10 minutes ago, jgab said:
Yes, the issue was that my parser was too strict and considered a semicolon at the end of a || >> ...;
to be an error. (It is unnecessary)
Yes, that was what I did. I took 49 and called it 51 so you could "upgrade" to a functioning version.
I found out. I was because the update rules where in the buttom of the rules
these
and because of the other error you mentioned . it didnt update
    these
    Yes, my thinking is that I will download the beta versions of the QA files (if any) and store them in the same ER QA together with the "stable" files.
    Then a quickAppVariable that is set to either 'stable' or 'beta' will select what version of files are used when restarting the QA.
    Then when no one complains about the beta I will upgrade the stable to the beta.
    This way it is easy to try out the beta and revert if it fails,
    This was confusing me but I managed all QA's without error
    //Sjakie
    //Sjakie
    v51 will give you the MIDNIGHT event error again. Fix tomorrow in v52
    I will stay on the old 50 no problem all is working.
    //Sjakie
    Jan, how to start a rule with,
    Thanks,
    //Sjakie
    Thanks,
    //Sjakie
    You can't.
    The @rule is only 24hours.
    You test every day at 12:18 if it's the right date.
    Rule.eval("@12:18 & day('5') & month('10') => ....
    Great Jan Thanks!
    On 1/8/2021 at 12:18 PM, jgab said:
    Ok, I think this will work...
    Here is a shortcut that I have done on my iPhone.
    If you in settings->shortcuts has checked allow untrusted shortcuts it should be possible to click on the link from your iPhone and import the shortcut.
    When the shortcut is imported open it and edit it.
    First the URL, It should be:
    http://<Your HC3IP>/api/devices/<ER4 QA ID>/action/RECIEVE_EVENT
    Then open "Show more" and change the Authorization header to your own credentials. (base64 encoded)
    Then go down to Request body and open the 'args' items
    Open the next level, and then the next again (the 'ev' key)
    The last level says
    'type'     'test'
    When I click on the shortcut it sends an event to my ER4 QA that I can pick up easily
    rule("#test => lights:off")
    It only works when my iPhone is on the local network, but its is convenient way to talk to ER4 without needing to go through other services or QAs...
    Hi Jan.
    Is is possible to do the same not using IOS? - have a button on a website that can trigger a switch? or should that be done through the FIBARO Assistant Integrations?
    11 hours ago, ChristianSogaard said:
    Hi Jan.
    You can always call the HC3 REST API and send an "event" to a ERR4 QA. The trick is how you can access the HC3 if it doesn't sit on the same network.
    The iOS shortcut only work if the iPhone/Mac sits on the same network as the HC3. It doesn't work if your iPhone is outside the home. It relies on the fact that it can call an URL that points to the HC3.
    To send an event {type="test", val=42} to ER4 with deviceID 53
    and it can be triggered with the rule
    Note that the event needs to be stuffed inside an event (x), it's kind of a bug that I will fix in the future.
    Thanz Jan :-) was more into from a webpage on the Internet.
    Jan,
    Question about devices.
    Fa my curtain has two positions open or close. I dont use any position in between.
    At the moment I will close the curtain it immediatley show position as closed, practically its still closing. In my opinion it should report close as it is closed!
    Is this also for all devices?
    Thanks in advance,
    //Sjakie
    52 minutes ago, Sjakie said:
    Jan,
    Thanks in advance,
    //Sjakie
    I don't have any device of that kind so I'm a bit unsure how it reacts.
    What value does it report when closed? and when fully opened? (device:value)
    device:isOpen is true for every value > 0.
    device:isClosed is true for value == 0
    It may work to test against 99 (if it's 99 when fully opened)
    i mean - from a website at the INternet. Outside your home. Can you integrate something at an internet website, using the same integration as google Home, Alexa?
    Jan, yes I use value but it still stay the same.
    If value becomes smaller than 99 it will change state instead of waiting till 0 is the new value.
    ok for my log I use 99 and 0 but that is not as I thought it supposed to be.
    But I guess it will be Fibaro setting.
    //Sjakie
    Jan, Question about HC2
    My daughter wants some home protection there for she takes my HC2.
    I am "in charge" of setting it up for her.
    I have from you the empty mail box rule.
    Can I extend it with automatic restart HC2?
    Thnaks in advance,
    //Sjakie
    Jan,
    I have  a problem again.
    Curtains operating for months without any problem today curtain (gorijnOpRit) did not close.
    According debug the command was given. The curtain was just a tad not complete open I dont know if HC3 started to close for  a part of a second???
    The Rule is:
    I added to prevent again malfunction      wait(00:00:05); woonKamer.gordijnOpRit:close;
    Any idea what I can improve or is this Fibaro? This happends also a few days ago with a HUE light
    Thanks,
    //Sjakie
    Jan, problem HC2 Aeotex doorbell. This work, debug show deurbel - belt
    This does not work
    hal.deurBell is in properties as 1311 value
    Any hint?
    //Sjakie
    I'm new to ER4 and I'm sure to be asking stupid questions. I have a few time rules
    that work.
    What is the difference between rule() and Rule.eval()?
    And why does this rule not work: Rule.eval([[RainSensor:value == true & Markise < 99 => fibaro.call(Markise,'setValue',99)]])
    Thanks for hints.
    that work.
    They are the same function. In the old ER for HC2 it was Rule.eval() and sometimes redefined as just rule()
    In ER4 I have defined Rule.eval to be backward compatible, but I would recommend to just use rule (shorter to write).
    You can see that in the beginning of ER4's main() that it is defined as
    local rule = function(...) return self:evalScript(...) end
    Thanks for hints.
    When you test Markise value, you need to get it's value property.
    To set the value of Markise you can do
    I'm happy to answer basic/easy questions - they are the best - so keep them coming :-)
    This does not work
    Any hint?
    //Sjakie
    Because you are missing a '=>' ?
