12 minutes ago, ChristianSogaard said:
Thank you Jan. You cant repeat my problem because you didnt do the same stupid error as I did. ???
Toolbox is downloaded.
Need to look into this
[30.01.2021] [13:58:02] |[35mSYS  [0m|: HC3 SDK v0.158
[30.01.2021] [13:58:02] |[35mSYS  [0m|: Created Event server at 192.168.201.236:6872
[30.01.2021] [13:58:02] |[31;1mERROR[0m|: Code crashed: cannot open Toolbox/Toolbox_basic.lua: No such file or directory
So I downloaded the MQTT, at I see it in the library. I guess the definition is missing in the hc3_emulator.FILE ?
    If you have the latest plugin there is a menu option to download toolbox, MQTT etc.
    You need to stand in the directory where you have the fibaroapiHC3.lua file when you download the other files.
    ...and the QA file you work on needs to be in the same directory
    ../MyQA.lua
    ../fibaroapiHC3.lua
    ../Toolbox/...
    ../mqtt/...
    IU
    ../MyQA.lua
    ../fibaroapiHC3.lua
    ../Toolbox/...
    ../mqtt/...
    I'm pretty sure, i have that right
    /monthly_2021_01/image.png.3d09bd187f9e094a93052993a8e91231.png" />
    Do i need something like this in the include /modules?
    hc3_emulator.FILE("MQTT/somethingmqtt.lua","Toolbox")
    No, mqtt is loaded differently. I check if the 'mqtt' subdirectory exists and load it at startup.
    (Same for the websocket support)
    Downloading latest MQTT/*
    Program starting as '/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/bin/lua.app/Contents/MacOS/lua53 /Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/myprograms/fibaroapiHC3.lua -downloadfile MQTT/*'.
    Program 'lua53' started in '/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/myprograms' (pid: 66166).
    [30.01.2021] [16:30:01] |[34mLOG  [0m|: Writing file mqtt/bit53.lua
    [30.01.2021] [16:30:01] |[34mLOG  [0m|: Writing file mqtt/bitwrap.lua
    [30.01.2021] [16:30:01] |[34mLOG  [0m|: Writing file mqtt/client.lua
    [30.01.2021] [16:30:01] |[34mLOG  [0m|: Writing file mqtt/init.lua
    [30.01.2021] [16:30:01] |[34mLOG  [0m|: Writing file mqtt/ioloop.lua
    [30.01.2021] [16:30:01] |[34mLOG  [0m|: Writing file mqtt/luasocket_ssl.lua
    [30.01.2021] [16:30:01] |[34mLOG  [0m|: Writing file mqtt/luasocket.lua
    [30.01.2021] [16:30:02] |[34mLOG  [0m|: Writing file mqtt/ngxsocket.lua
    [30.01.2021] [16:30:02] |[34mLOG  [0m|: Writing file mqtt/protocol.lua
    [30.01.2021] [16:30:02] |[34mLOG  [0m|: Writing file mqtt/protocol4.lua
    [30.01.2021] [16:30:02] |[34mLOG  [0m|: Writing file mqtt/protocol5.lua
    [30.01.2021] [16:30:02] |[34mLOG  [0m|: Writing file mqtt/tools.lua
    Download done! - MQTT/*
    Program completed in 1.67 seconds (pid: 66166).
    and the run
    Do a new lua files in the same directory with a single line
    require("mqtt")
    and test it. It should work...
    require("mqtt")
    You are not running a_test.lua, you are running something else (like your Nilan QA). In the console you see how it runs fibaroapiHC3.lua and loads ex. event manager.
    Have you set it as start file?
    I see what you mean. I got it working now . Thank you again ???
    Edited by ChristianSogaard
    P
    I properly need to look into to do the MQTT in EV4 if that is possible. Because this is flotting my logs ;-)
    P
    I'm a advocate for "source filtering". I think you should put in some filter on the events from MQTT. I can't imagine all the events being different, or different enough, to need to be posted to the ER QA.
    this filter just checks that the events are different. If they have numeric values that differs just a little the filter can take that into consideration too... but that's a later exercise.
    and then in your MQTT handler
    great idea Jan ? - i didnt see that myself. ?
    I have two errors in ZBS
    The first is
    [31.01.2021] [09:13:35] |[31;1mERROR[0m|: MQTT error:CONNECT failed with CONNACK [rc=5]: Connection Refused, not authorized
    but if i Deploy the QA - authentication works - and i dont see any error.
    Second is
    [31.01.2021] [09:20:03] |[31;1mERROR[0m|: QuickApp crashed: Toolbox/Toolbox_events.lua:77: Bad argument to postRemote
    the line --self:postRemote(1103,.... works fine when "--" is removed.
    The first is
    Second is
    Sorry, filter was wrong
    The first is
    How does your MQTT URL look like and how do you open the connection?
    Can you in the header set
    if dofile and not hc3_emulator then
      hc3_emulator = {
          debug = { mqtt = true},
    and see if you get any more debug logs?
      hc3_emulator = {
    So, I have very limited experience of MQTT. It looks like the authorisation fails (username password?) and then it retries and it succeeds? You get a message at the end?
    Are you sure you need to add username/password to the options when you connect? I add it to the MQTT connect and it may be the wrong username/password and you get the fail - On HC3 they may ignore it...?
    I deleted the proxy QA and run the code again, and now it dont show anymore.
    Filter is working SuperB ?
    Slave rule in EV4
    Hi Jan
    I would like to configure a slave rule - a rule that is triggered when another rule trigger, but does something else - so i tried these two rules
    the rule @{catch,00:01 never triggers, could i do something else than the catch ?
