    5 minutes ago, Sjakie said:
    Jan,
    Error:
    fix 10 no such funtion print??????
    //Sjakie
    Sorry about that - function moved - fixed.
    Pushed v0.5fix11
    Jan,
    Is it me or....................Murphy
    Toilet light there is NO listing at all of this rule?????
    Util.defTriggerVar("openVanBuitenDeurToilet",false)
    rule([[toilet.deur:breached =>
        || toilet.pir:safe >> openVanBuitenDeurToilet=true
        || toilet.pir:breached >> openVanBuitenDeurToilet=false
    rule("openVanBuitenDeurToilet==true => print(MyTAG, 'greenyellow','deftrigger openVanBuitenDeurToilet true')")
    rule("openVanBuitenDeurToilet==false => print(MyTAG, 'greenyellow','deftrigger openVanBuitenDeurToilet false')")
    rule("openVanBuitenDeurToilet==true => toilet.spotToilet:on; post(#toiletBezet);  $Toilet='Bezet'; log('TRIGGER:%s',tjson(env.event)); print(MyTAG, 'aqua','#toiletBezet1 - post')")
    rule("openVanBuitenDeurToilet==false => toilet.spotToilet:off; post(#toiletVrij); $Toilet='Vrij'; log('TRIGGER:%s',tjson(env.event)); print(MyTAG, 'aqua','#toiletVrij2 - post')")
    [02.09.2020] [15:56:04] [DEBUG] [QUICKAPP540]: [true]>>'Rule:1[@{catch,05:00} => Util.checkForUpdates()]'
    [02.09.2020] [15:56:57] [DEBUG] [QUICKAPP540]: [true]>>'Rule:6[toilet.deur:breached => log('deur - open') ]'
    [02.09.2020] [15:56:57] [TRACE] [QUICKAPP540]: deur - open
    [02.09.2020] [15:56:57] [DEBUG] [QUICKAPP540]: [false]>>'Rule:7[toilet.deur:safe => log('deur - dicht') ]'
    [02.09.2020] [15:56:57] [DEBUG] [QUICKAPP540]: [true]>>'Rule:8[toilet.deur:breached =>...]'
    [02.09.2020] [15:56:57] [DEBUG] [QUICKAPP540]: [true]>>'Rule:4[toilet.pir:breached => log('pir - beweging') ]'
    [02.09.2020] [15:56:57] [TRACE] [QUICKAPP540]: pir - beweging
    [02.09.2020] [15:56:57] [DEBUG] [QUICKAPP540]: [false]>>'Rule:5[toilet.pir:safe => log('pir - veilig') ]'
    [02.09.2020] [15:56:59] [DEBUG] [QUICKAPP540]: [false]>>'Rule:6[toilet.deur:breached => log('deur - open') ]'
    [02.09.2020] [15:56:59] [DEBUG] [QUICKAPP540]: [true]>>'Rule:7[toilet.deur:safe => log('deur - dicht') ]'
    [02.09.2020] [15:56:59] [TRACE] [QUICKAPP540]: deur - dicht
    [02.09.2020] [15:56:59] [DEBUG] [QUICKAPP540]: [false]>>'Rule:8[toilet.deur:breached =>...]'
    Jan,
    is  it me??I open 3 scenes and all show empty
    Pushed v0.5fix11
    Thanks Jan
    Error still valid
     --Nodered.connect("http://12.10.79.152:1880/ER_HC3")
     --rule("Nodered.post({type='echo1',value='Hello'},true).value")
     --rule("Nodered.post({type='echo1',value=42})")
     --rule("#echo1 => log('ECHO:%s',env.event.value)")
     --rule("log('Synchronous call:%s',Nodered.post({type='echo1',value=42},true))")
    14 minutes ago, minsad79 said:
    Thanks Jan
    Error still valid
    Surprisingly hard bug to fix.
    ...but I think I got it now - pushed v0.5fix12
    ...and I have tried your Nodered code and it works
    Jan,
    HC3 restarted, automativc repair, restore latest version>> hehe
    I see the rules again but the toilet is still NOT showing the deftrigger part.
    Any idea it was functioning this morning and now the whole first floor is in HC3, perhaps I will regret.
    Sorry to bother you now you  are very busy.
    Please advice,
    //Sjakie
    Jan,
    The first error of 64 is Telegram
    Telegram.msg(TID,'%s = %s, %s',idname(id),id:armed & 'armed' | 'disarmed',id:safe & 'safe' | 'breached') end;
     Must I replace it with push message?
    //Sjakie
    the second :
    Rule.eval([[#startDisarming & armFlag == 'arming' =>
        armFlag = 'disarming';
        log('violet','#doDisarming 45 sec delay - post'); cancel(aRef); aRef = post(#doDisarming,+/00:00:00)]])
    in Rule:6[#startDisarming & armFlag == 'arming' => ...]: {"msg":"Error executing instruction:'[\"cancel\",1]'","err":".\/include\/Toolbox_events.lua:103: Bad timer reference:nil","src":"Rule:6[#startDisarming & armFlag == 'arming' => ...]","ERR":true}
    //Sjakie
    I'm trying to move my scenes / triggers from "StateWatcher" to "EventRunner4".
    rule ("trueFor (00: 01, motion:safe) & light1:on | trueFor (00: 01, motion:safe) & light2:on | trueFor (00:01, motion:safe) & light3:on => alllights:off ")
    1. Why does it make all the lights go on and off every minute?
    2. Why, if I turn on the light remotely (without appearing within the range of the motion sensor), the rule does not activate?
    Welcome!
    Split it up in several rules. Having "or" | in the left hand side of the rule (the head) is not advised. Especially together with. trueFor....
    :on is the command to turn on. a light, :isOn is the check if a lights is on.
    I think what you want to say is that if the motion is safe for 1 minute and any of the lights are on turn off all lights - is that correct?
    rule("alllights = {light1,light2,light3}")                                                         -- setup variable with all lights
    rule("trueFor(00:01, motion:safe) & alllights:isOn => alllights:off")     --  :isOn for a list of lights is true if any lights is on.
    Is this what you want? Otherwise let me know and we fix it.
    16 minut temu, jgab napisał:
    Welcome!
    "isOn" was the KEY :)
    Yes that's correct.
    It works great now :) but with "or" in this case worked as well
    1. Maybe this is a stupid question, but I don't see in the examples how to trigger a scene with a rule? Or maybe I can control the heating directly from "EventRunner4"?
    2. How to make the light turn off after 1 minute in such a rule?
    rule ("door: open & light: isOff & sunset..sunrise & (luxpp: lux <20) & motion: safe => light: on")
    1. <sceneID>:start
    unfortunately we can't send parameters to scenes as we could on the HC2.
    I think you should be able to do all the heat control in ER4. What are the fibaro.calls etc that you. want to do?
    Btw. fibaro functions can be used in ER4 rules.
    rule("@sunset => fibaro.call(heaterID,.......)")
    2.
    To test if a door is open use :breached (:open opens a shutter/blinds, same as fibaro.call(id,"open") )
    You write several rules. One that turn on. Another that watches for the condition when to turn off
    rule("door:breached & light: isOff & sunset..sunrise & luxpp: lux <20 & motion: safe => light:on")
    Ex.
    rule("trueFor(00:01,light:on & motion:safe) & sunset..sunrise  => light:off"). -- sometimes you don't want the extra conditions (ex.- sunset..sunrise) as you always want to turn off the light is there is no motion.
    1. I want to set heating shedule for "normal" operation when conditions are met (outside temp / closed windows / selected month range) or just start scene to do it when outside temp is below 15
    2. respectively if temp is higher than 15, set heating schedule to 4 degrees until canceled
    Yes, i know...my mistake, but for example, my door/window sensor reports on/off state instead safe/breached
    My idea is to create a delay effect like in the scene... the light is turned on (after meeting the conditions) and then turned off after 1 minute but regardless of all conditions
    1. Yes, you could add the fibaro calls to set the schedule in the action part of the rule. Just like you would have done in a scene. I don't have any heating devices so I don't know what the appropriate calls are. But testing on temp/month/closed windows etc is easily done in the rule head.
    2. yes see 1.
    :breached is an synonym for :isOn - just makes it easier to read the rule and understand that it concerns a sensors. (:safe is synonym for :isOff). I assume that fibaro.getValue(sensorID,"value") returns true/false ?
    To always turn off a light 1minute after it's turned on, no matter what
    rule("trueFor(00:01,light:isOn) => light:off")
    Hello
    i have question, how to send push message to a specific user/phone ?
    this below sent messages to my phone in both cases:
      rule("@@00:01 => 73:msg=log('pushaaaaaaaa')")
      rule("@@00:01 => 20:msg=log('pushzzzzzzzzzz')")
    will be gratfull for any help
    Edited by domin12
    1 hour ago, domin12 said:
    Hello
    I have to admit that I only used it with my own phone and that worked after a fix last week.
    You know that the id is the user id on the HC3 and not the phone id as it was on the HC2?
    Yes, I know, I also tried with the phone id when the user id didn't work. It doesn't matter what I give as the ID (must be existing phone id or user id), always get this push message on my phone
    Edited by domin12
    Strange. What happens if you try to push using the fibaro api?
    fibaro.alert(alert_type, user_ids, notification_content)
    Send custom notification.
    • alert_type – one of the notification types: “email”, “sms” or “push”
    • user_ids – list of user identifiers to send the notification to
    • notification_content – content of the notification to send
    Examples:
    Send notification with “Test notification” content using email to users with id 2, 3 and 4.
    1
    fibaro.alert("push", {2,3,4}, "Test notification")
    Hi Guys
    First attempt at using Event Runner.
    Could someone let me know if the below makes sense or ive missed something?
    Also do you need to set the parameters to use sunrise & sunset or is that something that is already set?
    dblight = 359
    dbfan = 362
    dbhum = 599
    dblux = 598
    dbmotion = 397
      Util.defvars(HT)
      Util.reverseMapDef(HT)
    rule("dbmotion:breached => 06:00..18:00 >> dblight:value=30, 18:00..6:00 >> dblight:value=70")
    rule("trueFor(00:01,dbmotion:safe) => dblight:off")
