Jan,
HC2 and HC3 where running.
HC2 runs complex automation including HUE I dont have problems here.
I have deleted the part toilet and bathroom from HC2
HC3 is running toilet and bathroom including HUE
So both are independant?
All HUE lights are on HC2 and HC3 in my opinion sleeping in HC3 only toilet and bathroom
HUE operate with Fibaro plugin
While testing HC3 there was no switching HUE on/off by HC2
HC3>> I can switch on/off nummerous times HUE in devices as well by clicking on the icon in front or at the button on/off if you open devices but NOT in
HC3    QA ER 4
This sound logical:
If you run Hue scenes/devices on both the HC2 and the HC3 they will compete calling/polling the Hue hub and the Hue Hub may start to refuse to carry out commands.
I am just back with adding the devices again in HC2.
I will try to make some tests with a door sensor and than I will shut down HC2 to see if this can be the problem bt I think its not the problem
because
what will be the differnce? In device no problem but in QA only few times and after restart it will do it again a few times.
Jan is there a difference also between QA or scene?
A waiting your comment,
//Sjakie
    30 minutes ago, Sjakie said:
    Jan,
    HC3    QA ER 4
    This sound logical:
    because
    //Sjakie
    Well, ER4 doesn't know that it controls a Hue device, it just sends sends commands type fibaro.call(<hueDevice>,"turnOn") etc.like it does to any device.
    You can however send commands quicker to a device with Lua (ER4) than when you click on the UI. It could be that the Hue plugin can't handle to quick invocation of commands or sends them too quick to the Hue Hub...
    If you use the ER3 on the HC2 to control the Hue Hub it makes sure to pace the requests to the Hue Hub so it's not too fast...
    Your HC2 and HC3 is independent but they talk to the same Hue bridge that can't cope with too many parallell requests.
    Jan,
    Sorry wrong track.
    You made me think!
    In HC3 I created a rule to switch on/ off 8 pieces of HUE lights after each other not wait in between them.
    Remark HC2 is on!
    I can switch on off with door sensor after each other.
    So conclusion HUE is not the cause of my failing toilet light?
    Because in the toilet I only switch one HUE.
    What to do? Start all over again from scratch is the best way with only HUE and toilet and ER to see what is happening.
    I had hope that after the update my problems where passed but still fighting to get it working.
    //Sjakie
    Is it possible to do smth like this with double switch?
    single short push > toggle power on first relay
    double short push > toggle power on both relays
    greets
    greets
    Something like this?
    :manual returns the time in seconds since the switch was manually flipped. It return -1 if the script flipped the switch.
    Now if you flip switch1 back and forth within 2s it will turn on both switch1 and switch2, independent what state switch1 was in.
    If you want the same behaviour on switch2 I would recommend a second rule instead of trying to combine them into one rule.
    You could experiment with the time and set it to <2...
    hmm...it always returns false...
    Maybe I will say what I would like to achieve:
    I want to replace double bistable switches with single momentaries but keep double modules. And cause a single click to toggle the state of the first circuit and double click of both circuits.
    As You know i'm  using shelly modules, which has the following options for the buttons.
    I think the best option would be "detached", but probably it will need some modifications in the shelly QA?
    Ok, a shelly switch changes the equation...
    The problem is that you have to poll the switch every 1s to have a chance to detect double presses within 2s (that's why you always got false with the example rule)
    It would have been nice if the switch supported double presses but now you need to detect it on the HC3 side.
    You would need a low poll rate (1s) and there would be a chance if people press quickly that only one of the presses would be detected...
    Is there a 'last changed' value that could be read from the switch?
    Unfortunately, shelly doesn't support this feature at the moment
    Unfortunately, there is no such thing at the moment
    Is it possible to do on FIBARO FGS-221 modules?
    Yes, the rule I provided could work with the 221, but because the switch and the relay is not "detached", you would get "blinks" as you double press I guess.
    Is it possible on some other fibaro modules?
    Shelly supports "detached" switch, in web interface i can see when switch is powerd on/off and relay is on/off.Is there a chance it can be done? Even changing the pool for these few modules for 0.5s
    Jan,
    I am still trying to get it work.
    The rules are not (always) in debug as true or false??
    Remark toilet.pir:breached is added to have light.
    What can be done?
    Util.defTriggerVar("openVanBuitenDeurToilet",false)
    rule([[toilet.deur:breached =>
        || toilet.pir:safe >> openVanBuitenDeurToilet=true
        || toilet.pir:breached >> openVanBuitenDeurToilet=false
    rule("openVanBuitenDeurToilet==true => toilet.Spottoilet:on; toilet.wcLamp:on; post(#toiletBezet);  $Toilet='Bezet'; log('#toiletBezet1 - post');log('deftrigger openVanBuitenDeurToilet true')")
    rule("openVanBuitenDeurToilet==false => toilet.Spottoilet:off; toilet.wcLamp:off; post(#toiletVrij); $Toilet='Vrij'; log('#toiletVrij2 - post'); log('deftrigger openVanBuitenDeurToilet false')")
    Rule.eval([[toilet.pir:breached =>
        toilet.Spottoilet:on; toilet.wcLamp:on; log('pirrrrrrrrrrrrrr licht aan')]])
    [19.10.2020] [16:40:25] [DEBUG] [QUICKAPP171]: wait(5); publish(#foo) = {"type":"foo"}
    [19.10.2020] [16:40:47] [DEBUG] [QUICKAPP171]: Incoming trigger:{"type":"device","id":225,"property":"lastBreached","old":1603118256,"value":1603118447}
    [19.10.2020] [16:40:48] [DEBUG] [QUICKAPP171]: Incoming trigger:{"type":"device","id":225,"property":"value","old":false,"value":true}
    [19.10.2020] [16:40:48] [DEBUG] [QUICKAPP171]: [true]>>'Rule:4[toilet.deur:breached =>...]'
    [19.10.2020] [16:40:48] [DEBUG] [QUICKAPP171]: Incoming trigger:{"type":"device","id":227,"property":"lastBreached","old":1603118244,"value":1603118447}
    [19.10.2020] [16:40:48] [DEBUG] [QUICKAPP171]: Incoming trigger:{"type":"device","id":227,"property":"value","old":false,"value":true}
    [19.10.2020] [16:40:48] [DEBUG] [QUICKAPP171]: [true]>>'Rule:9[toilet.pir:breached =>...]'
    [19.10.2020] [16:40:50] [DEBUG] [QUICKAPP171]: fibaro.call(39,"turnOn") => nil
    [19.10.2020] [16:40:50] [DEBUG] [QUICKAPP171]: fibaro.call(219,"turnOn") => nil
    [19.10.2020] [16:40:50] [TRACE] [QUICKAPP171]: pirrrrrrrrrrrrrr licht aan
    //Sjakie
    The iCal example from the QA tips&tricks.
    There is a new version of ER4 that allows for string matching in events.
    Normally we can do
    This will bind the ER local variable 'val' to the matched key value of 'bar' in the #foo event.
    We can add constraints to the matching.
    This will only match #foo event with a bar key value > 6, and bind the local val to the value.
    Now we can also use string matching. The operator is '<>'
    and it will match a name key that has a string containing the 'Jan' substring. All of Lua patterns are available.
    This we can use to make the iCal example a bit more elegant
    Is there a way to utilize GPS through HC3 application in ER4?
    Like this?
    Jan,
    If arming for example partition and some devices are not safe>>>>>
    "partition has breached devices cancel arming"
    - How to get wich devices are causing this
    - How to  continue the arming
    Sometimes we are short away and a window or door ist close so we want arm.
    Please advice,
    //Sjakie
    On 10/24/2020 at 4:42 PM, Sjakie said:
    Jan,
    Please advice,
    //Sjakie
    I guess you could pick up the names of the breached devices and add them to the message
    So there is a new version of my Hue QA
    The nice thing is that lights supports startLevelIncrease & friends - like other dimmable devices.
    fibaro.call(id,"startLevelIncrease") starts a loop that increases the light of a devices. It turns on the device if it is off.
    fibaro.call(id,"startLevelDecrease") starts a loop that decreases the light of a devices.
    fibaro.call(id,"stopLevelChange") stops the loop.
    centralSceneDevices like the keyfob do emit 'HeldDown' and 'Released' events when a button is held down for a while and subsequently released.
    To assign dim up and dim down on button 1 and 2 of the keyfob the rules look like
    We start the dimming loop when we hold the buttons down and we stop the loop when we release the buttons
    Support for :leveIncrease & friends is available in ER4 v0.5fix32.
    The childrenOfHue QA also supports scenes and storing default startup values for lights (like,  start with a red light when lamp is turned on). There is no direct ER support for that yet but can be used with fibaro.call(....
    Hi!
    Could you please update the .fqa and post in here or on Github under Releases? The one released in your footer links is "V0.5 fix.22".
    Thank's!
    12 minutes ago, robw said:
    Hi!
    Thank's!
    Done.
    (fix22 should autoupdate to fix32 if you enable it.)
    I don't upload the fqa to my Github - only the source.
    Just now, jgab said:
    Done.
    Thank you for the quick update! :)
    Have a nice day!
