Purpose
HC-WebEye is designed to enhance debugging for Fibaro smart home controllers (HC2 and HC3), especially when dealing with scenes that output HTML-formatted debug data.
Since HC3 no longer supports HTML in its debugger, this tool provides a full-screen alternative for better visibility and interaction.
5.23.1🔧 Key Features
Feature |
HC2 Support |
HC3 Support |
Notes |
Display scene debug info |
HC3 filters by tags/levels |
Start scene |
VD debug info & button press |
Global variable display |
QApp debug info |
Clears HC3 debugger window |
QApp variable display |
QApp toggle & button press |
Toggle switches ON/OFF |
5.23.2🌐 Browser Compatibility
Works with Firefox, Chrome, and Edge browsers
Requires CORS to be disabled (a separate script is provided for that)
Login Prompt You'll be asked to log in on first use. Credentials are not stored for security.
Interface Flow
Select controller (HC2 or HC3)
Choose item type (Scene, VD, Variable, QuickApp)
Pick specific item from list
Press Reload to fetch debug info
Optional: Check "debug" to view API commands
🧪 Interaction Examples
Scene selected → “Start” button appears
VD selected (HC2 only) → Button list + “Press” button
QuickApp selected (HC3 only) → Button list + “Press” and “Toggle” buttons
Variable selected → Current value displayed
If you're planning to use this with advanced scenes like the All-in-One Scene /QA or Z-wave monitor, this tool is practically essential for visibility and control.
Edited by cag014
What's New in Version 4.0 See changelog
🆕 Update: Multi‑Hub Support & Easier Editing
✨ New Features
Edge Browser Option Added
Script now runs smoothly on Microsoft Edge with full compatibility. -
Multiple Hubs Support
You can now define any number of hubs in the configuration. No need to modify the logic — just add them to the list. -
Simplified Hub Editor
At the beginning of the file, a clean configuration block lets you add or remove hubs quickly.
Example:
// ============= USER CONFIGURABLE PARAMETERS =============
const controllers = [
{label: "HC2",
hubType: "HC2",
local: "http://198.0.0.69",
remote: "https://home.fibaro.com/newProxyLite?XXX&req=" },
{label: "hc3-home",
hubType: "HC3",
local: "http://198.0.1.11",
remote: "https://home.fibaro.com/newPro },
// ============= DO NOT CHNAGE CODE BELOW =============
