    The --FILE: directive has to start at the beginning of the line
    It seems like
     --FILE:EventRunner4Engine.lua,EventRunner;
    is  one space indented...? Because if so it is not included and you will not have any _debugFlags
    It seems like
    if dofile and not hc3_emulator then
      hc3_emulator = {
        credentials = { ip = "12.10.79.127", user = "minsad79",  pwd = "12345" },
        name="ER4_simulator",
        type="com.fibaro.genericDevice",
        --startTime="10:00:00 5/12/2020",
        --speed = 48,
        id=1563,
        --deploy=true,
        --proxy=true,
        --offline=true,
        debug = {trigger=false},
        UI = {
          {label='ERname',text="..."},
          {button='debugTriggers', text='Triggers:ON'},
          {button='debugPost', text='Post:ON'},
          {button='debugRules', text='Rules:ON'},
          {{button='Update', text='Update'},{button='restart', text='restart'}}
        --dofile("fibaroapiHC3_classic.lua")
      dofile("fibaroapiHC3.lua")
    --FILE:Toolbox/Toolbox_basic.lua,Toolbox;
    --FILE:Toolbox/Toolbox_events.lua,Toolbox_events;
    --FILE:Toolbox/Toolbox_child.lua,Toolbox_child;
    --FILE:Toolbox/Toolbox_triggers.lua,Toolbox_triggers;
    --FILE:Toolbox/Toolbox_files.lua,Toolbox_files;
    --FILE:Toolbox/Toolbox_rpc.lua,Toolbox_rpc;
    --FILE:Toolbox/Toolbox_pubsub.lua,Toolbox_pubsub;
    --FILE:EventRunnerDoc.lua,EventRunnerDoc;
    --FILE:Toolbox/Toolbox_profiler.lua,Toolbox_profiler;
    hc3_emulator.backup{
      type="*",
      dir="E:/DS_Drive/EventRunner/HC3/Backup(HC3)",
      namer = function(struct,name)
       local type = hc3_emulator.file.isType(struct) -- Returns "QA" for QAs and "Scene" for Scenes
        name = name..os.date(" %c",struct.modified or struct.updated)
        name = ""..struct.id.."_"..name:gsub("[^%w]","_")
        return type,name
      end,
    ----------- Code -----------------------------------------------------------
    _debugFlags.trigger = false -- log incoming triggers
    _debugFlags.fcall=false     -- log fibaro.call
    _debugFlags.post = false    -- log internal posts
    _debugFlags.rule=false      -- log rules being invoked (true or false)
    _debugFlags.ruleTrue=true  -- log only rules that are true
    _debugFlags.pubsub=true    -- log only rules that are true
    ------------- Put your rules inside QuickApp:main() -------------------
    function QuickApp:main()    -- EventScript version
      local rule = function(...) return self:evalScript(...) end          -- old rule function
      self._UNHANDLED_EVENTS = true
      self:enableTriggerType({"device","global-variable","custom-event","profile","alarm","location"}) -- types of events we want
      --DOWNLOADSOURCE()
    HT = fibaro.getGlobalVariable("HT")
    HT = json.decode(HT)
    Edited by minsad79
    8 minutes ago, jgab said:
    jgab
    Question again
    er4, er-test
    I use two er, but
    The emulator startup syntax is the same
    Only the name is different
    er4 works normally
    er-test is an error
    is
    What is the problem?
    12 minutes ago, minsad79 said:
    jgab
    Question again
    er4, er-test
    I use two er, but
    er4 works normally
    er-test is an error
    is
    QA name, or file name?
    What is the error?
    I load
    without problem
    What is the error?
     name="ER4_TEST"
     name="EventRunner4"
    QA name
    The rest is the same
    EventRunner4 => No error
    ER4_TEST => error
    Below error
    [01.04.2021] [00:03:25] |[35mSYS  [0m|: HC3 SDK v0.200
    [01.04.2021] [00:03:25] |[35mSYS  [0m|: Created Event server at 79.10.79.3:6872
    [01.04.2021] [00:03:25] |[35mSYS  [0m|: Created Terminal server at 79.10.79.3:6972
    [01.04.2021] [00:03:25] |[34mLOG  [0m|: Polling HC3 for triggers every 1000ms
    fibaroapiHC3.lua:4252: [string "if dofile and not hc3_emulator then
    ..."]:58: attempt to index a nil value (global '_debugFlags') (coroutine: thread: 0x7f8764596678, socket: tcp{client}: 0x7f8764847428)
    stack traceback:
        [C]: in function 'error'
        fibaroapiHC3.lua:4252: in field 'loadQA'
        fibaroapiHC3.lua:8588: in upvalue 'startEmulator'
        fibaroapiHC3.lua:8612: in upvalue 'f'
        fibaroapiHC3.lua:3439: in method 'callback'
        fibaroapiHC3.lua:2570: in function <fibaroapiHC3.lua:2566>
        (...tail calls...)
    Edited by minsad79
    Add debug.files=true
    and make sure that it load Toolbox. That's where _debugFlags are defined.
    Another thing.
    The emulator needs to parse the header of the file and find if there is a
    This means that the "if dofile ..." needs to start the line with no space before.
    ...and the 'end' needs to be on a single line with no space before. If you have any 'end' inside the header it needs to be indented at least one space.
    The regex I use to find the header is "if%s+dofile.-[\n\r]end"
    It looks like it misses the 'end' in the header and finds an 'end' later in the file - after the body (ex. _debugFlags)
    I will see if I can make the header matching better at reporting "errors".
    Btw what line is 4252 in your emulator file?
    Is it
    20 minutes ago, jgab said:
    Another thing.
    I think I found the error part with this advice.
    Multi er finally started working
    Always your advice is best
    So, requiring the 'end' to start the line may not be good and it's easy to make a mistake and not see it.
    I'm thinking of requiring  the last 'end' to be on the format
    I.e. requiring a '--hc3_emulator' after 'end' to signal that it's the correct end.
    there is a temperature sensor in the implant. And sometimes it happens that the implant gets used tightly and does not send any data, although as if in z-wave it is ...
    I came up with an idea: make a rule -> if the data (temperature in this case) has not changed for 12 hours, then send a message such as ATTENTION ATTENTION
    jgab wrote me the following code:
    Util.defTriggerVar ("tempWatch")
    rule ("temp: value => tempWatch = false; tempWatch = true"). start ()
    rule ("trueFor (12:00, tempWatch) => log ('ALERT')")
    But this rule does not work ... I just received messages that the temperature has not changed for 12 hours ... I went to
     internal graph for this thermometer and I see that the data actually changed.
    my rules:
    temp_R1 = 1102 - temperature in the refrigerator-1
    temp_R2 = 1103 - temperature in the refrigerator-2
    --6.2) Sweep the temperature and the implant for the refrigerator-1 does not freeze
    Util.defTriggerVar ("tempWatch_R1")
    rule ("temp_R1: value => tempWatch_R1 = false; tempWatch_R1 = true"). start ()
    rule ("trueFor (12:00, tempWatch_R1) => teleg_x2: email = log ('CONTROL: the temperature in refrigerator-1 has not changed for 12 years, the implant' hangs melodiously")
    --6.3) Sweep the temperature and the implant for the refrigerator-2 does not freeze
    Util.defTriggerVar ("tempWatch_R2")
    rule ("temp_R2: value => tempWatch_R2 = false; tempWatch_R2 = true"). start ()
    rule ("trueFor (12:00, tempWatch_R2) => teleg_x2: email = log ('CONTROL: the temperature in refrigerator-2 has not changed for 12 years, the implant' hangs melodiously"
    what am I doing wrong?
    my rules:
    Change the rule to
    rule ("temp_R1: value => log('Temp_R1 changed value to %s',temp_R1: value); tempWatch_R1 = false; tempWatch_R1 = true"). start ()
    If you get  log that "Temp_R1 changed value to ..." and the rest of the rules haven't triggered then we get some clues.
    If you don't get a log then there is an issue with the trigger.
    If you do can there be an issue with the send email?
    There are definitely no problems with mail, as it monitors many other processes in the ER through mail, or rather a telegram bot that works through mail.
    Email from the HC3 or email from Telegram? The former is a bit on and off...
    Anyway, to debug the logic you should add the log statement to the rule as described in the previous post.
    If the ER rule logs that the value changes, and then it doesn't notify you after 12 hours there is a problem with the ER rule and lets discuss it.
    If not, the HC3 doesn't react on the changed value in the correct way.
    Another thought,. 12 hours is a long time. If you restart the QA in-between  the 12 hour period will be reset. The QA needs to run continuously for the 12 hour period to trigger.
    To get around that the rule that react on the change can store the value in a quickVar or fibaro global so it survives a restart.
    you didn't understand me..it's not that the data didn't really change, but the rule didn't tell us ... just the opposite: the data changed, it's visible on the graph, but why did the rule say that the temperature didn't change ...
    I use telegram through a bot which is described in this link ... but once again: here a problem not in mail and the telegram .... I see logging.
    Ok, so if you have modified the rule to
    You would get a log "Temp_R1 changed"... when the value changes. If the other rule doesn't fire after 12hours it a problem with that rule. If it fires and logs "'CONTROL: the temperature ... " we know there is a problem with the email.
    Looking at this rule again, there are some problem with it - it is not terminated correctly (you are mixing up single and double quotes)
    It should look like
    ...that could explain your issues.
    Jan,
    What is the correct notation for:
    Thanks in advance,
    //Sjakie
    On 17.04.2021 at 17:51, jgab said:
    Итак, если вы изменили правило на
    Вы получите журнал «Temp_R1 changed» ... когда значение изменится. Если другое правило не срабатывает через 12 часов, проблема с этим правилом. Если он срабатывает и регистрирует «КОНТРОЛЬ: температура ...», мы знаем, что возникла проблема с электронной почтой.
    Еще раз посмотрев на это правило, вы обнаружите некоторую проблему - оно не завершается правильно (вы смешиваете одинарные и двойные кавычки)
    Это должно выглядеть так
    ... это могло бы объяснить ваши проблемы.
    did not understand where I confuse quotes?
    If you look at this rule you gave, it ends in a double quote.
    But its part of a
    so it should end in
    and remove the single quote in
    Jan,
    This combination of rules doest work properly. Curtain closes immeadiatly after start to open
    I need to add 30 seconds for open the curtain. Is this correct?
    How to adapt month in dates  ('04/14-10/31') or (04/10-10/31)
