10 hours ago, jgab said:
ZBS Menu->Project->Lua Interpreter->Lua 5.3
Thank you. So much.!!
Hi
I still get the error.
    2 hours ago, Earybeongbeong7 said:
    Hi
    Sorry, it was a stupid error introduced in v.198, It's been fixed in v.199 that's been out for 16 hours :-)
    OMG.
    48 minutes ago, Earybeongbeong7 said:
    OMG.
    What line in the log shows the error?
    ER4 restarts continuously as this log comes out.
    Edited by Earybeongbeong7
    That's just warnings that some timers are a bit late, and don't cause restart of the QA.
    You can turn it off with
    if dofile ....
       hc3_emulator = {
          debug = { timersWarn=false }
    I see that you restart the QA because of HT being updated. The plugin.restart() code is a bit experimental and can be the cause of this behaviour. I will test and see if I can reproduce it.
    if dofile ....
       hc3_emulator = {
    Well, ER4 behaves well when restarting.
    To restart a QA in the emulator is quite an "involved" procedure that is initiated with plugin.restart().
    There is no way the QA can spontaneously restart because some timer crashed (the behaviour that the QA restarts on crash like it does on the HC3 is not implemented in the emulator)
    ...so my point is that I think you have a ER rule that repeatedly calls plugin.restart().
    Is there something with the HT changed rule that triggers at every restart?
    How does the HT changed rule look like?
    Currently, the following TEST is being used by ZBS.
    It works fine in 0.158 version, but ER4 restarts continuously in 0.199 version.
    but what rule is logging this
    It works fine for 0.158 version.
    Yes, but plugin.restart was not implemented in v.158 (did nothing) but is implemented in v.199
    So how does the HT changed rule look like?
    Sorry. That's my big mistake.
    I thought there was no problem with the test rule because it could not be rerun in version 0.158.
    In the rule I wrote, there was something like the following.
    I am really sorry.
    I am really sorry.
    Well, now we know that plugin.restart() works in the emulator for you too :-)
    Jan,
    Something changed? Last Telegram 27 February
    {"ERR":true,"err":".\/include\/EventRunner.lua:1856: attempting to index non table with key:'msg'","msg":"Error executing instruction:'[\"%aref\",1,\"msg\"]'","src":"Rule:7[@08:17 =>...]"}
    <Telegram.msg(TID,'Let Op; Voordeur open positie slot - open{DAG}');>
    Please advice,
    //Sjakie
    HC3 or HC2? Who’s Telegram funktion?
    Jan,
    HC3, my HC2 is in a box.
    Telegram QA created by 10@der I believe, I will send by PM.
    It was working for a while but now the push messages admin doest work I noticed I dont get Telegram either.
    Note push message to another user are working strange.
    //Sjakie
    1 hour ago, Sjakie said:
    Jan,
    //Sjakie
    But calling another QA looks like
    fibaro.call(ID,"sendTelegram",...)
    or similar.
    You call something that looks like Telegram.send(....
    in your rule.
    Who defined that Telegram.send function?
    or similar.
    in your rule.
    Anything that looks like Telegram.send
    makes ER expect that Telegram is a table with a key 'send' that is assigned a function it can call
    Jan,
    Thanks! In 99/100 I get my advice from you>> much appriciated!!
    No idea from who. perhaps my initiative, but thanks its working again.
    Have a nice weekend,
    //Sjakie
    Hi - I´m trying to read my Netatmo Co2 sensor
    The trigger look like this - Incoming trigger:{"id":521,"value":862,"type":"device","property":"value","old":891.0}
    I tried several syntax with no luck. i could use some help
