [ power=0w ]
818: StaircaseCurtain [ virtual_device ]
180: StairsALC [ luaScene : Max Instances=6 : Instances=0 : TRIGGER_AND_MANUAL ]
--~~== Guest room ==~~--
200: GuestDimSW [ zwaveDevice : Parent of [201,202,203] : zwaveRoute [1] : Fibargroup : Hidden ]
201: 200.0 [ remoteController : ParentID=200 : Fibargroup : Hidden ] [ value=0 ] [ power=0w ]
202: GuestDimmer [ remoteController : ParentID=200 : Fibargroup ] [ value=0 ] [ power=0w ]
203: 200.2 [ remoteController : ParentID=200 : Fibargroup : Hidden ] [ value=0 ]
212: GuestBathSW [ zwaveDevice : Parent of [213,214,215] : zwaveRoute [1,204] : Fibargroup : Hidden ]
213: 212.0 [ binarySwitch : ParentID=212 : Fibargroup : Hidden ] [ value=false ]
214: GuestTowelRail [ binarySwitch : ParentID=212 : Fibargroup ] [ value=false ]
215: GuestBathLights [ binarySwitch : ParentID=212 : Fibargroup ] [ value=false ]
566: Spare Aircon [ virtual_device ]
710: SpareRoomSpeakers [ virtual_device ]
--~~== Carel room ==~~--
196: CarelBathSW [ zwaveDevice : Parent of [197,198,199] : zwaveRoute [1] : Fibargroup : Hidden ]
197: 196.0 [ binarySwitch : ParentID=196 : Fibargroup : Hidden ] [ value=false ]
198: CarelBathLights [ binarySwitch : ParentID=196 : Fibargroup ] [ value=false ]
199: CarelTowelRail [ binarySwitch : ParentID=196 : Fibargroup ] [ value=false ]
204: CarelDimSW [ zwaveDevice : Parent of [205,206,207] : zwaveRoute [1] : Fibargroup : Hidden ]
205: 204.0 [ remoteController : ParentID=204 : Fibargroup : Hidden ] [ value=22 ] [ power=0w ]
206: CarelDimmer [ remoteController : ParentID=204 : Fibargroup ] [ value=0 ] [ power=0w ]
207: 204.2 [ remoteController : ParentID=204 : Fibargroup : Hidden ] [ value=0 ]
564: Carel Aircon [ virtual_device ]
708: CarelSpeakers [ virtual_device ]
--~~== TopLounge room ==~~--
87: TopPassageSW [ zwaveDevice : Parent of [88,89,90] : zwaveRoute [1] : Fibargroup : Hidden ]
88: 87.0 [ binarySwitch : ParentID=87 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
89: TopPassLights [ binarySwitch : ParentID=87 : Fibargroup ] [ value=false ] [ power=0w ]
90: 87.2 [ binarySwitch : ParentID=87 : Fibargroup : Hidden ] [ value=false ]
253: TopLoungeSensor [ zwaveDevice : Parent of [254,255,256,257] : zwaveRoute [1] : Fibargroup : Hidden ]
254: TopLoungeMotion [ motionSensor : ParentID=253 : Fibargroup : Battery=85% ] [ value=false ]
255: TopLoungeTemp [ temperatureSensor : ParentID=253 : Fibargroup : Battery=85% ] [ value=23C ]
256: TopLoungeLux [ lightSensor : ParentID=253 : Fibargroup : Battery=85% ] [ value=760lux ]
257: TopLoungeSeismo [ seismometer : ParentID=253 : Fibargroup : Battery=85% : Hidden ] [ value=0 ]
346: TopPassSensor [ zwaveDevice : Parent of [347,348,349,350] : zwaveRoute [1,154,78] : Fibargroup : Hidden ]
347: TopPassMotion [ motionSensor : ParentID=346 : Fibargroup : Battery=100% ] [ value=false ]
348: TopPassTemp [ temperatureSensor : ParentID=346 : Fibargroup ] [ value=23.3C ]
349: TopPassLux [ lightSensor : ParentID=346 : Fibargroup ] [ value=154lux ]
350: TopPassSeismo [ seismometer : ParentID=346 : Fibargroup : Hidden ] [ value=0 ]
562: TopLounge Aircon [ virtual_device ]
632: TopLoungeStripSW [ zwaveDevice : Parent of [633,634,635,636,637] : zwaveRoute [1] : Fibargroup : Hidden ]
633: 632.0 [ binarySwitch : ParentID=632 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
634: 632.0.1 [ remoteController : ParentID=632 : Fibargroup : Hidden ]
635: 632.0.2 [ heatDetector : ParentID=632 : Fibargroup : Hidden ] [ value=false ]
636: TopLoungeStripLight [ binarySwitch : ParentID=632 : Fibargroup ] [ value=false ] [ power=0w ]
637: 632.2 [ binarySwitch : ParentID=632 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
655: PatioSW [ zwaveDevice : Parent of [656,657,658,659,660] : zwaveRoute [1] : Fibargroup : Hidden ]
656: 655.0 [ binarySwitch : ParentID=655 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
657: 655.0.1 [ remoteController : ParentID=655 : Fibargroup : Hidden ]
658: 655.0.2 [ heatDetector : ParentID=655 : Fibargroup : Hidden ] [ value=false ]
659: PatioLights [ binarySwitch : ParentID=655 : Fibargroup ] [ value=false ] [ power=0w ]
660: TopLoungeLights [ binarySwitch : ParentID=655 : Fibargroup ] [ value=false ] [ power=0w ]
707: TopLoungeSpeakers [ virtual_device ]
177: TopLoungeALC [ luaScene : Max Instances=6 : Instances=0 : TRIGGER_AND_MANUAL ]
--~~== Alarm room ==~~--
278: DSCpresenter [ virtual_device ]
280: DSClogger [ virtual_device ]
401: DSCengine [ virtual_device ]
402: DSCpartition1 [ virtual_device ]
403: DSCpartition2 [ virtual_device ]
916: Fire alarm VD v1.1 [ virtual_device ]
917: Flood alarm VD v1.1 [ virtual_device ]
113: Stay [ luaScene : Max Instances=2 : Instances=0 : MANUAL_ONLY ]
115: Panic [ luaScene : Max Instances=2 : Instances=0 : MANUAL_ONLY ]
116: Disarm [ luaScene : Max Instances=2 : Instances=0 : MANUAL_ONLY ]
117: Away [ luaScene : Max Instances=2 : Instances=0 : MANUAL_ONLY ]
128: DSCAlarmStatus [ luaScene : Max Instances=2 : Instances=0 : TRIGGER_AND_MANUAL ]
184: Fire Alarm v1.1 [ luaScene : Max Instances=6 : Instances=0 : MANUAL_ONLY ]
185: Flood Alarm v1.1 [ luaScene : Max Instances=6 : Instances=0 : MANUAL_ONLY ]
______________________ GroundFloor section ______________________
--~~== TVRoom room ==~~--
220: TVRoomSW [ zwaveDevice : Parent of [221,222,223] : zwaveRoute [1,612] : Fibargroup : Hidden ]
221: 220.0 [ binarySwitch : ParentID=220 : Fibargroup : Hidden ] [ value=false ]
222: TVRoomStripLights [ binarySwitch : ParentID=220 : Fibargroup ] [ value=false ]
223: 220.2 [ binarySwitch : ParentID=220 : Fibargroup : Hidden ] [ value=false ]
612: TVRoomDimSW [ zwaveDevice : Parent of [613,614,615,616] : zwaveRoute [1] : Fibargroup : Hidden ]
613: 612.0 [ remoteController : ParentID=612 : Fibargroup : Hidden ] [ value=0 ] [ power=0w ]
614: 612.0.1 [ remoteController : ParentID=612 : Fibargroup : Hidden ]
615: TVRoomDimmer [ remoteController : ParentID=612 : Fibargroup ] [ value=0 ] [ power=0w ]
616: 612.2 [ remoteController : ParentID=612 : Fibargroup : Hidden ] [ value=0 ]
667: TVStripSW [ zwaveDevice : Parent of [668,669,670,671,672] : zwaveRoute [1,91,612] : Fibargroup : Hidden ]
668: 667.0 [ binarySwitch : ParentID=667 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
669: 667.0.1 [ remoteController : ParentID=667 : Fibargroup : Hidden ]
670: 667.0.2 [ heatDetector : ParentID=667 : Fibargroup : Hidden ] [ value=false ]
671: TVStripLights [ binarySwitch : ParentID=667 : Fibargroup ] [ value=false ] [ power=0w ]
672: 667.2 [ binarySwitch : ParentID=667 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
715: DSTV [ virtual_device ]
717: Blueray [ virtual_device ]
728: Apple TV [ virtual_device ]
814: TVCurtains [ virtual_device ]
821: TVSheer2 [ virtual_device ]
822: TVBlockout2 [ virtual_device ]
827: TVBlockout1 [ virtual_device ]
847: TVShear1 [ virtual_device ]
--~~== Server room ==~~--
150: ServerRoomSW [ zwaveDevice : Parent of [170,171,172] : zwaveRoute [1] : Fibargroup : Hidden ]
170: 150.0 [ binarySwitch : ParentID=150 : Fibargroup ] [ value=false ] [ power=0w ]
171: ServerLights [ binarySwitch : ParentID=150 : Fibargroup ] [ value=false ]
172: 150.2 [ binarySwitch : ParentID=150 : Fibargroup : Hidden ] [ value=false ]
182: ServerLights [ luaScene : Max Instances=6 : Instances=0 : Autostart : TRIGGER_AND_MANUAL ]
--~~== Study room ==~~--
623: StudyAircon [ samsungAirConditioner : ParentID=622 ] [ value=17C ]
705: StudySpeakers [ virtual_device ]
747: StudySW [ zwaveDevice : Parent of [748,749,750,751,752] : zwaveRoute [1] : Fibargroup : Hidden ]
748: 747.0 [ binarySwitch : ParentID=747 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
749: 747.0.1 [ remoteController : ParentID=747 : Fibargroup : Hidden ]
750: 747.0.2 [ heatDetector : ParentID=747 : Fibargroup : Hidden ] [ value=false ]
751: StudyLights [ binarySwitch : ParentID=747 : Fibargroup ] [ value=false ] [ power=0w ]
752: StudyStripLight [ binarySwitch : ParentID=747 : Fibargroup ] [ value=true ] [ power=177.9w ]
807: StudyCurtains [ virtual_device ]
817: StudyCurtain1 [ virtual_device ]
824: StudyCurtain3 [ virtual_device ]
848: StudyCurtain2 [ virtual_device ]
931: StudySensor [ zwaveDevice : Parent of [932,933,934,935] : zwaveRoute [1,62] : Fibargroup : Hidden ]
932: StudyMotion [ motionSensor : ParentID=931 : Fibargroup : Battery=100% ] [ value=false ]
933: StudyTemp [ temperatureSensor : ParentID=931 : Fibargroup ] [ value=22.7C ]
934: StudyLux [ lightSensor : ParentID=931 : Fibargroup ] [ value=1128lux ]
935: StudySeismo [ seismometer : ParentID=931 : Fibargroup : Hidden ] [ value=0 ]
--~~== Jan room ==~~--
62: JanSW [ zwaveDevice : Parent of [63,64,65] : zwaveRoute [1] : Fibargroup : Hidden ]
63: 62.0 [ binarySwitch : ParentID=62 : Fibargroup : Hidden ] [ value=false ]
64: JanBathLights [ binarySwitch : ParentID=62 : Fibargroup ] [ value=false ]
65: JanTowelRail [ binarySwitch : ParentID=62 : Fibargroup ] [ value=false ]
563: Jan Aircon [ virtual_device ]
617: JanDimSW [ zwaveDevice : Parent of [618,619,620,621] : zwaveRoute [1] : Fibargroup : Hidden ]
618: 617.0 [ remoteController : ParentID=617 : Fibargroup : Hidden ] [ value=0 ] [ power=0w ]
619: 617.0.1 [ remoteController : ParentID=617 : Fibargroup : Hidden ]
620: JanDimmer [ remoteController : ParentID=617 : Fibargroup ] [ value=0 ] [ power=0w ]
621: 617.2 [ remoteController : ParentID=617 : Fibargroup : Hidden ] [ value=0 ]
706: JanSpeakers [ virtual_device ]
--~~== Foyer room ==~~--
404: FoyerSW [ zwaveDevice : Parent of [405,406,407,408] : zwaveRoute [1] : Fibargroup : Hidden ]
405: 404.0 [ binarySwitch : ParentID=404 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
406: FoyerRemote [ remoteController : ParentID=404 : Fibargroup : Hidden ]
407: FoyerLights [ binarySwitch : ParentID=404 : Fibargroup ] [ value=false ] [ power=0w ]
408: 404.2 [ binarySwitch : ParentID=404 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
639: FoyerSpeakers [ virtual_device ]
666: PassageLights [ binarySwitch : ParentID=661 : Fibargroup ] [ value=false ] [ power=0w ]
839: FoyerCurtain [ virtual_device ]
936: FoyerSensor [ zwaveDevice : Parent of [937,938,939,940] : zwaveRoute [1] : Fibargroup : Hidden ]
937: FoyerMotion [ motionSensor : ParentID=936 : Fibargroup : Battery=62% ] [ value=false ]
938: FoyerTemp [ temperatureSensor : ParentID=936 : Fibargroup ] [ value=23.3C ]
939: FoyerLux [ lightSensor : ParentID=936 : Fibargroup ] [ value=655lux ]
940: FoyerSeismo [ seismometer : ParentID=936 : Fibargroup : Hidden ] [ value=0 ]
175: FoyerALC [ luaScene : Max Instances=6 : Instances=0 : TRIGGER_AND_MANUAL ]
--~~== BMW room ==~~--
376: DoorSwBMW [ zwaveDevice : Parent of [377,378,379] : zwaveRoute [1,414] : Fibargroup : Hidden ]
377: 376.0 [ motionSensor : ParentID=376 : Fibargroup : Battery=60% : Hidden ] [ value=false ]
378: BMWDoor [ doorSensor : ParentID=376 : Fibargroup : Battery=60% ] [ value=false ]
379: 376.0.3 [ remoteController : ParentID=376 : Fibargroup : Battery=60% : Hidden ]
414: BMWLightSW [ zwaveDevice : Parent of [415,416,417,418] : zwaveRoute [1] : Fibargroup : Hidden ]
415: 414.0 [ binarySwitch : ParentID=414 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
416: 414.0.1 [ remoteController : ParentID=414 : Fibargroup : Hidden ]
417: BMWLights [ binarySwitch : ParentID=414 : Fibargroup ] [ value=false ] [ power=0w ]
418: 414.2 [ binarySwitch : ParentID=414 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
97: BMWLightsScene [ luaScene : Max Instances=2 : Instances=0 : Autostart : MANUAL_ONLY ]
--~~== Porsche room ==~~--
228: PorscheGarageSW [ zwaveDevice : Parent of [229,230,231] : zwaveRoute [1,96,861] : Fibargroup : Hidden ]
229: 228.0 [ binarySwitch : ParentID=228 : Fibargroup : Hidden ] [ value=false ]
230: PorscheLights [ binarySwitch : ParentID=228 : Fibargroup ] [ value=false ]
231: Unused [ binarySwitch : ParentID=228 : Fibargroup : Hidden ] [ value=false ]
372: DoorSwPorsche [ zwaveDevice : Parent of [373,374,375] : zwaveRoute [1,62] : Fibargroup : Hidden ]
373: 372.0 [ motionSensor : ParentID=372 : Fibargroup : Battery=100% : Hidden ] [ value=true ]
374: PorscheDoor [ doorSensor : ParentID=372 : Fibargroup : Battery=100% ] [ value=false ]
375: 372.0.3 [ remoteController : ParentID=372 : Fibargroup : Battery=100% : Hidden ]
96: PorscheLightsScene [ luaScene : Max Instances=2 : Instances=0 : Autostart : MANUAL_ONLY ]
--~~== Entrance room ==~~--
312: EntranceStripSW [ zwaveDevice : Parent of [313,314,315,316] : zwaveRoute [1,204] : Fibargroup : Hidden ]
313: 312.0 [ binarySwitch : ParentID=312 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
314: 312.0.1 [ remoteController : ParentID=312 : Fibargroup : Hidden ]
315: EntranceStripLights [ binarySwitch : ParentID=312 : Fibargroup ] [ value=false ] [ power=0w ]
316: FountainLights [ binarySwitch : ParentID=312 : Fibargroup ] [ value=false ] [ power=0w ]
331: EntranceSensor [ zwaveDevice : Parent of [332,333,334,335] : zwaveRoute [1,204] : Fibargroup : Hidden ]
332: EntranceMotion [ motionSensor : ParentID=331 : Fibargroup : Battery=100% ] [ value=false ]
333: EntranceTemp [ temperatureSensor : ParentID=331 : Fibargroup ] [ value=24.8C ]
334: EntranceLux [ lightSensor : ParentID=331 : Fibargroup ] [ value=2306lux ]
335: EntranceSeismo [ seismometer : ParentID=331 : Fibargroup : Hidden ] [ value=0 ]
367: EntranceDownSW [ zwaveDevice : Parent of [387,388,389,390] : zwaveRoute [1] : Fibargroup : Hidden ]
387: 367.0 [ remoteController : ParentID=367 : Fibargroup : Hidden ] [ value=0 ] [ power=0w ]
388: 367.0.1 [ remoteController : ParentID=367 : Fibargroup : Hidden ]
389: EntranceDownlights [ remoteController : ParentID=367 : Fibargroup ] [ value=0 ] [ power=0w ]
390: 367.2 [ remoteController : ParentID=367 : Fibargroup : Hidden ] [ value=2 ]
396: EntranceSensor2 [ zwaveDevice : Parent of [397,398,399,400] : zwaveRoute [1,595] : Fibargroup : Hidden ]
397: EntranceMotion2 [ motionSensor : ParentID=396 : Fibargroup : Battery=100% ] [ value=false ]
398: EntranceTemp2 [ temperatureSensor : ParentID=396 : Fibargroup ] [ value=25.2C ]
399: EntranceLux2 [ lightSensor : ParentID=396 : Fibargroup ] [ value=3403lux ]
400: EntranceSeismo2 [ seismometer : ParentID=396 : Fibargroup : Hidden ] [ value=0 ]
595: ChandelierDimSW [ zwaveDevice : Parent of [596,597,598,599] : zwaveRoute [1] : Fibargroup : Hidden ]
596: 595.0 [ remoteController : ParentID=595 : Fibargroup : Hidden ] [ value=0 ] [ power=0w ]
597: 595.0.1 [ remoteController : ParentID=595 : Fibargroup : Hidden ]
598: EntranceChandelier [ remoteController : ParentID=595 : Fibargroup ] [ value=0 ] [ power=0w ]
599: 595.2 [ remoteController : ParentID=595 : Fibargroup : Hidden ] [ value=0 ]
846: Blind1 [ virtual_device ]
850: Blind2 [ virtual_device ]
918: FrontDoorLock [ zwaveDevice : Parent of [919] : zwaveRoute [1] : Poly-control : Hidden ]
919: FrontDoor [ doorLock : ParentID=918 : Poly-control : Battery=89% ] [ value=true ]
176: EntranceALC [ luaScene : Max Instances=6 : Instances=0 : TRIGGER_AND_MANUAL ]
--~~== Kitchen room ==~~--
638: KitchenSpeakers [ virtual_device ]
809: KitchenCurtain [ virtual_device ]
871: KitchenFloodSensor1 [ zwaveDevice : Parent of [872,873] : zwaveRoute [1] : Fibargroup : Hidden ]
872: KitchenIslandBottom [ floodSensor : ParentID=871 : Fibargroup : Battery=95% ] [ value=false ]
873: IslandBottomTemp [ temperatureSensor : ParentID=871 : Fibargroup : Battery=95% ] [ value=23.97C ]
885: ROFloodSensor [ zwaveDevice : Parent of [886,887] : zwaveRoute [1,96] : Fibargroup : Hidden ]
886: ROFilterFloodSensor [ floodSensor : ParentID=885 : Fibargroup : Battery=100% ] [ value=false ]
887: ROFilterFloodTemp [ temperatureSensor : ParentID=885 : Fibargroup : Battery=100% ] [ value=21.88C ]
945: KitchenSensor [ zwaveDevice : Parent of [946,947,948,949] : zwaveRoute [1,200] : Fibargroup : Hidden ]
946: KitchenMotion [ motionSensor : ParentID=945 : Fibargroup : Battery=100% ] [ value=false ]
947: KitchenTemp [ temperatureSensor : ParentID=945 : Fibargroup ] [ value=24.1C ]
948: KitchenLux [ lightSensor : ParentID=945 : Fibargroup ] [ value=134lux ]
949: KitchenSeismo [ seismometer : ParentID=945 : Fibargroup : Hidden ] [ value=0 ]
955: KitchenSW [ zwaveDevice : Parent of [956,957,958,959,960] : zwaveRoute [1] : Fibargroup : Hidden ]
956: 955.0 [ binarySwitch : ParentID=955 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
957: 955.0.1 [ remoteController : ParentID=955 : Fibargroup : Hidden ]
958: 955.0.2 [ heatDetector : ParentID=955 : Fibargroup : Hidden ] [ value=false ]
959: KitchenLights [ binarySwitch : ParentID=955 : Fibargroup ] [ value=false ] [ power=117.1w ]
178: KitchenALC [ luaScene : Max Instances=6 : Instances=0 : TRIGGER_AND_MANUAL ]
--~~== Scullery room ==~~--
640: StreetLampSW [ zwaveDevice : Parent of [641,642,643,644,645] : zwaveRoute [1,200] : Fibargroup : Hidden ]
641: 640.0 [ binarySwitch : ParentID=640 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
642: 640.0.1 [ remoteController : ParentID=640 : Fibargroup : Hidden ]
643: 640.0.2 [ heatDetector : ParentID=640 : Fibargroup : Hidden ] [ value=false ]
645: 640.2 [ binarySwitch : ParentID=640 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
711: ScullerySW [ zwaveDevice : Parent of [712,713,714] : zwaveRoute [1,87,367,200] : Fibargroup : Hidden ]
712: 711.0 [ binarySwitch : ParentID=711 : Fibargroup : Hidden ] [ value=false ]
713: SculleryLights [ binarySwitch : ParentID=711 : Fibargroup ] [ value=false ]
714: 711.2 [ binarySwitch : ParentID=711 : Fibargroup : Hidden ] [ value=false ]
--~~== Braai room ==~~--
661: BraaiSW [ zwaveDevice : Parent of [662,663,664,665,666] : zwaveRoute [1] : Fibargroup : Hidden ]
662: 661.0 [ binarySwitch : ParentID=661 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
663: 661.0.1 [ remoteController : ParentID=661 : Fibargroup : Hidden ]
664: 661.0.2 [ heatDetector : ParentID=661 : Fibargroup : Hidden ] [ value=false ]
665: BraaiStripLights [ binarySwitch : ParentID=661 : Fibargroup ] [ value=false ] [ power=0w ]
797: BraaiSpeakers [ virtual_device ]
861: BraaiDimSW [ zwaveDevice : Parent of [862,863,864,865] : zwaveRoute [1,96,632] : Fibargroup : Hidden ]
862: 861.0 [ remoteController : ParentID=861 : Fibargroup : Hidden ] [ value=0 ] [ power=0w ]
863: 861.0.1 [ remoteController : ParentID=861 : Fibargroup : Hidden ]
864: BraaiDimmer [ remoteController : ParentID=861 : Fibargroup ] [ value=0 ] [ power=0w ]
865: 861.2 [ remoteController : ParentID=861 : Fibargroup : Hidden ] [ value=0 ]
--~~== GuestToilet room ==~~--
581: GuestToiletSW [ zwaveDevice : Parent of [582,583,584] : zwaveRoute [1,62] : Fibargroup : Hidden ]
582: 581.0 [ binarySwitch : ParentID=581 : Fibargroup : Hidden ] [ value=false ]
583: GuestToiletLights [ binarySwitch : ParentID=581 : Fibargroup ] [ value=false ]
584: 581.2 [ binarySwitch : ParentID=581 : Fibargroup : Hidden ] [ value=false ]
--~~== DiningRoom room ==~~--
91: DininingDimSW [ zwaveDevice : Parent of [92,93,94] : zwaveRoute [1] : Fibargroup : Hidden ]
92: 91.0 [ multilevelSwitch : ParentID=91 : Fibargroup : Hidden ] [ value=0 ] [ power=0w ]
93: DiningDimmer [ multilevelSwitch : ParentID=91 : Fibargroup ] [ value=0 ] [ power=0w ]
94: 91.2 [ multilevelSwitch : ParentID=91 : Fibargroup : Hidden ] [ value=0 ]
606: DiningSW [ zwaveDevice : Parent of [607,608,609,610,611] : zwaveRoute [1] : Fibargroup : Hidden ]
607: 606.0 [ binarySwitch : ParentID=606 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
608: 606.0.1 [ remoteController : ParentID=606 : Fibargroup : Hidden ]
609: 606.0.2 [ heatDetector : ParentID=606 : Fibargroup : Hidden ] [ value=false ]
610: DiningDownLights [ binarySwitch : ParentID=606 : Fibargroup ] [ value=false ] [ power=0w ]
611: DiningStripLights [ binarySwitch : ParentID=606 : Fibargroup ] [ value=false ] [ power=0w ]
828: DiningBlockout [ virtual_device ]
837: DiningSheer [ virtual_device ]
181: DiningALC [ luaScene : Max Instances=6 : Instances=0 : TRIGGER_AND_MANUAL ]
--~~== Workshop room ==~~--
522: WorkshopSW [ zwaveDevice : Parent of [523,524,525,526,527] : zwaveRoute [1] : Fibargroup : Hidden ]
523: 522.0 [ binarySwitch : ParentID=522 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
524: 522.0.1 [ remoteController : ParentID=522 : Fibargroup : Hidden ]
525: 522.0.2 [ heatDetector : ParentID=522 : Fibargroup : Hidden ] [ value=false ]
526: 522.1 [ binarySwitch : ParentID=522 : Fibargroup : Hidden ] [ value=false ] [ power=0w ]
527: WorkshopLight [ binarySwitch : ParentID=522 : Fibargroup ] [ value=false ] [ power=0w ]
--~~== System room ==~~--
3: YR_Weather [ yrWeather ]
391: VoiceAlertAAAA [ virtual_device ]
483: yrWeather [ yrWeather ]
622: SmartThingsAccount [ samsungSmartAppliances ]
875: Select lang v2.3 [ virtual_device ]
876: Icon Preview v2.4 [ virtual_device ]
877: System Debug v1.2 [ virtual_device ]
878: System Status v1.5 [ virtual_device ]
879: System Ctrl v1.5 [ virtual_device ]
880: User Setup v1.6 [ virtual_device ]
881: Watchdog VD v1.5 [ virtual_device ]
882: System Backup v1.1 [ virtual_device ]
884: ABC VD v1.6 [ virtual_device ]
888: Sunrise & Set 2.6 [ virtual_device ]
889: Home Timers v2.4 [ virtual_device ]
891: Sun Calc VD v1.1 [ virtual_device ]
892: Moon Calc VD v1.1 [ virtual_device ]
893: ANC Message v1.2 [ virtual_device ]
894: ANC Queue v1.2 [ virtual_device ]
895: Event Recorder v1.1 [ virtual_device ]
896: Weather state v3.1 [ virtual_device ]
897: Weather Fore. v3.1 [ virtual_device ]
901: Weather Provider [ WeatherProvider ]
903: ALC Sidekick v1.1 [ virtual_device ]
904: ALC Config. v1.2 [ virtual_device ]
907: Home Status v2.5 [ virtual_device ]
908: Presence Simple v1.1 [ virtual_device ]
910: SetVAR [ virtual_device ]
961: Darkness Monitor [ virtual_device ]
76: MakeHomeTable [ luaScene : Max Instances=1 : Instances=0 : Autostart : MANUAL_ONLY ]
80: AlarmClockScene [ luaScene : Max Instances=2 : Instances=0 : Autostart : MANUAL_ONLY ]
82: MainScene [ luaScene : Max Instances=1 : Instances=0 : Autostart : MANUAL_ONLY ]
83: PrintHomeTable [ luaScene : Max Instances=1 : Instances=0 : MANUAL_ONLY ]
84: CheckUserID [ luaScene : Max Instances=1 : Instances=0 : Autostart : MANUAL_ONLY ]
101: zWaveMonitor [ luaScene : Max Instances=1 : Instances=1 : MANUAL_ONLY ]
102: zWaveViewer [ luaScene : Max Instances=1 : Instances=0 : MANUAL_ONLY ]
103: GoodMorning [ luaScene : Max Instances=1 : Instances=0 : MANUAL_ONLY ]
104: GoodNight [ luaScene : Max Instances=1 : Instances=0 : MANUAL_ONLY ]
126: Home [ luaScene : Max Instances=2 : Instances=0 : MANUAL_ONLY ]
132: ClearDebugMsg [ luaScene : Max Instances=3 : Instances=0 : Autostart : MANUAL_ONLY ]
135: SMsgH [ luaScene : Max Instances=2 : Instances=0 : Autostart : MANUAL_ONLY ]
136: pushoverSend [ luaScene : Max Instances=2 : Instances=0 : MANUAL_ONLY ]
137: pushover Test [ luaScene : Max Instances=2 : Instances=0 : MANUAL_ONLY ]
147: GlobalTranslation [ luaScene : Max Instances=2 : Instances=0 : Autostart : TRIGGER_AND_MANUAL ]
148: SystemTranslation [ luaScene : Max Instances=2 : Instances=0 : Autostart : TRIGGER_AND_MANUAL ]
149: MessageTranslation [ luaScene : Max Instances=2 : Instances=0 : Autostart : TRIGGER_AND_MANUAL ]
150: ClimateTranslation [ luaScene : Max Instances=2 : Instances=0 : Autostart : TRIGGER_AND_MANUAL ]
151: MultimedTranslation [ luaScene : Max Instances=2 : Instances=0 : Autostart : TRIGGER_AND_MANUAL ]
152: TTSTranslation [ luaScene : Max Instances=2 : Instances=0 : Autostart : TRIGGER_AND_MANUAL ]
153: Reboot Scene [ luaScene : Max Instances=2 : Instances=0 : TRIGGER_AND_MANUAL ]
154: Remote Reboot [ luaScene : Max Instances=2 : Instances=0 : TRIGGER_AND_MANUAL ]
155: Watchdog [ luaScene : Max Instances=2 : Instances=1 : Autostart : TRIGGER_AND_MANUAL ]
156: Automatic backup [ luaScene : Max Instances=2 : Instances=0 : TRIGGER_AND_MANUAL ]
158: SiemensDevices [ luaScene : Max Instances=2 : Instances=0 : MANUAL_ONLY ]
159: Main Timers v1.3 [ luaScene : Max Instances=2 : Instances=1 : Autostart : TRIGGER_AND_MANUAL ]
160: Main Scene FTBE 2.8 [ luaScene : Max Instances=2 : Instances=1 : Autostart : TRIGGER_AND_MANUAL ]
162: Good Night UHAS 1.1 [ luaScene : Max Instances=2 : Instances=0 : MANUAL_ONLY ]
163: Suncalc v1.1 [ luaScene : Max Instances=2 : Instances=0 : TRIGGER_AND_MANUAL ]
164: ANC v1.7 [ luaScene : Max Instances=6 : Instances=0 : TRIGGER_AND_MANUAL ]
165: ANC Ask email [ luaScene : Max Instances=6 : Instances=0 : TRIGGER_AND_MANUAL ]
166: ANC Ask TTS [ luaScene : Max Instances=2 : Instances=0 : TRIGGER_AND_MANUAL ]
167: WeatherStateForecast [ luaScene : Max Instances=2 : Instances=0 : TRIGGER_AND_MANUAL ]
169: AOS [ luaScene : Max Instances=4 : Instances=0 : Autostart : MANUAL_ONLY ]
170: CPU-RAM Monitor [ luaScene : Max Instances=2 : Instances=0 : Autostart : MANUAL_ONLY ]
171: LocTracker [ luaScene : Max Instances=2 : Instances=0 : MANUAL_ONLY ]
183: DoorWindow check [ luaScene : Max Instances=6 : Instances=0 : MANUAL_ONLY ]
186: DeviceList v2.2 [ luaScene : Max Instances=2 : Instances=1 : MANUAL_ONLY ]
188: ZRangeAnalyzer [ luaScene : Max Instances=2 : Instances=0 : MANUAL_ONLY ]
190: RoutingCheck [ luaScene : Max Instances=2 : Instances=0 : MANUAL_ONLY ]
191: WakeUpPoling [ luaScene : Max Instances=2 : Instances=0 : MANUAL_ONLY ]
192: ListNodeIDs v2 [ luaScene : Max Instances=2 : Instances=0 : MANUAL_ONLY ]
193: TestZComms v2 [ luaScene : Max Instances=2 : Instances=0 : MANUAL_ONLY ]
194: SanityCheck151 [ luaScene : Max Instances=2 : Instances=0 : MANUAL_ONLY ]
_________________________ End of section _________________________
--~~== Unassigned room ==~~--
--~~== System Users ==~~--
2: [email protected] [ superuser : [email protected] : hasGPS="5min" : deviceRights=[] : sceneRights=[] ]
20: resia [ user : [email protected] : hasGPS="0min" : deviceRights=[3,63,65,88,93,128,129,130,133,135,155,167,170,182,184,197,199,202,206,213,215,221,229,250,252,254,255,256,264,265,266,267,268,269,278,300,305,306,315,316,332,333,334,347,348,349,374,378,389,397,398,399,402,407,410,417,423,425,426,427,517,518,527,547,557,560,562,563,564,566,579,582,598,610,611,615,620,623,636,638,639,644,653,659,660,665,666,671,697,698,704,705,706,707,708,709,710,712,715,717,728,733,751,752,797,807,811,812,814,817,818,821,822,824,827,828,829,832,834,835,837,839,841,843,845,846,847,848,849,850,851,856,864] : sceneRights=[103,104,113,115,116,117] ]
21: jan [ user : [email protected] : deviceRights=[3,63,65,88,93,128,129,130,133,135,155,167,170,182,184,197,199,202,206,213,215,221,229,250,252,254,255,256,264,266,268,278,300,305,306,315,316,332,333,334,347,348,349,374,378,389,397,398,399,402,407,410,417,423,425,426,427,517,518,527,547,560,562,563,564,566,579,582,598,610,611,615,620,623,636,638,639,644,653,659,660,665,666,671,697,698,704,705,706,707,708,709,710,712,715,717,728,733,751,752,797,807,809,811,812,814,817,818,821,822,824,827,828,829,832,834,835,837,839,841,843,845,846,847,848,849,850,851,856,864] : sceneRights=[103,104] ]
69: nicophone [ user : [email protected] : deviceRights=[3,63,65,88,93,128,129,130,133,135,155,167,170,182,184,197,199,202,206,213,215,221,229,250,252,254,255,256,264,265,266,267,268,269,278,280,300,305,306,315,316,332,333,334,347,348,349,374,378,389,391,397,398,399,402,407,410,417,422,423,425,426,427,496,517,518,520,521,527,547,557,560,562,563,564,566,579,582,598,610,611,615,620,622,623,636,638,639,644,653,659,660,665,666,671,697,698,704,705,706,707,708,709,710,712,715,717,728,733,744,751,752,797,807,809,811,812,814,817,818,821,822,824,827,828,829,832,834,835,837,839,841,843,845,846,847,848,849,850,851,856,864,867,868,872,873,875,876,877,878,879,880,881,882,884,886,887,888,889,890,891,892,893,894,895,896,897,901,903,904,906,907,908,910,911] : sceneRights=[76,80,82,96,97,103,104,113,115,116,117] ]
232: carel [ user : [email protected] : deviceRights=[3,63,65,88,93,128,129,130,133,135,155,167,170,182,184,197,199,202,206,213,215,221,229,250,252,254,255,256,264,265,266,267,268,269,278,300,305,306,315,316,332,333,334,347,348,349,374,378,389,397,398,399,402,407,410,417,423,425,426,427,517,518,527,547,560,562,563,564,566,579,582,598,610,611,615,620,623,636,638,639,644,653,659,660,665,666,671,697,698,704,705,706,707,708,709,710,712,715,717,728,733,751,752,797,807,809,811,812,814,817,818,821,822,824,827,828,829,832,834,835,837,839,841,843,845,846,847,848,849,850,851,856,864] : sceneRights=[] ]
497: roan [ user : [email protected] : deviceRights=[3,63,65,88,93,128,129,130,133,135,155,167,170,182,184,197,199,202,206,213,215,221,229,250,252,254,255,256,264,265,266,267,268,269,278,280,300,305,306,315,316,332,333,334,347,348,349,374,378,389,391,397,398,399,401,402,407,410,417,422,423,425,426,427,496,517,518,527,547,557,560,562,563,566] : sceneRights=[] ]
909: geofency [ user : [email protected] : deviceRights=[908] : sceneRights=[] ]
--~~== Mobile devices list ==~~--
472: NicoiPhone12 [ iOS_device : Push=true : last Logged [email protected] at Sun Dec 4 05:49:54 2022 ]
570: CareliPhoneXR [ iOS_device : Push=false : last Logged User=carel at Sun Dec 4 05:49:55 2022 ]
905: ResiaiPadPro [ iOS_device : Push=false : last Logged [email protected] at Sun Dec 4 05:50:04 2022 ]
913: iPhone [ iOS_device : Push=true : last Logged User=resia at Sun Dec 4 05:50:05 2022 ]
915: iPhone [ iOS_device : Push=true : last Logged User=nico---@---com at Sun Dec 4 05:53:07 2022 ]
Type Total Type Total Type Total
samsungSmartAppliances 1 samsungAirConditioner 1 luaScene 66
iOS_device 5 virtual_device 81 zwaveDevice 68
heatDetector 15 remoteController 55 multilevelSwitch 3
floodSensor 3 doorLock 1 binarySwitch 114
magicScene 4 WeatherProvider 1 yrWeather 2
smokeSensor 1 lightSensor 9 seismometer 9
doorSensor 2 accelerometer 1 FGMS001 1
temperatureSensor 18 motionSensor 12
Total physical devces = 68
Total Zwave/Virtual devices = 398
Battery operated = 16
I have also include the outputs from two other scripts which also don't show any problem :
Last Working Route (LWR) and Neighbors (NBR) script by @petergebruers, version 1.3.0
Spoiler
Report time: 2022-12-04 11:37:00
Mastr LWR                 Status Timestamp            Neighbors           Status Timestamp              Node Slave   Proto SDK   Name of a slave, library type
   57 1,96                    ok 2022-12-04 05:51:26  33:78,96,127,...        ok 2022-12-04 05:51:26 =     8  268  3,92==6.51.01 "Geyser2Switch in Roof" - Enhanced Routing Slave.
   62 1                       ok 2022-12-04 05:51:27  28:1,87,96,...          ok 2022-12-04 05:51:27 =     9   64  3,52==4.54.02 "JanBathLights in Jan" - Enhanced Routing Slave.
   78 1,96                    ok 2022-12-04 05:51:32  30:57,96,127,...        ok 2022-12-04 05:51:31 =    10  264  3,92==6.51.01 "Geyser1Switch in Roof" - Enhanced Routing Slave.
   87 1                       ok 2022-12-04 05:51:34  31:1,62,91,...          ok 2022-12-04 05:51:32 =    12   89  3,52==4.54.02 "TopPassLights in TopLounge" - Enhanced Routing Slave.
   91 1                       ok 2022-12-04 05:51:36  28:1,87,150,...         ok 2022-12-04 05:51:36 =    13   93   4,5==6.51.06 "DiningDimmer in DiningRoom" - Enhanced Routing Slave.
   96 1                       ok 2022-12-04 10:55:05  38:1,57,62,...          ok 2022-12-04 10:55:05 =    14  266  3,92==6.51.01 "Geyser3Switch in Roof" - Enhanced Routing Slave.
  127 1,57                    ok 2022-12-04 05:51:38   6:57,78,132,...        ok 2022-12-04 05:51:37 =    21  128  3,67==4.55.00 "MainBedroomMotion in MainBedroom" - Enhanced Routing Slave.
  132 1,200                   ok 2022-12-04 05:51:39  28:57,78,87,...         ok 2022-12-04 05:51:38 =    22  134  3,52==4.54.02 "MainBathroomLights in MainBathroom" - Enhanced Routing Slave.
  150 1                       ok 2022-12-04 05:51:39  40:1,62,87,...          ok 2022-12-04 05:51:39 =    26  170  3,52==4.54.02 "150.0 in Server" - Enhanced Routing Slave.
  154 1                       ok 2022-12-04 05:51:41  29:1,57,78,...          ok 2022-12-04 05:51:39 =    27  156  3,52==4.54.02 "PassageLights in MainBedroom" - Enhanced Routing Slave.
  166 1,96,204                ok 2022-12-04 10:51:04  28:57,78,87,...         ok 2022-12-04 10:51:04 =    30  168  3,52==4.54.02 "StoepLights in MainBedroom" - Enhanced Routing Slave.
  181 1                       ok 2022-12-04 05:51:45  33:1,87,96,...          ok 2022-12-04 05:51:45 =    33  183  3,52==4.54.02 "StaircaseLights in Staircase" - Enhanced Routing Slave.
  196 1                       ok 2022-12-04 05:51:45  39:1,57,78,...          ok 2022-12-04 05:51:45 =    35  198  3,52==4.54.02 "CarelBathLights in Carel" - Enhanced Routing Slave.
  200 1                       ok 2022-12-04 09:59:36  43:1,57,62,...          ok 2022-12-04 09:59:36 =    36  202   4,5==6.51.06 "GuestDimmer in Guest" - Enhanced Routing Slave.
  204 1                       ok 2022-12-04 05:51:48  53:1,57,62,...          ok 2022-12-04 05:51:48 =    37  206   4,5==6.51.06 "CarelDimmer in Carel" - Enhanced Routing Slave.
  212 1,204                   ok 2022-12-04 05:51:54  36:57,78,87,...         ok 2022-12-04 05:51:49 =    39  214  3,52==4.54.02 "GuestTowelRail in Guest" - Enhanced Routing Slave.
  220 1,612                   ok 2022-12-04 05:51:55  35:62,78,87,...         ok 2022-12-04 05:51:55 =    41  222  3,52==4.54.02 "TVRoomStripLights in TVRoom" - Enhanced Routing Slave.
  228 1,96,861                ok 2022-12-04 05:51:56  15:127,150,253,...      ok 2022-12-04 05:51:55 =    43  230  3,52==4.54.02 "PorscheLights in Porsche" - Enhanced Routing Slave.
  249 1,612,925               ok 2022-12-04 05:52:00   7:396,513,519,...      ok 2022-12-04 05:52:00 =    47  251  3,52==4.54.02 "RimflowSlow in PoolRoom" - Enhanced Routing Slave.
  253 1                       ok 2022-12-04 05:52:04  15:1,57,87,...          ok 2022-12-04 05:52:00 =    48  254  3,67==4.55.00 "TopLoungeMotion in TopLounge" - Enhanced Routing Slave.
  297 1,96,200                ok 2022-12-04 09:51:47  24:57,78,91,...         ok 2022-12-04 09:51:47 =    51  300   4,5==6.51.06 "StoreLights in Store" - Enhanced Routing Slave.
  302 1,96,404                ok 2022-12-04 05:52:06  20:57,78,196,...        ok 2022-12-04 05:52:06 =    52  305   4,5==6.51.06 "RefuseLights in Refuse" - Enhanced Routing Slave.
  312 1,204                   ok 2022-12-04 05:52:09  18:181,204,228,...      ok 2022-12-04 05:52:08 =    54  315   4,5==6.51.06 "EntranceStripLights in Entrance" - Enhanced Routing Slave.
  331 1,204                   ok 2022-12-04 05:52:09   8:57,204,212,...       ok 2022-12-04 05:52:09 =    56  332  3,67==4.55.00 "EntranceMotion in Entrance" - Enhanced Routing Slave.
  346 1,154,78                ok 2022-12-04 05:52:10  14:57,78,91,...         ok 2022-12-04 05:52:10 =    57  347  3,67==4.55.00 "TopPassMotion in TopLounge" - Enhanced Routing Slave.
  367 1                       ok 2022-12-04 05:52:10  33:1,62,87,...          ok 2022-12-04 05:52:10 =    60  389   4,5==6.51.06 "EntranceDownlights in Entrance" - Enhanced Routing Slave.
  372 1,62                    ok 2022-12-04 05:52:15  16:62,196,204,...       ok 2022-12-04 05:52:14 =    61  374   4,5==6.51.06 "PorscheDoor in Porsche" - Enhanced Routing Slave.
  376 1,414                   ok 2022-12-04 05:52:16  20:57,150,196,...       ok 2022-12-04 05:52:16 =    62  378   4,5==6.51.06 "BMWDoor in BMW" - Enhanced Routing Slave.
  396 1,595                   ok 2022-12-04 05:52:16  13:1,91,96,...          ok 2022-12-04 05:52:16 =    64  397  3,67==4.55.00 "EntranceMotion2 in Entrance" - Enhanced Routing Slave.
  404 1                       ok 2022-12-04 05:52:18  44:1,62,87,...          ok 2022-12-04 05:52:16 =    65  407  4,24==6.51.07 "FoyerLights in Foyer" - Enhanced Routing Slave.
  409 1                       ok 2022-12-04 05:52:18  19:1,62,87,...          ok 2022-12-04 05:52:18 =    66  410  3,52==4.54.02 "409.0 in Outside" - Enhanced Routing Slave.
  414 1                       ok 2022-12-04 05:52:20  35:1,62,87,...          ok 2022-12-04 05:52:20 =    68  417  4,24==6.51.07 "BMWLights in BMW" - Enhanced Routing Slave.
  419 1,150,693               ok 2022-12-04 05:52:20   5:132,166,693,...      ok 2022-12-04 05:52:20 =    69  422  4,24==6.51.07 "FloatSwitch in Borehole" - Enhanced Routing Slave.
  424 1,200,57                ok 2022-12-04 05:52:20  19:57,78,132,...        ok 2022-12-04 05:52:20 =    70  425   4,5==6.51.06 "MainBathMotion in MainBathroom" - Enhanced Routing Slave.
  513 1,612,925,519           ok 2022-12-04 05:52:22   7:249,519,543,...      ok 2022-12-04 05:52:21 =    81  517  4,24==6.51.07 "StudyPatioLights in Patio" - Enhanced Routing Slave.
  519 1,150,667,513           ok 2022-12-04 05:52:23   5:249,513,543,...      ok 2022-12-04 05:52:22 =    82  520  3,92==6.51.01 "RimFlow in PoolRoom" - Enhanced Routing Slave.
  522 1                       ok 2022-12-04 05:52:23  30:1,57,78,...          ok 2022-12-04 05:52:23 =    83  527  4,24==6.51.07 "WorkshopLight in Workshop" - Enhanced Routing Slave.
  543 1,204,606               ok 2022-12-04 05:52:24   8:166,249,513,...      ok 2022-12-04 05:52:24 =    87  547  4,24==6.51.07 "StatueFountain in Outside" - Enhanced Routing Slave.
  556 1,612,925,519           ok 2022-12-04 05:52:26   6:249,513,519,...      ok 2022-12-04 05:52:24 =    89  557  3,92==6.51.01 "Heatpump in PoolRoom" - Enhanced Routing Slave.
  578 1                       ok 2022-12-04 05:52:26   9:1,62,87,...          ok 2022-12-04 05:52:26 =    91  579   6,4==   P6,4 "WaterFeature in Outside" - Enhanced Routing Slave.
  581 1,62                    ok 2022-12-04 10:41:56  39:1,62,78,...          ok 2022-12-04 10:41:56 =    92  583  3,52==4.54.02 "GuestToiletLights in GuestToilet" - Enhanced Routing Slave.
  595 1                       ok 2022-12-04 05:52:27  37:1,57,62,...          ok 2022-12-04 05:52:27 =    95  598  4,24==6.51.07 "EntranceChandelier in Entrance" - Enhanced Routing Slave.
  606 1                       ok 2022-12-04 05:52:27  41:1,78,87,...          ok 2022-12-04 05:52:27 =    96  610  4,24==6.51.07 "DiningDownLights in DiningRoom" - Enhanced Routing Slave.
  612 1                       ok 2022-12-04 05:52:28  51:1,57,62,...          ok 2022-12-04 05:52:28 =    97  615  4,24==6.51.07 "TVRoomDimmer in TVRoom" - Enhanced Routing Slave.
  617 1                       ok 2022-12-04 05:52:28  33:1,62,87,...          ok 2022-12-04 05:52:28 =    98  620  4,24==6.51.07 "JanDimmer in Jan" - Enhanced Routing Slave.
  632 1                       ok 2022-12-04 05:52:29  47:1,57,62,...          ok 2022-12-04 05:52:28 =   100  636  4,24==6.51.07 "TopLoungeStripLight in TopLounge" - Enhanced Routing Slave.
  640 1,200                   ok 2022-12-04 05:52:34  15:200,204,212,...      ok 2022-12-04 05:52:33 =   101  644  4,24==6.51.07 "StreetLamps in Outside" - Enhanced Routing Slave.
  650 1,852,57                ok 2022-12-04 05:52:39  23:57,78,132,...        ok 2022-12-04 05:52:36 =   104  653  4,24==6.51.07 "MainBedroomDimmer in MainBedroom" - Enhanced Routing Slave.
  655 1                       ok 2022-12-04 05:52:40  47:1,57,62,...          ok 2022-12-04 05:52:39 =   105  659  4,24==6.51.07 "PatioLights in TopLounge" - Enhanced Routing Slave.
  661 1                       ok 2022-12-04 10:38:01  37:1,57,62,...          ok 2022-12-04 10:38:01 =   106  665  4,24==6.51.07 "BraaiStripLights in Braai" - Enhanced Routing Slave.
  667 1,91,612                ok 2022-12-04 10:44:38  23:78,132,150,...       ok 2022-12-04 10:44:38 =   107  671  4,24==6.51.07 "TVStripLights in TVRoom" - Enhanced Routing Slave.
  693 1,96,78                 ok 2022-12-04 05:52:45  37:1,57,78,...          ok 2022-12-04 05:52:45 =   108  697  4,24==6.51.07 "ExtractorFan in MainBathroom" - Enhanced Routing Slave.
  711 1,87,367,200            ok 2022-12-04 05:52:46  29:78,91,150,...        ok 2022-12-04 05:52:46 =   109  713  3,52==4.54.02 "SculleryLights in Scullery" - Enhanced Routing Slave.
  729 1,96,606                ok 2022-12-04 05:52:46  23:57,78,91,...         ok 2022-12-04 05:52:46 =   110  733  4,24==6.51.07 "Mirror in MainBedroom" - Enhanced Routing Slave.
  742 1,852,57                ok 2022-12-04 05:52:47  30:1,57,78,...          ok 2022-12-04 05:52:46 =   113  744  7,14==  P7,14 "WalliTemp in MainBedroom" - Enhanced Routing Slave.
  747 1                       ok 2022-12-04 05:52:47  35:1,62,87,...          ok 2022-12-04 05:52:47 =   114  751  4,24==6.51.07 "StudyLights in Study" - Enhanced Routing Slave.
  852 1,200                   ok 2022-12-04 05:52:47  27:1,57,78,...          ok 2022-12-04 05:52:47 =   117  856  4,24==6.51.07 "TowelRail2 in MainBathroom" - Enhanced Routing Slave.
  861 1,96,632                ok 2022-12-04 10:40:46  40:1,62,78,...          ok 2022-12-04 10:40:45 =   120  864  4,24==6.51.07 "BraaiDimmer in Braai" - Enhanced Routing Slave.
  866 1,612,693               ok 2022-12-04 05:52:48  16:1,62,87,...          ok 2022-12-04 05:52:48 =   121  867   5,3==6.71.03 "SmokeMotion1 in Roof" - Basic Routing Slave.
  871 1                       ok 2022-12-04 05:52:49  39:1,57,78,...          ok 2022-12-04 05:52:49 =   122  872  4,24==6.51.07 "KitchenIslandBottom in Kitchen" - Enhanced Routing Slave.
  885 1,96                    ok 2022-12-04 05:52:49  36:1,57,62,...          ok 2022-12-04 05:52:49 =   123  886  4,24==6.51.07 "ROFilterFloodSensor in Kitchen" - Enhanced Routing Slave.
  918 1                       ok 2022-12-04 05:52:50   7:1,312,367,...        ok 2022-12-04 05:52:49 =   124  919   5,3==6.71.03 "FrontDoor in Entrance" - Enhanced Routing Slave.
  925 1,581,955,612           ok 2022-12-04 05:52:50   7:249,513,519,...      ok 2022-12-04 05:52:50 =   125  929  4,24==6.51.07 "LoungePatioLights in Patio" - Enhanced Routing Slave.
  931 1,62                    ok 2022-12-04 05:52:50  19:1,62,87,...          ok 2022-12-04 05:52:50 =   126  932  3,67==4.55.00 "StudyMotion in Study" - Enhanced Routing Slave.
  936 1                       ok 2022-12-04 05:52:51  11:1,96,150,...         ok 2022-12-04 05:52:50 =   127  937  3,67==4.55.00 "FoyerMotion in Foyer" - Enhanced Routing Slave.
  941 1                       ok 2022-12-04 05:52:52  29:1,57,62,...          ok 2022-12-04 05:52:51 =   128  942  3,67==4.55.00 "FloodSense in Roof" - Enhanced Routing Slave.
  945 1,200                   ok 2022-12-04 05:52:52  14:1,62,96,...          ok 2022-12-04 05:52:52 =   129  946  3,67==4.55.00 "KitchenMotion in Kitchen" - Enhanced Routing Slave.
  955 1                       ok 2022-12-04 05:52:52  31:1,57,62,...          ok 2022-12-04 05:52:52 =   130  959  4,24==6.51.07 "KitchenLights in Kitchen" - Enhanced Routing Slave.
Devices with direct connection: 30
        Devices with 1 hop LWR: 17
        Devices with 2 hop LWR: 16
        Devices with 3 hop LWR: 5
        Devices with 4 hop LWR: 0
    Devices of type Controller: 0
     Devices with missing info: 0
Total number of devices listed: 68
Output from ListNodeIDs v2:
Spoiler
[DEBUG] 11:07:53: nodeId: 8 is master 57, has slave 268 - Geyser2Switch in Roof.
[DEBUG] 11:07:53: nodeId: 9 is master 62, has slave 64 - JanBathLights in Jan.
[DEBUG] 11:07:53: nodeId: 10 is master 78, has slave 264 - Geyser1Switch in Roof.
[DEBUG] 11:07:53: nodeId: 12 is master 87, has slave 89 - TopPassLights in TopLounge.
[DEBUG] 11:07:53: nodeId: 13 is master 91, has slave 93 - DiningDimmer in DiningRoom.
[DEBUG] 11:07:53: nodeId: 14 is master 96, has slave 266 - Geyser3Switch in Roof.
[DEBUG] 11:07:53: nodeId: 21 is master 127, has slave 128 - MainBedroomMotion in MainBedroom.
[DEBUG] 11:07:53: nodeId: 22 is master 132, has slave 134 - MainBathroomLights in MainBathroom.
[DEBUG] 11:07:53: nodeId: 26 is master 150, has slave 170 - 150.0 in Server.
[DEBUG] 11:07:53: nodeId: 27 is master 154, has slave 156 - PassageLights in MainBedroom.
[DEBUG] 11:07:53: nodeId: 30 is master 166, has slave 168 - StoepLights in MainBedroom.
[DEBUG] 11:07:53: nodeId: 33 is master 181, has slave 183 - StaircaseLights in Staircase.
[DEBUG] 11:07:53: nodeId: 35 is master 196, has slave 198 - CarelBathLights in Carel.
[DEBUG] 11:07:53: nodeId: 36 is master 200, has slave 202 - GuestDimmer in Guest.
[DEBUG] 11:07:53: nodeId: 37 is master 204, has slave 206 - CarelDimmer in Carel.
[DEBUG] 11:07:53: nodeId: 39 is master 212, has slave 214 - GuestTowelRail in Guest.
[DEBUG] 11:07:53: nodeId: 41 is master 220, has slave 222 - TVRoomStripLights in TVRoom.
[DEBUG] 11:07:53: nodeId: 43 is master 228, has slave 230 - PorscheLights in Porsche.
[DEBUG] 11:07:53: nodeId: 47 is master 249, has slave 251 - RimflowSlow in PoolRoom.
[DEBUG] 11:07:53: nodeId: 48 is master 253, has slave 254 - TopLoungeMotion in TopLounge.
[DEBUG] 11:07:53: nodeId: 51 is master 297, has slave 300 - StoreLights in Store.
[DEBUG] 11:07:53: nodeId: 52 is master 302, has slave 305 - RefuseLights in Refuse.
[DEBUG] 11:07:53: nodeId: 54 is master 312, has slave 315 - EntranceStripLights in Entrance.
[DEBUG] 11:07:53: nodeId: 56 is master 331, has slave 332 - EntranceMotion in Entrance.
[DEBUG] 11:07:53: nodeId: 57 is master 346, has slave 347 - TopPassMotion in TopLounge.
[DEBUG] 11:07:53: nodeId: 60 is master 367, has slave 389 - EntranceDownlights in Entrance.
[DEBUG] 11:07:53: nodeId: 61 is master 372, has slave 374 - PorscheDoor in Porsche.
[DEBUG] 11:07:53: nodeId: 62 is master 376, has slave 378 - BMWDoor in BMW.
[DEBUG] 11:07:53: nodeId: 64 is master 396, has slave 397 - EntranceMotion2 in Entrance.
[DEBUG] 11:07:53: nodeId: 65 is master 404, has slave 407 - FoyerLights in Foyer.
[DEBUG] 11:07:53: nodeId: 66 is master 409, has slave 410 - 409.0 in Outside.
[DEBUG] 11:07:53: nodeId: 68 is master 414, has slave 417 - BMWLights in BMW.
[DEBUG] 11:07:53: nodeId: 69 is master 419, has slave 422 - FloatSwitch in Borehole.
[DEBUG] 11:07:53: nodeId: 70 is master 424, has slave 425 - MainBathMotion in MainBathroom.
[DEBUG] 11:07:53: nodeId: 81 is master 513, has slave 517 - StudyPatioLights in Patio.
[DEBUG] 11:07:53: nodeId: 82 is master 519, has slave 520 - RimFlow in PoolRoom.
[DEBUG] 11:07:53: nodeId: 83 is master 522, has slave 527 - WorkshopLight in Workshop.
[DEBUG] 11:07:53: nodeId: 87 is master 543, has slave 547 - StatueFountain in Outside.
[DEBUG] 11:07:53: nodeId: 89 is master 556, has slave 557 - Heatpump in PoolRoom.
[DEBUG] 11:07:53: nodeId: 91 is master 578, has slave 579 - WaterFeature in Outside.
[DEBUG] 11:07:53: nodeId: 92 is master 581, has slave 583 - GuestToiletLights in GuestToilet.
[DEBUG] 11:07:53: nodeId: 95 is master 595, has slave 598 - EntranceChandelier in Entrance.
[DEBUG] 11:07:53: nodeId: 96 is master 606, has slave 610 - DiningDownLights in DiningRoom.
[DEBUG] 11:07:53: nodeId: 97 is master 612, has slave 615 - TVRoomDimmer in TVRoom.
[DEBUG] 11:07:53: nodeId: 98 is master 617, has slave 620 - JanDimmer in Jan.
[DEBUG] 11:07:53: nodeId: 100 is master 632, has slave 636 - TopLoungeStripLight in TopLounge.
[DEBUG] 11:07:53: nodeId: 101 is master 640, has slave 644 - StreetLamps in Outside.
[DEBUG] 11:07:53: nodeId: 104 is master 650, has slave 653 - MainBedroomDimmer in MainBedroom.
[DEBUG] 11:07:53: nodeId: 105 is master 655, has slave 659 - PatioLights in TopLounge.
[DEBUG] 11:07:53: nodeId: 106 is master 661, has slave 665 - BraaiStripLights in Braai.
[DEBUG] 11:07:53: nodeId: 107 is master 667, has slave 671 - TVStripLights in TVRoom.
[DEBUG] 11:07:53: nodeId: 108 is master 693, has slave 697 - ExtractorFan in MainBathroom.
[DEBUG] 11:07:53: nodeId: 109 is master 711, has slave 713 - SculleryLights in Scullery.
[DEBUG] 11:07:53: nodeId: 110 is master 729, has slave 733 - Mirror in MainBedroom.
[DEBUG] 11:07:53: nodeId: 113 is master 742, has slave 744 - WalliTemp in MainBedroom.
[DEBUG] 11:07:53: nodeId: 114 is master 747, has slave 751 - StudyLights in Study.
[DEBUG] 11:07:53: nodeId: 117 is master 852, has slave 856 - TowelRail2 in MainBathroom.
[DEBUG] 11:07:53: nodeId: 120 is master 861, has slave 864 - BraaiDimmer in Braai.
[DEBUG] 11:07:53: nodeId: 121 is master 866, has slave 867 - SmokeMotion1 in Roof.
[DEBUG] 11:07:53: nodeId: 122 is master 871, has slave 872 - KitchenIslandBottom in Kitchen.
[DEBUG] 11:07:53: nodeId: 123 is master 885, has slave 886 - ROFilterFloodSensor in Kitchen.
[DEBUG] 11:07:53: nodeId: 124 is master 918, has slave 919 - FrontDoor in Entrance.
[DEBUG] 11:07:53: nodeId: 125 is master 925, has slave 929 - LoungePatioLights in Patio.
[DEBUG] 11:07:53: nodeId: 126 is master 931, has slave 932 - StudyMotion in Study.
[DEBUG] 11:07:53: nodeId: 127 is master 936, has slave 937 - FoyerMotion in Foyer.
[DEBUG] 11:07:53: nodeId: 128 is master 941, has slave 942 - FloodSense in Roof.
[DEBUG] 11:07:53: nodeId: 129 is master 945, has slave 946 - KitchenMotion in Kitchen.
[DEBUG] 11:07:53: nodeId: 130 is master 955, has slave 959 - KitchenLights in Kitchen.
Do you have any idea why z-range-analyzer is not showing this device and room?
Thank you
cag014
48 minutes ago, nicopret said:
Hi @cag014, I picked up an anomaly where one of my master switches (200: GuestDimSW in room Guest) which is an "important repeater" in my network is not listed in Parent-ID data in the z-range-analyzer report. The device is listed in the Last Route for several other devices.
As far as I see, it is listed
Spoiler
Do you have communication problems?  If so, may I suggest downloading AOS and run it as is. You don't need to use it to control or monitor your devices.
The reason, that AOS shows information if device has communication problems (NACK), not necessarily dead device.  You could be surprised how many devices are struggling to communicate with the controller and you don't know about it, because usually they do the job, and you think it works OK. Those NACks are bombarding Z-wave traffic and slowdown your controller.
Here an example of my system
Spoiler
Edited by cag014
nicopret
Thank you @cag014. I could not find it in the "Rooms summary" and then changed showDevices=true. I then obviously missed it in the Devices summary. Any reason why the "Guest Room" would not be listed in the Rooms summary?
Not at the moment. I randomly sometimes experienced some 503 errors more than a year ago before I recently decided to implement UHAS by@Sankotronic and then experienced some random 503 errors again during the last week or so. I then started to do more detailed troubleshooting with z-wave-analyzer and z-wave-monitor and identified errors in my mesh routing table. I resolved these and then further optimised the routing table. After the optimisation, the recent 503 errors are gone and my HC2 is significantly more responsive than before.
Thank you for your advice with AOS. I'll use it to do further fine tuning to ensure optimal performance of my HC2.
