    Yes,
    88:last returns the time since 88 last changed value
    {88,77}:last returns a table of the last times for 88 and 77, ex {360, 400}
    The same if you would ask for :value or :lux or any other property for a list of devices.
    :isOn, :breached etc. behave differently and always return a boolean value.
    and you can't do  {360, 400} >= 24:00.
    You need to reduce the table to a value depending on what you want to achieve. Ex. the max or the min value of the table
    Ex.
    The same problem for the second rule
    there is also an 'average' function that returns the average value of a table of value. Ex. more useful for getting the average of a number of lux sensors.
    Hello. When ER4 restarts after auto-update, the HC3 message says it started. If it is updated, we recommend sending a notification message that it has been updated.
    That's a good idea. Will implement in next version.
    Glad it was helpful.
    If the content of the message can be modified by the user or the developer, I think it would be better to write it down when making a major update.
    Of course, there will be a lot of difficulty in writing.
    Developer.
    Thank you very much for his hard work.
    On 9/3/2020 at 12:06 AM, jgab said:
    Surprisingly hard bug to fix.
    ...but I think I got it now - pushed v0.5fix12
    ...and I have tried your Nodered code and it works
    Works
    Thanks for your advice
    Guest kallecux
    Hi @jgab, now that geolocation is working in HC3 and the new app, can you please give me a hint, how to catch geolocation events with ER4?
    Thank you
    Karl Heinz
    Jan,
    HC2 Hue.monitor if enabled checks continuous the state of the selected Hue's is see now.
    Can I reduce it to reduce the load of trafic between Hue bridge and HC2?
    Fa my  lights need only to be checked if its dark and or #nightLightsOn.
    Is that possible?
    What is the effect from Hue.monitor, 22 Hue lights,  if used in HC3 in relation with load / my crashes?
    I gues not to much because at night no problems but less load on HC3.
    Please your valuable advice,
    //Sjakie
    3 minutes ago, Sjakie said:
    Jan,
    Is that possible?
    //Sjakie
    The second argument to Hue.monitor is the interval in milliseconds to poll the hub. Set it to a higher value like 5000 or 10000.
    How to write?
    2 minutes ago, Sjakie said:
    How to write?
    Hue.monitor(<id>,10000)
    Jan,
    Hue.monitor(12095, 10000)
    Hue.monitor(12096, 10000)
    or
    Hue.monitor("grondSpotVlag", 10000)
    Hue.monitor("sotBeeld", 10000)
    Both gives a continous flow of payload.
    //Sjakie
    Thank you
    Karl Heinz
    I haven't seen a GeoEvent yet. I think ER4 will log "unhandled event -- please report" when it sees one.
    Then it is easy to add it to allowed triggers.
    I will see if I can manage to trigger one...
    15 hours ago, Sjakie said:
    Jan,
    or
    //Sjakie
    I believe it should allow both names and deviceIDs.
    What do you mean by continuous? Can you show the code and the log?
    Hello Jan,
    it gives continuous the lines
    Hue number of lamp and payload
    Fibaro dont let me post .png anymore
    //Sjakie
    sorry command see previous post
    5 minutes ago, Sjakie said:
    Hello Jan,
    //Sjakie
    Can you PM me the scene?
    Guest kallecux
    Hi @jgab, sorry, but there is no unhandled event.
    I get this in the console:
    i tried this in ER4 - but no result:
    self:enableTriggerType({"device","global-variable","custom-event","location"}) -- types of events we want
    rule("#location => log('location event erhalten')")
    Greetings!
    Greetings!
    Sorry, set this flag in QuickApp:main()
      self._UNHANDLED_EVENTS = true
    Ok, I managed to trigger one.
    I have pushed v0.5fix15
    Rule
    {type='location', id=<user>, value=<"leave"/"enter">, property=<location id>}
    and remember to self:enableTriggerType({"location"})
    Guest kallecux
    Yes - it is working - thank you very much!!
    Greetings!
    Karl Heinz
    On 8/13/2018 at 5:38 PM, jgab said:
    -- Toggle lamp if key '1' pressed on keyfob Rule.eval("myKeyfob:central.keyId=='1' => myLight1:toggle")
    Is there a way to easily translate this to another z-wave remote control with multiple buttons? I have a RC-90 where each button can be given different tasks for one press, double press, and "long" press. I tried the below rule where I want to turn on a window lamp that is connected through a Fibaro wall plug. I do not get any error message so it is hard to say what is wrong...
     rule("Remote_entre:centralSceneEvent=='1' => Arbetsrum_fonster:on")
