    3 hours ago, Earybeongbeong7 said:
    Module 'childs' missing
    Can I currently ignore this debug content after the update?
    I proceeded the update in the following way.
    I compared the structure of the newly installed Quick App. The quick app that was updated did not have a new module. (child)
    When updating the existing Quick App, I hope that new module files are uploaded.
    Is it okay to upload new module code? in  Existing used Quick APP.
    Thank you very much for upgrading the maintenance and new features every time.
    Yes, you can update the file(s) manually.
    I never update "main" as it contains your  rules.
    The other files are updated from my GitHub so it can be a bit difficult to know which files to use.
    It consist of the EventRunner4Engine.lua and files from the /toolbox subdirectory
    I will try to more regularly update the QA linked in the EventRunner4 intro post so that it contains the last version of the files (I just did that)
    However, in the best of worlds, the autoupdate will work.
    I'm also thinking about a model with beta-releases that would make it a bit less risky...
    Guest kallecux
    Hi @jgab i updated the function: Util.updateFile(file) and it works - thanks for your quick response.
    I get this warning while startup:
    [28.09.2020] [08:26:28] [WARNING] [QUICKAPP490]: Module 'childs' missing
    Greetings!
    Greetings!
    Yes, there is a bug in the update routine for new modules. You can ignore it for now (unless you use the new child feature) and I will fix it in the next update.
    Thank you for your confirmation. The new features work so well.
    Could you please find out about the problem below?
    4 hours ago, Earybeongbeong7 said:
    is there a way to send global variable value or local variable value in QA message?
    AND.
    Which button content can be changed based on an arbitrary button like the attached picture? What is updated is the global variable value.
    You mean like this?
    The second question I'm not sure I understand. You want to update the text of the button?
    It means whether the content of the button can be replaced with the value of a global variable.
    ex,
    The value of the global variable TimeOfDay will change according to this rule.
    Is there a way to display the value in the preview screen of the quick app?
    The picture is an example of another quick app.
    If the content or status of the value appears like the lined part, I think it will be possible to easily check the global variable in the setting of HC3 when using ER4.
    Therefore, I suggest this part.
    And,
    Can other types of equipment be supported?(ex. Multilevel sensor, Energy meter ??)
    Edited by Earybeongbeong7
    How is auto update applied when writing ER4 rules through ZBS? Are the versions of QuickApp and ZBS compatible? Or should I put the update related files in ZBS? (ER4engin, toolbox, etc)
    Yes, you need to put them in the right directories by hand. (maybe I can automate it in the future)
    Jan,
    I have a handshake error where to look? Thus the number guid to some where?
    Please advice,
    //Sjakie
    New version of fibaroapiHC3.lua v0.135.
    New version of ER4 0.5fix24
    Wan running ER4 in ZBS you can call
    It will download the latest
    Toolbox/Toolbox_basic.lua
    Toolbox/Toolbox_events.lua
    Toolbox/Toolbox_child.lua
    Toolbox/Toolbox_triggers.lua
    Toolbox/Toolbox_files.lua
    Toolbox/Toolbox_rpc.lua
    Toolbox/Toolbox_pubsub.lua
    to the current directory
    On 9/14/2020 at 11:13 AM, jgab said:
    lamps={22,33,44,55,66,77,88} rule("$Away => lampStates = lamps:value") -- Save lamps current states rule("!$Away=> lamps:value = lampStates") -- Restore lamp states rule("@@rnd(00:10,00:30) & $Away & sunset..sunrise => lamps[rnd(1,length(lamps))]:toggle") -- toggle a random light every 10-20min
    Is it possible to set a specific time frame that this should be valid instead of between sunset to sunrise? Say that you want to simulate that someone is at home between 10:00 and 15:00 on weekdays.
    I also did a simple test with switching the sunrise and sunset (see below) but that gave the attached error message.
    sorry Jan, I forgot to paste the error
    Yes,
    rule("@@rnd(00:10,00:30) & $Away & 10:00..15:00 & wday('mon-fri') => lamps[rnd(1,size(lamps))]:toggle") -- toggle a random light every 10-20min
    Sorry, the length function is called 'size' in ER
    rule("@@rnd(00:10,00:30) & $Home_Away=='Away' & sunrise..sunset => lamps[rnd(1,size(lamps))]:toggle") -- toggle a random light every 10-20min
    6 hours ago, Sjakie said:
    Jan,
    Please advice,
    //Sjakie
    It's a http request. I need to see the error message to try to figure out what it comes from. Nodered, Telegram, Hue?
    Jan,
    I gues Telegram.
    I still have the telgram errro network unreachable not able to tackle it.
    I didt see it for a long time.
    Now I play with Danalock and noticed it
    Can it be related with
    /monthly_2020_09/image.png.f03128bf17009bbe0fdf1ef915ae0f7b.png" />
    Thank you,
    So, can we just change fibaroapiHC3.lua and run er4 on ZBS right away?
    Or should I put ‘DOWNLOADSOURCE() in the ‘rule’ code and execute it?
    Wow!! Very good idea!! Thanks.
    1 minute ago, Earybeongbeong7 said:
    Thank you,
    The DOWNLOADSOURCE() function is defined inside EventRunner4Engine.lua so you need to open EventRunner4.lua in ZBS, add the call to
    DOWNLOADSOURCE() in QuickApp:main() and run it once to download the code.
    Ex.
    If you have the autoupdate rules you could do something like this
    and it will download the new source when available. If  it downloads you need to restart the debugging session so it will use the latest source.
    It's not default as it makes a web request every time to my GitHub which may slow things down when developing/debugging
    Thanks, no it works! A question on the rnd command, does it take one lamp at a time or can you control that by the first numerical in the parenthesis? rnd(1, size etc)
    rnd(x,y) returns a random number between (and inclusive) x and y.
    In our case it generates a number between 1 and the number of lamps, that we use to select a lamp from the array.
    A more sophisticated function would run through each lamp to get a optimal distribution. Now lamp 4 may be turned on/off twice in a row - it's random ;-)
    It does not proceed when forced update is performed in my version (0.5fix 23).
