Jan,
overloop.pir is one motionsensor.
Used in :
<Rule.eval([[badKamer.deur:breached & badKamer.doucheDeur:breached =>
            log('Check - badKamer.deur:breached %s',badKamer.deur:breached);
            log('Check - badKamer.doucheDeur:breached %s',badKamer.doucheDeur:breached);
            log('Check - overLoop.pir:breached %s',overLoop.pir:breached);
            log('Check - overLoop.pir:safe %s',overLoop.pir:safe);
        || overLoop.pir:breached >> openVanBuitenDeurBadKamer=true;
             $SanitairBadKamer='Bezet'; badKamer.Badkamer:on; zolder.mechVentLaag:on;
             myLog('douche deur open openVanBuitenDeurBadKamer -  true  -- GV BadkamerB is BEZET');
        || overLoop.pir:safe >> openVanBuitenDeurBadKamer=false
            $SanitairBadKamer='Vrij'; badKamer.Badkamer:off; zolder.mechVentLaag:off;
            myLog('douche deur open openVanBuitenDeurBadKamer -  false -- GV badkamer is VRIJ');
add in this case it should be safe >>I was in the bathroom
    On 2/9/2021 at 12:21 PM, Sjakie said:
    Jan,
    Used in :
    No, this doesn't make sense. unless the pir is breach just between the log messages being printed but that's seems unlikely. Do you always get that strange log result?
    Jan,
    Thanks,
    Situation bathroom; door and pir - entrance; pir
    I was in the bathroom and started to leave the bathroom and noticed the light was acting strange.
    Till now I only have seen it once the passed 24 hours all was okay.
    //Sjakie
    Jan,
    Correct me if Iam wrong.
    The behaviour of the HC3 with ethernet connection is difference as HC2 it will connect again after loosing signal.
    Last night my ISP had a breakdown and there for need to manual restart my router.
    Can HC3 do that if connection is lost for lets say 15 min? If yes how to implement with a wallplug?
    Thanks in advance for the excellent service,
    //Sjakie
    Making progress with the setup, looking forward to start more challenging things this week end
    some (stupid) questions, yet I could not find / work out the answer..
    - I would like the 4th line of the code below to actually work, meaning, activate the Night mode if all motions are safe for 30 mins, only between 22h and 6h30. But it immediately activate "Night" at 22h even if motions are not safe since 30 mins. I guess I've done something terribly wrong..
    - I tried to have each of these rules to simply log something (the status of the &DayTime variable) each time they are triggered, but always get an error. I believe I do not handle properly the "& log('something') part. What would be the correct way to write it?
    - I would like to set up a rule that changes the value to which a Fibaro Dimmer would go ON depending on &DayTIme, if and only when triggered by a manual switch. This, without actually putting the dimmer ON. If this feasible?
    Thanks a lot for the support!
    There are 4 types of rules
    • @rules. They schedule the rule to run at specific times.
      • @10:00 run at 10:00
      • @{10:00,sunset+00:10} runs at 10:00 and 10min past sunset. We use {...} to list several times
      • A specific for @ rules is to add the key 'catch' that runs the rule if the time has past when the QA starts up.
      • So, in your case you can't use catch with trueFor...
    • @@rules that run rules at specific intervals
      • @@00:05 runs a rule every 5 minutes
      • @@+00:05 runs a rule every 5min starting at even 5min.
    • Triggers rules
      • Ex. 66:isOn & 55:isOff => ...
    • Event rules
      • #myEvent => ...
    You can mix trigger and event rules but a '@' or '@@' will only trigger on times or intervals.
    In trigger rules if we want to only trigger at specific times we typically use time interval tests like 'sunrise+00:10..15:00' or day or month tests etc.
    4th rule would be
    log can use string formatter the same way as Lua's string.format.
    You can then log
    However, you can make a separate rule that log the DayTime when it changes
    This will log the state when other rules change DayTime too.
    It's general not possible to make a dimmer start at a given value. (Hue lights can be set to a startup value).
    My strategy is to detect if the lamp is turned on and then immediatly dim it down. Not a perfect solution but it's quick enough so it doesn't completely destroy your night vision :-)
    Hi Jan,
    Thanks a lot, very helpful!
    kr
    Jan,
    Is it normal practice that HC3 restarts?
    //Sjakie
    25 minutes ago, Sjakie said:
    Jan,
    //Sjakie
    No
    Jan, thanks will try to see what is causing it.
    Is it possible ER can give a notification if a device is deadand or batery empthy?
    I know Fibaro send message if batery level is below x, they flood my inbox, I have more faith in your solution.
    If yes how to implement?
    Thanks in advance,
    //Sjakie
    Hi Jan,
    A few more (quick) questions
    - I would like a motion sensor to trigger a light, but I would like a person to be able to override this by manually switching off the lamp. If the user manually switchs it off, I would like the rule to be switched off for like 10 min (to avoid the motion sensor to immediately switch the lamp on again). Is this possible?
    - Is there a simple "wake up" script running on ER4? ie: to wake up in the morning with lights increasing slowly over a period of 30 min, and sonos music playing a defined tune?
    - Is there an easy way to integrate a sonos system in the ER4?
    - sometimes, I observe a "lag" in the execution of the rule, of up to 2 sec. What could be the cause? Is there something I can do to optimize this? I'm not running any scene on my HC3, only ER4, and global polling interval is 300s
    Thanks a lot for any ideas!
    58 minutes ago, ndelaet said:
    Hi Jan,
    If you have a dim light you can do
    ...also works now with the :dim property {sec,dir,step,curve,start,stop}
    rule("@sunrise => lamp:dim={5*60,1,1,'linear',0,99)")
    call a Sonos QA with fibaro.call(SonosID,"play") etc...
    How do you observe the lag?
    Difference between the incoming trigger being logged and the log that the rule is executing?
    I'm asking because sometimes it's just the HC3 that is very slow at sending/receiving z-wave events. When my code does a fibaro.call(88,"turnOn") because a rule says 88:turnOn, I do it and hope that the HC3 executes it fast enough - nothing I can do.
    When a sensor is breached, I pick it up as soon as it hits the HC3 /refreshStates queue.
    33 minutes ago, jgab said:
    luxsensor = 99 switch = 109 Util.triggerVar('flag',false) --  declare 'flag' to be a script variable that can trigger rules when it changes value rule("luxsensor:value < 200 & !flag => switch:on") -- if low light and flag is false turn on light rule("switch:isOn & switch:manual >= 0 => flag=true") -- if switch turned on manual then set flag to true --- device:manual returns seconds since it was last changed manually or < 0 if it was changed by script rule("trueFor(00:10,flag) => flag=false") -- when flag been true for 10min turn off flag
    Thanks looks great!
    When trying to implement I get this
    (I've changed the 'flag' for 'lightManOffCuisine' everywhere)
    I guess I've not put the Util.triggerVar() in the right place in the main loop..?
    I think the issue is indeed with the HC3 Z Wave; the lag is between the action being logged, and the actual action being launched by the device. Especially for the motion sensors: sometimes 1-2 seconds can pass before the light is actually on...
    10 hours ago, ndelaet said:
    Thanks looks great!
    Sorry, that was an error. The function to define a trigger variable is Util.defTriggerVar
    So:
    Working perfectly, thank you.
    I would like to state again that I've never had a home system working soo smoothly and reliably, thanks to the ER4.
    I now have approx 100 rules running, and all is working perfectly. It was easy to set up (for someone like me who knows almost nothing about coding), it's easy to maintain... Quite light in terms of resources... Really great.
    I will try to set up some push notifications to my mobile app in my next round of improvements... Will certainly have more questions!
    Thanks again for such a great development!
    Goodmorning Jan,
    <rule("#se-start => 2:msg='HC3 rebooted'; 20:email='HC3 rebooted'; myLog('HC3 Booted up Is in scene beveiligen')")>
    This rule doest notice me if:
    -by admin menu restart
    - by admin menu backup
    The action part is working idf I use @14:00
    Please advice,
    //Sjakie
    Jan,
    To give some sensors  a different if>>then option to arm  in the arming scene I like to use this rule, is that possible?
    but =arm generates an error if I changes in == no error.
    I thought in the trigger part ==  and in action =?
    Also the #listSensorStautus doest show  the correct state of the device.
    <Rule.eval([[hal.kamerBeneden:isOff & alarmApp.beveiligenComplex:isOn & $VerwarmingVriesStand=='Nee' =>
            bijKeuken.deur:armed==true; log('Bijkeuken deur is - beveiligd')]])>
    <  rule([[#listSensorStatus => log('AANWEZIGSENSORS'); for id,_ in pairs(aanwezigSensors) do log('%s = %s, %s',idname(id),id:armed & 'armed' | 'disarmed',id:safe & 'safe' |'breached'end;>
    Please advice,
    //Sjakie
    3 hours ago, Sjakie said:
    Jan,
    Please advice,
    //Sjakie
    HC2 or HC3?
    Hello again,
    So after more in depth testing, it seems that... It does not work as well as I thought ;)
    This rule in particular never seems to turn to "true" even when switch are manually activated:
    rule("lightPlafSaM:isOff & lightPlafSaM:manual >= 0 => lightManOffCuisine=true"-- if switch turned off manual then set lightManOffCuisine to true
    any clue?
    Thanks!
    Hello again,
    any clue?
    Try add this rule
    and see if it reports 'Manual' or 'Script' when. you flip the switch manual
