    11 minutes ago, Sjakie said:
    Jan,
    In your arming scene HC3 there is a beautiful msg service.
    It was working when I left the admin panel in the evening when arming the house no msg.
    I upload a backup of Arming scene msg worked. I
    deleted the new scene and armed the house and the "old" arming scene sends the msg.
    What happend?
    Please advice,
    //Sjakie
    Unrelated to ER I have also received random notifications from scenes/QAs that no longer exists. I believe it's an issue with the Fibaro notification service...
    Hehe Jan,
    Any progres with Telegram for HC3?
    If push msg ist reliable?
    //Sjakie
    Hello Jan,
    My arming scene contains 7 parts.
    To reduce the number off msg I want to combine some msg I tryed a few things but I am not smart enough to acomplish.
    Is it possible to give me an example of arming 1,3,4?
    Thanks in advance,
    //Sjakie
    Jan,
    I used this in HC2
      Rule.eval([[woonKamer.tv:isOn => wait(00:00:03); fibaro.call(471, "changeActivityState"]])
    Converted into for HC3 I dont see error in Debug
      Rule.eval([[woonKamer.tv:isOn => wait(00:00:03); media.Tv:value=changeActivityState
    is this correct?
    I dont get action but that happends more on my HC3.
    If Fibaro has reset my migration HC3>>HC3 I will try to migrate to another box and see if all those hick ups I have still stay or disapear.
    Thanks for support,
    //Sjakie
    3 hours ago, Sjakie said:
    Jan,
    I used this in HC2
    is this correct?
    The rule should look the same as on the HC2
    Jan,
    Thanks for support!
    Same as with some other devices, cmd in LUa no reaction when i push button in devices >>>action.
    I found your Telegram.fqa sorry for asking but it doest work.
    I created  a new bot after finishing that I saw the text messages in HC3 debug
    Is to use Telegram the same cmd as in HC2?
    Rule.eval([[@16:51 =>
    Telegram('testing - do we see this?'); log('test telegram')
    [26.11.2020] [17:55:00] [ERROR] [QUICKAPP450]: in Rule:5[@17:55 =>...]: {"msg":"Error executing instruction:'[\"Telegram\",1]'","ERR":true,"src":"Rule:5[@17:55 =>...]","err":".\/include\/EventRunner.lua:1824: No such function:Telegram"}
    //Sjakie
    Jan,
    Sorry fot the picture I thought that I did a delete.
    Getting error:
    [26.11.2020] [19:00:21] [ERROR] [QUICKAPP162]: in Rule:98[woonKamer.tv:isOff =>fibaro:call(471, "changeActivityState")]: {"err":".\/include\/EventRunner.lua:264: Wrong parameter type, string required. Provided param '471' is type of number","ERR":true,"src":"Rule:98[woonKamer.tv:isOff =>fibaro:call(471, \"changeActivityState\")]","msg":"Error executing instruction:'[\"%calls\",4]'"}
    //Sjakie
    Jan,
    In QA I get this message but there is no link with QA 172 what does that mean?
    /monthly_2020_11/image.png.d3be8e477004a29142a17abafc05715e.png" />
    Sorry for asking so many questions but I am in the middle of migration.
    //Sjakie
    13 hours ago, Sjakie said:
    Jan,
    //Sjakie
    If you have more than one ER QA they will coordinate subscriptions between them. In this case QA 172 just made sure that there was no subscriptions from 177. It's a debug message that can be ignored.
    16 hours ago, Sjakie said:
    Jan,
    Thanks for support!
    //Sjakie
    Telegram is not included in ER4. You are expected to use a "Telegram QA" to send your messages from ER4.
    Jan,
    rule("kerstVerlichting={kerst.kerstBoom, kerst.kerstVers, kerst.kerstVers2, kerst.kerstSchilderij, kerst.kerstKrans, keuken.vliegenVerdelger}")
    Rule.eval([[@10:23 =>
    kerstVerlichting:on]])
    Is it possible here to do something simular as what is written in the rule below with a wait cmd?
    If yes it should shorten my rules a lot.
        Rule.eval([[hoofdSlaapKamer.lader:isOn =>
        kerst.kerstBoom:off; wait(00:00:02); kerst.kerstVers:off; wait(00:00:02); kerst.kerstVers2:off;wait(00:00:02); kerst.kerstSchilderij:off; wait(00:00:02);
        kerst.kerstKrans:off; wait(00:00:02); keuken.vliegenVerdelger:off;
        log('kerst verlichting - Uit')]])
    Please advice,
    //Sjakie
    21 hours ago, Sjakie said:
    Jan,
    Please advice,
    //Sjakie
    There is no way to automatically insert delays in a group command. But this should work
    Jan,
    You are the best always a nice solution to improve thehome automation!
    Thanks,
    //Sjakie
    Hello All
    Santa brought me Fibaro The Button, anyone know how to use it with ER3 ? Jan :) ?
    Just now, domin12 said:
    Hello All
    Is it a centralSceneEvent type of device?
    ...and Santa seems to be a bit early in your part of the world :-)
    If it is try this script to see what key values you get
    %%events
    77 CentralSceneEvent
    rule("button=77")
    rule("button:scene => log('KeyId:%s, KeyAttribute:%s',env.event.keyId, env.event.keyAttribute)")
    If you get keyid == 1 and keyAttribute == 'Pressed' you can make a rule type
    rule("button:scene.keyId==1 & button:scene.keyAttribute=='Pressed' =>lamp:on")
    Jan,
    In HC2proxy I add curtain switch.
    If I change the name I see it in Debug as activity.
    If I want to operate the curtain:
    - push the button in devices>>>nothing happen
    - use on/off button in preview >>>opens/close the curtain but No debug of the action and   no change in device icon it stays red(off)
    -in ER with trigger from HC2 no action.
    -in Blockscene with trigger HC3 >>>curtain close/opens
    I would like the curtain as trigger so I can try to use my HC3  a bit
    Thanks in advance,
    //Sjakie
    %%events
    rule("button=77")
    Hi Jan,
    Nothing happened when click the button.....
    this is a solution from other topic, and it works
    Edited by domin12
    3 hours ago, domin12 said:
    Hi Jan,
    Sorry, should be :central instead of :scene
    7 hours ago, Sjakie said:
    Jan,
    Thanks in advance,
    //Sjakie
    What type has you set the curtain to?
