    Working with event runner rules it can be useful to understand a bit how they work behind the "hood".
    Rules are always on the form
    Ex
    If there is no "=>" in the rule it is considered just an expression that is executed immediately.
    When the rule is defined (the function rule(<str>) executes) the string is compiled to an internal efficient way to run the rule.
    The rules are usually defined within a main() function that is run once. The definition/compilation stores the rules in a rule database to be triggered when appropriate events happens. It means that in main() is also a good place to run things that should only be run once when EventRunner starts up. Like initialising  device to off or setting ups Lua variables etc.
    At "compile time" the test part - the left-hand side - is examined for tests that involved devices, events and globals - referred to as "triggers".
    Ex. the above rule contains a reference to device 88 and a breached test (which is the same as a 'value' property change)
    The list of triggers for a rule is used to determine when a rule should run. The above rule will only be run when we get a system event that device 88's value property has changed,
    This will trigger when 88's lux property change or the fibaro global MyDay changes value (then it will test if  $MyDay=='work')
    If the examination of the test can't find any triggers it will give the error "no triggers found in rule ..."
    The effect of this is that rules will only run when a trigger is coming in that could actually trigger the rule.
    This is very efficient as we don't have to run through all the rules every time - because that would mean that the system became slower the more rules we added.
    Instead, this allows us to scale and manage a lot of rules.
    If it triggers the rule we run the test part to see if the condition is full-filled and in that case we run the right-hand side, the actions..
    So, a rule can still be triggered but the test being false - we can't get around that.
    There is another trigger that is the 'time triggers'. @<expr> and <exprA>..<exprB> causes the rule to be triggered at given times.
    The <exprA>..<exprB> is the interval test. Ex sunrise-00:10..sunset+00:10
    It causes the rule to be triggered at time <exprA> and at time <exprB>+1s
    Ex.
    We want this rule to trigger if 88 changes value. We also want it to trigger at sunrise. Because the 88 can have been breached just before sunrise but the rule didn't execute because it was before sunset. Then when sunrise happens we want the rule to run (if 88 is still breached of course). The reason we also trigger the rule at <exprB>+1s is because we want negations to work too
    ! is the logical  'not' operator - it requires a bit of thinking to understand why it needs to test x+1s, but the important is that it makes the rules easy and logical to write.
    The last type of trigger is events. Events are Lua tables with a type field.
    The above is a typical sourceTrigger on the HC2 (on the HC3 the fields are a bit different but still has a type field)
    An event trigger in a rule can be written
    and it will trigger the rule when an incoming trigger matching the event is seen. It can of course be combined with other triggers described above.
    However, the above rule is exactly as this rule
    The compiler translate it to the same code.
    Sometimes if there is a new type of device emitting new types of sourceTrigger events and I haven't updated EventRunner to deal with that using the <deviceId>:<property> format, one can still use the full sourceTrigger as in the example above.
    However, the real power of EventRunner comes with the fact that we can post our own events. As long as it's a table with a type field it's considered an event by EventRunner.
    In a previous post I show an example on how to catch centralSceneEvents and re-post them as #Key events.
    This allows us to structure our home automation rules so that they still makes sense when we have to update them a month later :-)
    The fact that we can also post events at a given time in the future allows us to make timers in a simple way.
    It's also a simple way to make loops
    We can also use the same technique to define state-machines (useful in more complex automation  systems) and specific "flows" throughout rules. I will come back on that later.
    In effect, EventScript - what I call the language - is a (Turing) complete programming language getting it's inspiration from languages like Prolog and Erlang but adapted to deal with time and timers and concepts making it suitable for describing home automation tasks...
    • Thanks 2
    On 9/14/2020 at 4:14 AM, Earybeongbeong7 said:
    Hello. I am using ER4 well. I would like to provide additional comments.
    I wish there was a restart button for ER4 and an update confirmation button (or automatic update on-off button, etc.) on the preview screen of ER4. It looks like a good test for home center errors (or other checks).
    I have pushed 0.5v16 that has a new model for handling UI buttons.
    You can add your own buttons in the UI for ER and handle them.
    Ex. define a button 'Label' = "Restart" with the 'ID' = "restart". The onReleased you can leave.
    Then define a rule like ´below and you have a restart button
    Insert another button to do update (if available)
    button 'Label' = "Update" with the 'ID' = "update". (this will be instead of the regular 05:00 update check)
    The ER4 comes with some pre-defined buttons for turning on/off some debug flags.
    However, the thinking has been that you define your own buttons in ER4 that trigger the rules you want. ...and now it's possible.
    Guest kallecux
    Hi @jgab, thanks for your description!
    You wrote on page 1 of this post the following description:
    -- Turn on 2 lamps  15min past sunrise on weekdays
    Rule.eval("@sunrise+00:15 & wday('mon-fri') => {myLight1,myLight2}:on")
    The lamp turns on at sunrise AND the day of week is a weekday!
    Here you wrote:
    88:lux & $MyDay=='work' => log('Tada')
    This will trigger when 88's lux property change OR the fibaro global MyDay changes value.
    I thought, that "Tada" sounds when 88:lux changes AND $MyDay is "work" - i am confused.
    Is this true?:
    88:lux > 50 & 88:breached => log("light on")
    It will be logged when 88:lux > 50 AND 88:breached? or
    It will be logged when 88:lux > 50 OR 88:breached?
    Edited by kallecux
    Yes from a high level the rule will run (logging 'Tada') when 88:lux changes AND $MyDay is "work.
    However, describing what's going on under the hood, the rule is actually triggered either when 88:lux changes value or $MayDay changes value.
    When the rule is triggered the test (left-hand side will run) and check if 88:lux is true (which it always is if it has a lux property. We don't test what the lux value should be), and then it checks if $MyDay is "work". If the test is true it will run the action part (right-hand side) and log "TaDa"
    Is this true?:
    AND :-)
    Guest kallecux
    Yes yes yes - Who can read has a clear advantage!
    You wrote the rule is actually triggered either when 88:lux changes value or $MayDay changes value.
    Thanks for the enlightenment! :-)
    Thank you very much for reflecting my opinion.
    I made a button like this now, and I confirmed that it works well.
    How can I turn on and off random automation from a button like this?
    r = rule("@@00:05 => log('5min ping between 12:00 and 15:00')")
    rule("#UI{name='r_start'} => r.enable()"); wait(03:00); r.disable()")
    If you want to start with the "incomming trigger" turned off upon restart, can you modify it as follows?
    In this case, is the state of the button synchronized with the initial restart?
    _debugFlags.trigger = false -- log incoming triggers
    Edited by Earybeongbeong7
    Something like below. I realise that there is no way to check of a rule is enabled or not. I will add a flag to the 'r' value returned by rule() in the next version so it's easier to toggle the enabled state. Now we have to keep the state in a variable (r_start).
    You could also let it run every 5min and check of it should ping (it doesn't take much resources)
    The Util.defTriggerVar makes an eventscript variable behave like a fibaro global - it can be used to trigger rules when it changes values. Normal eventscript variables (or lua globals) don't behave like that. It only triggers rules if it changes value, so if it is set to the same value it won't trigger a rule (like fibaro globals)
    Quote
    Yes, but only for the 3 debug flags that are predefined. Next version I will make a more general mechanism so it is easy to add debugFlag buttons for any debug flag.
    1. Is this save the internal value of "r_start" in reverse?
    2. Is this the right code?
    Isn't the following code correct?
    3. Can I get more explanations on what exactly this means??
    Yes, '!' is the. logical NOT operator.  Like "X = not X"
    Quote
    Well, it just defines the rule and sets it to disabled immediately.
    Same as
    The idea was that it starts disabled and you enable it with the button.
    Quote
    The eventscript variable 'r_start' is defined as a trigger variable. (Uti.defTriggerVar) This means that when it changes value it can be used to trigger rules.
    When we change the value of 'r_start' in the #UI rule by doing "r_start = !r_start" it will trigger these rules.
    When set to true to will trigger the first rule and when set to false it will trigger the second (!r_start => ....)
    It then enables or disables the rule (r) and updates the text of the button (with ID 'r_start'). QA is a variable bound to the QuickApp's 'self' variable so we can use it to call methods like updateView.
    I made a mistake and used """ for the strings in the QA:updateView - it should be single quotes.
    Same as
    I don't understand logically about "!", so I ask again.
    Is "r_start =! r_start" correct to store "r_start = false" as "r_start = true"?
    Of course the opposite is stored as "r_start = false"?
    Does "r_start => r.enable ()" mean to execute the command if "r_start" is "true"?
    In other words, is it the same as "r_start==true => r.enable()"?
    In the same way, "!r_start => r.disable()" means to execute the command if "r_start" is "false"?
    That is, is it the same as "r_start == false => r.disable()"?
    Sorry for not understanding it properly.
    If you teach me, I will try my best to understand.
    Jan,
    This error I have
    /monthly_2020_09/image.png.1b4cb63b9fc55646411c5f768f617226.png" />
    but the rule is:
    Rule.eval([[sunrise-02:30..10:30 & hal.Kamerboven:isOn & overloop.Pir:breached  =>
                    hal.Danalock:unlock;
            log('TRIGGER:%s',tjson(env.event)); log('Kamerboven bezet pir overloop beweging Danalock  - geopend')]])
    Please advice,
    //Sjakie
    !true == false
    !false == true
    ...so yes, it sets 'r_start' to the opposite value.
    Yes, the rule is triggered every time 'r_start' changes value. The test, "'r_start' => ..." is true (because r_start is set to true and the rest of the rule will be run)
    Yes
    Yes.
    No problem, you are a fast learner :-)
    2 minutes ago, Sjakie said:
    Jan,
    This error I have
    but the rule is:
    Please advice,
    //Sjakie
    So I don't have any locks. The code device:unlock results in a fibaro.call(device,"unsecure") that have worked for other users in the past. However, it doesn't seem to be the right action for your lock to unlock....  (have you tried "hal.Danalock:value=1" or "hal.Danalock:value=0" ?)
    Can you send me the device definition struct for your lock?
    or if you copy from the swagger UI.
    Thank you for your kind explanation.
    I understood the code below.
    But I didn't understand the code below.  Can I get help?
    There is no “r.enable()” with the above code alone.  But I don't know how to run the r rule.
    Also, can you see "r" as any character?
    In other words, is it possible with characters other than “r” (ex. a, b, abc ...)? (a.enable(), b.enable(), abc.enable() ..)
    Quote
    The @@00:05 will trigger the rule every 5min, 24x7.
    However, the action (log) will only run if the test 12:00..15:00 is true,
    We add another condition that the variable 'r_start' also needs to be true. (something we change with the button)
    It's not so very wasteful to trigger the rule every 5min, even if the test is not true, It takes just a few ms every 5min to make the test.
    Quote
    Yes, so we don't enable/disable the rule. It triggers every 5min but the action only runs if "r_start & 12:00..15:00 " is true.
    Quote
    Yes, of course,
    Quote
    Yes you can use any valid Lua variable.
    However, the action will only if the test 12:00..15:00 is true,
    It's to very wasteful to trigger the rule every 5min, event if the test is not true, It takes just a few ms every 5min to make the test.
    do the two codes below mean the same thing?
    And
    In the above code, “r_start =>” is a condition that triggers when “r_start is true”. What does it mean to have “r_start = true” at the end?
    In other words, is the code below an efficient code that consumes a little less of the resource (or load) of “HC3”?
    8 hours ago, Earybeongbeong7 said:
    Util.defTriggerVar("r_start",false) -- start disabled
    rule("#UI{name='r_start'} => r_start = !r_start")
    r = rule("@@00:05 & 12:00..15:00 => log('5min ping between 12:00 and 15:00')").disable() -- start disabled
    rule("r_start => r.enable(); QA:updateView('r_start','text','Rule ON')")
    rule("!r_start => r.disable(); QA:updateView('r_start','text','Rule OFF')")
    On the contrary, can you understand that the same effect as enable() by button operation is under the conditions below, which is an automation without a condition that triggers every 5 minutes?
    My last answer was not so good - a crucial "not" was missing in one of the sentences (not easy to type on the iPhone).
    We have 2 variants of the rule.
    1. Disabling the @@-loop rule when we press a button. We use r.disable() and r.enable(). Note that if we enable the rule at 10:00 it will only ping between 12-15 because we have the test "12:00..15:00".
    2. Adding a extra check in the @@-loop that the variable 'r_start' must also be true if it should ping. This rule will trigger every 5min 24x7, but only ping when 'r_start==true' and "12:00..15:00"
    Rule 1 is a little more efficient as it disables the rule. In practice it will not show a difference on the HC3 load. It only runs every 5min to and the check takes milliseconds. You could have a 100 of these loops going on every 5min.
    If you have a rule that runs every second (@@00:00:01 => ...) I would recommend to disable it when it doesn't need to run.
    Yes the two rules. above are equal.
    Quote
    And
    The "r_start = true" and the "r_start = false" are unnecessary. The rule ""r_start => r_start = true; ..." trigger because 'r_start' is true so unnecessary to set it again. Sorry for the confusion. (changed it in the original post)
    Quote
    The variant that disables the rule is a little more efficient (less load. on the HC3) but it's so small you will not notice in this case.
    Quote
    missing @@00:05 in the above rule.
    Now I understand.  Thank you very much.
    Util.defTriggerVar("test",false)
    In this command, we can see that the local variable (test) acts as a trigger.
    Does this local variable only have true and false values?
    If you execute a command like the one below, does it have an arbitrary value?
    If so, the command below cannot be executed, right?
    Util.defTriggerVar("test",home)
    rule("test=> lamp: on")
    rule("!test=> lamp: off")
    Any value. This works:
