Jan,
Happenly I am complete on HC3, thanks to your coaching and service excellence.
Sorry to be not clear but I was fighting with some  exceptional arming stuff. I have fixed that in the arming scene to split some arming rules and add a few others but to check in debug for testing I like to see wich devices are armed/safe to see if I did the job well.
Therefor I used the #sensorlist from HC2to see what I want but thats didt work.
Thanks for your time,
//Sjakie
Hi
Is there a way to trigger on power change and do rules like this ?
    1 hour ago, ChristianSogaard said:
    Hi
    Yes, but you need to set a variable to Kokken.Emhatte:power or repeat it in every test...
    13 hours ago, jgab said:
    and see if it reports 'Manual' or 'Script' when. you flip the switch manual
    It reports nothing when I manually toggle the switch (it's a momentary switch), but it reports "script" when motion sensor is breached.
    It's like if the fibaro dimmer was not catching on the manual switching. Yet, it effectively turns off the light...
    Apart from that, I observed 2 errors today in the logs:
    It's not a systematic error for rules 25 and 87, they seems to work ok most of the time. Dunno what happened at that particular moment.. If any idea, welcome!
    Please post complete rules. You can't do lightPlafSalon:value:isOn
    :value returns the value property and :isOn returns true/false if device is considered 'on'
    Jan,
    What is wrong?
    <Rule.eval([[@08:59 =>   log('AANWEZIGSENSORS'); for id,_ in pairs(aanwezigSensors) do log('%s = %s, %s',idname(id),id:safe 'breached'end;  ]])>
    error:
    {"err":".\/include\/Toolbox.lua:210: bad argument #4 to 'format' (no value)","msg":"Error executing instruction:'[\"log\",3]'","src":"Rule:96[@08:59 =>...]","ERR":true}
    Thanks,
    //Sjakie
    Here is the complete rule. For the moment I disabled the 'Evening' execution
    My bad, I corrected it now, thanks!
    3 minutes ago, Sjakie said:
    Jan,
    What is wrong?
    error:
    Thanks,
    //Sjakie
    Missing a comma after id:safe ?
    Just for the sake of clarity: what I would like to achieve is that if someone manually switch OFF the lightPlafSaM, then I want to avoid that the motions:breached puts in ON again 1 second later
    many thanks!
    It may be that the device doesn't update last correctly - can you try the below debug rules?
    Another question: how can I formulate the rule below to state that $DayTime IS NOT EQUAL TO 'Day'?
    Should I do that?
    rule("DoorHallNuitDN:breached & 06:45..09:30 & $DayTime != 'Day' => $DayTime='Morning'")
    Sorry, it's really a basic question, but I cannot manage to make it work..
    Thks!
    Jan,
    thanks its working but I want
    <Rule.eval([[@09:49 =>log('AFWEZIGSENSORS'); for id,_ in pairs(afwezigSensors) do log('%s = %s, %s',idname(id),id:safe, 'safe' |'breached'end  ]])>
    output:
    [18.02.2021] [09:57:30] [TRACE] [QUICKAPP802]: hoofdSlaapKamer.deur = false, safe
    desired:
    [18.02.2021] [09:57:30] [TRACE] [QUICKAPP802]: hoofdSlaapKamer.deur = breached
    Thanks in advance,
    //Sjakie
    Should I do that?
    Thks!
    rule("DoorHallNuitDN:breached & 06:45..09:30 & $DayTime ~= 'Day' => $DayTime='Morning'")
    rule("DoorHallNuitDN:breached & 06:45..09:30 & !($DayTime == 'Day') => $DayTime='Morning'")
    59 minutes ago, Sjakie said:
    Jan,
    output:
    desired:
    Thanks in advance,
    //Sjakie
    Rule.eval([[@09:49 =>log('AFWEZIGSENSORS'); for id,_ in pairs(afwezigSensors) do log('%s = %s, %s',idname(id),id:safe & 'safe' |'breached'end  ]])
    OK so now for the code
    I get the debug:
    And some debug of this morning:
    Code for rule 87 is
    Code for rule 87 is
    Well, somehow you 'DoorHallNuitDN' is set to nil or you use the wrong name.
    Try
    rule("log('Start DoorHallNuitDN = %',DoorHallNuitDN | 'nil' )") -- Check at startup
    rule("log('Rule DoorHallNuitDN = %',DoorHallNuitDN | 'nil' ) & once(DoorHallNuitDN:breached) & 06:45..09:30 & $DayTime ~= 'Day' => $DayTime='Morning'") -- Check when rule runs
    Ok, indeed I made a mistake with a capital "D" in some places. Solved and now it works, thanks!
    For the other rules (using the button pushed), will try again tonight and see. According to the logs gathered following your suggestion, it seems to me that it should work...
    we'll see
    thanks again,
    Jan, a problem with remote
    [21.02.2021] [00:22:08] [DEBUG] [QUICKAPP797]: fibaro.call(796,"RECIEVE_EVENT",{"type":"EVENT","ev":{"type":"bedTijd","_time":1613863328,"_from":797}}) => nil
    [21.02.2021] [00:20:53] [DEBUG] [QUICKAPP796]: fibaro.call(787,"turnOff") => nil
    [21.02.2021] [00:22:10] [DEBUG] [QUICKAPP796]: [{"type":"stekkersOff"}]>>'Rule:29[#stekkersOff  =>...]'
    "bedTijd" ist recieved by QA796
    "stekkersoff"came trough
    Please advice,
    //Sjakie
    Jan, please diregard I found my mistake.
    //Sjkaie
    Jan,
    -Is ER capable to let say report every hour the memory usage?
    I saw it is much higher as before, I know HC3 is working harder as before also.
    To sleep well I would like to report if it is > 65%
    - what to see in Crash notifyer if a QA restarts?
    I modified a QA and was witing to see the time trigger executed and it was restarting!
    Second time I have seen a QA restarting, in the morning I sometimes scroll in the debug windows up but didt see any restart.
    Also I dont know if I should worry if thats happening.
    - What I see know is HC3 runs very nice also thanks to your effort!
     (only need to tackle a few HTTP isues)
    Thanks for the service,
    //Sjakie
