12 godzin temu, jgab napisał:
Sorry, should be :central instead of :scene
Both, KeyId and KeyAttribute are empty:
[DEBUG] 12:11:04: KeyId:%s, KeyAttribute:%s
    Good news, it triggers.
    Try this
    Try this
    [DEBUG] 12:22:40: KeyData:{"type":"property","deviceID":1233,"value":{"keyAttribute":"Pressed","icon":{"path":"fibaro/icons/com.fibaro.FGPB101_black/com.fibaro.FGPB101-1Pressed_black.png","source":"HC"},"deviceId":1233,"keyId":1,"timestamp":1607512960},"_sh":true,"propertyName":"CentralSceneEvent"}
    Ok, sorry, The rule that log the key values should look like
    This rule should work, if you have a 'lamp'...
    Perfect, Thank You
    Hello Jan,
    I am very satified with your proposal!
        Rule.eval([[#knipperenAan =>
            for _,id in pairs(kerstVersiering) do id:on; wait(00:00:01) end;
            for _,id in pairs(kerstVersiering) do id:off; wait(00:00:01) end;
            post(#knipperenAan);
                log('kerst verlichting knipperen - Loopt')
    It let to blink our Christmaslight.
    How to kill post(#knipperenAan)?
    Or is there a better solution?
    Thanks in advance,
    //Sjakie
    The above part with saving the lamps' individual state doesn't work for me, none of the lamps go back to their previous state when I switch back to to Home after being Away. Any idea on what can be wrong? My other code with specific random toggling of the lights when Away works fine (so the global Home_Away variable works fine).
    Hmm, it seems like the code for table assignment fell off when converting ER3->ER4. Because you are using ER4?
    I have pushed a new version v0.5fix36 - restart if you have autoupdate enabled.
    Thanks!
    No, I use an old version of EventRunner3 for HC2 so I will update to the latest version as a starting point.
    Error after this update
    Version v0.5fix36
    2020-12-13] [11:00:06 pm] [ERROR] [QUICKAPP1532]: in Rule:34[$PresentState=='Home'  & bedmotion:breached =>...]: {"err":"attempt to get length of a number value","ERR":true,"src":"Rule:34[$PresentState=='Home'  & bedmotion:breached =>...]","msg":"Error executing instruction:'[\"%setprop\",2,false,[\"color\"]]'"}[2020-12-13] [11:01:13 pm] [DEBUG] [QUICKAPP1532]: [true]>>'Rule:25[$PresentState=='Home' & officemotion:breached => ...]'[2020-12-13] [11:01:13 pm] [ERROR] [QUICKAPP1532]: in Rule:25[$PresentState=='Home' & officemotion:breached => ...]: {"err":"attempt to get length of a number value","ERR":true,"src":"Rule:25[$PresentState=='Home' & officemotion:breached => ...]","msg":"Error executing instruction:'[\"%setprop\",2,false,[\"color\"]]'"}
      rule("officedeskLight={of.Office_Rgbw1,of.Office_Rgbw2}; officemotion=of.Aeotec_Motion; officeLight=of.Office_Light ")
      rule("officetimer = 00:05")
      rule([[$PresentState=='Home' & officemotion:breached =>
        || 22:00..23:00 >> officedeskLight:value=50; officedeskLight:color={0,255,0,0}
        || 23:01..00:00 >> officedeskLight:value=50; officedeskLight:color={0,119,155,0}
        || 00:01..01:00 >> officedeskLight:value=20; officedeskLight:color={129,70,0,0}
        || 01:01..02:00 >> officedeskLight:value=20; officedeskLight:color={215,0,255,0}]])
      rule([[$PresentState=='Home' & trueFor(officetimer,officemotion:safe) & 22:00..03:10 => officedeskLight: value=5]])
      rule("@03:20   =>  officedeskLight:off")
      rule("bedmotion=br.Bed_Motion; Bedlamp={br.Bed_Blub1,br.Bed_Rgbw}")
      rule("bednight = 00:05")
      rule([[$PresentState=='Home'  & bedmotion:breached =>
         || 21:00..02:00    >>Bedlamp:value=50; Bedlamp:color={227,143,6,0}
         || 02:10..03:00-1  >>Bedlamp:value=30; Bedlamp:color={227,143,6,0}
      rule([[$PresentState=='Home' &  trueFor(bednight,bedmotion:safe) & 21:00..03:00-1 => Bedlamp:value=5]])
      rule("@03:00   =>  Bedlamp:off")
    Version v0.5fix36
    Thanks, v0.5Fix37 pushed.
    Thanks very fast update Works
    Hello Jan,
    I do something wrong but dont know what.
            Rule.eval([[hal.locatieGezin:isOff =>
            || (@23:15 & wday('sun')) >> post(#nightLightsOff); log('licht uit locatieGezin afwezig en rond 23 uur');
            || @23:20 & wday('mon') >> post(#nightLightsOff); log('licht uit locatieGezin ...............
    This rule is executed at the moment hal.locatieGezin:isOff independant from time, extra () doest help.
    PLease advice,
    //Sjakie
    Jan, sorry to solve I know I will add the time in trigger and the post with delay.
    The syntax is a bit wrong.
    To make it clearer you can split it into 2 rules.
    The question os what you want with the time test? When the hal.locatieGezin is turned off it is most likely not exact 23:15 etc. Do you mean after 23:15? Then you test now >= 23:15
    Jan, Thanks!
    Just to know what is the end time if not specified?
    Jan,
    This morning I was surprised that my main curtain just opend half???
    It never has happend before.
    Debug showed curtain open.
    Is my asumtion right?
    -if curtain is not closed he reports open and vice versa
    -lights respond if curtain is open but in reality they respond if curtain goes open
    Please enlight me
    Can I change cmd to open 100%?
    Thanks in advance,
    //Sjakie
    I start migrating all my scenes to Event Runner 4
    This works for Children of Hue - but was wondering if there is a more optimal way of doing this . This was i think I will end up with at least 250 rules.
    Can I for example group the rules with pressed or pressed2 into one rule(per matrix)
    Yes, it becomes many rules. In principle you only need the triggering rule per matrix device, what to do with what key combo can be taken from a table - similar to the scene version.
    We also create a helper lua function (callLamp) that do all the work - easier in Lua than in EventScript.
    On 12/24/2020 at 9:01 AM, Sjakie said:
    Jan,
    Please enlight me
    Thanks in advance,
    //Sjakie
    You can check and see what "value" property the device is set to. Is it ~50? I guess 0 and 99 is the min and max values for closed and opened.
    Dear @jgab, it has been a while since I have looked at this topic and wow, your work has really expanded and matured :)
    I am still using v1.4, which is ancient compared to what happened here in the meantime; it still runs like a charm btw :)
    I am building a new use case in which I need a scene to be triggered when event B follows event A within 1 minute. If B happens without A or B happens before A, something else should happen. Can your framework handle that? (NB I am still running HC2)
    Thanks!
    Edited by 3JL
    Thanks!
    The tricky part is the last rule that needs to have a test that is false when the second rule's test is true.
