9 minutes ago, jgab said:
Yes,
and if. you set it to nil the next rules will not be tagged.
Wow, that's a very amazing feature! Does the rule of nill tag stop when tag(winter) is activated?
    No, only tagged (~= nil)  rules are affected by enable/disable
    Thank you for answer.
    I enjoy every time with amazing features.
    Do you have any plans to make WIKI for all functions?
    It seems that accessibility is inferior because I keep searching for the contents of the forum each time or receiving answers through questions.
    I organize the rules I learned here and organize them using a program called Notion.
    It can be managed like a WIKI page and can be shared.
    However, please understand that it is in Korean.
    Edited by Earybeongbeong7
    I would really like that the Fibaro forum had a wiki so the members could collaborate on documenting things and sharing tips. A topic thread is not very good at organising stuff. In my "HC3 tips and tricks" thread I try/tried to keep the first post like an index with pointer to interesting posts in the thread but it's not easy to maintain - and only I have write access to the first post.
    External wiki? yeah, maybe but it's always hard to keep spread out resources up to date....
    Thanks for the much effort.
    On 1/26/2021 at 8:11 PM, jgab said:
    ER has the concept of rule sections that makes it easy to group rules. A feature that has been available in ER for a long time.
    Does only one tag work?
    For example, in the above rule, if the summer tag starts after Winter, does the winter tag stop?
    Yes, if you enable with enable(<name>,true) all other rules with tags will be disabled.
    You can also do it explicitly like enable(<tag1>);disable(<tag2>);disable(<tag3>)
    That means it can be partially run?
    enable(<tag1>);enable(<tag2>);disable(<tag3>); disable(<tag4>); enable(<tag5>)
    Jan,
    What kind offcause can give this error?
    [28.01.2021] [10:59:39] [ERROR] [QUICKAPP797]: refreshStates:End of file
    32 minutes ago, Sjakie said:
    Jan,
    Your HC3 didn't respond correctly to an api call (refreshstates) - maybe too busy? ER4 will report and continue. If you see the error repeating every second you have a serious problem where the HC3 stopped responding to api call all together...
    Hi @jgab
    thank you for your amazing work on
    I was wondering if is possible to have triggers in EV4 from the HC3 MQTT Client?
    and also do publish MQTT topics ?
    9 minutes ago, ChristianSogaard said:
    Hi @jgab
    Yes, with a bit of code
    If you have a MQTT message handler
    If the event look like (Example from <
    We can pick it up with a ER rule with
    Exactly how you want to recode the MQTT event to an ER event depends on usage. Note that the 'type' field of a MQTT event is a number and the 'type' field for an ER event is a string so we need another mapping
    To publish something, given that you have stored the MQTT client in self.client like in the example above:
    Hi Jan
    I have a QA with device ID 1117 where this function is called  and Eventrunner in another QA.
    I see the "onMessage" in the log each time a topic is posted to the MQTT,
    I dont see the {"payload": in eventrunner. - does it need to be in same QA?
    I still lack the proper understanding of using the self and UpdateProperty that could be usefull here..
    so you can point me in a direction I could read, i would be really great.?
    47 minutes ago, ChristianSogaard said:
    Hi Jan
    Ok, I understand.
    Do you get an error from self:post or are you using my toolbox library?
    If you do you can replace self:post({...}) with
    self:postRemote(ID_of_ER_QA,{...})
    and it will send the event to the ER QA.
    1 minute ago, jgab said:
    Ok, I understand.
    If not you can implement postRemote yourself
    19 minutes ago, jgab said:
    Ok, I understand.
    I dont see any errors in the Log.
    I think is best to learn to implement you toolbox - does this seems correct?
    Just uncomment the evens module
    Do you know why this happens ?
    I tried downloading the newest fibaroapiHC3.lua - this also gives a "unexpected symbol near '<'"
    not sure how to fix this?
    Open fibaroapiHC3.lua and run it.
    You should get a better error message and try to see what line is offending (line 7 is in the middle of a multi-line comment in the original file so that doesn't make sense)
    So, I can't repeat your problem.
    Can't see where the name'fibarapiHC3.lua' comes from either.
    You use the latest plugin?
    Thank you Jan. You cant repeat my problem because you didnt do the same stupid error as I did. ???
    Toolbox is downloaded.
    Need to look into this
    [30.01.2021] [13:58:02] |[35mSYS  [0m|: HC3 SDK v0.158
    [30.01.2021] [13:58:02] |[35mSYS  [0m|: Created Event server at 192.168.201.236:6872
    [30.01.2021] [13:58:02] |[31;1mERROR[0m|: Code crashed: cannot open Toolbox/Toolbox_basic.lua: No such file or directory
