47 minutes ago, ChristianSogaard said:
Slave rule in EV4
Hi Jan
I would like to configure a slave rule - a rule that is triggered when another rule trigger, but does something else - so i tried these two rules
the rule @{catch,00:01 never triggers, could i do something else than the catch ?
I got it ?
    50 minutes ago, ChristianSogaard said:
    Slave rule in EV4
    Hi Jan
    @00:01 means 1 minute after midnight.
    @@00:00:01 would run after a second and could work.
    However, it is much better to just post an event of your own - think about it as calling a subroutine. Note, the first rule will execute to the wait(00:10) before the other rule triggers and start to execute. (ecerytime a rule does a wait() it will give time to other rules to run that are waiting for it)
    Jan,
    I need your expertise this rue doest work:
    Rule.eval([[$SanitairToilet=='Vrij' & (toilet.Spottoilet:last - now) > 00:01:12 =>
         $ToiletExtraAfzuiging='Aan';
            log('Extra afzuiging toilet -aan en na x min - Uit')
    Please advice,
    //Sjakie
    Interesting, you can pee in less than 1 minute and 12 seconds ???
    2 hours ago, Sjakie said:
    Jan,
    Please advice,
    //Sjakie
    last - now can never be positive, unless last is in the future - you probably need to switch the values
    Btw, if you paste the code inside an editor "code comment" <...> it may be better formatted, it's really hard to read otherwise.
    Jan,
    Thanks for the solution, stupid I didt see it by myself.
    I wast aware how to tackle this issue, mostly I copy/paste first in Notepath before paste in forum. Thanks for the hint.
    @SmartHomeEddyyou smart...!
    I am fastSjakie
    56 minutes ago, Sjakie said:
    I am fastSjakie
    hahaaa, especially the 12 seconds, sounds like you pee with a stopwatch in your other hand ? Or is there a international benchmark for that? ?
    maybe @jgab could add a routine to EV based on gender, age. ..
    Edited by SmartHomeEddy
    12 sec has a purpose!
    My QA is rather long and its easy to find a rule back if seconds are added to determine ad once where to look.
    A day not laughed is a day not lived!
    //Sjakie
    Hi all,
    I just received a new HC3 to replace my old HC2.
    Very interested in setting up EventRunner4 to replace all my HC2 scenes. I checked here and on GitHub, but not sure on "step by step, how and where to start"
    I installed the last version of EventRunner4 and QA_toolbox QuickApps, and would like to start to play with some rules.
    How exactly should I set up the script? as a scene?
    Thanks for your support and indulgence toward a rookie and his questions ;)
    edit: actually I see that there is nothing else to do, working just fine (I was not yet familiar with the edition of QA in HC3, but now I found out how to do it! Thanks for this amazing tool, will start using it to re-build my old HC2 scenes.
    Edited by ndelaet
    2 hours ago, ndelaet said:
    Hi all,
    You don't need to install QA_toolbox, relevant files are included in the ER4 QA.
    If you want to run and debug ER4 QA offline you need to download some of the supporting files.
    Here is "ER4 the movie"
    Please feel free to ask questions in this thread  if you have difficulties with creating rules.
    A reminder to all using ER4 is that it's easy to integrate own Lua functions into rules, so all logic does not necessarily need to be expressed with event script.
    Hi jgab,
    Thanks a lot for the reply.
    Working with Eventscript almost non stop since yesterday, I am really amazed… So powerful, so easy, so reactive on the HC3. It’s a real game changer for fast, efficient yet advanced automation. Most of my old scenes are already "converted", and working perfectly!
    Being totally rookie in programming, I re-create most of the rules by mimetism, leveraging on the many examples in the dozens of posts on this forum.
    A few things I could not (yet?) find:
    1. I would like a given lamp to “follow” the dimming level of the main lamp, only as of the moment the main lamp’s value is above 5%. How can I do that with a rule?
    2. I would like to trigger a scene through the sceneActivationEvent of a Fibaro dimmer 2. I tried to use an adapted version of the “Rule.eval("mySwitch:scene == S2.click => myLight1:on”)” but it does not work. Is there a more up to date “formula”?
    Thanks! I will certainly have more questions in the coming days, as I will start using more "advanced" ER4 capabilities
    Hi jgab,
    rule("mainLamp:value > 5. => followLamp:value = mainLamp:value")
    Everytime mainLamp changes value and the value is greater than 5 (0..99 ~5%) set the followLamps value to the mains value
    1. I would like to trigger a scene through the sceneActivationEvent of a Fibaro dimmer 2. I tried to use an adapted version of the “Rule.eval("mySwitch:scene == S2.click => myLight1:on”)” but it does not work. Is there a more up to date “formula”?
    It looks ok to me. Sometimes the sceneActivationEvents can be tricky to get to work.
    Can you create a block scene that reacts on the sceneActivation from that switch?
    Do you see a trigger being logged in ER4 when you make an S2 click?
    Perfect thanks, working!
    Ok it works now, used (sorry, in French):
    I now finalised the transfer of what I had on HC2... Now I will think about all the new things I will be able to add thanks to your QA!
    Is there somewhere a repository of all rules examples, or all rules that have been developed by you or others, to get inspired?
    Thanks,
    Good. ...but it doesn't work if you test against S2.click? (that is 26)
    Thanks,
    No, no real repository. Would be nice if Fibaro allowed for a Wiki where we could edit together.
    Good morning Jan,
    Question I use your alarm scene with full satisfaction.
    Is it possible to in- or exclude devices in alarm panel with ER?
    Why, now its freezing and to prevent frozen waterpipes heating is enabled on some places but also doors need to stay open to heat other places and therefor excluded from alarm.
    Okay I know I can do it by hand but it should be nice if my GV $Freezing=='Yes' can do it for me.
    Thanks in advance,
    //Sjakie
    I checked, and it also works fine... I think I had an issue with the device itself (I reconfigured it, now it works much better...)
    Other question: I have 2 remotes, and currently their rules are quite heavy, yet exactly identical:
    --> Is there a possibility to use a "toggle" function to alternate between ON and OFF status of a device?
    --> Is there a possibility to use the same rules for both remotes? I tried to put keyfobDN = {75, 77} but it does not seem to work
    Thanks for any ideas!
    Yes, toggle should work if it's a binary switch.
    Create a rule that re-posts the keys in a more compact format.
    and then re-use these events in the rules
    etc.
    etc.
    Another variant, one rule per remote and a || >> selector
    Jan,
    What can cause this?
    [09.02.2021] [11:30:59] [TRACE] [QUICKAPP797]: Check - overLoop.pir:breached false
    [09.02.2021] [11:30:59] [TRACE] [QUICKAPP797]: Check - overLoop.pir:safe false
    Should be one of the two true?
    //Sjakie
    12 minutes ago, Sjakie said:
    Jan,
    //Sjakie
    What is overLoop.pir? More than one device?
