Jan,
Goodmorning, is it possible to integrate the IPhone alarm as trigger in HC2 or HC3?
Thanks in advance,
//Sjakie
    49 minutes ago, Sjakie said:
    Jan,
    Thanks in advance,
    //Sjakie
    You can create a iPhone shortcut. There you create a "Personal automation" (at the bottom of the first screen) and select alarm as trigger and the Home Center app as action.
    Unfortunately you can only choose to run a scene on the HC3. So you need to make a simple scene that calls ER4 or ER3 with the event needed.
    Actually, it would be possible to have a web action that calls the HC3 API directly.
    Thanks will look into it later I started again with ER4
    but???
    This rule is copied from HC2
    Util.defTriggerVar("openVanBuitenDeurToilet",false)
    rule([[toilet.deur:breached =>
        log('Check!!!!!!!!!! - toilet.pir:safe %s',toilet.pir:safe); log('Check!!!!!!!!! - toilet.deur:safe %s',toilet.deur:safe);
        || toilet.pir:safe >> openVanBuitenDeurToilet=true; toilet.Spottoilet:on;
        || toilet.pir:breached >> openVanBuitenDeurToilet=false; toilet.Spottoilet:off;
    rule("openVanBuitenDeurToilet==true => log('DEFTRIGGER >>>>>>>>>>>>>>>openVanBuitenDeurToilet true')")
    rule("openVanBuitenDeurToilet==false => log('DEFTRIGGER >>>>>>>>>>>>>>openVanBuitenDeurToilet false')")
    rule("openVanBuitenDeurToilet==true => toilet.Spottoilet:on; log('DefTrigger maaktttttttttt  Spottoilet toilet - aan')")
    Unfortuanally it doest switch the toilet light on!
    In debug I see log('Check.........
    But no true rule openvanbuitendeurtoilet??
    If I add toilet.Spottoilet:on; it will switch light on.
    Jan what I am doing wrong?
    //Sjakie
    The deftrigger doest operate
    Jan, toilet light is working now with sometimes a miis.
    What is the correct notation in ER4 for:
    fibaro.alert('push', {[1] = 2, }, 'HC3 rebooted')
    Thanks in advance,
    //Sjakie
    Thanks in advance,
    //Sjakie
    rule("... => 2:push='HC3 rebooted'")
    You can also write
    rule("... => fibaro.alert('push', {2}, 'HC3 rebooted')")
    Thanks Jan thats working great the msg if HC3 is rebooted.
    Other small problem:
    - I did a HomeTable in QA >> can it show in debug the list of devices?
    - I have one device who gives an error if name is being used >>no trigger?
      if I use the number it shows the action so I checked the name if I copy/past it still give an error
    Thanks,
    //Sjakie
    Thanks,
    //Sjakie
    You want to print the HT table?
    You can print out the HT in a readable format with
    self:prettyJsonStruct(<table>) returns a readable string representation of the table that is indented and with newlines.
    On 11/17/2020 at 7:55 AM, jgab said:
    90min is 00:90, or 01:30
    Parenthesis missing and misplaced, I changed a bit.
    trueFor(<time>,<expression>)
    takes 2 argument, a time and and expression that should be true for that time.
    Now it triggers on key 2 for Pressed, Pressed2. etc. You could add
    Rule("Matrix:central.keyId==2 & Matrix:central.keyAttribute=='Pressed' => Heating:on")
    @ is a timmer that starts the rule at a specific time. To test a time use interval test <timeA>..<timeB>
    In general you don't need to use global variables ($) unless you use it to communicate with other scenes
    The last rule turns off the light if light is on and door is safe for 10min (both) during the sunset..sunrise period.
    Hi
    This syntax fails - towel_dryer = matrix_badV + 5
    is is not possible, or how should I write it ?
    matrix_badV = 182
    towel_dryer = matrix_badV + 5 -- 187 Device/Switch
    Rule("@06:15 & wday('mon-fri') => towel_dryer:on")
    15 hours ago, ChristianSogaard said:
    Hi
    matrix_badV = 182
    Sorry I don't understand
    is ok syntax ?
    @jgab Can You please tell me how to convert scene like this (with ID Central Scene and it's buttons) to ER4?
    /monthly_2021_01/1245120972_Zrzutekranu2021-01-4o15_38_55.png.946c614060f372304a52d33fa50304ea.png" />
    My polish is not good :-) Have to guess a bit. The condition (left) is it AND or OR ?
    If I have guessed right it could be something like:
    If you double-click. on key 1 and the salon lamps are on, then turn on the 'binary' lamps.
    OK, will be easier if I write it down :)
    For example I want to achieve:
    Lamp1:isOff & Lamp2isOff & Double press button 1 > turn both lamps on
    Lamp1:isOn & Lamp2IsOff & Single press button 1 > turn of lamp1
    This modules has 5 devices:
    Alternatively
    is ok syntax ?
    I wanted to create a new variable - towel_dryer (this is Key 2 on Matrix )
    matrix has device ID 182
    So new variable based on first variable with device ID 182 +1+2+2 = 187
    I hope i explained it better ?
    It should work if you do
    'towel_dryer' should be accessible inside the rule.
    Note that it has to be a Lua global. You can't declare it local
    local towel_dryer = matrix_badV + 5 -- Will not work!
    You could also create a rule variables
    towel_dryer and matrix_badV is only accessible inside rules and not visible to outside Lua code.
    2 minuty temu, jgab napisał:
    rule([[button:central.keyId==1 & button:central.keyAttribute=='Pressed2' & Lamp1:isOff & Lamp2:isOff => {Lamp1,Lamp2}:on]])
    It doesn't work...and I think I can't because rule doesn't know which button check?, we have "button:central.keyId==1" but from  which module should it take from? maybe I get it wrong?
    button is a variable that should be assigned the deviceId of the remote/keypad
    Ex. rule("button=88")
    You could write
    rule([[88:central.keyId==1 & 88:central.keyAttribute=='Pressed2' & 99:isOff & 88:isOff => {99,88}:on]])
    but using rule variables are more convenient
    rule([[485:central.keyId==2 & button:central.keyAttribute=='Pressed2' &
           486:isOff & 487:isOff => {486,487}:on]])
    i recieve:
    [QUICKAPP453]: in Rule:7[485:central.keyId==2 & button:central.keyAttribute=='Pressed2' &...]: {"err":".\/include\/EventRunner.lua:1851: bad deviceID 'nil' for '%prop' '\"button\"?'","src":"Rule:7[485:central.keyId==2 & button:central.keyAttribute=='Pressed2' &...]","msg":"Error executing instruction:'[\"%prop\",1,\"central\"]'","ERR":true}
    i recieve:
    You missed second 'button' in the rule
    OMG...sorry for that, too many hours in front of the screen
