The functions
<ID>:thermostatSetpoint=<val>
<ID>:setThermostatMode=<val>
<ID>:setCoolingThermostatSetpoint=<val>
<ID>:setThermostatFanMode=<val>
work very well.  But these are for the action side of the rule.
I am trying to check if the AC is off for X minutes or if the Fan is set to High for example with a rule like:
rule("trueFor(00:01:00,(ACScara:thermostatMode=='Off')) => log('test OK')")
or
rule("trueFor(00:01:00,(ACScara:thermostatFanMode=='High')) => log('test OK')")
and the error i get is :
[01.07.2021] [18:03:24] [ERROR] [QUICKAPP1312]: Error in 'trueFor(00:01:00,(ACScara:thermostatMode=='Off')) => log('test OK')': ./include/EventRunner.lua:1996: attempt to index a nil value (field '?')[01.07.2021] [18:03:24] [ERROR] [QUICKAPP1312]: main() error:./include/EventRunner.lua:2308: Main() ERROR:./include/EventRunner.lua:2143: ./include/EventRunner.lua:1996: attempt to index a nil value (field '?')
I have no idea why, but my guess is that it does not see this device interfaces.
The swagger for this device is:
    14 hours ago, Momos said:
    The functions
    or
    v0.5fix64 pushed.
    The set functions (actions) are now
    Note that I removed the prefix "set" from some of the functions - cleaner this way.
    Access functions that are available now (yes, there was a bug)
    @jgab  Thank you very much :)
    unfortunatelly still does not work. I have updated to latest version
    My rules are
    and the log:
    Simple test rules, rule 8 triggers, rules 9 and 10 do not do anything.
    Thank you again ?
    My rules are
    and the log:
    Thank you again ?
    Rule 10 seems to not be compiled and is thus not installed.
    Check if you have some invisible characters around the "=>". Rule 9 compiles and I copied both rules to my emulator and they compile there too.
    So I did some tests with a false thermostat QA and it works quite well for me.
    Note that rules are only triggered when the thermostat change the property value that you use in the test.
    A "trueFor" rule will not start to watch the property until the property changes value.
    However, you can force the rule to run when it is defined by adding .start()
    Ex.
    rule("trueFor(00:01:00,(ACScara:thermostatMode=='Off')) => log('test 2 OK')").start()
    rule("trueFor(00:01:00,(ACScara:thermostatFanMode=='High')) => log('test 3 OK')").start()
    That causes the rule to be triggered when the QA starts up and if the ACScara:thermostatMode is 'Off' the trueFor will start monitoring the property. Note that the time is measured from when the rule triggers so if the thermostatMode property has been off for a long time it only counts from when it is triggered.
    rule("trueFor(00:30,(3:alarm.armed == false) => 2:msg=log('Alarm dismarmed for 30 minutes    '); again()").start()
    What should be the correct syntax for the above rule? Is it even possible to use "trueFor" to check how long the alarm is disarmed?
    Jan,
    In Children of HUE (I have V1.17) I dont hope I missed a version?
    I still have screen full of see below and my CPU has an extra load of 30%
    CAn you fix or do I need  something to change?
    I want to use the option Lights off/on
    Thanks for your service and time,
    //Sjakie
    Well, use the property :armed directly on the partition
    11 minutes ago, Sjakie said:
    Jan,
    //Sjakie
    In main() do
    Jan
    [02.07.2021] [12:44:21] [ERROR] [QUICKAPP1498]: main.lua:23: attempt to index a nil value (global 'self')
    1 minute ago, Sjakie said:
    Jan
    You need to do it inside function QuickApp:main() where you have your rules
    Jan excuse me
    QA 1498 is Children of Hue
    the error is from 1498 so I added in main QA 1498 line 23 >>
    I dont have rules in Children of HUE
    If I add in QA where HUE is used error in 1498 stays
    On 7/2/2021 at 12:50 PM, Sjakie said:
    Jan excuse me
    ChildrenOfHue is not ER so this is the wrong thread...
    Anyway, here is 1.19 that turns of propwarn and with new btn handlers
    Sorry Jan to post in wrong topic.
    Thanks error is not showing anymore.
    Children of HUE V1.18
    Lights off>>works
    Lights On >> Nothing happens
    //Sjakie
    How does the rule look like where you do On ?
    Jan, in Edit/Preview we have buttons
    Lights On>>> press>>>action is called  in Debug nothing.
    If I switch some HUE lights on and push Lights Off >>>all lights switch off
    //Sjakie
    //Sjakie
    Ok, I have never used that button :-) Sure you want to turn on all lights?
    Anyway, that button was configured wrong.
    If you go into the QA editor and press the 'Lights On' button you see that the 'onReleased' field says 'allLightsOffClicked'
    Change that to 'allLightsOnClicked'
    Jan,
    Yes I want all lights on >>> if alarm=true
    Shoot me
    If I change>>save >>push Lights Off>>>push Lights On>>>it will show again old value!
    In control:
    allLightsOn>>>>>must be On too I asume? Doest matter in both cases it happens
    Lights On
    allLightsOnClicked
    /monthly_2021_07/afbeelding.png.47ccc83a0528fd65d96ca8aef7a85ec1.png" />
    2 minutes ago, Sjakie said:
    Jan,
    Shoot me
    In control:
    Lights On
    allLightsOnClicked
    allLightsOnClicked
    with a capital 'C'.
    Yes, and press save.
    sorry had allready C
    its saved but lights doest switch on or off now
