    44 minutes ago, ChristianSogaard said:
    Hi Jan
    I seems that the ´;;´dont work - the two last lines only work when || value < 500 & value  line is hit
        || value < 500 & value > 225  >> extractor_step=4; extractor_light = 1;;
        post(#Extractor{step=extractor_step,light=extractor_light});
        log(extractor_step++' '++extractor_light);
    Try triple - ';;;'
    1 hour ago, jgab said:
    Try triple - ';;;'
    Tried - having same behavior. only running  last two lines when last line trigger, changed back to ;;
    I also looks like rule two only runs when light is 1
    Edited by ChristianSogaard
    P
    On 6/25/2021 at 11:36 AM, jgab said:
    Ok, they didn't exist as ER4 commands.
    I pushed v0.5fix62 with new commands:
    Bit unsure if you need to quote number values like '18' or it is ok with 18.
    You need to stringify 'Cool' etc as they are sent as strings. Without quotes, ER will interpret Cool as a variable (that is probably nil)
    For actions I don't support yet you can use the fibaro call in the rule...
    Ex.
    rule("trueFor(00:01:00,(PVFronius:value > 1000 & DanfosRSHolEtajTemp:value > 26)) => fibaro.call(ACScara,'setThermostatMode','Cool')")
    ...and then tell me to implement it as a :command.
    I still can not make it work fully ;(  Must be all the drinks i had in the weekend... or something
    The new commands work, so does the fibaro.call in rules.
    But i need to check if for example Fan was set on High or Mode is Off for the last 10 minutes.
    Something like :
    rule("trueFor(00:10:00,(PVFronius:value > 1000 & DanfosRSHolEtajTemp:value > 24 & ACScara:thermostatMode='Off')) => log('test OK')")
    Must be something easy which i am overlooking.
    Thank you for help :)
    Jan since short time I have some difficulties with my arming scene.
    After some long investigation I see that the trigger is not working in one QA (1306).
    If I copy the debug to the other (1306) scene it does not show the change of state see debug
    QA1305 is the originator if hoofdslaapkamer.laders:isOn it generate a post and remote (#opStaan) and the same for (#bedTime)
    BUT;
    The remote (#opStaan) and (#bedTime) are comming trough.
    If I copy Event Runner page from 1305 to 1306 the editor show its the same, save is not blue
    Any idea?
    //Sjakie
    BUT;
    Any idea?
    //Sjakie
    HI @Sjakie - did you put alarm into the self:enableTriggerType({"device","global-variable","custom-event","profile","alarm", "sceneEvent" }) ?
    Hello Cristian,
    No I did not.
    The alarm was working perfect except I wanted to recieve only one message independant wich partiton, I have9, is/will be armed/disarmed.
    So my gues is I dont need to do that orsomething is/has changed in ER? Jan did you changed something?
    I can not restore back totest do to renaming/numbering all partitions and all equipment in alarmsystem.
    The missing messages are reverting back to the trigger mentioned in previous post.
    Thanks for your remark,
    Jan
    In this QA time rules does  notwork either, I am on fix 62
    //Sjakie
    I have no clue at all what is happening but now its working again!!!!!!!!!!!
    //Sjakie
    //Sjakie
    behind the scenes Jgab Magic what else :)
    Hahaha yep great service from Jan!
    Jan,
    I am playing with some dates and time I want every even week number a message but also a start weeknumber if possible?
    Here I do something wrong.
    Please advice,
    //Sjakie
    Jan,
    wnum % 2 == 0 & wnum >= 20 & wnum <= 40
    Even weeks between week 20 and 40
    Please advice,
    //Sjakie
    Time needs @ and is only 24h
    rule(“@11:20 & day(‘29’) & month(‘6’) => ….
    On 6/27/2021 at 11:23 AM, ChristianSogaard said:
    Hi Jan
    Hi @jgab - any thoughts what i can try, now where ;; and ;:; if not working as delimiter for the "|| value" statements ?
    Jan, thanks for the answer on my two questions.
    I started again with ICAL V01  it will shows my calender items in edit preview window
    When I use the version V09 i see no items in the preview window???
    Besides that it will give in trace:
    If I create a second calender it will crash both Ical QA's
    Please advice,
    //Sjakie
    Sorry, it's a bug in the script compiler - will look at it during the weekend.
    (It's strange as it has passed tests  in the past)
    Please advice,
    //Sjakie
    I don't actively support the iCAL QA as I don't use it myself. I may have a look this weekend.
    Something like :
    Please please @jgab tell me what can i do ?   I tried everything i could think about...
    Hi Momos,
    If your value >1000 is Watt you need to use power
    give it a try,
    tip:
    break rule in pieces and see where it goes wrong
    //Sjakie
    here with other devices it works
    The problem is with the thermostats:
    This is where the rule breaks.
    Ex.
    this:)
    Yes, to test a property you need to use '==' like in Lua
    If you only use '=' it is interpreted as an assignment.
    1 hour ago, Momos said:
    this:)
    These functions are in 0.5,fix62
    <ID>:thermostatSetpoint=<val>
    <ID>:setThermostatMode=<val>
    <ID>:setCoolingThermostatSetpoint=<val>
    <ID>:setThermostatFanMode=<val>
    what functions are you missing still missing?
    Hi, the || >> is fixed now. Pushed 0.5fix63
    Note that you need to use ;; the end the ||>> sequence.
    Because the actions to the right of the >> can be a sequence of statements separated by ';'.
    Therefore the compiler needs a double ';;' to signal that the sequence has ended.
    Ex.
