Jan, Is it possible in ER 3 HC2 to send a push message?
If yes please can you give me an example?
//Sjakie
sorry for picture I deleted it but its still here
    //Sjakie
    push is just :msg=...
    or do you mean interactive push +
    Yes inter active push please, now I have it inFibaro push.
    //Sjakie
    Jan,
    If I arm the house I use to get the information needed:
    msg,Telegram or inter active push.
    Fa frontDoor:armed==true =>
    ER execute this rule 3 times
    How to avoid to get the message also 3 times? Or this ist possible?
    Please advice,
    //Sjakie
    2 hours ago, Sjakie said:
    Jan,
    Please advice,
    //Sjakie
    Sorry, need more information. Is it ER3 or ER4? ER4 are you using the alarm rules I posted earlier?
    Jan,
    HC3 is paused wits for a new Children of HUe?
    Sorry this is ER 3 HC2.
    All the messages I reviewed and if necessary I want to add also Interactive push.
    I am still using your alarm rules but removed all seperate Telegram messages>>this solved the Telegram error I had.
    I see in debug rule <true>  Rule.eval([[eetKamer.deur:armed==true & badKamer.dakRaam:armed==true & kamerBoven.deur:armed==true & kamerBeneden.voorDeur:armed==true =>
            fibaro:call(210, "sendDefinedPushNotification", "259");
            fibaro:call(455, "sendDefinedPushNotification", "259");
            Telegram.msg(TID,'Beveiliging actief - Aanwezig, Dakraam, KamerBeneden en KamerBoven');
            log('259 - Beveiliging actief - Aanwezig, Dakraam, KamerBeneden en KamerBoven')
    3 times
    On that way I recieve also 3 messages.
    //Sjaak
    I've got two questions:
    1. Why this rule is "ok" but doesn't work? It start to wok when I leave only one month range ex. oct-dec .
    rule("once(oknazuzia:isOff & (outsideTemp < 12) & month ('jan-apr' | 'oct-dec') )=> ZuziaOgrzAutoOn:start")
    2. Is it possible to use seconds instead minutes?
    I think you want to write the first rule like this
    So if oknazuzia is. off and outsideTemp goes under 12 then
        If its jan-apr or oct-dec
        then start ZuziaOgrzAutoOn
    Note that the temp needs to go above or equal to 12 before the rule can trigger again (the 'once')
    The month('jan-apr,oct-dec') can also be written (month('jan-apr') | month('oct-dec'))
    Yes minutes can be specified
    rule("@12:00:10 => log('10s after 12')")
    rule("@@00:00:10 => log('Log every 10s')")
    Thank You
    On 9/25/2020 at 12:27 PM, jgab said:
    Example of alarm handling on the HC3 and ER4
    Of course these events could be used to start other rules like simulating presence, turning off stuff etc.
    The cool thing here is that we get a notification when the user turns on the alarm and we have the "delay time" to check if partition is safe. If not we abort the arming.
    One could also setup a rule that watches if something is breached during the arm delay timespan and also cancel the arming.
    Could you use a Logic Group Matrix as KeyPad of ARM/DisARM the alarm - like a trippleklik on one button and a double klik on another? Perhaps a trippleklik is enough, who would know "this is the way"
    You can combine clicks from the Matrix. Here we concatenate keyId and KeyAttributes from 2 keys clicked within 2s.
    I´m trying to understand everything in this Rule
    matrix1 = 77 -- DeviceID of matrix device - This is Clear
    • The [[ ]] is for indicating more that one expression is being evaluated ?
    • central is CentralSceneEvent
    • keyPrim - is a Key Pressed
    So :central & keyPrim = Event from CentralScene and there is a Key Pressed ?
    So what is this?
     post({type=fmt('%s_%s_%s',keyPrim,matrix1:central.keyId,matrix1:central.keyAttribute)});
    -- Post a LIST  - Save the LIST for later use ??
    -- type=fmt -- not sure -- is this the Formating of the LIST
    -- matrix1:central -- Read CentralSceneEvent
    -- central.keyId -- What Key
    -- matrix1:central.keyAttribute -- Is pressed
         keyPrim=nil -- is Empty keyPrim variable
    rule([[matrix1:central & keyPrim =>
         keyPrim=nil
    So now we again detect CentralSceneEvent and key pressed - and keyPrim should be empty (nil)?
    So this part has a 2 sec wait - before deleting keyPrim. When keyPrim is empty 3 rule wont trigger.
    rule([[matrix1:central & keyPrim==nil =>
        keyPrim=fmt('Key%s_%s_%s',matrix1,matrix1:central.keyId,matrix1:central.keyAttribute);
        wait(2);  ----
        keyPrim=nil
    # - this is a new trigger created, based on the former rules.
    This rule triggers when both rules are triggered?
    rule("#Key77_2_Pressed3_4_Pressed2 => post(#disArm)") -- Matrix iD 77, key 2 3-clicks, key 4 2-clicks
    I can just accept it working - But them I wont be able to create something like this from scratch - And this i my goal. Would you have time to do a detailed explanation?
    [[ ...  ]] is the Lua way to write a string that is spanning multiple lines. Sometimes it is convenient to format a rule over multiple lines if it is a long expression.
    Every rule(<string) only defines one rule.
    The other advantage of using  [[ ... ]] is that you can freely use " and ' inside the rule. Otherwise if you use " ... " to define a rule you must use ' ... ' for strings inside the rule (for log commands ex)
    Yes.
    Not really, keyPrim is a variable that is bound to the first key press if any. Otherwise keyPrim is nil - which works as 'false' in a boolean expression.
    Not really. matrix1:central is that we got a centralSceneEvent from the device with deviceID matrix1.
    keyPrim is true if we have seen a key before (the first click)
    So this rule only triggers if we have seen a key before and the key we get now is the second key. Now we need to put them together into an event that we can post
    So what is this?
    So fmt is like Lua's string.format that is a bit like C's sprintf. Here we use it to concatenate 3 strings with '_' between
    The first key string (keyPrim), the second key's id, and the second key's keyAttribute
    'post' see below
    Formatting of expression into a string
    The second key, see above.
    When we put together a double-click-event, we clear the keyPrim variable so that we don't trigger the rule again until we press a new first key.
         keyPrim=nil
        wait(2);  ----
        keyPrim=nil
    So this rule triggers the first key click. We know it's the first because keyPrim is. nil
    We assign keyPrim the string (deviceID) .."_"..(keyId).."_"..keyAttribute.
    This string will be the prefix when we create the string for the second key, so we get
    (deviceID)_(keyID first key)_(keyAttribute first key)_(keyID second key)_(keyAttribute second key)
    Rules are started (triggered) when they match incoming events.
    An event is a lua table with a type key. Ex. {type='device', id=88, property='value', value=true}
    It's similar to sourceTrigger in HC3 scenes.
    A short format (macro) for writing events in ER is to use the # prefix.
    #device{id=88, property='value', value=true} is the same as  {type='device', id=88, property='value', value=true}
    We actually save a few characters by that, and we make the type of the event stand out.
    The shortest event just have a type field. #foo is the same as {type='foo'}
    Rules always trigger on events but ER has some syntactic sugar for timers, devices being breached etc.
    If we have a rule that trigger on {type='foo'} we can write it as
    To trigger the rule someone has to post a #foo event.
    This will post the event #foo at sunset and the previous rule will trigger and print the message.
    In our case we have created that long string that uniquely identified the two keypresses. "Key77_2_Pressed3_4_Pressed2"
    We post that event with
    And then we have other rules that triggers on the various types combined key events. like
    The post/event-handler model is key to understand how to do some of the more advanced stuff in ER.
    It's actually a complete programming model that allows to express all types of traditional control structures.
    post cab take a delay before it will post an event
    This creates a loop that logs ding every 5min. We need the second rule to start the loop.
    Etc.
    There are some attempts to tutorials <
    >, and <
    > (they may not explain 'fmt' specifically)
    There is also a tutorial in writing event handlers in Lua instead of my made up ERscript language <
    It gives a good background on the underlying mechanism of ERscript (it compiles to lua event handlers)
    The only difference in ER4 is that it's a QA and the Event.rule() function is self:event() and Event.post() is self:post()
    That's the spirit! The source code to ER is <
    Yes.
    'post' see below
    Etc.
    >, and <
    I tried create two Event runner4  Rules
    Please comment on them :-)
    Bathroom
    Condition
    •    Monday 2 Friday
    Action
    •    Turn on Switch for Heating 06.15
    •    Turn off after 90 min
    OR Condition
    All Days
    •    If manuel turned ON
    Action
    Heating = { 356 } – Device/Switch
    Rule ("@(06:15) & wday('mon-fri' => Heating:on
    Rule ("Matrix:central.keyId==2) => Heating:on")
    Rule("trueFor(90:00) & Heating:on => Heating:off)")
    In Real live ER trigger looks like this
    Incoming trigger:{"value":{"keyAttribute":"Pressed","keyId":2},"type":"device","id":182,"property":"centralSceneEvent"}
    Entre
    Condition
    •    Between Sunset to Sunrise
    •    Door Switch i Breach
    Action
    •    Turn ON.
    •    Turn off after 10 min
    lamps = { 101 }
    rule("@sunset ) => $SunStatus='Nat'")
    rule("@sunrise) => $SunStatus='Dag'")
    rule("door:breached => lamps:on")
    rule("trueFor(00:05, 101:isOn & door:safe) => lamps:off")
    OR
    rule("@sunset-sunrise & door:breached  => 101:off”)
    rule("trueFor(00:05, 101:isOn & door:safe) => 101:off")
    Bathroom
    Condition
    •    Monday 2 Friday
    Action
    OR Condition
    All Days
    Action
    90min is 00:90, or 01:30
    Parenthesis missing and misplaced, I changed a bit.
    trueFor(<time>,<expression>)
    takes 2 argument, a time and and expression that should be true for that time.
    Now it triggers on key 2 for Pressed, Pressed2. etc. You could add
    Rule("Matrix:central.keyId==2 & Matrix:central.keyAttribute=='Pressed' => Heating:on")
    Quote
    Entre
    Condition
    Action
    •    Turn ON.
    lamps = { 101 }
    OR
    @ is a timmer that starts the rule at a specific time. To test a time use interval test <timeA>..<timeB>
    In general you don't need to use global variables ($) unless you use it to communicate with other scenes
    The last rule turns off the light if light is on and door is safe for 10min (both) during the sunset..sunrise period.
    On 9/9/2020 at 10:33 PM, jgab said:
    With the "new" location trigger one can do rules like this
    The set of rules keep track of the number of people at home, all, some, and none.
    It can trigger rules with the trigger variables 'allAway', 'allAtHome' and 'someAtHome'
    Now 'allAtHome' causes 'someAtHome' to trigger too - it's easy to modify if you want it exclusive.
    When the QA starts locations are unknown - need some more code to lookup current positions.
    I was looking into doing something like that - and someone already thought about it?. I just want to have a trigger more for ALARM Armed, so I can send a push message when ALARM NOT ARMED and allAway = True.
    Jan,
    Weird two curtains opens and rest stay closed the trigger is there the action is there too but practical>>nothing
    Please advice,
    //Sjakie
    sorry forgot to mention yesterday the curtains closed correctly.
    Jan, sorry for bothering it was hanging on NodeRed error.
    Fixed now.
    //Sjakie
    Jan,
    In your arming scene HC3 there is a beautiful msg service.
    It was working when I left the admin panel in the evening when arming the house no msg.
    I upload a backup of Arming scene msg worked. I
    deleted the new scene and armed the house and the "old" arming scene sends the msg.
    What happend?
    Please advice,
    //Sjakie
