7 hours ago, jgab said:
Any value. This works:
Thank you very much.
Now i understand.
    Simple rule for turning on/off light in bathroom. We leverage the fact that if someone moves inside the bathroom when the door is closed we keep the light on until the door opens again.
    What’s mean ??
    53 minutes ago, Earybeongbeong7 said:
    What’s mean ??
    Just setting the 'inside' variable to the state of the door (true or false)
    Jan,
    Because we are with two persons present my wife hates the light will switch of when I leave the bathroom.
    shower in bathroom with door sensor, motion dont detect if some one takes a shower, if shower is free door = open:
    Util.defTriggerVar('inside',false)
    rule("bath.sensor:breached & => bath.light:on; inside=bath.door:safe") -- turn on light when sensor breached, also set state depending on door
    rule("bath.sensor:safe & douche.door:safe => bath.light:on; inside=bath.door:safe") -- light stays on someone in the shower
    rule("trueFor(00:05,bath.sensor:safe & douche.door:breached & !inside) => bath.light:off")  -- Turn off light after 5min, if state is not inside bathroom
    rule("bath.door:breached => inside=false")
    Jan two pir's one outside and one inside to let the light on if second person is involved"
    rule("landing.sensor:breached & bath.door:breached => bath.light:on; inside=bath.door:safe") -- turn on light when sensor breached, also set state depending on door
    rule("bath.door:breached & landing.sensor:safe => inside=false")
    rule("bath.door:breached & landing.sensor:breached=> inside=!false")
    rule("bath.door:breached & bath.sensor:breached & landing.sensor:breached => bath.light:on; inside=bath.door:safe")  --second person in
    how to count?
    Please advice,
    //Sjakie
    If this works I can use it for more rooms.
    The state of the statement in the variable is saved as "true or false", right?
    bath.door:safe > true
    bath.door:breached > false
    Is it stored differently depending on the status of the door?
    For example, if the motion is violated but the door is open, will the value of "inside" be "false"?
    Then
    Do the two codes below mean the same thing? I wonder if they are theoretically the same.
    Edited by Earybeongbeong7
    how to count?
    Please advice,
    //Sjakie
    This is very difficult to get 100% right. I would say it's impossible to count in general. It could depend on how the bathroom look like. If there is enough of a "landing zone"  so you can tell that a new person entered without staying at the same place as someone else also inside it could work - but in general really tricky,.
    One could try to rely on habits like double-flicking the light earn existing and there is someone still inside (in the shower) to tell the light to not close. However, these things are easy to forget.
    Yes, :safe returns a boolean
    Can't use > and < with booleans. (even though in theory 'true' should be bigger than 'false' ;-) )
    correct,
    Then
    Nop,
    The first rule sets 'inside' to false if door is breached  (door:breached == true)
    The second sets 'inside' to true if door is breached (door:breached == true)
    39 minutes ago, jgab said:
    Quote
    My meaning is wrong.
    Is it correct to store "true" in "inside"?
    Is it correct to store "false" in "inside"?
    And
    I don't understand that "true" is stored in "inside".
    Isn't "inside = bath.door: safe" storing "true" in "insde"?
    If the sensor is breached and the door is closed (safe) we set variable 'inside' to true.
    If the sensor is breached and the door is open (not safe) we set variable 'inside' to false.
    This will set 'inside' to true when door is open - if door is open we don't know where the user is and we set the variable 'inside' to false.
    And
    When door is opened (breached) we wan't to set variable 'inside' to false - like in the case with the sensor.
    I checked again slowly.
    Now I understand.
    I was mistaken. Thank you.
    Is the code below correct what I understand?
    The automation usability of this code doesn't matter.
    I just want to understand the meaning of the code.
    Does "Livingbath_door: value" read the current state even if there is no physical state change of the "door sensor"?
    I know that the "trigger" of the "rule" works only when the physical state of the "door sensor" changes.
    Yes, the HC2/HC3 always read the current state,
    When a physical device changes state it immediately reports the value to the HC2/HC3. The HC2/HC3 stores the value in an internal database.
    When the value is stored/updated the HC2/HC3 also generates a 'sourceTrigger' that scenes (and QAs) can react on
    EventRunner3/4. reacts on those triggers and run the rules that are concerned.
    fibaro.getValue(id, prop) reads the value from that database. So, we always get the latest reported value.
    Livingbath_door: value is internally translated to a fibaro.getValue(Livingbath_door,"value")
    A note. There is a difference between sensors on the HC2 and HC3. On the HC3 the "value" of a sensor is a boolean.
    On the HC2 it is a number. 0 for safe and 1 for breached. This means that sensor:value on the HC2 returns a number and on the HC3 a boolean, for sensors.
    However, sensor:breached and sensor:safe always return a boolean both on the HC2 and the HC3.
    Thank you very much for your answer.
    Deleted
    Hello.  Thanks to this, I am learning ER well.  Is there any way or example of using the profile in HC3 in the ER4 rule?
    Well, you can trigger on profile changes.
    When a profile is activated a trigger is posted
    So you can trigger like this
    So, you could activate and deactivate a set of rules depending on what profile is activated
    in ER4. arming and alarms work differently from ER3 and the HC2.
    We arm alarm partitions. Alarm partitions have names and ids.
    There is a new function/property :alarm in ER4.
    Ex. <partition id>:alarm will return the partition structure for partition with id 1
    will print out the structure.
    Will print the armed and breached status of partition 1
    Will arm/disarm partition 1.
    An id of 0 will enable/disable all partitions.
    One fields of a partition structure is '.devices' that is an array of all devices that belong to a partition.
    This means that we can do this
    and we also get triggers when partitions are enabled/disabled and breached....
    Is it correct that a profile such as a picture is controlled?
    fibaro.profile('activateProfile',Away=2)
    Is there any er4 instruction that can utilize this??
    v0,5fix18
    or
    and then triggers type
    Jan,
    Will this work?
     Rule.eval([[hal.locatieGezin:isOn & hal.kamerBoven:isOff & hal.kamerBeneden:isOff =>
            1:alarm=true; log('Huis aanwezig armed');
            3:alarm=true; log('kamerBoven afwezig armed');
            4:alarm=true; log('kamerBeneden afwezig armed');
    Please advice,
    //Sjakie
