Jan,
its my stupidity but no error message and no execution!
Rule.eval([[@17:20 => post(#lichtAan,+/00:00:05); post(#lichtUit,+/00:00:10)
    log('post licht - aan - uit')]])
I forgot a semi colon behind the 2nd post
//Sjakie
2 godziny temu, jgab napisał:
This is fun
When the first rule triggers is turns on swiatlokuchnia1
Then when the second rule is tried, swiatlokuchnia1 is on...
2 ways around this
because || >> is. like if-then-elseif-then-... it will only run the rule that matches
Other approach is to add a break at the end of the first rule. A break menas that it will not try any other rules that matches
Once again, thank You very much ... as always, You are right and Your help is invaluable?
    Ok, I think this will work...
    Here is a shortcut that I have done on my iPhone.
    If you in settings->shortcuts has checked allow untrusted shortcuts it should be possible to click on the link from your iPhone and import the shortcut.
    When the shortcut is imported open it and edit it.
    First the URL, It should be:
    http://<Your HC3IP>/api/devices/<ER4 QA ID>/action/RECIEVE_EVENT
    Then open "Show more" and change the Authorization header to your own credentials. (base64 encoded)
    Then go down to Request body and open the 'args' items
    Open the next level, and then the next again (the 'ev' key)
    The last level says
    'type'     'test'
    When I click on the shortcut it sends an event to my ER4 QA that I can pick up easily
    rule("#test => lights:off")
    It only works when my iPhone is on the local network, but its is convenient way to talk to ER4 without needing to go through other services or QAs...
    Jan,
    I dont see it but is there a way to see in the new app wich devices are armed?
    //Sjakie
    2 hours ago, Sjakie said:
    Jan,
    //Sjakie
    HC3 it's only zones that can be armed.
    Jan,
    I only need to move arming into HC3 but before I think its smart to fix the telegram first to have a more relaiable data.
    Telegram I am able to send message from IPhone to HC3
    HC3 shows in debug "sorry I dont understand text msg"
    error says:
    [08.01.2021] [16:18:14] [ERROR] [QUICKAPP382]: Telegram error: 403, Forbidden: bot can't send messages to bots
    Whats the syntax to use in other QA?
    Thanks in advance,
    //Sjakie
    Good morning Jan,
    I have
    [13.01.2021] [08:40:07] [ERROR] [QUICKAPP798]: main() error:./include/EventRunner.lua:2198: Main() ERROR:./include/main.lua:703: attempt to index a nil value (global 'Event')
    in:
    function watchProperty(deviceIDs,property,threshold,interval)
        local values={}
        Event.schedule(interval,function()
            for _,id in ipairs(deviceIDs) do
              if id==nil then log(log.ERROR,"Nil in deviceID list"); break;  end
              local val = values[id] or 100000
              local newVal = tonumber(fibaro:getValue(id,property))
              if newVal==nil then log(log.ERROR,"deviceID %s don't have property %s",id,property) end
              if newVal and math.abs(newVal-val) >= threshold then
                values[id]=newVal
                Event.post({type='property', deviceID=id, propertyName=property, value=newVal})
          end)
    Please advice,
    //Sjakie
    Good morning Jan,
    I have
    in:
        local values={}
                values[id]=newVal
          end)
    Please advice,
    //Sjakie
    You can just remove it as it is not necessary in ER4
    On 1/8/2021 at 4:22 PM, Sjakie said:
    Jan,
    error says:
    Thanks in advance,
    //Sjakie
    Sorry, I haven't worked with the telegram QA for 6+month... it's on my todo list to have a look at it but Im pretty busy at the moment
    Jan,
    Thanks, no problem will wait till you have time.
    Thought so that you are busy the last days.
    I hope it goes well with you?
    On 9/21/2020 at 5:49 AM, jgab said:
    Any value. This works:
    Hi @jgab
    I was looking for an EV4 example.
    My goal is to use Keyfob/matrix - where a tripple click select next Color in a list in Children of Hue activated Bulp.
    so eg.
    list={red, yellow, blue, green} or a list of HUE, Saturation and Brightness for each Bulp.
    I learned to to the Keyfob/matrix trigger part already, so I dont need that. -
    So a function for Pressed3 = {HUEID:color={255,0,0,138}} - but were is taking the next in the list ?
    Would you have time to support me again again ???
    @jgab
    why this generate error in ZBS:
     rule("@{catch,03:15} => Util.checkForUpdates()")
    [16.01.2021] [23:12:36] [[31;1mERROR[0m]: Error in '@{catch,03:15} => Util.checkForUpdates()': EventRunner4Engine.lua:308: attempt to concatenate a nil value
    [16.01.2021] [23:12:36] [[31;1mERROR[0m]: main() error:EventRunner4Engine.lua:2198: Main() ERROR:EventRunner4Engine.lua:2056: EventRunner4Engine.lua:308: attempt to concatenate a nil value
    It looks that I have problems with rules with @ in ZBS ie.
    rule("@01:00 & @sunrise & month('nov-jan') => log('test')
    but in HC3 it works correctly.
    Edited by petrkl12
    9 hours ago, petrkl12 said:
    @jgab
    What is printed if you do
    print(tostring({}))
    in ZBS? Plain editor buffer without fibaroapiHC3.lua.
    The problem is that I rely on tostring({}) returning something of the format
    ".... 0x......"
    which is true for all Lua's I have seen so far....
    What version of ZBS, what Lua interpreter, and what OS are you running on? and what version of fibaroapiHC3.lua?
    20 hours ago, ChristianSogaard said:
    Hi @jgab
    so eg.
    You need to keep a state of what is 'next' in your list
    You could make a list 'object' with this function
    every
    will return the next value in the list and wrap around
    print(tostring({}))
    ".... 0x......"
    print(tostring({}))
    it returned:
    table: 007a9dd0
    ZBS: ZeroBrane Studio (1.90; MobDebug 0.706)
    Lua interpreter: Lua 5.3
    OS: Windows 10 Pro 20H2
    local FIBAROAPIHC3_VERSION = "0.152"
    Edited by petrkl12
    In case of switching to lua interpreter:
    table: 0x001a9780
    In case of switching to lua 5.2 interpreter:
    table: 009904F0
    In case of switching to lua 5.3 interpreter:
    table: 00803e88
    It seems that it will work only in Lua interpreter ...
    12 minutes ago, petrkl12 said:
    print(tostring({}))
    it returned:
    table: 007a9dd0
    Thanks. I have updated my "gensym" algorithm to work with that format too...
    I have pushed a new version of EventRunner4 (fix 0.43) that should work better.
    Also updated fibaroapiHC3.lua
    table: 0x001a9780
    table: 009904F0
    table: 00803e88
    Yes, it seems to be a thing for Lua 5.2/3 in ZBS on Windows
    Thanks. btw. what version of Lua is in HC3?
    5.3 in QAs and 5.2 in Scenes.
    @jgab
    I have error in HC3 in this rule:
      rule("#dimPrac{attr='Released',dim='$d'} => log('Dalkovy ovladac 8tl. v pracovne - konec - dlouhy stisk klavesy %s',d.keyID); d.ref=cancel(d.ref)")
    [17.01.2021] [10:17:38] [ERROR] [QUICKAPP515]: in Rule:14[#dimPrac{attr='Released',dim='$d'} => log('Dalkovy ovladac 8tl. v pracovne - kon...]: {"ERR":true,"err":".\/include\/Toolbox_events.lua:103: Bad timer reference:nil","msg":"Error executing instruction:'[\"cancel\",1]'","src":"Rule:14[#dimPrac{attr='Released',dim='$d'} => log('Dalkovy ovladac 8tl. v pracovne - kon...]"}[17.01.2021] [10:17:38] [DEBUG] [QUICKAPP515]: Incoming trigger:{"id":29,"old":35,"value":40,"type":"device","property":"value"}
    7 minutes ago, petrkl12 said:
    @jgab
    all rules that are connected:
    Edited by petrkl12
