Jan,
If I check HC3 I see the same (this is myLog)
/monthly_2021_05/afbeelding.png.428af2d921af69086ec2c884fe000746.png" />
    36 minutes ago, Sjakie said:
    Jan,
    It needs to pass the extra arguments to the function
    jan
    I don't think the profile is working
    rule ("@@00:01 => 1:profile=true ")
    [27.05.2021] [22:56:54] [[31;1mERROR[0m] [QUICKAPP1965]: in Rule:2[@@00:01 => 1:profile=true ]: {"msg":"Error executing instruction:'["%setprop",1,[true],["profile"]]'","ERR":true,"err":"[string "EventRunner4Engine.lua"]:1623: Wrong parameter type, number required. Provided param 'activateProfile' is type of string","src":"Rule:2[@@00:01 => 1:profile=true ]"}
    1 hour ago, minsad79 said:
    jan
    I think. it was fibaroapiHC3.lua. that was buggy.
    fibaro.profile have it's argument swapped between Scenes and QAs...
    I pushed. .308 with a fix.
    thanks
    It works
    Hi, is it possible to send critical alert from ER4 to phone? For example for alarm breach?
    @michal85pl,
    PhoneID is working for me 9126), userID not.
    For incase Fibaro mess it up I also use Telegram msg
    Succes
    //Sjakie
    You mean catching alarm breach and send a push to the phone?
    ...or picking up any critical alert in the notification center and push it to the phone?
    Catching alarms I showed in an earlier post. If that's it I can repost if you want.
    If it's catching all critical then
    ...when notifications are created one can catch that event in ER4
    The m.data is a table with title, text etc.
    2 godziny temu, Sjakie napisał:
    @michal85pl,
    Succes
    //Sjakie
    I meant the push to the phone, which will bypass silencing the ringer and the do not disturb mode, so that I would be woken up by it in the event of a violation of the alarm, and not find out about it in the morning after waking up :) something like this is described here, but I do not know where and how to implement it with android -
    Well, unless you have another idea to solve this problem?
    Nope, I don't know how to generate a "critical" push. I suspect that it's something that is hidden by Fibaro and only used for some devices notifications....
    Jan,
    how to locate where this error is?
    [31.05.2021] [00:00:00] [ERROR] [QUICKAPP1301]: in Event({"type":"%MIDNIGHT"}) => ..: ./include/EventRunner.lua:2178: bad argument #2 to 'date' (number has no integer representation)
    Please advice,
    //Sjakie
    11 minutes ago, Sjakie said:
    Jan,
    Please advice,
    //Sjakie
    Pushed fix59 that fixes that bug.
    @jgab
    in newest version I have this error (I didn't do any changes):
    in Rule:48[trueFor(timeLightsOff,Satna.PohybSatna:isOff & _roomSatnaManual==0) => SwitchOff...]: {"msg":"Error executing instruction:'["SwitchOffL",1]'","ERR":true,"err":"./include/main.lua:76: attempt to perform arithmetic on a nil value","src":"Rule:48[trueFor(timeLightsOff,Satna.PohybSatna:isOff & _roomSatnaManual==0) => SwitchOff...]"}
    in this rule:
    It looks that error appeared a few version ago.
    33 minutes ago, petrkl12 said:
    @jgab
    in this rule:
    It looks like the SwitchOffL function crashes.
    The line
    main.lua:76
    refers to the main file in the QA with the rules.
    Is line 76 pointing into SwitchOffL and in that case what is the lua code in that line?
    thanks, solved
    Thanks Jan for fix 59
    //Sjakie
    Jan,
    How to get in my QA a debug log of wich fix  number is the present one?
    Can you advice me something?
    Thanks for your time,
    //Sjakie
    1 hour ago, Sjakie said:
    Jan,
    //Sjakie
    Lua global E_VERSION and E_FIX
    rule("log('Current version is %s - %s',E_VERSION,E_FIX)")
    Thanks!!!
    //Sjakie
    Jan,
    I made a typo in date no error in debug, perhaps for a next update?
    /05/161/00:00
